[Sammelthread] Asus P5B / P5B Deluxe /-WiFi–AP (Intel P965) [7]
Aktuell
Die komplette P5B-Reihe ist 45nm CPU ready : XS.org
1hoch
Inhalt
uber
Überblick
Sockel: LGA775
Unterstützte CPUs_
Intel® LGA775 Platform
Intel® Penryn Ready
Intel® Quad-core CPU Ready
Intel® Core™2 Extreme / Core™2 Duo Ready
Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
Unterstützte FSBs_ 1066/800/ 533 MHz
Chipsatz_ P965 Express
1 PCIe x16 PEG Link
Sehr gut übertaktbar, FSBs über 500MHz keine Seltenheit [P5B Deluxe]
[Ich brauch noch mehr Allgemeines]
p5b
P5B
  • Storage
    • 4x SATA 3Gb/s [ICH8]
    • 1x IDE über JMicron
    • 1x eSATA über JMicron
    • 1x SATA über JMicron
  • RTL8111B PCI-E Gb LAN
  • 8-channel HD Audio
  • AI NOS™ / AI Gear / AI Nap
^Inhalt
clbBios-Changelog fürs P5B
2104 - 2009/05/27
Support new CPUs. Please refer to our website: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
1604 - 2007/07/13
1. Enhance memory compatibility under FSB1333 mode
1501 - 2007/07/05
1. Add new CPU uCode to support new processor
1405 - 2007/06/13
1. Update CPU ucode to support new processor
2. Revise SLP 2.0 rule
3. Enable hotplug support under AHCI mode
4. Fix displayed CPU frequency incorrectly after downgrade CPU ratio
1202 2007/04/04
1. Fix system may sometimes hang after load default in setup then exiting right away while having Conroe CPU
installed.
2. Add new uCode to support new CPU.
1102 - 2007/01/31
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
1. Finetune Q-Fan control algorithm
2. Enable EIST under VISTA
3. Update CPU Ucode to support new CPU
4. Fix BBS device string not correct under AHCI mode
5. Support SLP2.0 string
6. Fix HCT unreported I/O and memory issuse
7. Support disable USB function item
8. Allow disable XD for conroe L
9. Add full reset after change DRAM mode to enhance memory compatibility
10. Support CONROE E0 CPU(FSB 1333)
11. Fix AC Power loss function not correct
12. Support x4 DIMM
0806 - 2006/11/
1. Enable support for WiFi-TV card
2. Enable PreslerXE 3.73 support
3. Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI
mode
4. Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
5. Enhance ATA ODD compatibility
6. Support Conroe-L CPU
7. Fix CPU VCORE too high after overclocking fail
0701 - 2006/10/5
2. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
3. Reduce system full reset of times
4. Patch some VGA card can't found when NB Vcore value has been set too high
5. Fix DDR frequency 889 unstable by SPD
6. Add new CPU Ucode to support Kentsfield B3 stepping CPU
7. Improve S3 resume time
8. Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
9. Fix chassis fan 2 speed not correct when fan speed too low.
^Inhalt
p5bp
P5B-Plus
  • Intel LGA775 Platform
  • Intel® Quad-core CPU Ready
  • Intel® Core™2 Extreme / Core™2 Duo Ready
  • Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
  • 1066/800/ 533 MHz
  • Dual-channel DDR2 800/667/533
  • 1x PCI Express x16
  • Storage
    • 6x SATA 3Gb/s [ICH8R]
  • PCI-E Gigabit LAN controller
  • AI NOS™ / AI Gear / AI Nap/ TPM Support
  • All High-quality Conductive Polymer Capacitors
^Inhalt
clpBios-Changelog fürs P5B Pus
0638 - 2008/10/29
Enhance the compatibility with certain memory.
0604 - 2007/06/13
1. Fixed PCProbe II fail to install problem
2. Add new uCode to support new processors
3. Enable SATA Hotplug support under AHCI mode
^Inhalt
p5bd
P5B Deluxe
  • Crossfire-Freigabe, 2te Karte über elektrischen PCIe-x4-Slot über die Southbridge angebunden [ca. 20% Leistungsverlust]
  • Storage
  • Dual Gigabit LAN controllers, Marvell® PCI-E and PCI Gigabit LAN controllers
  • 8 Phase Power Design
  • Fanless Design - Heat Pipe & Stack Cool 2
  • Array Mic / Noise Filter
    WiFi-AP: WiFi-AP Solo
^Inhalt
cldBios-Changelog fürs P5B Deluxe
Download --> http://amd.co.at/anti/asus/
1238 - 2009/02/11
Fix system hangs at POST while using certain 4GB memory and CPUs.
