[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Ich würde nie ein Windows Flash machen. Wie schon ataridelta9 schrieb, ist es mittlerweile so einfach diese Boards zu flashen.
Einfach das entpackte BIOS auf einen Stick oder auch auf der Festplatte lassen, wo du genau weißt wo es sich befindet und dann vom BIOS aus zugreifen und flashen. Dazu einfach mal ein Blick ins Handbuch werfen ;)
Was ich schön finde ist,d ass jetzt auch im AMD-Segment das UEFI Bios Einzug findet!
Leider sind noch nicht alle dabewi (Gigabyte z.B)
Was ich wiederum etwas doof finde ist, dass keine vollwertige X-FI 2 verbaut wird, sondern
nur dieser Realtekschei** mit X-FI 2 Emulation.... :grrr:
Ist aber etwas gewöhnungsbedürftig, so ein UEFI BIOS, ich nutze dennoch die Tastatur, geht einfach schneller ;)
Das mit dem Sound-Chip ist leider bei allen Formula Brettern von Asus, auch bei meinem Rampage.
Ajo.. ich finds gut das sich da jetzt mal was ändert... Immer das gleiche wird irgendwann auch ätzend.
Der Soundchip ist eh für den Sack... hab lieber ein ganze normalen ALC889.
Mein Optischer Ausgang geht nämlich nicht wirklich... sobald Last vorhanden ist knackt es wie wild.
Mi8r ist klar geworden: "Mit ner vernünftigen Onboardsoundlösung" wirds NIE einen geben....
Ich bleibe bei meiner guten X-FI Xtreme Music mit althergebrachten PCI-Interface ;)
Klar gibt es eine vernünftige Onboardlösung - ALC 889... Kann sogar DDL. Ob ich nun die teuerste x-fi oder den billigsten Realtek Chip nehme macht bei digitaler Übertragung kein Unterschied :p
Hätte mal ne Frage, bin vom Crosshair IV auf das Crosshair V umgestiegen...Nun ist ja auf dem Crosshair V ein Molex Anschluss verbaut, sowie ein 4 poliger, sowie ein 8 poliger Stecker 12V ATX Anschlüsse. Soll ich den Molex Anschluss "anstöpseln", der sollte ja für Crossfire/SLI zur Unterstützung sein oder? Die 12V Stecker alle anschließen, denke schon :d
Der 8Pin (und davon sogar nur 4 Pin) reicht. Der zusätzliche 4Pin ist für extremes OC und der Molex Anschluss speziell für SLI/Crossfire.
@burn_deh: Thx :) Hab im Handbuch gerade gesehen; 8pin oder 4pin (von 8pin) oder 4pin...
Hm ich hab ein HD5770 CF, meinst du dafür brauche ich schon den extra Strom
über den Molex Anschluss auf dem Board? :-/ Auf dem Crosshair IV gings auch
ohne... :confused:
Hab es selber nie getestet, im Handbuch wird es halt empfohlen / erwähnt.
Hm.. ich gehe davon aus das man den nur für die größeren Karten im CF braucht.
Voher hat es ja wiegesagt auch ohne zusätzlichen Molex geklappt.
Ich beobachte des mal weiter.
Das HD 5770 CF Gespann läuft ohne den Molex Problemlos.
Hatte die selbe Config auch schon hier stehen.
Grüße
Der Zusätzliche Molex Stecker ist auch nur für Extreme OC. Den brauchte ich bisher noch nicht mal bei meinem Rampage III Formula anschließen in Verbindung mit meinen zwei GTX 470ern.
Bei mir habe ich beide 12-Volt-ATX Stecker drauf.(4 Polig und 8 Polig)Der vierpolige soll wohl extra für den Speichercontroller sein.Link
Hmm komisch, hab mir extra die deutsche Anleitung von Asus runtergeladen, da steht drin 8pol in 8pol ODER 4pol in 8pol ODER 4pol in 4pol...
Jungs, wie sieht das eigentlich mit dem MB aus, mit SLI.
Fuktioniert des gut, oder giebts irgendwelche Probleme.
Oder sollte man die Finger davon lassen Nvidia karten zu verbauen?
