[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Jo, wenn es sich lohnt und nicht allzu teuer ist.
Hab das IV eigentlich sehr lieb gewonnen.
Sollte die Einschränkung lediglich beim Stromverbrauch zu finden sein, dann bleibt es drin.
Hauptsache BD lässt es fliegen :d
Falls das CHIV den Bulli voll unterstützt (also volle Performance incl. der neuen Turbo Funktion) sehe ich auch keinen Grund zu wechseln.
Steht bei mir auf Manual.
Aber CPU Ratio steht auf Auto und lässt sich nicht ändern.
Was muss unter ENERGIE > bei Suspend - Modus eingestellt sein?
CPU Ratio einfach mal mit Ziffernblock eingeben. Klappt bei mir super.
CloudStrife81 schrieb:
Hmmm, ok. Dachte da ging noch mehr 24/7.
Muss wohl von nem Triple auf einen Quad-Radi umsteigen.
Unter LinX geht der X6 bis auf 61 Grad rauf.
Werde aber erstmal auf BD warten. Wenn das mit dem Formula IV funktionieren sollte, fliegt der 1090T raus.
Alter! Da pack ich mit LuKü bessere Temps! Habe 4GHz @ 1,405v bei 100% und LinX. Nie über 55°C. °_°" Hab allerdings auch 7 Lüfter im Case. :fresse2:
Jo, dafür habe ich nur drei @ Low-RPM --> angenehme Lautstärke ...
Der Radi ist eben zu klein für die Abwärme von CPU & GPU.
Das werde ich noch ändern, dann passt es.
Der Sinn meiner WaKü liegt auch eher in der 580 GTX, da habe ich die Temps unter Last halbiert ...
Bei einer CPU kriegt man nicht mehr soviel raus, da die LuKü inzwischen gut aufgeholt hat.
ich hab mich auch schon gewundert was das für werte sind, ich erreiche mit meinem
1055t@4.03GHz@1.42 mit nem arctic freezer noch temps unter 62 grad unter lix :)
ich glaub nicht das Lukü so gut geworden ist sondern das mit deinem cpukühler was nicht stimmt
Immer noch FSB Drop mit dem 1902er Bios. Im Bios ist jeglicher Schwachsinn deaktiviert!
Wahrscheinlich noch viel mehr als bei euch weil ihr das Ding ja für den 24/7 Betrieb nutzt und ich wollte nur ein wenig mit spielen.
Ich liebe ASUS einfach ... :motz:
@m0ped
1,72@ram o_O Alter Schwede.
Bin atm auch noch @work, aber ich werd mal deine settings ausprobieren.
LG
@Spcial:
Hast du denn die beiden CPU u. NB Spread Spectrum deaktiviert?
Vielleicht noch die Stromsparmechanismen wie C&Q und C1E auch deaktivieren und neu
testen. Vielleicht bringt es eine Verbesserung.
Muß aber dazu sagen, das bei mir sämtliche Spannungen manuell
Eingestellt habe. Kann auch was damit zutun.
MfG
Sent from my iPhone using Hardwareluxx App
Speed Spectrum (CPU/NB) ist natürlich aus. Das deaktiviere ich immer als erstes, auch wenn ich mal für jemand einen PC zusammen baue^^
Wo kann ich "C1E" deaktivieren?
Dinge die noch unklar sind:
-CPU/NB Voltage OCP
-CPU PMW Frequency # Was habt ihr da eingestellt? Auto oder Manuell?
-CPU Voltage OCP
P.S.: Habt ihr wirklich absolut keinen FSB drop?
Habt ihr mal zwei CPU-Z Fenster geöffnet, jeweils den Reiter "CPU" und "Memory" und dann mal aufmerksam auf den FSB und die DRAM Frequency geachtet?
Bleibt es immer genau am eingestellten Wert?
Kann sein das ich da etwas pingelig bin, aber so etwas kenne ich von meinem Asrock 890FX Deluxe4 eben nicht. Habe seid dem Kauf keinen FSP Drop gesehen^^
Hatte damals relativ zeitnah nach dem Release schon mal Crosshair gehabt = gleiches Problem. :(
@Spcial:
Also ich habe definitiv keinen FSB Drop. Bei mir dropt nur der CPU Takt
minimal. Das stört weiter nicht, und ist so gewollt von AMD.
