[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
hab mal das mit dem Formula-Z Bios Chip grad getestet und es geht, zwar stimmen paar Werte nicht aber ist der Start bis zum Windows booten deutlich kürzer!!!!
Kann es daran liegen dass das Formula-Z Eprom 64MB hat und das normale Formula nur 32MB?
hier mal screens von der Aktion heute früh :bigok:
Formula:
Fprmula-Z:
Welche Werte stimmen jetzt nicht mehr?
Aber sonst gibt es keine Probleme? Einstellungen und Spannungen werden korrekt übernommen?
update:
nun wie es scheint geht das nicht so einfach, nachdem ich es heute umgesteckt habe und den PC gestartet habe kam ne Meldung das iROG Firmware ge updatet wird nach kurze zeit ging es aus und seit dem startet es nicht mehr mit dem Z Chip :(
wenn ich den non-Z wieder einstecke geht wieder
Schade. Klang am Anfang so gut. Hatte mich schon auf einen kleinen Test von dir gefreut.
bin noch nicht fertig und so schnell gebe ich nicht auf, evtl geht das non-Z ROM auf das z CHip drauf. werd mal checken und mich wieder melden
Update: werde als erste die Teile des Z Bios entfernen die überhaupt nicht im non-Z drin sind und mal Testen bevor ich den 64MB Chip mit non-Z ROM überschreibe
Berichte dann bitte mal hier ob's geklappt hat.
oki doki
Board läuft wieder, wollte zwar erst nicht, aber nach 3-4 mal neu starten lief es dann Erstmal wieder das 1703 Bios drauf machen und dann gehts wieder ans Benchen
Sollte man eigentlich immer das neuste BIOS installieren oder nur wenn man es wirklich benötigt? Seit dem 13ner habe ich es nicht mehr aktualisiert.
"Normalerweise" sagt man, Nur wenn man es benötigt,bzw wenn man Probleme hat ;)
Wobei es da unterschiedliche Meinungen gibt. Ich hab eigentlich immer das aktuellste drauf :coffee:
Ich glaub ich bin zu blöd für ein bios update an meinem crosshair v formula z
Egal was ich versuche sagt er kein efi bios
Einer nen tipp was ich falsch mache?
Vieken dank schonmal
Gesendet von meinem GT-I9505 mit der Hardwareluxx App
Hast du auch das richtige Bios runtergeladen? Nicht das du das non Z und das Z verwechselt hast.
einfach mal saugen und entpacken ...
das .ROM File auf der Platte liegenlassen..
dann im BIOS unter "TOOLS"
das "ASUS Ez 2" Utility auswählen
darin zur richtigen Festplatte (dort wo das BIOS-ROM-File liegt)
dann zum richtigen Directory und BIOSFILE hangeln und draufklicken...
dann sollte es ohne Probleme gehen...
den Umweg über den Stick kannste Dir sparen..
Gruß Achim
sorry ...
natürlich .CAP File...
in diesem Falle für das letzte BIOS
CROSSHAIR-V-FORMULA-Z-ASUS-1503.CAP
EDIT...
aber versuche das nur einmal ,
mit der Nummer über das BIOS...
Genau die datei hab ich und er sagt kein efi bios hmmm
---------- Post added at 20:23 ---------- Previous post was at 20:02 ----------
Ihr könnt mich ja für blöd erklären aber dss funzt nicht
Hast du die Datei nochmal neu runtergeladen. Vielleicht hat sich beim ersten mal etwas zerschossen.
So hatte gerade erfolg
Jetzt hab ich die datei über die ai Suite aktualisiert bekommen
Das bios selbst frisst sie nach wie vor nicht
Habe meine USB 3 Probleme am "Formula Z" behoben....
Mein Problem lag darin , das immer mal wieder beim kopieren über den USB 3 Port , die Übertragung abbrach..