1215 - 2007/07/13
1212 - 2007/07/09
1. Add new CPU uCode to support new processors
3. Enable support for SATA hot plug function under AHCI mode
4. Fix after downgrade CPU ratio, the Conroe L frequency not correct under ASUSCPU
1101 - 2007/04/04
1 Add new uCode to support new CPU.
2 Fix system won''t complete POST with GV-MVP/RZ2(TV tuner) connected and power on before motherboard.
1004 - 2007.01.30
**This BIOS does not support roll back to older BIOS**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
0910 - 2006.01.16
1. Update Jmicron option ROM to 1.06.59
2. Fix AC Power loss function not correct
3. Support x4 DIMM
4. Moidfy Write to Precharge Delay default from 10 to 11
5. Enable support for EIST under VISTA
6. Finetune Q-Fan rule
7. Support SLP 2.0
8. Fix BBS device string not correct under AHCI mode
9. Enable Disable USB capability
10.Support ASUS WIFI-TV card
11.Revise CPU temperature calculation algorithm for PECI
0910 - 2006/12/27
no changelog avaible..
0908 - 2006/12
0903 - 2006/11/
0804 - 2006/10/25
1. Support conroe L processor
2. Update JMicron option rom 1.06.22
3. Modify CPU fan low limit speed from 800 RPM to 600 RPM
4. Implement ASUS CGI performance with ATI 1950 graphic cards
0801 - 2006/10/11
we havent changelog ...
0711 - 2006/10/04
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
0706 - 2006/09/20
1. Enhance CrossFire performance.
2. Enable NVIDIA 7950GX2 display under crashfree mode
3. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
4. Fix memory display message not correct under multi-language (dank an Norstern)
5. Add Kentsfield B3 uCode
0701 BETA - 2006/09/11
1. Fix chassis fan2 may not detect fan speed under ProbII if low spin fan is used.
0614 - 2006/09/06
1 Support DDR2 SO DIMM
2 Support DDR2 double side X16
3 Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
4 Fix Kentsfield B0 stepping CPU can't adjust ratio issue
5 Support Conroe / Kentsfield ratio overclocking higher than default (multi max 6- 11 (x-6800) -13
6 Fix CPU Fan Profile mode not correct after system shutdown
^Inhalt
ram
Kompatibler Speicher
kein Anspruch auf Vollständigkeit
sämtliche Micron D9: D9GMH und mit D9GKX
AENEON PC2-5300U-555-12 (DDR2-667) (AET760UD00-30DA98Z)
A-DATA Vitesta Extreme Edition DDR2-800+MHz PC2-6400 Dual Channel Kit CL4-4-4-15 2x1024MB
Corsair XMS2 PC2-5300U CL4-4-4-12 (DDR2-667) (TWIN2X1024-5400C4)
Corsair XMS2 PC2-6400U CL5-5-5-12 (DDR2-800) (TWIN2X1024-6400)
Corsair XMS2 PC2-6400U CL3-4-3-9 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400U CL4-4-4-12 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400PRO CL4-4-4-12 (DDR2-800) (TWIN CM2X1024-6400C4PRO)
Corsair XMS2 PC2-8500U CL5-5-5-15 (DDR2-1066) (TWIN2X2048-8500C5)
Corsair XMS2 Dominator Series PC2-8500U CL5-5-5-15-2T (DDR2-1066) (TWIN2X2048-8500C5D)
Corsair XMS2 Dominator Series PC2-8888U CL4-4-4-12-2T (DDR2-1111) (TWIN2X2048-8888C4DF)
Crucial Ballistix PC2-6400U CL4-4-4-12 (DDR2-800) (BL2KIT12864AA804)
