[Sammelthread] Asus P5B / P5B Deluxe /-WiFi–AP (Intel P965) [7]
Aktuell
Die komplette P5B-Reihe ist 45nm CPU ready : XS.org
1hoch
Inhalt
uber
Überblick
Sockel: LGA775
Unterstützte CPUs_
Intel® LGA775 Platform
Intel® Penryn Ready
Intel® Quad-core CPU Ready
Intel® Core™2 Extreme / Core™2 Duo Ready
Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
Unterstützte FSBs_ 1066/800/ 533 MHz
Chipsatz_ P965 Express
1 PCIe x16 PEG Link
Sehr gut übertaktbar, FSBs über 500MHz keine Seltenheit [P5B Deluxe]
[Ich brauch noch mehr Allgemeines]
p5b
P5B
  • Storage
    • 4x SATA 3Gb/s [ICH8]
    • 1x IDE über JMicron
    • 1x eSATA über JMicron
    • 1x SATA über JMicron
  • RTL8111B PCI-E Gb LAN
  • 8-channel HD Audio
  • AI NOS™ / AI Gear / AI Nap
^Inhalt
clbBios-Changelog fürs P5B
2104 - 2009/05/27
Support new CPUs. Please refer to our website: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
1604 - 2007/07/13
1. Enhance memory compatibility under FSB1333 mode
1501 - 2007/07/05
1. Add new CPU uCode to support new processor
1405 - 2007/06/13
1. Update CPU ucode to support new processor
2. Revise SLP 2.0 rule
3. Enable hotplug support under AHCI mode
4. Fix displayed CPU frequency incorrectly after downgrade CPU ratio
1202 2007/04/04
1. Fix system may sometimes hang after load default in setup then exiting right away while having Conroe CPU
installed.
2. Add new uCode to support new CPU.
1102 - 2007/01/31
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
1. Finetune Q-Fan control algorithm
2. Enable EIST under VISTA
3. Update CPU Ucode to support new CPU
4. Fix BBS device string not correct under AHCI mode
5. Support SLP2.0 string
6. Fix HCT unreported I/O and memory issuse
7. Support disable USB function item
8. Allow disable XD for conroe L
9. Add full reset after change DRAM mode to enhance memory compatibility
10. Support CONROE E0 CPU(FSB 1333)
11. Fix AC Power loss function not correct
12. Support x4 DIMM
0806 - 2006/11/
1. Enable support for WiFi-TV card
2. Enable PreslerXE 3.73 support
3. Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI
mode
4. Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
5. Enhance ATA ODD compatibility
6. Support Conroe-L CPU
7. Fix CPU VCORE too high after overclocking fail
0701 - 2006/10/5
2. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
3. Reduce system full reset of times
4. Patch some VGA card can't found when NB Vcore value has been set too high
5. Fix DDR frequency 889 unstable by SPD
6. Add new CPU Ucode to support Kentsfield B3 stepping CPU
7. Improve S3 resume time
8. Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
9. Fix chassis fan 2 speed not correct when fan speed too low.
^Inhalt
p5bp
P5B-Plus
  • Intel LGA775 Platform
  • Intel® Quad-core CPU Ready
  • Intel® Core™2 Extreme / Core™2 Duo Ready
  • Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
  • 1066/800/ 533 MHz
  • Dual-channel DDR2 800/667/533
  • 1x PCI Express x16
  • Storage
    • 6x SATA 3Gb/s [ICH8R]
  • PCI-E Gigabit LAN controller
  • AI NOS™ / AI Gear / AI Nap/ TPM Support
  • All High-quality Conductive Polymer Capacitors
^Inhalt
clpBios-Changelog fürs P5B Pus
0638 - 2008/10/29
Enhance the compatibility with certain memory.
0604 - 2007/06/13
1. Fixed PCProbe II fail to install problem
2. Add new uCode to support new processors
3. Enable SATA Hotplug support under AHCI mode
^Inhalt
p5bd
P5B Deluxe
  • Crossfire-Freigabe, 2te Karte über elektrischen PCIe-x4-Slot über die Southbridge angebunden [ca. 20% Leistungsverlust]
  • Storage
  • Dual Gigabit LAN controllers, Marvell® PCI-E and PCI Gigabit LAN controllers
  • 8 Phase Power Design
  • Fanless Design - Heat Pipe & Stack Cool 2
  • Array Mic / Noise Filter
    WiFi-AP: WiFi-AP Solo
^Inhalt
cldBios-Changelog fürs P5B Deluxe
Download --> http://amd.co.at/anti/asus/
1238 - 2009/02/11
Fix system hangs at POST while using certain 4GB memory and CPUs.
