[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Neueste Freigabe von ASUS So. AM3+ Boards und AMD FX-9590
ASUS Sabertooth 990FX R2.0
SABERTOOTH 990FX R2.0 - Mainboards - ASUS
Ab BIOS/UEFI 1703 werden lt. ASUS die neuen
FX-9370 und FX-9590 CPUs unterstützt!
Das GEN3 R2.0 und das CROSSHAIR V Formula und Formula Z sollen folgen/aktualisiert werden!
Quelle
AMD FX-9000-Reihe: Asus verkündet offiziellen Support ohne BIOS-Update
http://www.planet3dnow.de/cms/2092-asus-unterstutzt-fx-9000-serie-in-allen-990fx-platinen/
HeXus
ASUS Announces Full Support for AMD FX-9000 Series Processors with Existing 990FX-Based Motherboards
grEEtz :coffee:
fuzzy
Muss ich mir sorgen machen, wenn nach dem Umbau auf den Wasserkühler nach 10min Prime ein leichtes Fiepen an der Spannungsversorgung der CPU auftritt?
Also wie das "bekannte" Spulenfiepen bei Grafikkarten , nur leiser.
War mit Luftkühlung nicht.
Auch wundert mich, dass die Spawas auf der Rückseite nicht gekühlt werden müssen?
Achja, bringt ein übterakten der NB was?
And last but not least:
Welcher Speicher passt denn optisch gut auf das Formula-Z?
MFG
Ich glaube , das das Fiepen kommen kann, weil mir Wasserkühlung nun kein Luftstrom vom Prozessorkühler
über die Spannungsversorgung streicht..
Ich kenne Deine Case-Lüftung nicht, aber die solltest Du eventuell mit einem Lüfter ,der innen über das Board bläst ,
erweitern..
Das mit den Spawas , vermute ich, das wenn man,
die vorn kühlt , die Wärme dann von hinten nach vorn wandert und so eine Thermische Bewegung entsteht...
Laienhaft ausgedrückt ..
und ob NB Übertaktung "allein" was bringt..das glaube ich nicht...
Zum Speicher
Ich habe rot/schwarze GSkill F3 14900CL drin..
passen perfekt zum Board
mfG
Achim
Danke für die Fixe Antwort.
Aktuell habe ich Praktisch keinen Airflow,betreibe ohne Seitenwände.
Zum Speicher, danke werde mal 16Gb ordern.
Ich meinte auch NB Übertaktung in Verbindung mit schnellerem Ram(1866) und die CPU auf 8x4,5 GHz.
Bei mir piepst nix! Selbst bei 4,8 Ghz nicht! Hab aber auch genug Airflow.
Gruss
Mir wärs lieber die schreiben dazu welcher Bug behoben wurde und nicht immer Improve system stability.
Ich bin seit 1998 , dem sagenhaften Asus Sockel 7 P55T2P4 (bestückt mit einem K6), bei Asus Boards......
Seither hatte ASUS nie in Einzelheiten geschrieben , sondern immer nur solch vernebelte Fakten wie "Improve" irgendwas..
Sie scheinen ja mit dieser "Desinformation" gut zu fahren...denn Ihre Boards verkaufen sich immer noch sehr gut...
mfG
Achim
In Sachen Bios ist Asus momentan auch Top. Bugs werden innerhalb 2-3 Wochen behoben. Bei anderen kann sowas durchaus Jahre dauern :d
Asus >>><<< top ???
Na, na mein Freund. :popcorn:
So TOP finde ich ASUS inzwischen nun nicht mehr. :shake: :shake: :shake: :shake:
Für das Crosshair V Formula >>ohne<< Z tut sich in Sachen UEFI/BIOS absolut garnichts mehr seit Okt. 2012.
Für's SABERTOOTH R2.0 hat man ein aktualisiertes UEFI rausgebracht (wegen FX-9590), aber für's Crosshair macht man garnichts mehr.
Ich habe 2 Crosshair V [ohne Z] für Max. - Aufnahme eines FX-8350. :(
LG :coffee:
fuzzy
Soweit ich weiß war das ja schon bekannt dass es keinen offiziellen Support bekommt? Der 9590 läuft ja trotzdem auf dem Board.
Mir ging es in erster Linie um die vielen Einstellmöglichkeiten im Bios sowie der schnelle Bug Support.
Mein damaliger 9370 hat ohne Probleme auf dem Sabertooth R2 mit einem alten Bios funktioniert. Ist ja nur ein aufgemotzter Vishera also funktioniert er auch mit jeden Vishera supporteten Bios.
Selbst die Vishera funktionieren auch wenn nur ein BD Bios aufgespielt ist.
Für das SABERTOOTH R2.0 ist die FX-9590 ja auch schon auf der Homepage
in der Liste aktualisiert als kompatibel genau wie die FX-9370 mit UEFI 1708.
