[Sammelthread] Asus P5B / P5B Deluxe /-WiFi–AP (Intel P965) [7]
Aktuell
Die komplette P5B-Reihe ist 45nm CPU ready : XS.org
1hoch
Inhalt
uber
Überblick
Sockel: LGA775
Unterstützte CPUs_
Intel® LGA775 Platform
Intel® Penryn Ready
Intel® Quad-core CPU Ready
Intel® Core™2 Extreme / Core™2 Duo Ready
Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
Unterstützte FSBs_ 1066/800/ 533 MHz
Chipsatz_ P965 Express
1 PCIe x16 PEG Link
Sehr gut übertaktbar, FSBs über 500MHz keine Seltenheit [P5B Deluxe]
[Ich brauch noch mehr Allgemeines]
p5b
P5B
  • Storage
    • 4x SATA 3Gb/s [ICH8]
    • 1x IDE über JMicron
    • 1x eSATA über JMicron
    • 1x SATA über JMicron
  • RTL8111B PCI-E Gb LAN
  • 8-channel HD Audio
  • AI NOS™ / AI Gear / AI Nap
^Inhalt
clbBios-Changelog fürs P5B
2104 - 2009/05/27
Support new CPUs. Please refer to our website: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
1604 - 2007/07/13
1. Enhance memory compatibility under FSB1333 mode
1501 - 2007/07/05
1. Add new CPU uCode to support new processor
1405 - 2007/06/13
1. Update CPU ucode to support new processor
2. Revise SLP 2.0 rule
3. Enable hotplug support under AHCI mode
4. Fix displayed CPU frequency incorrectly after downgrade CPU ratio
1202 2007/04/04
1. Fix system may sometimes hang after load default in setup then exiting right away while having Conroe CPU
installed.
2. Add new uCode to support new CPU.
1102 - 2007/01/31
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
1. Finetune Q-Fan control algorithm
2. Enable EIST under VISTA
3. Update CPU Ucode to support new CPU
4. Fix BBS device string not correct under AHCI mode
5. Support SLP2.0 string
6. Fix HCT unreported I/O and memory issuse
7. Support disable USB function item
8. Allow disable XD for conroe L
9. Add full reset after change DRAM mode to enhance memory compatibility
10. Support CONROE E0 CPU(FSB 1333)
11. Fix AC Power loss function not correct
12. Support x4 DIMM
0806 - 2006/11/
1. Enable support for WiFi-TV card
2. Enable PreslerXE 3.73 support
3. Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI
mode
4. Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
5. Enhance ATA ODD compatibility
6. Support Conroe-L CPU
7. Fix CPU VCORE too high after overclocking fail
0701 - 2006/10/5
2. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
3. Reduce system full reset of times
4. Patch some VGA card can't found when NB Vcore value has been set too high
5. Fix DDR frequency 889 unstable by SPD
6. Add new CPU Ucode to support Kentsfield B3 stepping CPU
7. Improve S3 resume time
8. Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
9. Fix chassis fan 2 speed not correct when fan speed too low.
^Inhalt
p5bp
P5B-Plus
  • Intel LGA775 Platform
  • Intel® Quad-core CPU Ready
  • Intel® Core™2 Extreme / Core™2 Duo Ready
  • Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
  • 1066/800/ 533 MHz
  • Dual-channel DDR2 800/667/533
  • 1x PCI Express x16
  • Storage
    • 6x SATA 3Gb/s [ICH8R]
  • PCI-E Gigabit LAN controller
  • AI NOS™ / AI Gear / AI Nap/ TPM Support
  • All High-quality Conductive Polymer Capacitors
^Inhalt
clpBios-Changelog fürs P5B Pus
0638 - 2008/10/29
Enhance the compatibility with certain memory.
0604 - 2007/06/13
1. Fixed PCProbe II fail to install problem
2. Add new uCode to support new processors
3. Enable SATA Hotplug support under AHCI mode
^Inhalt
p5bd
P5B Deluxe
  • Crossfire-Freigabe, 2te Karte über elektrischen PCIe-x4-Slot über die Southbridge angebunden [ca. 20% Leistungsverlust]
  • Storage
  • Dual Gigabit LAN controllers, Marvell® PCI-E and PCI Gigabit LAN controllers
  • 8 Phase Power Design
  • Fanless Design - Heat Pipe & Stack Cool 2
  • Array Mic / Noise Filter
    WiFi-AP: WiFi-AP Solo
^Inhalt
cldBios-Changelog fürs P5B Deluxe
Download --> http://amd.co.at/anti/asus/
1238 - 2009/02/11
Fix system hangs at POST while using certain 4GB memory and CPUs.