Crucial Ballistix PC2-5300 3-3-3-12 D9GMH
Crucial Value CL5 D9GMH + D9GKX
GSkill GBHZ old D9GMH
G.Skill PC2-4200U CL4 (DDR2-533) (F2-4200PHU2-2GBNT)
G.Skill PC2-5300U CL5 (DDR2-667) (F2-5400PHU2-2GBNS)
G.Skill 2GB F2-6400PHU2-2GBNS ab 0614 Bios
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNR)
G.Skill PC2-8000U CL4-4-4-5 (DDR2-1000) (F2-8000PHU2-2GBHZ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-1GBNQ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNQ)
^Inhalt
G.e.i.L PC2-6400 CL4-4-4-12 (PC800) (GX21GB6400UDC)
Kingston DDR2-RAM 2x512MB 533MHz KVR533D2N4/512
Kingston DDR2-RAM 2x1024MB 533MHz KVR533D2N4K2/2G
Kingston HyperX DIMM 1 GB DDR2-750, KHX6000D2/1G ( max 850 mhz)
MDT PC2-6400U CL5 (DDR2-800) (M1GB-800K)
Mushkin EM2-5300 2048MB PC2-5300U CL5 (DDR2-667) (991382)
Mushkin EM2 PC6400 2048MB DualKit
Cellshock DDR2-800 CL4 (CS2221041)
OCZ OCZ2P10002G-K (OCZ Platinum Enhanced Latency XTC)
OCZ2N9001GEB
OCZ28001024EBDCPE- (OCZ Platinum DIMM Kit 1024MB PC2-6400U CL4-3-3-8)
OCZ2N11001G
Hynix HYMP564U64BP8-S5 (512MB 5-5-5)
Hynix HYMP512U64BP8-S5 (1GB 5-5-5)
Hynix HYMP564U64AP8-S6
Hynix HYMP512U64AP8-S6
Golden Emp. 8HTF6464AY-80EA3
Golden Emp. 16HTF12864AY-80EA3
Golden Emp. 8HTF6464AY-80ED4
Golden Emp. 16HTF12864AY-80ED4
Transcend TS64MLQ64V8J (Transcend DIMM 512MB PC2-6400U CL5)
TwinMos ??? M2Y51264TU88A2B-25
NANYA NT512T64U88B0BY-25
NANYA NT1GT64U8HB0BY-25C
^Inhalt
eigEigenarten
botBoot-Bug/An-Aus-Bug
Wie äußert sich dieser Bug?
Wird der PC nach dem Herunterfahren komplett vom Strom getrennt, zum Beispiel in dem man das NT danach abschaltet, wird das Board beim nächsten Systemstart zuerst einmal starten, dann wieder ausgehen um dann normal zu booten, was nicht gerade lebensdauerförderlich für die angeschlossenen Festplatten ist.
Kann man dieses Verhalten umgehen?
Den "Boot Bug" nach Netztrennung kann man auf verschiedene Weisen umgehen: Den Rechner herunterfahren und Netzschalter des NT auf AN lassen, sodaß das Board weiterhin mitStandBy-Strom versorgt wird, dann bootet der Rechner beim nächsten Start normal oder mittels Master / Slave Leiste. Der Verbrauch hierbei schwankt zwischen 2 und 20 Watt - je nach angehängten Verbrauchern. Achtung: auch die verwendete Leiste kann den Verbrauch beeinflussen. Mit einer alten Lidl-Leiste lag der Verbrauch bei 3 Watt und mit einer viel aktuelleren Aldi-Leiste zeigte der Verbrauchsmesser bei gleicher Konfig fast 18Watt. Sofern ich mich nicht verrechnet habe, hier ein Rechenbeispiel: 14 Std. täglich "Standby" (also PC heruntergefahren an der Leiste) mit 20Watt bei 0,18€ pro kw/h ergeben ~ 19€ für ein Jahr. Ist Umweltpolitisch nicht ganz korrekt, aber mir den 1,50€ im Monat wert ;)
Strap-Verhalten [Umschalten der internen Timings][/B]von Sven Bode
Hier gehts weiter>>
messMesspunkte
vCore
vFSB
^Inhalt
BiosBIOS
bif0Bios-Flashen *BETA*
Vor dem Flashen das System auf Standardtakt zurücksetzen.