Die genauen Settings kann ich dir heute Abend durchgeben, weil ich jetzt arbeiten bin.
Die Beiden Voltage Ocp kannst du deaktivieren.
Wieso sollte das so von AMD gewollt sein? Bei meinem Asrock dropt gar nix^^
@CH4F: Ich Konter heute noch im RAM Max Clock Thread. :asthanos:
-CPU/NB Voltage OCP
-CPU Voltage OCP
zu den bios optionen gibts von bingo im xs forum eine erklärung: XtremeSystems Forums - View Single Post - ASUS AMD Beta BIOS Releases
@fsb drop: bei mir wackelt da nix. bleibt bis auf die kommastelle fix bei bclck und dram.
MFG
Hmm irgendwie will meine CPU nicht so recht auf dem Board - welche Einstellungen sind den genau relevant fürs übertakten, ich komm da durcheinander weil z.B. NB einmal als reine NB und einmal als CPUNB auftaucht ?!
@Spcial:
Sry hab das mit der CPU Spannung verwechselt, das ist so von AMD gewollt. Wenn du im Netz suchst, wirst fündig.
Bei mir dropt wie gesagt nur der CPU Takt und das nur minimal nach
Den Kommastellen. Also nur 0,01 MHz. ;)
Grüße
im prinzip benötigst du nur cpu spannung und falls du die cpu/nb auch übertaktest auch cpu/nb. (cpu/nb= auch auf der cpu)
die nb (die nb des 890fx auf dem mobo also) spannung selbst brauchst du außer für neue bclck-rekorde jenseits der 300.
MFG
320 Mit 1090T gehen aber ohne Probleme. BCLK Drop hab ich auch: von 250,9MHz auf 250,8. :fresse2:
Fragen wir anders: was muss ich wieder runtertakten damit alles auf standardwerten ist, wenn ich den FSB hochziehe.
Lg
CPU/NB, Multiplikator, Ram Takt und HT Link. FSB gabs bei Intel im Sockel 775. Hier wäre Referenztakt eher angemessen.
aus irgendeinem Grund schalten sich bei mir die Festplatten immer ab wenn ich einen Neustart mache, diese müssen dann bei der BIOS Abhandlung wieder hochfahren, ist das bei euch auch so bzw. weiß jemand einen Tip wie man das abstellt?
welchen AHCI Treiber verwendet ihr eigentlich? bzw. habt ihr einen Downloadlink?
@Bullseye2550:
Ich verwende aufgrund meiner SSD den originalen Windows 7 AHCI Treiber. Den AMD Ahci Treiber habe ich gar nicht installiert.
MfG
ich hab den AMD AHCI treiber drauf, seitdem er TRIM unterstützt. die plattenabschaltung findest du im win unter den energieoptionen, da hast du wahrscheinlich auf AUSGEWOGEN stehn und da is standardmäßig 20min für die plattenabschaltung eingestellt
Hallo Leute,
hab nun ein Problem, jedes mal wenn ich irgendwas auf die Systemplatte kopiere oder z.b. was installiere dann wird mein Sys sau lahm, kann da dann nimmer mal nebenbei surfen, vor n paar Tagen ging eigentlich alles ohne Probleme.
Hab die Tage auch keine Treiber gewechselt, updates sind auch keine hinzugekommen, woran kann das liegen?
Wollte mal guggn ob es vllt. n neuen chipsatztreiber gibt, hab aber nix gefunden, gibs da was neues??
thx
Was ist das für eine Systemplatte (Hersteller, Modell, usw.)?
Samsung HD332HJ Spinpoint F1, lief bisher butterweich, glaubst die segnet bald das zeitliche??
Ach mensch ich hätte auch auf Dein SysProfil-Profil gucken können ;)
Schwer zu sagen. Wieviele Jahre hat die denn nun schon auf dem Buckel? Lahmt das ganze System, also auch die anderen Platten oder nur die Systemplatte? Ist das bei jedem Schreibzugriff so? Hast Du schonmal probiert, die Systemplatte an einem anderen SATA-Anschluss laufen zu lassen?