1215 - 2007/07/13
1212 - 2007/07/09
1. Add new CPU uCode to support new processors
3. Enable support for SATA hot plug function under AHCI mode
4. Fix after downgrade CPU ratio, the Conroe L frequency not correct under ASUSCPU
1101 - 2007/04/04
1 Add new uCode to support new CPU.
2 Fix system won''t complete POST with GV-MVP/RZ2(TV tuner) connected and power on before motherboard.
1004 - 2007.01.30
**This BIOS does not support roll back to older BIOS**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
0910 - 2006.01.16
1. Update Jmicron option ROM to 1.06.59
2. Fix AC Power loss function not correct
3. Support x4 DIMM
4. Moidfy Write to Precharge Delay default from 10 to 11
5. Enable support for EIST under VISTA
6. Finetune Q-Fan rule
7. Support SLP 2.0
8. Fix BBS device string not correct under AHCI mode
9. Enable Disable USB capability
10.Support ASUS WIFI-TV card
11.Revise CPU temperature calculation algorithm for PECI
0910 - 2006/12/27
no changelog avaible..
0908 - 2006/12
0903 - 2006/11/
0804 - 2006/10/25
1. Support conroe L processor
2. Update JMicron option rom 1.06.22
3. Modify CPU fan low limit speed from 800 RPM to 600 RPM
4. Implement ASUS CGI performance with ATI 1950 graphic cards
0801 - 2006/10/11
we havent changelog ...
0711 - 2006/10/04
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
0706 - 2006/09/20
1. Enhance CrossFire performance.
2. Enable NVIDIA 7950GX2 display under crashfree mode
3. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
4. Fix memory display message not correct under multi-language (dank an Norstern)
5. Add Kentsfield B3 uCode
0701 BETA - 2006/09/11
1. Fix chassis fan2 may not detect fan speed under ProbII if low spin fan is used.
0614 - 2006/09/06
1 Support DDR2 SO DIMM
2 Support DDR2 double side X16
3 Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
4 Fix Kentsfield B0 stepping CPU can't adjust ratio issue
5 Support Conroe / Kentsfield ratio overclocking higher than default (multi max 6- 11 (x-6800) -13
6 Fix CPU Fan Profile mode not correct after system shutdown
^Inhalt
ram
Kompatibler Speicher
kein Anspruch auf Vollständigkeit
sämtliche Micron D9: D9GMH und mit D9GKX
AENEON PC2-5300U-555-12 (DDR2-667) (AET760UD00-30DA98Z)
A-DATA Vitesta Extreme Edition DDR2-800+MHz PC2-6400 Dual Channel Kit CL4-4-4-15 2x1024MB
Corsair XMS2 PC2-5300U CL4-4-4-12 (DDR2-667) (TWIN2X1024-5400C4)
Corsair XMS2 PC2-6400U CL5-5-5-12 (DDR2-800) (TWIN2X1024-6400)
Corsair XMS2 PC2-6400U CL3-4-3-9 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400U CL4-4-4-12 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400PRO CL4-4-4-12 (DDR2-800) (TWIN CM2X1024-6400C4PRO)
Corsair XMS2 PC2-8500U CL5-5-5-15 (DDR2-1066) (TWIN2X2048-8500C5)
Corsair XMS2 Dominator Series PC2-8500U CL5-5-5-15-2T (DDR2-1066) (TWIN2X2048-8500C5D)
Corsair XMS2 Dominator Series PC2-8888U CL4-4-4-12-2T (DDR2-1111) (TWIN2X2048-8888C4DF)
Crucial Ballistix PC2-6400U CL4-4-4-12 (DDR2-800) (BL2KIT12864AA804)
Crucial Ballistix PC2-5300 3-3-3-12 D9GMH
Crucial Value CL5 D9GMH + D9GKX
GSkill GBHZ old D9GMH
G.Skill PC2-4200U CL4 (DDR2-533) (F2-4200PHU2-2GBNT)
G.Skill PC2-5300U CL5 (DDR2-667) (F2-5400PHU2-2GBNS)
G.Skill 2GB F2-6400PHU2-2GBNS ab 0614 Bios
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNR)
G.Skill PC2-8000U CL4-4-4-5 (DDR2-1000) (F2-8000PHU2-2GBHZ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-1GBNQ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNQ)