Schonmal jemand das neueste BIOS (1102) getestet und evtl. für gut befunden? :P
Habe es seit geraumer Zeit drauf und was soll ich sagen: es funtzt.
Die Corsair Vengeance 1600 C9 laufen jetzt auch ohne Probleme mit 1600 Mhz und CR 1T bei vollen ( 4X4 GB ) Speicherbänken.
Vorher sind sie mir bei Einstellung 1T einfach abgestürzt.
Jetzt wird auf den FX 8150 geschielt und auch wenn 6 Kerne ( Phenom II 1100T @ 3574 Mhz) schon mehr als ausreichend sind ( ein Glück, das Cool'n Quiet abeschaltet iss, sonst würden die bei Crysis 2 wohl in diesem Modus laufen :d ).
Irgendwann ist auch die Software soweit, mit den Kernen spielen zu können :d
Ich überlege derzeit in euer Lager zu wechseln :d
(Vdrop Problem beim UD5 und Ram OC mag es auch nicht ...)
Was machen eure Boards so an Referenz- und Ramtakt mit ?
Hallo!
Ich habe ein Problem. Nach einigen Freezes habe ich das BIOS von 1003 auf 1102 aktualisiert. Jetzt startet das BIOS zwar, aber Win7 kann nicht von meiner Corsair Force F660 starten. Die SSD wird im BIOS angezeigt, aber es wird kein OS gefunden (AHCI war auch vor dem Update aktiviert). Kann es sein, daß das neue BIOS ein Problem mit der SSD hat oder soll ich mal zurück flashen?
Edit: Sollte F60 heißen und ein PII X6 1090T ist drauf mit 2x4GB DDR3-1600
Versuche mal mit der Windows Install. DVD/CD den Rechner zu starten und führe die Reparatur-Funktion (1. von oben) aus.
Dann sollte dein "Loader" repariert werden. :coffee:
good luck
fuzzy
Danke Dir! Hatte gerade zum 4.Mal gebootet, jetzt läuft Windows:fresse2: . Werd mal ein Game anwerfen. Hatte gestern Abend auf einmal ein Freeze und dann ist das Board nur bis zur CPU LED gestartet und sonst nichts. Habe dann die RAM einzeln getestet. Windows ist nur gestartet wenn ich den RAM raus und wieder eingebaut hatte. Das funktionierte auch mit dem gleichen Riegel. Prime lief stabil, danach wieder freezes. Werde mal einiges Testen, hoffe ja, daß es mit dem BIOS Update geht.
Edit: Zu früh gefreut - Rechner schon wieder gefreezt. Ich habe es sowohl mit den 2x4GB und den "alten" 2x2GB und auch einzeln getestet. Kann mir nicht vorstellen, daß 4 RAM Riegel defekt sind, die bis gestern funktioniert haben. Ist es möglich, daß die CPU den Geist aufgegeben hat? immerhin bleibt er ja bei der CPU LED hängen. Hatte auf der CPU seit Dezember ca. 1,35V mit ner Wakü. Board hat auch ne Wakü.
Hoffe, daß das nicht als Doppelpost gilt 2 Tage später.
Habe jetzt mal einen Sempron 145 eingebaut und jeweils mit 1 RAM-Riegel (alle 4 Riegel durchprobiert). Beim Start leuchtet die rote CPU LED durchgängig und manchmal blinkt die RAM LED dazu, aber nicht immer, also wäre die CPU auch ausgeschlossen. Bleibt nur die wenig wahrscheinliche Variante, daß alle 4 RAM durch sind (liefen mit 1,5V @ 1926MHz) oder schon wieder mal das Board. Das ist aber wassergekühlt. - Alles lief seit ca. 2 Monaten stabil ohne Veränderungen. - Was meint Ihr dazu?
Nun ich hatte mit Asus bis jetzt immer Pech. Das erste Crosshair V hab ich gleich zurück gesendet (Kühler lag schief auf der NB) und vor Jahren hatte ich ein P5N32-SLI. das hat mir 2x auf die RAM 3V gegeben. Dazwischen nur gigabyte und XFX (nie Probleme).
Du meinst, es ist das Board?