1215 - 2007/07/13
1212 - 2007/07/09
1. Add new CPU uCode to support new processors
3. Enable support for SATA hot plug function under AHCI mode
4. Fix after downgrade CPU ratio, the Conroe L frequency not correct under ASUSCPU
1101 - 2007/04/04
1 Add new uCode to support new CPU.
2 Fix system won''t complete POST with GV-MVP/RZ2(TV tuner) connected and power on before motherboard.
1004 - 2007.01.30
**This BIOS does not support roll back to older BIOS**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
0910 - 2006.01.16
1. Update Jmicron option ROM to 1.06.59
2. Fix AC Power loss function not correct
3. Support x4 DIMM
4. Moidfy Write to Precharge Delay default from 10 to 11
5. Enable support for EIST under VISTA
6. Finetune Q-Fan rule
7. Support SLP 2.0
8. Fix BBS device string not correct under AHCI mode
9. Enable Disable USB capability
10.Support ASUS WIFI-TV card
11.Revise CPU temperature calculation algorithm for PECI
0910 - 2006/12/27
no changelog avaible..
0908 - 2006/12
0903 - 2006/11/
0804 - 2006/10/25
1. Support conroe L processor
2. Update JMicron option rom 1.06.22
3. Modify CPU fan low limit speed from 800 RPM to 600 RPM
4. Implement ASUS CGI performance with ATI 1950 graphic cards
0801 - 2006/10/11
we havent changelog ...
0711 - 2006/10/04
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
0706 - 2006/09/20
1. Enhance CrossFire performance.
2. Enable NVIDIA 7950GX2 display under crashfree mode
3. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
4. Fix memory display message not correct under multi-language (dank an Norstern)
5. Add Kentsfield B3 uCode
0701 BETA - 2006/09/11
1. Fix chassis fan2 may not detect fan speed under ProbII if low spin fan is used.
0614 - 2006/09/06
1 Support DDR2 SO DIMM
2 Support DDR2 double side X16
3 Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
4 Fix Kentsfield B0 stepping CPU can't adjust ratio issue
5 Support Conroe / Kentsfield ratio overclocking higher than default (multi max 6- 11 (x-6800) -13
6 Fix CPU Fan Profile mode not correct after system shutdown
^Inhalt
ram
Kompatibler Speicher
kein Anspruch auf Vollständigkeit
sämtliche Micron D9: D9GMH und mit D9GKX
AENEON PC2-5300U-555-12 (DDR2-667) (AET760UD00-30DA98Z)
A-DATA Vitesta Extreme Edition DDR2-800+MHz PC2-6400 Dual Channel Kit CL4-4-4-15 2x1024MB
Corsair XMS2 PC2-5300U CL4-4-4-12 (DDR2-667) (TWIN2X1024-5400C4)
Corsair XMS2 PC2-6400U CL5-5-5-12 (DDR2-800) (TWIN2X1024-6400)
Corsair XMS2 PC2-6400U CL3-4-3-9 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400U CL4-4-4-12 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400PRO CL4-4-4-12 (DDR2-800) (TWIN CM2X1024-6400C4PRO)
Corsair XMS2 PC2-8500U CL5-5-5-15 (DDR2-1066) (TWIN2X2048-8500C5)
Corsair XMS2 Dominator Series PC2-8500U CL5-5-5-15-2T (DDR2-1066) (TWIN2X2048-8500C5D)
Corsair XMS2 Dominator Series PC2-8888U CL4-4-4-12-2T (DDR2-1111) (TWIN2X2048-8888C4DF)
Crucial Ballistix PC2-6400U CL4-4-4-12 (DDR2-800) (BL2KIT12864AA804)
Crucial Ballistix PC2-5300 3-3-3-12 D9GMH
Crucial Value CL5 D9GMH + D9GKX
GSkill GBHZ old D9GMH
G.Skill PC2-4200U CL4 (DDR2-533) (F2-4200PHU2-2GBNT)
G.Skill PC2-5300U CL5 (DDR2-667) (F2-5400PHU2-2GBNS)
G.Skill 2GB F2-6400PHU2-2GBNS ab 0614 Bios
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNR)
G.Skill PC2-8000U CL4-4-4-5 (DDR2-1000) (F2-8000PHU2-2GBHZ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-1GBNQ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNQ)
^Inhalt
G.e.i.L PC2-6400 CL4-4-4-12 (PC800) (GX21GB6400UDC)
Kingston DDR2-RAM 2x512MB 533MHz KVR533D2N4/512
Kingston DDR2-RAM 2x1024MB 533MHz KVR533D2N4K2/2G
Kingston HyperX DIMM 1 GB DDR2-750, KHX6000D2/1G ( max 850 mhz)
MDT PC2-6400U CL5 (DDR2-800) (M1GB-800K)
Mushkin EM2-5300 2048MB PC2-5300U CL5 (DDR2-667) (991382)
Mushkin EM2 PC6400 2048MB DualKit
Cellshock DDR2-800 CL4 (CS2221041)
OCZ OCZ2P10002G-K (OCZ Platinum Enhanced Latency XTC)
OCZ2N9001GEB
OCZ28001024EBDCPE- (OCZ Platinum DIMM Kit 1024MB PC2-6400U CL4-3-3-8)
OCZ2N11001G
Hynix HYMP564U64BP8-S5 (512MB 5-5-5)
Hynix HYMP512U64BP8-S5 (1GB 5-5-5)
Hynix HYMP564U64AP8-S6
Hynix HYMP512U64AP8-S6
Golden Emp. 8HTF6464AY-80EA3
Golden Emp. 16HTF12864AY-80EA3
Golden Emp. 8HTF6464AY-80ED4
Golden Emp. 16HTF12864AY-80ED4
Transcend TS64MLQ64V8J (Transcend DIMM 512MB PC2-6400U CL5)
TwinMos ??? M2Y51264TU88A2B-25
NANYA NT512T64U88B0BY-25
NANYA NT1GT64U8HB0BY-25C
^Inhalt
eigEigenarten
botBoot-Bug/An-Aus-Bug
Wie äußert sich dieser Bug?
