[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Wie hattest du deine LS angeschlossen?
Bei mir läuft es über das optische Kabel zum AVR....
Damit geht es bei mir auch, aber das hilft mir nicht weiter...
Ich sehe es nicht ein bei so einem Mainboard auf die digitale Übertragung zu verzichten :rolleyes:
Gerade getestet:
Klinke, 1,33V, vollast ---> keine Störgeräusche.
Wakü
Hi Leutz, :wink:
hat von Euch schon jemand eine FX CPU auf dem Board mit einer Wakü verbaut?
Wenn ja welche kann Mensch denn da bedenkenlos nehmen?
Greetz HerrZ
ja, ein Heatkiller Rev. 3.0 :confused:
ich habe da mal die Suchmaschine bemüht, aber keinen für einen AM3+ Sockel gefunden, hast du ihn dir selber gebaut oder wo hast du das Ding her?
Greetz HerrZ
Ty für deine Antwort nun kann ich ja richtig loslegen
:banana:
Greetz HerrZ
:confused:
Hi Leutz,
nun habe ich angefangen mein neues Board in Betrieb zu nehmen und ....
schrei es läuft nicht hoch.
Ich komme noch nicht einmal ins Bios und was ich noch nie gehabt habe es gibt noch nicht einmal ein Piep von sich.
...kurz die Daten: Board ist ja klar
Ram: G.Skill 8GB (2x4096MB) SNIPER DDR3-1866 DIMM
CPU: AMD FX 8120 mit Scythe Mugen 3 (leider noch keine Wakü)
Graka: Sapphire 6790 Flex
HD: WD 500GB WD5000aaKX 7200 u/min
Netzteil bquiet Pure Power 730W
angeschlossen habe ich den EATXPWR und 8-pin EATX12V den 4-pin EATX12_1 nicht ! Hoffe das ist richtig.
Die Status LED's: Da leuchten die Grünen nur bei der CPU da leuchtet die Orange.
Hat jemand eine Ahnung was das sein könnte?
Greetz HerrZ
Ich vermute fast du hast ein Bios drauf wo den FX noch nicht unterstützt.
Hast du noch eine alte CPU? Wenn ja diese einbauen und schauen ob du damit ins Bios kommst.
Hm habe ich leider nicht, außerdem wenn ich ein Board kaufe das für FX angepriesen wird erwarte ich auch das es die CPU erkennt
ASUS dazu: SpezifikationenProzessor / Sockel AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
Ich hoffe das Board kann die auch.
Greetz HerrZ
Leider hatten mehrere das Problem. Board kam ja vor Release vom FX raus und deshalb hat es ihn noch nicht unterstützt (kurz gesagt).
Du musst mind. Bios 0813 drauf haben. Vermute du hast ein älteres Board erwischt das noch 0705 drauf hat.
Dann hilft nur CPU von einem Bekannten ausleihen.
Sehe ich auch so. Wäre jedenfalls im Augenblick die einzige Erklärung.
Nabend,
ja ty für die Antworten, habe schon mal im Compiladen nachgefragt die kannten das Prob auch und ich werde das Board nun wieder ausbauen und dort zum Biosupdate hintragen ( füer 15€ machen die das dort).
Ist trotzdem ein starkes Stück da wird das Board als FX fähig beworben und dann geht das nicht auf anhieb und Mensch hat nochmal Kosten weil die nicht in der Lage sind, oder es aus Kostengründen, nicht updaten.
Schaut man auf der Asus Seite ist noch nichtmal ein Hinweis darauf was einen erwartet.
Greetz HerrZ :grrr:
Ja du hast schon recht. Das Board ist nicht der Renner...
Mit der "orangenen" LED meinst du sicher die Q_Leds?
EATX12 muss man nur bei SLI/CF anschliesen.
Steck mal alle USB Geräte ab.
gut.. es können nämlich auch die LEDs für die Komponenten Rot/Orange/Grün leuchten ;)
Sagt mal, welche Erfahrungen habt ihr mit dem neusten Bios (1003) gesammelt?
Kann man des nehmen ohne Einschränkungen befürchten zu müssen?
:banana:
neus Bios drauf und die Welt ist wieder in Ordnung.
Jetzt wird erstmal wieder alles installiert und das dauert...