^Inhalt
G.e.i.L PC2-6400 CL4-4-4-12 (PC800) (GX21GB6400UDC)
Kingston DDR2-RAM 2x512MB 533MHz KVR533D2N4/512
Kingston DDR2-RAM 2x1024MB 533MHz KVR533D2N4K2/2G
Kingston HyperX DIMM 1 GB DDR2-750, KHX6000D2/1G ( max 850 mhz)
MDT PC2-6400U CL5 (DDR2-800) (M1GB-800K)
Mushkin EM2-5300 2048MB PC2-5300U CL5 (DDR2-667) (991382)
Mushkin EM2 PC6400 2048MB DualKit
Cellshock DDR2-800 CL4 (CS2221041)
OCZ OCZ2P10002G-K (OCZ Platinum Enhanced Latency XTC)
OCZ2N9001GEB
OCZ28001024EBDCPE- (OCZ Platinum DIMM Kit 1024MB PC2-6400U CL4-3-3-8)
OCZ2N11001G
Hynix HYMP564U64BP8-S5 (512MB 5-5-5)
Hynix HYMP512U64BP8-S5 (1GB 5-5-5)
Hynix HYMP564U64AP8-S6
Hynix HYMP512U64AP8-S6
Golden Emp. 8HTF6464AY-80EA3
Golden Emp. 16HTF12864AY-80EA3
Golden Emp. 8HTF6464AY-80ED4
Golden Emp. 16HTF12864AY-80ED4
Transcend TS64MLQ64V8J (Transcend DIMM 512MB PC2-6400U CL5)
TwinMos ??? M2Y51264TU88A2B-25
NANYA NT512T64U88B0BY-25
NANYA NT1GT64U8HB0BY-25C
^Inhalt
eigEigenarten
botBoot-Bug/An-Aus-Bug
Wie äußert sich dieser Bug?
Wird der PC nach dem Herunterfahren komplett vom Strom getrennt, zum Beispiel in dem man das NT danach abschaltet, wird das Board beim nächsten Systemstart zuerst einmal starten, dann wieder ausgehen um dann normal zu booten, was nicht gerade lebensdauerförderlich für die angeschlossenen Festplatten ist.
Kann man dieses Verhalten umgehen?
Den "Boot Bug" nach Netztrennung kann man auf verschiedene Weisen umgehen: Den Rechner herunterfahren und Netzschalter des NT auf AN lassen, sodaß das Board weiterhin mitStandBy-Strom versorgt wird, dann bootet der Rechner beim nächsten Start normal oder mittels Master / Slave Leiste. Der Verbrauch hierbei schwankt zwischen 2 und 20 Watt - je nach angehängten Verbrauchern. Achtung: auch die verwendete Leiste kann den Verbrauch beeinflussen. Mit einer alten Lidl-Leiste lag der Verbrauch bei 3 Watt und mit einer viel aktuelleren Aldi-Leiste zeigte der Verbrauchsmesser bei gleicher Konfig fast 18Watt. Sofern ich mich nicht verrechnet habe, hier ein Rechenbeispiel: 14 Std. täglich "Standby" (also PC heruntergefahren an der Leiste) mit 20Watt bei 0,18€ pro kw/h ergeben ~ 19€ für ein Jahr. Ist Umweltpolitisch nicht ganz korrekt, aber mir den 1,50€ im Monat wert ;)
Strap-Verhalten [Umschalten der internen Timings][/B]von Sven Bode
Hier gehts weiter>>
messMesspunkte
vCore
vFSB
^Inhalt
BiosBIOS
bif0Bios-Flashen *BETA*
Vor dem Flashen das System auf Standardtakt zurücksetzen.
Es gibt 3 verschiedene Methoden:
EZ-Flash
1. Neues Bios von Asus herunterladen und entpacken
2. Bios-Datei auf Diskette oder USB-Stick speichern
3. Neustarten
4. Entweder beim POST ALT+F2 drücken, oder EZ-Flash im Bios unter Tools/Werkzeuge auswählen
5. Laufwerk auswählen mit TAB, dann ENTER zum Flashen
6. Der Rechner startet nach Abschluss des Flashvorgangs neu​
Afudos
2. Am besten direkt in P5B.rom umbenennen
3. entsprechendes Afudos-Programm von Asus herunterladen
4. Bootbare Diskette erstellen
5. afudos.exe und P5B.rom auf die Diskette kopieren
6. Rechner mit der Diskette im Laufwerk neustarten
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom
9. ENTER Der Flashvorgang beginnt. Den weiteren Anweisungen folgen​
Unter Windows mit ASUSUpdate[Erhöhtes Risiko]
2. ASUSUpdate von Asus herunterladen
3. ASUSUpdate installieren
4. ASUSUpdate starten und dem folgenden Dialog folgen
5. Rechner neustarten​
Nun wieder alles so einstellen, wie gewohnt.