Wird der PC nach dem Herunterfahren komplett vom Strom getrennt, zum Beispiel in dem man das NT danach abschaltet, wird das Board beim nächsten Systemstart zuerst einmal starten, dann wieder ausgehen um dann normal zu booten, was nicht gerade lebensdauerförderlich für die angeschlossenen Festplatten ist.
Kann man dieses Verhalten umgehen?
Den "Boot Bug" nach Netztrennung kann man auf verschiedene Weisen umgehen: Den Rechner herunterfahren und Netzschalter des NT auf AN lassen, sodaß das Board weiterhin mitStandBy-Strom versorgt wird, dann bootet der Rechner beim nächsten Start normal oder mittels Master / Slave Leiste. Der Verbrauch hierbei schwankt zwischen 2 und 20 Watt - je nach angehängten Verbrauchern. Achtung: auch die verwendete Leiste kann den Verbrauch beeinflussen. Mit einer alten Lidl-Leiste lag der Verbrauch bei 3 Watt und mit einer viel aktuelleren Aldi-Leiste zeigte der Verbrauchsmesser bei gleicher Konfig fast 18Watt. Sofern ich mich nicht verrechnet habe, hier ein Rechenbeispiel: 14 Std. täglich "Standby" (also PC heruntergefahren an der Leiste) mit 20Watt bei 0,18€ pro kw/h ergeben ~ 19€ für ein Jahr. Ist Umweltpolitisch nicht ganz korrekt, aber mir den 1,50€ im Monat wert ;)
Strap-Verhalten [Umschalten der internen Timings][/B]von Sven Bode
Hier gehts weiter>>
messMesspunkte
vCore
vFSB
^Inhalt
BiosBIOS
bif0Bios-Flashen *BETA*
Vor dem Flashen das System auf Standardtakt zurücksetzen.
Es gibt 3 verschiedene Methoden:
EZ-Flash
1. Neues Bios von Asus herunterladen und entpacken
2. Bios-Datei auf Diskette oder USB-Stick speichern
3. Neustarten
4. Entweder beim POST ALT+F2 drücken, oder EZ-Flash im Bios unter Tools/Werkzeuge auswählen
5. Laufwerk auswählen mit TAB, dann ENTER zum Flashen
6. Der Rechner startet nach Abschluss des Flashvorgangs neu​
Afudos
2. Am besten direkt in P5B.rom umbenennen
3. entsprechendes Afudos-Programm von Asus herunterladen
4. Bootbare Diskette erstellen
5. afudos.exe und P5B.rom auf die Diskette kopieren
6. Rechner mit der Diskette im Laufwerk neustarten
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom
9. ENTER Der Flashvorgang beginnt. Den weiteren Anweisungen folgen​
Unter Windows mit ASUSUpdate[Erhöhtes Risiko]
2. ASUSUpdate von Asus herunterladen
3. ASUSUpdate installieren
4. ASUSUpdate starten und dem folgenden Dialog folgen
5. Rechner neustarten​
Nun wieder alles so einstellen, wie gewohnt.
Das Flashen war erfolgreich und ihr habt euer BIOS auf die den Letzten Stand aktualisieren.
bif1Flashen älterer Versionen
1. Bios von Asus herunterladen
3. Afudos v2.07 von hier herunterladen
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom /n /pbnc
bif1Totes Bios wiederbeleben
Bei Ami-BIOS braucht man eine Diskette, bei dem das BIOS-Image als "amiboot.rom" im Rootverzeichnis liegt. Die legt man ein, schaltet den Rechner ein und hält eine magische Tastenkombination (üblicherweise Ctrl + Home, deutsch Strg + Pos1) gedrückt. Das System sollte dann beepen, auf die Disk zugreifen und das BIOS flashen (der Bildschirm bleibt dabei aber dunkel - Flash-Ende wird durch einen oder mehrere Beeps angezeigt).