Die externe USB3 Platte auch gern mal aus dem Explorer verschwand...oder einfach mal die Lampe am Laufwerk nicht mehr leuchtete...
Bisher war die Lösung mehr schlecht als recht, denn sie bestand darin, das externe Laufwerk aus und einzuschalten..
sehr unbefriedigend , meiner Meinung nach...
Das alleinige herausnehmen der USB Ports aus den Energiespar Maßnahmen , war zumindest soweit erfolgreich , das die externe Platte zumindest nicht mehr mitten in der Übertragung abbrach...
Das verschwinden der externen Platte aus dem Explorer war aber weiterhin vorhanden
Die wirkliche Lösung bestand in der Installation neuer ASMEDIA USB 3 Treiber ...
Die Version 1.16.2.0 vom November 2012 (ASMedia ASM104x) , kann über Computerbase bezogen werden...(USB 3.0 Host Controller-Treiber Download - ComputerBase)
dort sind auch viele andere USB3.0 Treiber , anderer Hersteller zu finden)
Als Nebeneffekt , sind die Übertragungsdaten , beim kopieren , stabiler als vorher (nicht mehr so schwankend)
Asus scheint hier nicht gewillt zu sein diese Treiber auf der Supportseite bereit zu stellen..
warum auch immer..
denn hier sind immer noch die 1.14.3.0 vom Januar 2012 die aktuellsten
Vielleicht auch etwas für Leute , die noch keine Probleme mit den USB3.0 Ports festgestellt haben....
mfG
Achim
Hallo Netboy.....
Ich hätte hierzu mal eine konkrete Frage:
Braucht das Crosshair V Formula (Z) überhaupt ein Firmware Update???
wird das nicht direkt über das Bios geregelt?
Demnach die Firmware eventuell nur für Zusatzkarten ???
Schon bei meinem Crosshair IV Formula gab es für die USB3.0 Controller von NEC/Renesas Firmware (für deren Chipsatz µPD720200 und µPD720200A...)
die sich aber nicht installieren ließ...
Daher also meine Frage dazu...
weißt Du oder eventuell jemand anderes , genaueres dazu??
mfG
Achim
Dazu müsste Asus das Firmware Update in das Bios integrieren.
Da die USB 3.0 Ports über den zusatz Chip (ASM 1041) und (ASM 1042) Umgesetzt werden
ist dieser extern zu Flashen unabhängig vom Bios.
Also ich hab die Firmware seit Anfang Aprill drauf. Läst sich mit dem Asus Tool sehr einfach aus Windows machen.
Zwar nicht ganz aktuell, aber evtl hilfts dir http://www.computerbase.de/forum/showthread.php?t=934271
Vielen Dank für Deine Aufklärung...
Auch der Link gibt einiges her...
es ist immer gut dort auch die Einträge zu lesen , egal ob die nun alt sind..
denn nur so ergibt sich ein Gesamtbild....
Das mit dem "übers BIOS geregelt" habe ich , so glaube ich , irgendwo mal gelesen...
Aber wenn man soviel liest , kann man auch schon mal ein paar Sachen durcheinander bringen...
Aber diesmal nicht
lese mal hier (bertakten | Anleitungen | Tests: OC-Facts.de)
direkt unter den Treibern von Fresco Logic steht im Absatz
Laden Sie falls nötig die Treiber und danach falls vorhanden die Firmware herunter und installieren diese. In beiden Fällen müssen Sie die ZIP-Datei nur mit einem Packprogramm wie z.B. WinRar entpacken und danach die Setup.exe ausführen. Danach folgen Sie einfach den Anweisung des Installationsassistenten. Bei den neueren Chipsätzen ist es nicht mehr nötig eine extra Firmware herunterzuladen, da diese direkt über das Bios aktualisiert werden.
Daher war ich unschlüssig ob das so stimmt...
Habe jetzt auch mal das Firmware-Update installiert ..erkenne jetzt mal keinen Unterschied...
mfG
Achim