Es gibt 3 verschiedene Methoden:
EZ-Flash
1. Neues Bios von Asus herunterladen und entpacken
2. Bios-Datei auf Diskette oder USB-Stick speichern
3. Neustarten
4. Entweder beim POST ALT+F2 drücken, oder EZ-Flash im Bios unter Tools/Werkzeuge auswählen
5. Laufwerk auswählen mit TAB, dann ENTER zum Flashen
6. Der Rechner startet nach Abschluss des Flashvorgangs neu​
Afudos
2. Am besten direkt in P5B.rom umbenennen
3. entsprechendes Afudos-Programm von Asus herunterladen
4. Bootbare Diskette erstellen
5. afudos.exe und P5B.rom auf die Diskette kopieren
6. Rechner mit der Diskette im Laufwerk neustarten
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom
9. ENTER Der Flashvorgang beginnt. Den weiteren Anweisungen folgen​
Unter Windows mit ASUSUpdate[Erhöhtes Risiko]
2. ASUSUpdate von Asus herunterladen
3. ASUSUpdate installieren
4. ASUSUpdate starten und dem folgenden Dialog folgen
5. Rechner neustarten​
Nun wieder alles so einstellen, wie gewohnt.
Das Flashen war erfolgreich und ihr habt euer BIOS auf die den Letzten Stand aktualisieren.
bif1Flashen älterer Versionen
1. Bios von Asus herunterladen
3. Afudos v2.07 von hier herunterladen
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom /n /pbnc
bif1Totes Bios wiederbeleben
Bei Ami-BIOS braucht man eine Diskette, bei dem das BIOS-Image als "amiboot.rom" im Rootverzeichnis liegt. Die legt man ein, schaltet den Rechner ein und hält eine magische Tastenkombination (üblicherweise Ctrl + Home, deutsch Strg + Pos1) gedrückt. Das System sollte dann beepen, auf die Disk zugreifen und das BIOS flashen (der Bildschirm bleibt dabei aber dunkel - Flash-Ende wird durch einen oder mehrere Beeps angezeigt).
Weitere Verarbeitung folgt, bei Fehlern PM an mich.
bif2PECI-Interface
***In Arbeit***​
bif3Static Read Control
***In Arbeit***​
trsTreiber/Software
Aktuelle Treiber gibt es auf
support.asus.com
  • chipAktuelle Chipsatztreiber bei Intel
    >>Link<<
  • soundSoundtreiber
  • ahciAHCI-Einbindung
    AHCI-Einbindung bei der Neu-Installation von Win XP (für alle, die das auch wissen wollten).
    Vorbereitung (Treiberdiskette erstellen)
    1. Datei iata62_cd.exe von der Intel-Webseite runterladen
    2. Datei in d:\temp\ kopieren (Beispiel)
    3. Start>Ausführen> "d:\temp\iata62_cd.exe -a -a"
    4. Den Lizenzvereinbarungen zustimmen.
    Anmerkung zu 3. und 4.: Keine Angst, es wird nichts installiert, auch wenns so aussieht.
    5. Die Dateien aus dem Verzeichnis c:\programme\intel\Intel Matrix Storage Manager\Driver (...\Driver64 bei der
    64bit edition) auf eine Diskette speichern (direkt nach a:\ )
    Win-XP-Installation
    1. Nach dem Neustart ins Bios gehen
    2. Main > IDE Configuration > SATA Configuration [Enhanced]
    3. Configure SATA as: [IDE/RAID/AHCI]
    4. AHCI auswählen
    5. Bootreihenfolge: CD oder DVD-Laufwerk muss an erster Stelle stehen
    6. F10 und Neustart (vorher noch Win XP Installations-CD einlegen )
    7. Irgendwann gleich zu Beginn wird man aufgefordert, F6 zu drücken -> F6 drücken
    Anmerkung zu 7.: Bei mir ist dann nicht gleich was passiert, hab F6 noch paarmal weitergedrückt, ist nix
    "Schlimmes" passiert
    8. Irgendwann stellt Windows fest, dass es gar keine Festplatte gibt, aber man kann, wenn man möchte, einen
    externen Treiber einbinden (JA!)
    9. Diskette rein, Windows-Installation lädt die nötigen Dateien ohne zu mucken von der Diskette
    10. Dann wird festgestellt, dass 3 Treiber zur Verfügung stehen (RAID, AHCI, SCSI) - AHCI wählen
    11. Danach alles wie gehabt - bis es dann heisst: Fertig!
    Dank an pheeacs für dieses Tutorial]
^Inhalt
nbsStrap-Verhalten[Umschalten der internen Timings]
Auslöser der ganzen Problematik - verbunden mit dem Performanceeinbruch ist
hier zu finden.