Weitere Verarbeitung folgt, bei Fehlern PM an mich.
bif2PECI-Interface
***In Arbeit***​
bif3Static Read Control
***In Arbeit***​
trsTreiber/Software
Aktuelle Treiber gibt es auf
support.asus.com
  • chipAktuelle Chipsatztreiber bei Intel
    >>Link<<
  • soundSoundtreiber
  • ahciAHCI-Einbindung
    AHCI-Einbindung bei der Neu-Installation von Win XP (für alle, die das auch wissen wollten).
    Vorbereitung (Treiberdiskette erstellen)
    1. Datei iata62_cd.exe von der Intel-Webseite runterladen
    2. Datei in d:\temp\ kopieren (Beispiel)
    3. Start>Ausführen> "d:\temp\iata62_cd.exe -a -a"
    4. Den Lizenzvereinbarungen zustimmen.
    Anmerkung zu 3. und 4.: Keine Angst, es wird nichts installiert, auch wenns so aussieht.
    5. Die Dateien aus dem Verzeichnis c:\programme\intel\Intel Matrix Storage Manager\Driver (...\Driver64 bei der
    64bit edition) auf eine Diskette speichern (direkt nach a:\ )
    Win-XP-Installation
    1. Nach dem Neustart ins Bios gehen
    2. Main > IDE Configuration > SATA Configuration [Enhanced]
    3. Configure SATA as: [IDE/RAID/AHCI]
    4. AHCI auswählen
    5. Bootreihenfolge: CD oder DVD-Laufwerk muss an erster Stelle stehen
    6. F10 und Neustart (vorher noch Win XP Installations-CD einlegen )
    7. Irgendwann gleich zu Beginn wird man aufgefordert, F6 zu drücken -> F6 drücken
    Anmerkung zu 7.: Bei mir ist dann nicht gleich was passiert, hab F6 noch paarmal weitergedrückt, ist nix
    "Schlimmes" passiert
    8. Irgendwann stellt Windows fest, dass es gar keine Festplatte gibt, aber man kann, wenn man möchte, einen
    externen Treiber einbinden (JA!)
    9. Diskette rein, Windows-Installation lädt die nötigen Dateien ohne zu mucken von der Diskette
    10. Dann wird festgestellt, dass 3 Treiber zur Verfügung stehen (RAID, AHCI, SCSI) - AHCI wählen
    11. Danach alles wie gehabt - bis es dann heisst: Fertig!
    Dank an pheeacs für dieses Tutorial]
^Inhalt
nbsStrap-Verhalten[Umschalten der internen Timings]
Auslöser der ganzen Problematik - verbunden mit dem Performanceeinbruch ist
hier zu finden.
Für die Praxis relevant ist der Verlauf der grünen Linie welcher sich bzgl. der Performance wie folgt äußert.
Beispiele:
Boot bis 400 (laut Kurvenverlauf Strap 1333 genannt) - hier im Forum gerne 1067er genannt - ein SuperPi 32M
Durchlauf:
bis dorthin ist die Welt noch in Ordnung (bis FSB 400) aber dann mit FSB 401:
wie kann man diese Situation umgehen - diesen Performanceabfall, hervorgerufen durch Verlangsamung der internen
Chipsatztimings, wenn man im Bios FSB 401 einstellt und somit in der "langsameren" Strap (1600 lt. Diagramm oder
im Forum 1333) landet? [Anm.: Strapverhalten wg. FSB1333-CPUs neu prüfen]
Mittels eines Tools wie
Clockgen
wenn man vorher mit einem FSB von max 400 gestartet hat. Aber dabei gilt es zu bedenken:
1. Boot mit 333-400 - wenn Boot mit weniger werdet ihr Schwierigkeiten haben die 400 zu erreichen (langsamere
Straps)
2. Genug Boardspannung einstellen - ein guter Wert für FSB 400-420 bei der Arbeit mit Clockgen sind 1,45V - 1,55V
auch möglich, mehr bitte nur mit WaKü.
Kurze Erläuterung bei der Einstellung des Tools:
1. Herunterladen (Siehe Link) oder eben hier:
http://www.computerbase.de/downloads/software/systemueberwachung/clockgen/?url=11187
2. Tool Starten und auf "PLL Setup" klicken
3. Im Clock Genarator Setup den Taktgeber CY28551 auswählen
4. Ignore GSB/PCI anklicken
5. Apply Selection
6. Dann über PLL Control den Takt erhöhen
Selbstverständlich muss man dieses nicht nach jedem Start einstellen,
Unter "Options" Punkt "Apply Current Setting at Startup" einfach aktivieren ;)
Resultat ist dann folgendes:
keine Verlangsamung mehr :d...
