[Sammelthread] Asus Maximus V Gene R.O.G (Intel Z77)
Willkommen im Sammelthread zum ...
Layout:
weitere Bilder:
Spezifikationen:
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, red) *2
1 x PCIe 2.0 x4 (black)
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset : *4
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s), black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
LAN Intel®, 1 x Gigabit LAN Controller(s)
Audio SupremeFX III built-in 8-Channel High Definition Audio CODEC
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- 1500 uF Audio Power Capacitor
- Gold-plated jacks
- X-Fi® Xtreme Fidelity™
- EAX® Advanced™ HD 5.0
- THX® TruStudio PRO™
- Creative ALchemy
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase QPI/DRAM power design
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Backpanel:
1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0
4 x USB 2.0 (one port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
OnBoard-Anschlüsse:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
8 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Lieferumfang:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x ROG Door Hanger(s)
UEFI SCREENS:
Links:
Preisvergleich
Produktseite / Info beim Hersteller
Downloads: Bios, Treiber, Handbuch,...
Downloads: Bios, Treiber, Handbuch... Direktlinks
+ Handbuch MAXIMUS V GENE User's Manual (English)
+ Maximus V GENE Bios 0402 - [First Release Bios]
+ Maximus V GENE Bios 0503 - [1.Improve system stability. 2.Enhance compatibility with some USB devices.]
+ Maximus V GENE Bios 0602 - [Official Beta Bios Asus FTP]
+ Maximus V GENE Bios 0650 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0701 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0805 - [Added DRAM Tuning Improved Performance Default enable thunder bolt support IRST Update]
+ Maximus V GENE Bios 0880 - [Updates system compatibility Improves performance Improves DRAM Overclocking]
+ Maximus V GENE Bios 0881 - [fixed data vref bug ]
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1019 XpVistaWin7
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1020 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.0.1262 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.4.1441 Win7 32bit & 64bit
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.10.1464 Win7 32bit & 64bit Windows XP HE MCE Pro 32bit & 64 Bit
+ Treiber SATA: Intel® Rapid Storage Technology V11.0.0.1032 Windows XP/7 32bit & 64bit (WHQL)
+ Treiber SATA: Intel® Rapid Storage Technology V11.1.0.1006 Windows XP/7 32bit & 64bit.(WHQL)
+ Treiber SATA: Intel® Rapid Start Technology Software V1.0.0.1022 for Windows 7 32bit & 64bit
+ Treiber SATA: Asmedia SATA Controller V1.3.4.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.1.209 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.4.220 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Asmedia USB 3.0 V1.14.3.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.6.0.0 WHQL XpWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 64-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 64-Bit
+ Treiber Video: Intel Graphics Accelerator V8.15.10.2598 Windows Win7 32bit & Win7 64bit (WHQL)
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 64-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.2696 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.64.2696 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU V2111120856 Win7
+ Utility Video: LucidLogix Virtu MVP Wizard V1.00.08 for Windows Win7 32bit & Win7 64bit
+ Utility Video: Lucid Virtu Universal MVP Software V2.1.110.19997
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6570 & 6.0.1.6570 WHQL XpVistaWin7
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6602 & 6.0.1.6602 WHQL XpVistaWin7
+ Utility Audio: Sound Blaster X-Fi 2 Utility Package V1.0 (R11) Windows 7
+ ASUS AI Suite II 1.0.2.27 Windows XP Win7
+ ASUS AI Suite II 1.0.2.29 Windows XP Win7
+ ROG GameFirst V1.0.1.09
+ ROG ConnectPlus V1.0.0.14
+ ROG Connect V1.0.6.03
+ ROG CPU-Z V1.59.2
+ ROG Theme V1.0.0.12
+ DAEMON Tools Pro V44003120221 XP Win7
Besonderheiten:
Reviews:
[url=http://www.overclockers.com/asus-maximus-v-gene-motherboard-review/]ASUS Maximus V GENE Motherboard Review | Overclockers.com
ASUS Maximus V GENE (Intel Z77) Motherboard Review | TweakTown USA Edition
ASUS Maximus V GENE Motherboard review | guru3d.com
ASUS Maximus V Gene Overclocking Review And Benchmarks | motherboards.org
Asus Maximus Gene V Preview | lanoc.org
ASUS Maximus V GENE Review | votez.net
Asus Maximus V Gene (Z77) Motherboard Sandy Bridge Review | eTeknix.com
Intel Z77 Chipset Launch Roundup - ASUS Maximus V Gene | hardwareheaven.com
ASUS Maximus V Gene| AwardFabrik.de
Au-Ja! - ASUS Maximus V Gene | au-ja.de
Weitere Infos und nützliche Links:
- Maximus IV GENE-Z BIOS Guide - Overclocking
Kompatibilität Arbeitsspeicher:
QVL - QUALIFIED VENDOR LIST - DOWNLOAD
User Berichte:
Kompatibilität CPU Kühler:
+ Corsair H60 (Preisvergleich)(Foto von Emiras)
+ Corsair H70 (Preisvergleich)
+ EKL Alpenföhn K2 (Preisvergleich)
+ Noctua NH-C14 (Preisvergleich)
+ Noctua NH-D14 (Preisvergleich)
+ Prolimatech Genesis (Preisvergleich)
+ Prolimatech Megahalems (Preisvergleich)
+ Prolimatech Black Series Megahalems (Preisvergleich)
+ Thermalright Venomous-x (Preisvergleich)
+ Thermalright HR-02 Macho (Preisvergleich)
+ Thermalright Silver Arrow (Preisvergleich)
Overclocking Ergebnis:
Moin Moin.