Für die Praxis relevant ist der Verlauf der grünen Linie welcher sich bzgl. der Performance wie folgt äußert.
Beispiele:
Boot bis 400 (laut Kurvenverlauf Strap 1333 genannt) - hier im Forum gerne 1067er genannt - ein SuperPi 32M
Durchlauf:
bis dorthin ist die Welt noch in Ordnung (bis FSB 400) aber dann mit FSB 401:
wie kann man diese Situation umgehen - diesen Performanceabfall, hervorgerufen durch Verlangsamung der internen
Chipsatztimings, wenn man im Bios FSB 401 einstellt und somit in der "langsameren" Strap (1600 lt. Diagramm oder
im Forum 1333) landet? [Anm.: Strapverhalten wg. FSB1333-CPUs neu prüfen]
Mittels eines Tools wie
Clockgen
wenn man vorher mit einem FSB von max 400 gestartet hat. Aber dabei gilt es zu bedenken:
1. Boot mit 333-400 - wenn Boot mit weniger werdet ihr Schwierigkeiten haben die 400 zu erreichen (langsamere
Straps)
2. Genug Boardspannung einstellen - ein guter Wert für FSB 400-420 bei der Arbeit mit Clockgen sind 1,45V - 1,55V
auch möglich, mehr bitte nur mit WaKü.
Kurze Erläuterung bei der Einstellung des Tools:
1. Herunterladen (Siehe Link) oder eben hier:
http://www.computerbase.de/downloads/software/systemueberwachung/clockgen/?url=11187
2. Tool Starten und auf "PLL Setup" klicken
3. Im Clock Genarator Setup den Taktgeber CY28551 auswählen
4. Ignore GSB/PCI anklicken
5. Apply Selection
6. Dann über PLL Control den Takt erhöhen
Selbstverständlich muss man dieses nicht nach jedem Start einstellen,
Unter "Options" Punkt "Apply Current Setting at Startup" einfach aktivieren ;)
Resultat ist dann folgendes:
keine Verlangsamung mehr :d...
...und funktioniert auch mit 4GB
Dank an Sven Bode
^Inhalt
oceOC-Einstellungen
  • Gute Erklärung zu den wichtigsten Einstellungen bei XS.org
    >>Link<<
  • Overclocking-Guide bei tthetechrepository
    >>Link<<
  • Zusammenspiel von FSB, CPU und RAM (Teiler) (dank an Shaguar)
    >>Link<<
oclOC-Liste
oclhwmHardware-Mods
Hier Pics zum VDroop Mod
Anklicken der Bilder führt zur großen Version]
noch ein Link dazu: http://www.xtremesystems.org/forums/showpost.php?p=2007217&postcount=30
Ein Bleistift ist ausreichend dafür ;)
[Modifikationen auf eigene Gefahr und unter Verlust der Garantie]
^Inhalt
raz
Passendes Zubehör
  • Speicherkühler
    • OCZ - XTC Memory Cooler
    • Corsair Airflow RAM-Kühler
Unterschiede P5B --- P5B deluxe (WiFi):
Die Unterschiede werden in dieser Liste von Asus sehr gut dargestellt:
http://event.asus.com/2006/mb/P5B/models.html
Darüber hinaus gibt es Unterschiede in den Bios-Einstellungen, die dazu führen, dass das P5B keine so guten OC
Eigenschaften wie das P5B Deluxe (WiFi) besitzt. (Dies wird hoffentlich durch ein Bios-Update gelöst)
vDimm 1,8-2,1 / vCore 1,2125 - 1,7 (P5B)
vDimm 1,8-2,45 / vCore 1,1 - 1,7 (P5B Deluxe)
Einmal kann man die Speicher-Riegel beim P5B Deluxe mit mehr Spannung versorgen, was dazu führt, dass man sie bei
höherer Taktung stabil laufen lassen kann.