...und funktioniert auch mit 4GB
Dank an Sven Bode
^Inhalt
oceOC-Einstellungen
  • Gute Erklärung zu den wichtigsten Einstellungen bei XS.org
    >>Link<<
  • Overclocking-Guide bei tthetechrepository
    >>Link<<
  • Zusammenspiel von FSB, CPU und RAM (Teiler) (dank an Shaguar)
    >>Link<<
oclOC-Liste
oclhwmHardware-Mods
Hier Pics zum VDroop Mod
Anklicken der Bilder führt zur großen Version]
noch ein Link dazu: http://www.xtremesystems.org/forums/showpost.php?p=2007217&postcount=30
Ein Bleistift ist ausreichend dafür ;)
[Modifikationen auf eigene Gefahr und unter Verlust der Garantie]
^Inhalt
raz
Passendes Zubehör
  • Speicherkühler
    • OCZ - XTC Memory Cooler
    • Corsair Airflow RAM-Kühler
Unterschiede P5B --- P5B deluxe (WiFi):
Die Unterschiede werden in dieser Liste von Asus sehr gut dargestellt:
http://event.asus.com/2006/mb/P5B/models.html
Darüber hinaus gibt es Unterschiede in den Bios-Einstellungen, die dazu führen, dass das P5B keine so guten OC
Eigenschaften wie das P5B Deluxe (WiFi) besitzt. (Dies wird hoffentlich durch ein Bios-Update gelöst)
vDimm 1,8-2,1 / vCore 1,2125 - 1,7 (P5B)
vDimm 1,8-2,45 / vCore 1,1 - 1,7 (P5B Deluxe)
Einmal kann man die Speicher-Riegel beim P5B Deluxe mit mehr Spannung versorgen, was dazu führt, dass man sie bei
höherer Taktung stabil laufen lassen kann.
Zum anderen kann die Spannung der CPU beim P5B deluxe deutlich niedriger gesetzt werden als beim P5B
(non-deluxe). Im Fall eines Allendale hat dies z.B. den Vorteil, dass man ihn mit dem Standard-Takt auf 1,1V
laufen lassen kann, während man beim non-deluxe erst bei 1,2125V anfangen kann und somit Potenzial verschenkt
(Strom / Temperatur).
amnAnmerkungen zum Thread
allAllgemeines
Eure Mitarbeit ist natürlich erwünscht!​
chaChangelog
26.03.10 V1.00: Die jeweils letzten BIOS-Versionen nachgetragen
28.07.07 V0.41: BIOS-Flash-Guide hinzugefügt
20.07.07 V0.35: Noch mehr Infos eingefügt
20.07.07 V0.30: Weitere Infos eingefügt
19.07.07 V0.11: Geordnet, Bios-Changelogs aktualisiert
19.07.07 V0.10: Erster Release: Vorläufige Gliederung eingefügt​
danDanksagungen
  • Seppelchen dafür, mich zu überreden, den Thread zu übernehmen und Infos
  • Sven Bode für das Versorgen mit Infos
  • pheeacs für das AHCI-Tutorial
  • Berlinrider
  • Antivirus für das Erstellen des ersten Sammelthreads
  • Und die vielen anderen, die hier aktiv sind
^Inhalt
Ich hab kein Problem damit, Grafikeinstellungen runter zu schrauben. Ich brauche nicht die beste optik, das Spiel soll nur flüssig laufen.
Bestellt hab ich die 1GB Variante.
Wenn ich die Zeit habe, werde ich mal ein 3dMark2006 Bench laufen lassen und dann nochmal eins, wenn der PC umgebaut und übertaktet ist und mit Win7 läuft.
Die Geschichte mit dem Ramteiler schaue ich mir nachher im Bios mal an. Vielen Dank für deine Ausführungen :)
Kein Thema.
Und bedenke daß der P965 Chipsatz schon etwas älter ist und gerade die P5B Serie seine Eigenheiten (besonders beim Übertakten) hat.
Somit kann es auch leicht passieren daß Du mit 400MHz FSB und Deinen 4 x 1GB RAMs gar nicht booten kannst. Und selbst wenn daß Du eventuell Probleme mit der Stabilität hast und an den Speichertimings und Spannungen herumschrauben musst.
So, das mit den Eigenheiten hab ich auch feststellen müssen, aber dazu gleich mehr oO
Vorgestern die Graka bei hoh bestellt, gestern war sie da. Alte Graka deinstalliert und PC runtergefahren. Baue die 8800 aus und im Größenvergleich fiel erst mal auf, das die HD5770 deutlich kürzer ist...sehr erfreulich.
Will die neue Graka einsetzen...natürlich möglichst wenig Aufwand betreiben und den Rechner bloß nicht hinlegen....würge also die Karte in den Slot, treffe wohl nicht richtig und zack...die Lasche vom PCI-E Slot erst mal abgebrochen, die da ganz am Ende dran hängt und die Karte fixiert oO
aaaaaaaaaargh, hatte ich nen Hals. Ok, dann wenigstens die Karte am Slotblech mit ner Schraube fixieren. Leider bin ich gerade umgezogen...da findet man seine Schraubendose mit PC Schräubchen natürlich nicht. Ab auf den Dachboden, da hatte ich noch ne Kiste mit altem PC Kram und zumGlück ein paar Schrauben gefunden. Wieder in den Keller, Karte fixiert...puh, die sitzt und hält zum Glück.