Das Flashen war erfolgreich und ihr habt euer BIOS auf die den Letzten Stand aktualisieren.
bif1Flashen älterer Versionen
1. Bios von Asus herunterladen
3. Afudos v2.07 von hier herunterladen
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom /n /pbnc
bif1Totes Bios wiederbeleben
Bei Ami-BIOS braucht man eine Diskette, bei dem das BIOS-Image als "amiboot.rom" im Rootverzeichnis liegt. Die legt man ein, schaltet den Rechner ein und hält eine magische Tastenkombination (üblicherweise Ctrl + Home, deutsch Strg + Pos1) gedrückt. Das System sollte dann beepen, auf die Disk zugreifen und das BIOS flashen (der Bildschirm bleibt dabei aber dunkel - Flash-Ende wird durch einen oder mehrere Beeps angezeigt).
Weitere Verarbeitung folgt, bei Fehlern PM an mich.
bif2PECI-Interface
***In Arbeit***​
bif3Static Read Control
***In Arbeit***​
trsTreiber/Software
Aktuelle Treiber gibt es auf
support.asus.com
  • chipAktuelle Chipsatztreiber bei Intel
    >>Link<<
  • soundSoundtreiber
  • ahciAHCI-Einbindung
    AHCI-Einbindung bei der Neu-Installation von Win XP (für alle, die das auch wissen wollten).
    Vorbereitung (Treiberdiskette erstellen)
    1. Datei iata62_cd.exe von der Intel-Webseite runterladen
    2. Datei in d:\temp\ kopieren (Beispiel)
    3. Start>Ausführen> "d:\temp\iata62_cd.exe -a -a"
    4. Den Lizenzvereinbarungen zustimmen.
    Anmerkung zu 3. und 4.: Keine Angst, es wird nichts installiert, auch wenns so aussieht.
    5. Die Dateien aus dem Verzeichnis c:\programme\intel\Intel Matrix Storage Manager\Driver (...\Driver64 bei der
    64bit edition) auf eine Diskette speichern (direkt nach a:\ )
    Win-XP-Installation
    1. Nach dem Neustart ins Bios gehen
    2. Main > IDE Configuration > SATA Configuration [Enhanced]
    3. Configure SATA as: [IDE/RAID/AHCI]
    4. AHCI auswählen
    5. Bootreihenfolge: CD oder DVD-Laufwerk muss an erster Stelle stehen
    6. F10 und Neustart (vorher noch Win XP Installations-CD einlegen )
    7. Irgendwann gleich zu Beginn wird man aufgefordert, F6 zu drücken -> F6 drücken
    Anmerkung zu 7.: Bei mir ist dann nicht gleich was passiert, hab F6 noch paarmal weitergedrückt, ist nix
    "Schlimmes" passiert
    8. Irgendwann stellt Windows fest, dass es gar keine Festplatte gibt, aber man kann, wenn man möchte, einen
    externen Treiber einbinden (JA!)
    9. Diskette rein, Windows-Installation lädt die nötigen Dateien ohne zu mucken von der Diskette
    10. Dann wird festgestellt, dass 3 Treiber zur Verfügung stehen (RAID, AHCI, SCSI) - AHCI wählen
    11. Danach alles wie gehabt - bis es dann heisst: Fertig!
    Dank an pheeacs für dieses Tutorial]
^Inhalt
nbsStrap-Verhalten[Umschalten der internen Timings]
Auslöser der ganzen Problematik - verbunden mit dem Performanceeinbruch ist
hier zu finden.
Für die Praxis relevant ist der Verlauf der grünen Linie welcher sich bzgl. der Performance wie folgt äußert.
Beispiele:
Boot bis 400 (laut Kurvenverlauf Strap 1333 genannt) - hier im Forum gerne 1067er genannt - ein SuperPi 32M
Durchlauf:
bis dorthin ist die Welt noch in Ordnung (bis FSB 400) aber dann mit FSB 401:
wie kann man diese Situation umgehen - diesen Performanceabfall, hervorgerufen durch Verlangsamung der internen
Chipsatztimings, wenn man im Bios FSB 401 einstellt und somit in der "langsameren" Strap (1600 lt. Diagramm oder
im Forum 1333) landet? [Anm.: Strapverhalten wg. FSB1333-CPUs neu prüfen]
Mittels eines Tools wie
Clockgen
wenn man vorher mit einem FSB von max 400 gestartet hat. Aber dabei gilt es zu bedenken:
1. Boot mit 333-400 - wenn Boot mit weniger werdet ihr Schwierigkeiten haben die 400 zu erreichen (langsamere
Straps)
2. Genug Boardspannung einstellen - ein guter Wert für FSB 400-420 bei der Arbeit mit Clockgen sind 1,45V - 1,55V
auch möglich, mehr bitte nur mit WaKü.