Plane auch das MoBo in meinen neuen Rechner einzubauen.
Was meint ihr würde das Mobo zusammen mit CPU Kühler "be quiet! Dark Rock Advanced C1" und/oder "Enermax ETD-T60-VD inkl. T.B.Vegas DUO PWM 12cm LED" passen? (Noch besser zusammen mit dem Gehäuse Zalman Z9 Plus)
Oder würden einige Ram bzw. PCIe Slots verdeckt?
Danke für Eure antworten =)
Welches ist denn die aktuellste BIOS-Version? Einige der hier verlinkten BIOS-Versionen sind doch entweder nicht offiziell oder im Beta-Status?!
Die letzte finale Version müsste doch 0602 sein?
MfG.
0701 ist die neuste ... die enthält einige fixes ... direkt von einem der Entwickler des Boards ... besser geht es nicht.
Hier gibt es ein Bild von Dark Rock C1 auf M4GZ ... die Abstände sind praktisch gleich.
http://cdn.overclock.net/e/ed/eddb1127_vbattach224570.jpeg
IMHO gibt es bessere Kühler für das Geld - die außerdem nicht so viele Ram Slots verdecken.
Der Thermalright HR-02 Macho ist einfach ideal für das Board wegen des asymmetrisch Designs.
Okay, dann wirds wohl der Macho...
Vielen dank Iron für den Tip =)
Send from my Samsung Galaxy S
Danke; BIOS 0701 läuft wirklich rund; die Spannung ist nochmals etwas runter - cool :-)
1-2 Frames plus/minus in insgesamt drei Games ... als ob das statistisch relevant wäre - vom Stromverbrauch abgesehen sehe ich NULL Advantage MSI.
Eher ein Advantage in Sachen Übertaktung für das Maximus V Gene. Kompetenz des Autors in Sachen Overclocking ?! NAJA :hmm:
Also ich will das Asus nicht verteidigen. Da gebe ich eigentlich nichts drauf, aber ich sehe ganz klar, dass es bei den FPS selbstverständlich kaum Unterschiede gibt.
Beim Stromverbrauch liegt das MSI vorne und beim OC setze ich aufs Asus. Das ist dann halt eine Entscheidung, die man beim Kauf trifft. OC oder Sparsamkeit...
... außerdem würde ich auch - von der Rohleistung mal abgesehen - mATX und ATX-Boards nicht ohne Weiteres miteinander vergleichen wollen;
die geringen Performance-Unterschiede zwischen dem MSI-Board und dem Gene V können mit einer neueren BIOS-Version - oder je nach Systemkonfiguration -
schon ganz anders aussehen. Im mATX-Bereich ist das Gene V schon (fast) konkurrenzlos ...
Mit verteidigen hat das nichts zu tun - Beurteilung "schlechter" sehe ich bei einer Differenz im Bereich der Messungenauigkeit als unangemessen an.
In mein TJ08-E passt eh nur ein MATX-Board und in der Größe gibt es nun leider keine wirkliche Alternative zum V Gene.
Zuletzt konnte ich mit meinem V Gene mit G530/IGP, only SSD an einem be quiet! Straight Power E9 450W mit allen Onboardkomponenten aktiv/Idle 23Watt Verbrauch ablesen! Finde ich nun wirklich recht passabel :)
Moin Moin,
Wie gut ist eigtl. diese Funktion ??
ASUS Hybrid Processor - TurboV EVO :
- CPU Level Up
Taugt das was?
Bin noch neuer im OC Bereich und würde gerne wissen ob das wirklich was taugt diese "One-Klick" OC.
Danköö
Moin Moin,
- CPU Level Up
Taugt das was?