Kabels wieder dran und Büchse angeschaltet. Juchu ich hab ein Bild....hatte bisschen Angst, das mein 430Watt beQuiet Dark Power da mit der Leistung nicht nach kommt.
Den aktuellsten Treiber hatte ich vorher runter geladen, der wurde nun drauf geschmiergelt. Dann schnell 3dMark laufen lassen und irgendwas mit 11500Pkt oder so, mit der alten Graka waren es ca 9500.
Dann Battlefield BC2 gestartet und kein Vergleich zu vorher...endlich mal kein Geruckel ;)
Also gefühlt hat sich da ne Menge getan, durch die neue Karte.
Aber ich wollte ja auch übertakten. PC neu gebootet, ab ins Bios, FSB auf 333, PCIE Clock auf 100 und PCI auf 33,3 gestellt.
Dann noch ein paar Optionen disabled, was ich so im Board gelesen hatte. Da lief der Proz nu auf 3 Ghz, leider nur bis zum Windows Lade Screen..dann war Schicht und er hat sich rebootet.
Ok, dann bin ich auf 320 FSB runter und er ist bis ins Windows gebootet. Das entsprach 2,88 Ghz. Schnell nen 3Dmark gemacht, irgendwas mit 12900 Pkt meine ich.
Danach Battlefield, lief sahnig...leider ist mir der Rechner nach ca 10min eingefroren. Dann reset gedrückt, leider kam kein Bild mehr (ich meine hier im Forum gelesen zu haben, das das an zu wenig Northbridge Spannung liegt, kann das?). PC komplett ausgemacht, kein Bild. Erst nachdem ich den Netzstecker gezogen hab, hatte ich wieder nen Bild. Ab ins Bios und auf 300 FSb runter gegangen, was 2,7 Ghz entspricht.
Leider hatte ich keine Zeit mehr, zum ausführlichen Testen. Temperaturprobleme hatte ich laut Asus PC Probe keine. Ich denke, das sind eher Spannungsprobs.
Welche Spannungen soll ich ihm mal mitgeben?
@bucho
hi, danke für die antwort.
ja nun. mir persönlich sind die temps auch etwas zu hoch. aber ich kann dir auch sofort sagen weshalb :d
gut möglich, dass der AC Freezer 7 gut ist, aber leider ist das NZXT Hush nicht zum übertakten geeignet. ist zwar ein super gehäuse, wirklich leise, aber mit nur 2 lüftern am gehäuse und dem engen aufbau zum OC'en nicht gut.
Hallo Luxx-Gemeinde,
wollte nur mal meine (äußerst positiven) Erfahrungen zum P5B Deluxe posten. Ich habe es nach wie vor mit High-End Hardware im Einsatz und habe immer übertaktet.
Unglaublicherweise - obwohl das Board schon über 3,5 Jahre alt ist - eignet es sich sogar zum Übertakten der QuadCores noch ganz gut:
- Q9650 E0 @ 4050MHz (WaKü)
- FSB 333 @ 450MHz
- BIOS 1238 Beta
- Für diesen FSB müssen die Voltage Werte vom Board wohl schon ziemlich nach oben geschraubt werden, trotzdem sind die Temps alle im grünen Bereich. Mit FSB 445 und 4GHz läuft mein Q9650 völlig stabil, die 450MHz verwende ich nur zum Benchen.
Also nach wie vor ein tadellos OC-Board, für DualCore sowieso, schaffte mit meinem E8400 (aka Xeon X3110) immerhin 550MHz FSB und bis zu 4,8 GHz!
Also warum ein neues Board kaufen, die X38 & P35 Boards können es nur schlechter, einzig der P45er Chipsatz ist zum Übertakten der Quads noch besser geeignet. Und da auch nicht alle...
Greetz,
XStoneX
ich sehe grad dass laut deiner systeminfo dein RAM mit 1200 mhz läuft. wie ist das mit der vom p5b deluxe maximal möglichen tRFC von 42 möglich?
oder taktest du erst in windows hoch, nachdem du tRFC mit memset erhöht hast?
Ist ein Fehler von mir, der RAM läuft nun mit 890 MHz @ CL4. Mit dem DualCore lief er @ 1200 MHz, mit dem Quad bekomme ich es so nicht mehr hin. Habe zwar noch nicht wirklich getestet, werd' ich noch nachholen.
Greetz,
XStoneX
Hallo habe mir 2x2Gb von folgendem Ram gekauft: OCZ PC2-8500 1066Mhz
Kmelektronik.de: Hardware, Software, Computer und Notebooks zu günstigen Preisen
Leider bekomme ich den Ram nicht zum Laufen. Ich habe bereits dieverse unterschiedliche Einstellungen an CPU Frequenz und DRAM Frequenz vorgenommen und dabei alle anderen Settings auf Auto gelassen. Aber entweder ich komme nicht mal mehr ins Bios und muss dann einen CMOS Reset durchführen oder aber Windows wird nicht gestartet (System hängt bevor das WIndows Logo erscheint und es kommt Fehler beim Lesen des Datenträgers.)