Allerdings auf der Crosshair - Seite steht sie in der CPU-Support Liste NICHT drinnen, genau wie die FX-9370.
Dort ist bei der FX-8350 mit UEFI 1703 Schluss! (UEFI 1703 vom 24.10.12)
>>>>> BD Bios???? <<<<< sagt mir nichts.
oki doki :coffee:
Hier wurde laut Angaben des Threaderstellers ein Crosshair V Formula verwendet - und da lief die 9000er Serie drauf. Da ich das schon aus mehreren Richtungen gehört habe, gehe ich davon aus, dass das auch tatsächlich stimmt. Aktuelles BIOS drauf, FX9xx0 drauf und ab gehts - auch ohne offiziellen Support.
oki doki :coffee:
Reous meint ein BIOS, welches ursprünglich herausgebracht wurde, als Bulldozer in Form von Zambezi herausgebracht wurde - also die FX-8150 und co. Mit einem solchen BIOS hat Vishera ja auch problemlos funktioniert.
Hallo jungs
ich habe ein Asus formula-z und jetzt das Aktuelle 1602 BIOS aufgespielt könnt ihr hier eine Verbesserung
Spüren der Stabilität...
Ich habe ein 1090T @4Ghz Kriegt man dehn nicht Höher wie 4GHZ ?
Was Empfiehlt ihr mir für Einstellungen für einen Kompromiss zwischen Occen und Stabilität. ?
Ich bin verwundert das asus in der BIOS für RAM Eintelungen denn ECC automatisch immer auf ein hat WTF....:wall:
Viel höher gehen die 1090T auch nicht. Wo willst Du überhaupt hin mit dem Ding? 4,5 GHz oder mehr? Sei doch zufrieden, daß er überhaupt die 4 GHz macht!
Was für einen Ram hast du eigentlich. Deine Timings (10-12-7) sehen schon komisch aus.
Wenn du keine Probleme mit dem alten Bios hast brauchst du es auch nicht zu flashen. Die neueren bringen meist nur kleinere fixes sowie neue CPU Unterstützung mit sich.
Ich verwende dieses Ram Kingston HyperX Predator, 2x4GB, DDR3-2400 CL11....
Von den einstellungen was macht sin fürs Maximum ich ignoriere den Stromverbrauch ...
Ist nicht unbedingt eine Frage des Stromverbrauchs sondern der Kühlung. Ich halte 4GHz aber für ausreichend ;)
Du kannst mal probieren ob den Ram auf 1866 9-10-9 bei 1.5v bekommst.
@Reous
Die Ram lasse ich lieber auf Orginal Tackt Da läuft es Stabil Es bringt auch kein mehr an FPS...
Aber der HT Limitiert soviel ich weis darum Lieber den auf 2,4 GHZ ...
Ram Originaltakt wäre DDR3-2400 CL11-13-13 und dein Ram läuft auf DDR3-1600 ;). Im Normalfall sollte deine CPU aber max 1866 packen.
ja du hast schon recht nur :-) Es läuft bei mir nicht immer auf 1600 :-) am stabielsten ist es schon bei 1300 :-)...
Sag mal bei deinem FX8350 in deiner Signatur hasst du dort dein HT ja bei 2ghz gelassen wieso dass denn ? Der Limmitiert doch Tottal bei
5GHZ CPU?
Die 5GHz waren nur zum Spaß. Hab da alles runter gestellt um Fehlerquellen auszuschliesen. In meinem 24/7 PC werkelt ein Opteron mit 3.6GHz und 2215MHz HT
Grossartig: Improve system stability.
Finde ich eigentlich sehr beschämend, solch eine Beschreibung für ein Board der Preisklasse.
Die sollten mal was an den Einstellungen für die Lüfterregelung machen
Mal was anderes:
Ich habe eine Wasserkühlung. An dem Dual-Radi laufen 2 120er PWM Noiseblocker Lüfter, auf dem Board an den beiden CPU-Fan Anschlüssen angeschlossen.
Im BIOS habe ich als Target Temp 55°C eingestellt
Min PWM 20% weniger geht NICHT :-(
max PWM 80%
Nun die eigentliche Frage (an die BIOS Modder): gibt es eine Möglichkeit, auch z.b. 5% bzw 0% zu programmieren?
Bei 20% laufen meine Lüfter mit 1000 U/min ist mir zu "laut" und unnütz bei 29°C CPU Temp
bei 80% 1700 U/min
bei 100% 1900 U/min
Grüße
ganz schön was los hier
Lässt darauf schließen das es keine Bios Modder gibt ;). Einfachste Möglichkeit ist wohl einen Widerstand dazwischen zu hängen oder einfach Lüfter kaufen welche langsamer drehen.