Aussage zum Bios kann ich noch nicht machen nur soviel mein FX 8120 läuft, ansonsten habe ich ja noch kein Vergleich.
Greetz HerrZ
P.S. Ty nochmal für die Tips!
Hab jetzta uch des neuste Bios drauf, weil ich vorher das Gefühl hatte das der Rechner etwas instabil war (Probleme mitd em SATA Controller)
Gut mal sehen was die Zukunft bringt!
Ich nutze ein Mod BIOS, daher kann ich jetzt auch nichts zu dem 1003 sagen.
Na dann mal Happy Testing ;)
Also ich hatte jetzt auch mit dem neuen Bios mal wieder so ne Art slowmotion Freez...
Habe 2x Crucial C300 128GB drin und halt noch zwei HDDs. Windoof 7 (x64) ist auf einer der C300er.
Drei Mal ist es bisher vorgekommen, das der Rechner anfängt nicht mehr zu reagieren, aber halt nur
nach und nach. Die LED für den HDD-Zugriff leuchtet dabei ununterbrochen...
Jemand schon ähnlicher Erfahrungen gemacht?
OS hab ich beim Wechsel nicht neu installiert, nur die Treiber.
Hatte vorher genau die gleiche Konfig nur statt dem Asus Crosshair V+ FX8150
das Crosshair IV mit nem X6 1055T...
Hi liebe Community,
ich habe mir das OCC Board Asus Formula V vor kurzem bestellt und auch gleich verbaut alles überprüft und es hat auch gleich alles auf anhieb funktioniert mir ist aber nach paar min bzw. nach 30min ;) aufgefallen das ich kein ton hab obwohl meine Anlage angeschlossen ist (Klinge) also kein Digital. In den Windows einstellung ist alles ok der Pegel geht dementsprechend hoch und runter also der Equalizer :) und im Bios habe ich auch schon nach geschaut Sound ist aktiviert auf SPDIF und für Fronttafel HD wenn ich vorne anstecke geht es auch also kann ich musik bzw die Töne hören da er nach vorne schaltet sobald ich abstecke vorne switch er nach hinten ab da gibt er nichts raus und ja ... treiber sind installiert von der asus HP und auch von der cd beides probiert und auch Xi-Fi MB2 treiber aber ich krieg es nicht hin. Vielleicht weiß jemand die Lösung oder ich übersehe etwas . Danke schon mal im vorraus :d
CPU:Phenom X6 1100T 3.3GHz (Wakü)
Ram:Corsair Vengeance 2x4Gb
GPU: AMD HD 6870
HD: WD 500GB
Netzteil: Be Quiet Dark Power 650W
Wenn wir schon dabei sind, nach dem ich auch die graka eingebaut habe und die treiber dazu von der hp musste ich wie üblich skalieren dem bildschirm hat super geklappt aber sobald ich ein Spiel starte oder den pc neustarten skaliert r den bildschirm total über mein bildschirm rand und so muss man jedes mal es zurücksetzten :/ ist jetzt nicht das problem aber ist schon doof. Monitor 25Zoll
Schonmal jemand das neueste BIOS (1102) getestet und evtl. für gut befunden? :P
So, hallo, bin neu im Club :d
Hatte vorher ein Asrock 990fx Extreme3, bei dem die Spawas ab der minimalsten CPU-Übertaktung so eine Hitze ausgestrahlt haben, dass meine CPU Temp unter last pro Sekunde um etwa 5° stieg, bis der Multi von meinem FX nach etwa 5 sek Prime auf 7 runterging und damit auch die Spannung. Totaler Produktfehler.
Mit dem Crosshair siehts sehr gut aus bis jetzt, habs aber gerade erst drin und muss mein Windows noch zurechtfummeln.
Da sind ja nun 1000 Software Programme bei, gibts eins zum Bios flashen unter Windows oder geht das nur im Bios selbst?
Edit: Ohwei, ist ja super einfach, dann ist das natürlich besser als es im Windows zu machen ;D
Ist aber schons eit lagem so, dass es so einfach ist des Bios zu flashen im Bios selbst xD
Tjoa keine Ahnung, habs immer im Windows gemacht, weils halt so gut ging. Never change a running System :d
