[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Ich hab mal das 3017er Bios editiert und den "CBP Mode" auf Default Disabled gestellt, bin mal gespannt ob es jetzt funktioniert. Das hoch/runter Takten ist ja schrecklich.
hi,
ein kollege hat dieses board auch und er beschwert sich darüber, dass seine internetverbindung, die über das onboard lan angeschlossen ist, auffallend häufig abstürzt. besonders beim onlinezocken ist das nervig.
ich kann gleiches phänomen eigentlich nicht bestätigen.
jetzt meine frage. ist das etwas typisches ? hatte jemand anderes ähnliche probleme ? wie habt ihr das dann in den griff bekommen ?
danke im voraus.
gruß
H.
interessant ... welches hoch und runtertakten meinst du und was ist der CBP mode?
hi,
danke im voraus.
gruß
H.
er soll mal aktuellen treiber bei marvel laden und OC komplett rausnehmen und nochmal versuchen.
...er soll mal aktuellen treiber bei marvel laden und OC komplett rausnehmen und nochmal versuchen.
hat er schon gemacht. oc hat er bisher gar nicht betrieben, im gegensatz zu mir.
daher glaube ich nicht, dass es überhaupt am board liegt, aber ich habe ihm versprochen, dass ich mal hier nachfrage.
@coxon, der CBP Mode wird evtl. der neue Turbo-Mode des Bulldozers werden. Im 3012er Bios ist er noch vom User selbst anwählbar und taktet bei enabled meinen 1090T von 4,2GHz im Idle Modus auf 1GHz runter, natürlich auch dabei die VCore von 1,5V auf 1,4V und jetzt kann sich ja jeder denken das es nicht wirklich rund läuft, da er oft bei kurzen "Lastpausen" schnell wechselt und somit Programme oft zum Crashen bringt.
Im 3017er Bios ist dieser Mode leider versteckt und somit nicht deaktivierbar, evtl. auch nur für AM3+ CPUs ersichtlich. Deshalb habe ich da angesetzt und ihn auf Standard disabled gestellt, da bei Ocern sowieso der Turbo Modus immer an ist ;).
Ist das neue Bios nicht speziell für AM3+ CPU's, so stehts auf der Seite, habt ihr solch ein
System, oder kann man die neue Bios Version auch mit AM3 CPUs flashen??
flashen kann mans schon, aber ich würds nicht riskieren - zum spaß werden sie die warnung wohl eher nicht hinschreiben. wüsste vor allem nicht welchen vorteil es gegenüber dem 1902er haben sollte...
edit: und ein am3+ system haben sicher nur eine handvoll leute, die das aber dann wiederum nicht zugeben dürfen wegen der NDA mit AMD;)
Gibt es irgendwas im Bios zu beachten, was ich unbedingt aktivieren bzw. deaktivieren muss, damit ich keinen beschissen FSB Drop habe?
Das nervt mich gerade doch schon wieder ungemein ab ...
Wäre für Tipps sehr dankbar!
Welches Bios hast du? Ich hatte mit 3102 immer FSB Probleme.
Board gestern neu mit Version 1304 erhalten! Nix besonders eingestellt. Momentan unnötige Sachen wie USB3, Firewire, Sound, CoolnQuite usw. deaktiviert. Spannungen fast alle manuell! Im Bios eingestellt. FSB 200, Muli 14 (X6 1055T). 4 Kerne sind deaktiviert.
CPU-Z zeigt mir ständig andere FSB Werte an. Von 200-203, immer abwechselnd. Das resultiert sich dann auch im Speichertakt, der sich je nach Teiler ständig um 10-30 MHz ändert! Das nervt einfach nur, weil ich mal vor hatte ein kleines Speichervergleichsreview zu erstellen.
@Spcial:
minimal ist das glaube ich normal, hast Spread Spectrum aus? Soweit ich weiß
ist doch dieses Feature für den FSB Drop zuständig, einfach mal ausprobieren.
Bei mir ist der FSB Wert unter CPU-Z sehr stabil, und habe keinen Drop im Idle.
Nur der CPU Takt dropt minimal.
Seit 1902 ist das bei mir nicht mehr, flashe doch mal Bios 1902. :d
Jo bei mir ist auch Bios 1902 druff, zur Info halt. ;) MfG
Eigentlich ging das an Spcial. :fresse:
Jaah ist mir klar war ja auch an Spcial gerichtet. :fresse:
Sollte als Info dienen das ich auch das 1902 druff ist und
bei mir ebenfalls kein Drop vorhanden ist. ;)
MfG.
EDIT:
Aber wie bereits vorher erwähnt liegt der FSB Drop meiner Meinung nach nicht
am BIOS selber sondern an der Einstellung "Spread Spectrum".
Sent from my iPhone using Hardwareluxx App
Ist die Asus-Meldung noch aktuell, dass die BD-CPU's ohne grosse Abstriche z.B. auf dem CH IV laufen?
Ja, die bleibt auch aktuell.
Prima CH4F :)
Bin eben endlich dazu gekommen, mein BIOS von 1102 auf 1902 anzuheben.
Das hat aber sichtlich was gebracht.
Liege derzeit bei 4,2 GHz mit 1,396V - 1,402V
Da hab ich bei gleicher VCore schonmal 150 MHz "gefunden" :)
Hmm, na ja, da bekomm ich aber mit LinX trotz WaKü in der Spitze 64 Grad.
Bin deshalb auf 4,1 GHz runtergegangen ... Peanuts ;)
Ich brauch einen größeren Radiator :fresse:
@All
Nun habe ich auch endlich mein BIOS auf 1902 geflasht.
Finde mich aber im BIOS überhaupt nicht mehr zurecht. Wie komme ich jetzt an Multis und VCores?
Danke für eure Hilfe und Hinweise.
oki doki
fuzzy
Steht bei mir auf Manual.
Aber CPU Ratio steht auf Auto und lässt sich nicht ändern.
Was muss unter ENERGIE > bei Suspend - Modus eingestellt sein?
fuzzy ... um 15 uhr kann ich Dir genaueres sagen, wenn sich bis dahin noch niemand gemeldet hat.
Mal was anderes in die Runde gefragt: Wieviel VCore gebt ihr dem 1090T für OC maximal?
Bin jetzt bei 1,396V.
Grenzwertig oder besteht noch Luft nach oben?
mit wakü sollten 1,4V für ein 24/7 setting akzeptabel sein
Hmmm, ok. Dachte da ging noch mehr 24/7.
Muss wohl von nem Triple auf einen Quad-Radi umsteigen.
Unter LinX geht der X6 bis auf 61 Grad rauf.
Werde aber erstmal auf BD warten. Wenn das mit dem Formula IV funktionieren sollte, fliegt der 1090T raus. :)
Bei mir wird dann auch der 1055T rausfliegen, vorher will ich ihm aber nochmal richtig feuer unter'm Hintern machen. Mal schauen wieviel der so geht, erreicht man mit dem AMD Overclocking Tool eig. auch halbwechs gute Ergebnisse?
LG
Ich werd auch gleich mal guggn wie das Crosshair V wird, vllt wird beides gewechselt :)