Danköö
Da würde ich gepflegt die Finger von lassen. Habe nur spaßeshalber das Levelup auf 4,6 Ghz ausprobiert. Meine CPU braucht für 4,5 GHz ca. 1,27 und für 5,1 GHz irgendwas um die 1,48 V. Für 4,6 GHz hat die Auto-OC-Funktion 1,56 Vcore angelegt oder so .... so schnell hatte ich den Rechner schon lange nicht mehr aus :fresse:
Morgen werde ich das Board mal verbauen und einen 2700K trauf hauen.....:p
Denke auch darüber nach, umzusteigen... Lohnt sich das von nem MSI Z68A-GD80 noch umzusteigen? Vorallem kein PCI für meine WLan Karte... Diese Mini-PCI-WLan-Geschichte, kann ich da einfach Antennen reinschrauben, (hab noch welche...) oder brauch man da noch irgendeine Bastellösung?
Greetz Joe
Moin!
Ich bin jetzt auch kurz davor zu bestellen, denke das Board reicht für mich, nur mit dem kleinen PCI steckplatz bin ich mir nicht sicher, ich möchte auf jedenfall meine Sound Blaster X-Fi Titanium Fatal1ty weiter benutzen.jetzt habe ich dem Artikel auf pcgh gelesen, wenn kein Ivy Bridge-Prozessor benutzt wird verliert man automatisch 8 Lanes an der Grafikkarte? wenn ich in dem kleinen pci-e meine Soundkarte verwende.
Z77-Mainboards: Dritter PCIe-Slot funktioniert nur mit Ivy Bridge-Prozessoren
Ich hab wirklich versucht mich zusammen zu reißen und nicht zu bestellen, aber heute musste ich dann doch das Asus Board bestellen. Ich möchte unbedingt die 5GHz(+) im Regelbetrieb sehen, die 4,8GHz die ich jetzt habe sehen einfach nicht so schön aus. Bin ja gespannt auf die Ergebnisse die Microborg uns präsentieren wird. Mindfactory hat das Board schon in den Versand gegeben, dann kann ich am We wieder basteln - lange ist her
Hätte da auch noch eine Frage bezüglich sound. Einerseits wird bei Asus von EAX5,XFi usw. geschrieben das auf eine Creative hindeutet, andererseits sehe ich bei Asus nur Treiber für eine realtek. Sind da nun 2 Onboard oben oder wie soll das gehen ? Wenns nur eine realtek mit irgendwelchen Lizenzen von Creative ist würde ich gerne wissen welche realtek da denn nun genua verbaut wurde.
Ich hoffe ihr könnt mir helfen denn ich sehe den Wald vor lauter Bäumen nicht mehr :)
Also handelt es sich bei diesen X-Fi um eine reine Software Lösung und als hardware ist auch hier nur eine stinknormale realtek verbaut ? :)
Stimmt - das Control Panel von X-FI MB ist schon stark eingeschränkt gegenüber dem einer richtigen X-FI Soundkarte.
Da ich den x4 PCIe Slot benötige darf ich mir wohl eine Ivy Bridge CPU kaufen.
Endlich einen Grund dafür gefunden meinen 2500K zu tauschen. :fresse:
(Der 24/7 auf 5 GHz läuft auf dem Board unter Luftkühlung - super Teil eigentlich)
Ich weiß das es stark vom verwendeten Prozi abhängt, aber hast Du die 5 GHz relativ zügig hin bekommen oder war viel Feintuning von Nöten? Ich finde es einen Fluch und Segen zugleich, wenn ein Board überdurchschnitllich viele OC-Einstellungen anbietet. Bei manchen bin ich mir einfach nicht sicher was diese wirklich bewirken - mal abgesehen von den Standard-Einstellungen die es seit dem P67-Boards eigentlich in jedem Bios gibt (und eventuell schon vorher).
Haste so nen WLan-Chip bzw mini-Steckkarte drin? Möchte mal wissen, ob die funktionieren und was ich da basteln muss^^
Greetz Joe
Denke bis 4.5 GHz ist es relativ easy ... über 4.8 GHz wenn man hinsichtlich VCore optimieren nöchte muss man etwas mehr Zeit investieren.
Lies Dir einfach mal den OC Guide durch - das was fürs Gene-Z gilt lässt sich größtenteils aufs M5G übertragen.
Greetz Joe
Ich denke, dass jede MiniPCIe WLAN-Karte gehen wird, wie man sie aus Notebooks kennt. Allerdings brauchen diese Teile auch eine Antenne, die gewöhnlich im Notebook-Gehäuse verlegt ist. Die muss man also irgendwie dazu kaufen und verdrahten, denke ich.
Das wird dann wohl eher frickelig :-[
Greetz Joe
Ne leider noch nicht verbaut,bin gerade am testen mit meinen neuen Speicher bestückt mit bbse von Mushkin und die laufen perfekt.:d