Zum anderen kann die Spannung der CPU beim P5B deluxe deutlich niedriger gesetzt werden als beim P5B
(non-deluxe). Im Fall eines Allendale hat dies z.B. den Vorteil, dass man ihn mit dem Standard-Takt auf 1,1V
laufen lassen kann, während man beim non-deluxe erst bei 1,2125V anfangen kann und somit Potenzial verschenkt
(Strom / Temperatur).
amnAnmerkungen zum Thread
allAllgemeines
Eure Mitarbeit ist natürlich erwünscht!​
chaChangelog
26.03.10 V1.00: Die jeweils letzten BIOS-Versionen nachgetragen
28.07.07 V0.41: BIOS-Flash-Guide hinzugefügt
20.07.07 V0.35: Noch mehr Infos eingefügt
20.07.07 V0.30: Weitere Infos eingefügt
19.07.07 V0.11: Geordnet, Bios-Changelogs aktualisiert
19.07.07 V0.10: Erster Release: Vorläufige Gliederung eingefügt​
danDanksagungen
  • Seppelchen dafür, mich zu überreden, den Thread zu übernehmen und Infos
  • Sven Bode für das Versorgen mit Infos
  • pheeacs für das AHCI-Tutorial
  • Berlinrider
  • Antivirus für das Erstellen des ersten Sammelthreads
  • Und die vielen anderen, die hier aktiv sind
^Inhalt
Ja auf einem Gigabyte EP-45 EXTREME hat er die CPU mit 500 betrieben ;)
ziemlich schlecht für ein P45 "extreme".
bin ich froh ein P5B zu haben.
ziemlich miserable fotografische fälschung :d
also ich warte jetzt erstmal auf den neuen ram und gucke dann mal was so geht...
Tja du bist halt einer von den wenigen hier, die einen Quadcore auf verschiedenen Brettern hatte und jeweils den Fax FSB getestet hat und zudem noch den Thread ab und an besucht ;)
den FSB schön geschmeidig bei FSB 400 lassen - und den RAM auf 1000 - das ist das Optimum für das Brett. Alles andere ist Unsinn - und der Stress lohnt einfach nicht - es wird ja noch nicht einmal wirklich schneller.
Was aber nicht bedeuten soll dass das P5B Deluxe ein schlechtes Brett ist - ganz im Gegenteil. Es ist über die Zeit gesehen eines der besten Boards für den Sockel.
Ich kenne nur 1.03g und 1.04g. Gabs mal 1.01 und 1.02??
Ich habe jetzt einen E6500K bekommen und den gestern eingebaut.
Der läuft standardmässig mit 11er Multiplikator und 2,93 GHZ.
Als ersten Versuch habe ich einfach den Multiplikator auf 13 gesetzt und er bootet mit 3,4 GHZ. Habe danach den PC ca. 2 Stunden genutzt und die CPU hat eine Temperatur von max. 48°C erreicht.
Allerdings wollte irgendwann weder XP noch Win7 mehr booten. Ich bekam nen BSOD beim Booten mit DRIVER IRQL NOT LESS OR EQUAL also denke ich, dass der Speicher Probleme macht (4x1 GB 800 MHZ OCZ sind eingebaut). Sollte ich irgendwelche Temperaturen anhaben, damit die Kiste stabil läuft?
Ausserdem ist mein Arctic Cooling Freezer 7 (Heatpipe) viel zu laut bei über 2000 Umdrehungen. Kann mir jemand einen besseren und leiseren Kühler empfehlen? Die Scythe sollen sehr gut seinen, welchen sollte man nehmen?
rev 1.04g hat doch einen c2 chipsatz, keine ahnung was da anders dran ist, aber muss ja irgendwas verändert worden sein, nicht wahr?
ich weiß gar nicht wie lang ich mein board jetzt schon hab, aber ich behalte das noch so lang es geht. wüsste eigentlich auch gar nicht was passieren muss, damit ich ein anderes kaufe. Fehlt ja eigentlich an nichts.
warum hast du deins nicht mehr? war deins nicht gut?
sucht nach was anderem ja... aber beim board ist es bei mir was anderes. da bin ich froh wenn alles läuft, wenn die kühler sitzen, wenn ich nicht mehr rumbasteln muss.
aber seitdem damals bekannt wurde das die c2q auf dem board laufen, war mir klar das ich es nicht weggeben brauche.
und für pci-e 2 oder usb 3 oder was auch immer, wechsle ich nicht.
genauso wie mit win xp.. wechsel ich auch nicht. bei vista haben auch alle gesagt oh schnell wechseln, das ist so gut usw, und hinterher alle in die scheiße getreten... jetzt win 7 als wiedergutmachung, aber ohne mich. nicht mal geschenkt!
läuft ja auch alles unter xp.
brauch nur noch ne neue grafikkarte bald.