Kann mir jemand sagen welche Einstellungen ich vornehmen muss damit ich den Ram zum laufen bekomme?
Ne ich hab die Platinum, keine Reaper.
Mir gehts mehr darum welche Einstellung soll ich denn am FSB und DRAM einstellen damit die Dinger laufen. Mir gehts nicht darum, CPU oder Ram zu übertakten, ich will nur dass es überhaupt läuft.
Mit folgenden Einstellungen schaffe ichs in WIndows.
Allerdings ist meine CPU nun übertaktet oder interpretier ich das was falsch.
Habe im Bios folgende Einstellungen vorgenommen
CPU Frequenz: 355Mhz
DRam Frequenz: 1066Mhz
PCI-E Frequenz: 100Mhz
PCI Clock: 33,33Mhz
Spannung Ram: 2,1V
Core Speed liegt bei 2130 MHz.
Das ist eher das was die CPU ohnehin bringt.
Wenn's stabil läuft, scheint es OK zu sein. Allerdings würde ich versuchen die Core Voltage auf ca. 1,25 V oder weniger abzusenken (1,38 V erscheinen mir sehr hoch). Hast du wahrscheinlich noch auf AUTO stehen, oder?
Läuft :d
Besten Dank, sonst noch irgendwelche Einstellungen die nicht gut sind.
Ich habe bisher immer alles auf Auto betrieben.
Ram habe ich wie auf Packung geschrieben auf 2,1V gestellt
Na, ist doch prima. :)
Die Einstellungen scheinen soweit in Ordnung zu sein. Bei mir steht, glaub ich, gar nichts auf AUTO. Bei den ganzen Spannungen hab' ich damals (ist mittlerweile schon Jahre her) tagelang getüftelt, bis ich die jeweils niedrigsten Werte für einen stabilen Betrieb fand.
Beim RAM kann es allerdings gut sein, das die auch wirklich die angegebene Spannung von 2,1 V brauchen. Kann man nichts machen. Hauptsache 's läuft stabil.
Eine Frage hätte ich noch.
Warum steht hier eine andere CPU Frequenz als bei CPU-Z.
@m1kka
Windows zeigt hier den CPU Takt an den die CPU beim booten hat. CPU-Z zeigt Dir den gerade aktuellen Takt an.
Nachdem Du den FSB erhöht hast (von 266MHz auf 355MHz) geht natürlich auch der CPU Takt rauf solange Du nicht den Multiplikator herabsetzt.
Deine CPU hat per Default: 266MHz FSB x 8 Multi = ~2133MHz
Nachdem die CPU jedoch auch EIST (Enhanced Intel Speed Step) kann taktet die CPU im Leerlauf runter. Das macht sie indem sie den niedrigsten Multi wählt ( = 6)
Sprich im Normalfall hast Du da: 266MHz FSB x 6 Multi = ~1600MHz
Du hast jetzt aber:
355MHz FSB x 8 Multi = ~2840MHz
und im Leerlauf daher:
355MHz FSB x 6 Multi = ~2130MHz
Alles klar?
Belaste mal das System und lass CPU-Z im Hintergrund offen - dann wirst Du es schon sehen.
Und die RAMs dürften nun ziemlich genau mit den Einstellungen laufen für die sie gedacht sind: 532 MHz lt. CPU-Z (= DDR2-1066) und 5-5-5er Timings sowie 2,1Volt.
Teste das System jedoch auch zur Sicherheit mal ein paar Stunden mit Prime95 Blend Test oder LinX ob das Sys auch wirklich stabil ist.
Besten Dank für die ausführliche Antwort.
Ich habe gestern über 2 Stunden L4D2 gezockt ohne Abstürze, das sollte auch als Belastungstest ausreichen oder?
Noch ne blöde Frage, wenn ich den Multiplikator von Auto auf x6 herabsetze dann ändert sich gar nix, CPU Takt bleibt trotzdem zwischen 2,1 und 2,8Ghz.
Ich habe folgendes Problem:
Ich bin von S939 auf s775 umgestiegen mit einem Intel E5200 und einem ASUS P5B.
Habe dann soweit alles eingebaut und versucht zu starten wobei ledigidlich für eine halbe Sekunde die Lüfter ansprangen und danach auch sofort wieder alles ausging.
Verschiedene Kombinationen mit Grafikkarte, Ram etc probiert aber das hat alles auch nichts gebracht.
Dann habe ich versucht mit einem Intel E6320 zu booten. Diesmal startete der PC irgendwie (die Lüfter zumindestens alle) aber ich bekam keine Rückmeldung, kein biepen und auch kein Bild.
Die Biosversion ist eine alte, wenn nicht sogar eine der ältesten, also wie behebe ich das Problem ohne es einzuschicken oder sonstiges.