Tag zusammen!
Bin neu hier im Board! Da ich denke, dass hier die richtigen Experten zu dem Thema sitzen, würde ich mich freuen, wenn ihr mir helfen könntet :-)
Folgendes zu meiner Situation:
Ich habe ein CPU-Upgrade durchgeführt, bis gestern hatte ich einen E6600 auf meinem P5B Deluxe WiFi, jetzt einen Q9550 (E0-Stepping). Nachdem ich einige Zeit brauchte um rauszufinden, warum der Rechner nicht richtig starten wollte (musste öfters mal die Batterie rausholen um wieder ins BIOS zu kommen :-( --> Speicherspannung wurde erhöht, danach ging es), ging es zwar, nur Windows (XP, Vista und 7) macht mir Probleme.
Ist langsam (XP braucht gefühlte 10 Minuten bis ich es benutzen konnte), Vista und 7 verabschieden sich spätestens nach ein paar Minuten (mit Bluescreen). Hat da jemand ähnliche Erfahrungen woran es liegen könnte? Könnte es sein, dass ich die Betriebssysteme neu installieren muss oder liegt dass eventuell an einer falschen BIOS-Konfiguration? Programme stürzen nach einer kurzen Zeit ab (habe mal testweise RaceDriver Grid und GTA IV getestet, so nach ca. 2-3 Minuten Absturz, Firefox ließ sich auch nur für 1 Minute öffnen, der IE etwas länger, aber auch mit Absturz).
Treiber für den Prozessor wurden zumindest unter XP automatisch installiert.
Da ich gerade in der Arbeit bin, versuche ich mal die BIOS-Einstellungen aus dem Kopf zu zitieren.
BIOS-Ver.: 1238
CPU-Freq.: 333 MHz
RAM auf 833 MHz (eventuell die Fehlerquelle? RAM ist eigentlich für 800 / 900 MHz ausgelegt, siehe weiter unten)
VCore-Spannung: 1,25V
RAM-Spannung: 1,9 (drunter gings nicht, Rechner hat nicht gebootet; eventuell ist sie sogar zu niedrig und ist der Grund für den Absturz, nur leider hab ich den genauen Namen des Speichers nicht im Kopf und kann nicht nachgucken, ob er mit mehr Spannung noch sicher läuft ohne zu schmoren)
Spread Spectrum disabled
Rest auf Standard (soweit ich es noch im Kopf habe)
SpeedStep und C1E disabled
Hardware-Infos:
CPU: Q9550
RAM: 2*OCZ 800 MHz + 2*OCZ 900 MHz (läuft auch auf 800), Details kommen nach, sobald ich zuhause bin und nachgeguckt habe
Board: P5B Deluxe WiFi
Kühler: Zalman CNPS 9700
NT: Xilence 600W
GK: Geforce 8800 GTS 512
EDIT: Achso, um eines schonmal zu sagen: CPU-Temp so bis maximal 39°C, mit CoreTemp unter den div. BS nachgeguckt, bei einer CPU-Auslastung von bis zu max. 5%.
Ich wäre auch sehr dankbar für Vermutungen, würde mir auch weiterhelfen ;-)
Was denkt ihr woran es liegen könnte? Bzw. hat jemand ähnliche Probleme gehabt unter einem der Betriebssysteme?
wieso zum geier startet mein pc nicht bei 4 x 2 GB DDR1000 ?!
wozu hab ich denn 4 speicherbänke?
habe ich etwas falsch eingestellt?
jemand ne ahnung?
jemand ne ahnung?
kommste ins bios rein?was für Einstellungen für den Ram sind dort vorhanden? versuch es erstmal mit der Einstellung als 800er.
nee ich komm nicht ins bios.
ich habe die rams von corsair. Die ersten beiden riegel laufen ja, jetzt aber 4 stück nicht. habe einfach nur 2 der gleichen dazugesteckt.
DDR800 probier ich gar nicht erst da ich ja DDR1000 will.