Mein Gedanke wäre kurz eine alte CPU zu besorgen die auch unterstützt wird aber welche CPU wird wirklich von der ersten Biosversion an unterstützt damit ich das neueste Bios flashen kann.
Hier die CPUs, die vom P5B offiziell unterstützt werden (es laufen alle mit aktuellstem BIOS ganz nebenbei) samt erforderlicher BIOS-Version:
ASUSTeK Computer Inc.-Support-
Ich würde mir irgendeinen Celeron oder Pentium 4 besorgen, die sind am günstigsten. Dann neuestes BIOS drauf und alles sollte laufen. Außerdem kann es helfen, das System vorläufig mit nur einem Speicherriegel zu betreiben.
Greetz,
XStoneX
Mein Asus P5B vergisst gelegentlich welches die Boot Festplatte ist
Habe im Forum gesucht und noch nichts gefunden das passt.
Mein Asus P5B vergisst gelegentlich welches die Boot Festplatte ist und setzt dann im Bios eine andere Festplatte auf den ersten Platz, und zwar eine welche gar nicht in der Boot Reihenfolge eingetragen war (die Boot Platte verschwindet aus der Boot Reihenfloge.
Das merke ich dann wenn Windows nicht startet und nur der Cursor blinkt. Ab ins BIOS, wieder auswählen und es geht wieder.
Anmerkung: Der Fehler passiert nur gelegentlich und auch nur bei Kaltstart.
Anmerkun 2: Der Fehler ist passiert als ich von einem normalen Raid gebootet habe und tritt immer noch auf seit ich von SSD boote.
Liegts an der Batterie? Die anderen Einstellungen werden alle sauber gespeichert und gingen bis jetzt auch nie verloren.
Hatte jemand ein ähnliches Problem? Wie habt ihr's gelöst?
@And007
Also ich kann mir nicht so recht vorstellen daß das die Batterie ist. Denn wenn dann würde er alle Einstellungen im BIOS (vor allem die Uhrzeit) vergessen. Wenn er sich die aber merkt dann denke ich nicht daß die Batterie leer / schwach ist.
Soviel ich weiß erkennt das BIOS mal die Platten - und bietet dann anhand der erkannten Laufwerke die Bootmöglichkeiten bzw. Einstellungen im BIOS an. Sprich falls er die Platten mal neu erkennt kann sich die Reihenfolge ändern.
Somit würde ich immer die Bootplatte an den ersten SATA / IDE Anschluss stecken.
@bucho
Vielen Dank für den Tip. Leider ist die Bootplatte schon am ersten Sata Anschluss. Zumindest glaube ich das
Es sind ja sechs Sata Anschlüsse welche folgendrmassen angeordnet sind
An dem mit den === hab ich sie angeschlossen
P.S: Kleine Korrektur: Bei Meinem Motherboard handelt es sich um das P5B Deluxe wifi. Ich glaube aber da solte sich nichts aendern.
Trotzdem vielen vielen Dank.
Hallo P5Ber,
habe hier ein P5B del. am werkeln, würde jetzt gerne auf eine GK mit ATI 5770 aufrüsten. Sind da Probeleme bekannt, z.B. mit PCIe 1.0, 1.0a und 2.0?
Oder noch besser, hat jemand eine entsprechende GK am laufen?
Hatte bis vor kurzem eine 5870er drin - funktioniert also bestimmt problemlos! Zur Sicherheit würde ich zwar prinzipiell auf das BIOS 1238 updaten, trotzdem sollte die Karte ohne Mucken auch mit älteren BIOS-Versionen laufen.
Greetz,
XStoneX
@BOOMsDAY
Ein Kumpel von mir hat ebenfalls ein P5B-E (wie ich in meinem 2. PC) und der verwendet ohne Probleme ne HD5770. Läuft super.
Nur hat er einen alten Core2Duo E6300 drauf ( 2 x 1,86GHz, 2MB Cache, 266MHz FSB ) und den muss er natürlich kräftig übertakten damit die Grafikkarte nicht einschläft.
Auf ~ 3GHz geprügelt und dann mit etwa DDR2-855 läuft die HD5770 aber schon sehr ordentlich. Würde mal behaupten daß die in etwa die Leistung einer GTX260 mit 192 Shadern erreicht. Mal mehr - mal weniger.
Mushkin XP2-8500 (DIESER HIER) laufen auch nur schlecht auf dem Board :/
da liefen meine 2x1 Gb Kingston Value besser drauf ;)
Aber ab nächster Woche gibts eh erstmal nen neues Board :) hoffe da rennt dann alles (Asus P5N-T Deluxe)
Läuft der Q8400 auf dem P5B und dem P5B Deluxe?
Neustes Bios ist jeweils vorhanden.
Jau das steht bei beiden Boards dabei, allerdings nur "beta support FSB1333 CPU"
Und beta ist halt beta. Google spuckt da nämlich teilweise andere Meinungen aus.
Hatte halt gehofft, dass die Kombination hier jemand am laufen hat.