Und wie gesagt ich rede von 4 ! riegeln, 4 mal 2 GB, also 8 GB insgesamt, nicht 4.
habe gerade die nb spannung auf 1.55v gesetzt, hat aber auch nix gebracht. Ram mehr vcore bringt auch nix...
mein system läuft auf FSB400 mit dem quad.
und die du dazu gesteckt hast, laufen die auch einwandfrei ohne die anderen beiden? was für Ram Spannung haste eingestellt? kann mir vorstellen, das es bei z.b. 4x2,1V zu sehr in die Knie geht. ich habe die LV Version der 1066 OCZ Blade. Einwandfrei
soll ich die vcore auf 2.25v stellen bei vollbestückung?
wiviel volt brauchst du für deine? du hast auch 8 gb, oder 4 ???
ob die andern beiden alleine laufen teste ich gleich...
habe 4 GB drin. wollte vorher es mit 2x2 GB Gskill 1000er probieren, Teiler dafür war ja vorhanden. aber keine chance. lief absolut nicht. die 1066 laufen super bei 1,8 Volt und standard timings. da ist aber noch potential drin....
probier erstmal die einzelne rams aus, bevor du spannung erhöhst. Mit was isr corsair angegeben, 2,1Volt?
Edit: hatte vorher 4x 1 GByte mit 2,2 Volt am laufen. also vollbestückung funktioniert eigentlich
ja 2.1v und das bekommen sie auch.
4GB kannst du mit 8 GB nicht vergleichen, dann werden die ocz bei mir auch nicht laufen. Das ist ein tiefgründigeres problem. Da spielt die nb auch mit rein.
scheint als ginge das nicht mit ddr1000.
ja, die nb Spannung mußte ich auch anheben, da sonst bei der Übertaktung die Grafikkarte auf x1 anstatt x16 ging. Aber werde das board sowieso bald wechseln, da es doch möglich sein muss über 400er FSB zu kommen bei dem Quad:-) MIr schwebt da der Maximus II Formula im Sinn. mal schauen
zugegeben, das P5B hat nun auch langsam sein alter erreicht:-) und der 965 Chipsatz sowieso
solang die leistung top ist, gibt es keinen sinnvollen grund zum wechseln.
und ob du nun 3,6ghz hast oder 4,x... merkste eh nix von. aber kannst ja wechseln wie du magst :p
Ich schaffe mit FSB400 auch nicht DDR2 1000, obwohl ich nur 2 Riegel drin habe. Am Speicher liegt es auf keinen Fall, denn bei einen kleineren FSB schafft der Speicher 600mhz. Hab auch schon alles versucht, der Rechner startet nicht mal.
Daher hab ich jetzt 1:1 die DDR2 800 eingestellt und halt die Timings auf 4-4-4-10 runtergedreht.
ich bekomme mit 4 gb auch ddr1000 hin, und das bei fsb400 und teiler 4:5.
es geht af jeden fall! aber ich hatte auch schon ram gehabt von ocz bei dem es nicht ging, also es liegt teilweise doch schon am ram.
aber ist auch egal, ich bekomm die 8gb ja nicht zum laufen, daher warte ich jetzt bis es die ersten 8gb kits mit ddr1066 gibt, also 2 x 4GB DDR1066. momentan gibts nur ddr800... das ist ja doof. wennschon dann will ich da was geht...
du brauchst dich auch nicht geschlagen geben mit ddr800. mach mal auf spd und guck obs dann geht. man kann da schon ein bischen was tricksen.
Laufen ja übers SPD, da sind ja auch die 4er Timings für DDR800 hinterlegt. Hab mir auch mal bei OCZ ein neues SPD geladen und geflasht, hat sich aber nix geändert. Wie gesagt bei nen niederigen FSB 3xx hab ich es schon mit DDR1200 ins Bios geschafft. Aber mit FSB400 hab ich keine Chance, komme nicht mal ins Bios. Hab schon alles versucht incl. max. Spannungen beim Board und 2,25V beim Speicher. Ich habs schon lange aufgegeben. Schade, aber kann man nicht ändern.
und womit kühlst du?
Funktionieren muss es grundsätzlich aber. Vielleicht mag der ram keinen hohen fsb, dann müsstest du anderen probieren wenn es dir das wert ist.