Kurze Erläuterung bei der Einstellung des Tools:
1. Herunterladen (Siehe Link) oder eben hier:
http://www.computerbase.de/downloads/software/systemueberwachung/clockgen/?url=11187
2. Tool Starten und auf "PLL Setup" klicken
3. Im Clock Genarator Setup den Taktgeber CY28551 auswählen
4. Ignore GSB/PCI anklicken
5. Apply Selection
6. Dann über PLL Control den Takt erhöhen
Selbstverständlich muss man dieses nicht nach jedem Start einstellen,
Unter "Options" Punkt "Apply Current Setting at Startup" einfach aktivieren ;)
Resultat ist dann folgendes:
keine Verlangsamung mehr :d...
...und funktioniert auch mit 4GB
Dank an Sven Bode
^Inhalt
oceOC-Einstellungen
  • Gute Erklärung zu den wichtigsten Einstellungen bei XS.org
    >>Link<<
  • Overclocking-Guide bei tthetechrepository
    >>Link<<
  • Zusammenspiel von FSB, CPU und RAM (Teiler) (dank an Shaguar)
    >>Link<<
oclOC-Liste
oclhwmHardware-Mods
Hier Pics zum VDroop Mod
Anklicken der Bilder führt zur großen Version]
noch ein Link dazu: http://www.xtremesystems.org/forums/showpost.php?p=2007217&postcount=30
Ein Bleistift ist ausreichend dafür ;)
[Modifikationen auf eigene Gefahr und unter Verlust der Garantie]
^Inhalt
raz
Passendes Zubehör
  • Speicherkühler
    • OCZ - XTC Memory Cooler
    • Corsair Airflow RAM-Kühler
Unterschiede P5B --- P5B deluxe (WiFi):
Die Unterschiede werden in dieser Liste von Asus sehr gut dargestellt:
http://event.asus.com/2006/mb/P5B/models.html
Darüber hinaus gibt es Unterschiede in den Bios-Einstellungen, die dazu führen, dass das P5B keine so guten OC
Eigenschaften wie das P5B Deluxe (WiFi) besitzt. (Dies wird hoffentlich durch ein Bios-Update gelöst)
vDimm 1,8-2,1 / vCore 1,2125 - 1,7 (P5B)
vDimm 1,8-2,45 / vCore 1,1 - 1,7 (P5B Deluxe)
Einmal kann man die Speicher-Riegel beim P5B Deluxe mit mehr Spannung versorgen, was dazu führt, dass man sie bei
höherer Taktung stabil laufen lassen kann.
Zum anderen kann die Spannung der CPU beim P5B deluxe deutlich niedriger gesetzt werden als beim P5B
(non-deluxe). Im Fall eines Allendale hat dies z.B. den Vorteil, dass man ihn mit dem Standard-Takt auf 1,1V
laufen lassen kann, während man beim non-deluxe erst bei 1,2125V anfangen kann und somit Potenzial verschenkt
(Strom / Temperatur).
amnAnmerkungen zum Thread
allAllgemeines
Eure Mitarbeit ist natürlich erwünscht!​
chaChangelog
26.03.10 V1.00: Die jeweils letzten BIOS-Versionen nachgetragen
28.07.07 V0.41: BIOS-Flash-Guide hinzugefügt
20.07.07 V0.35: Noch mehr Infos eingefügt
20.07.07 V0.30: Weitere Infos eingefügt
19.07.07 V0.11: Geordnet, Bios-Changelogs aktualisiert
19.07.07 V0.10: Erster Release: Vorläufige Gliederung eingefügt​
danDanksagungen
  • Seppelchen dafür, mich zu überreden, den Thread zu übernehmen und Infos
  • Sven Bode für das Versorgen mit Infos
  • pheeacs für das AHCI-Tutorial
  • Berlinrider
  • Antivirus für das Erstellen des ersten Sammelthreads
  • Und die vielen anderen, die hier aktiv sind
^Inhalt
Bei mir wird alles per Luft gekühlt und Temperaturprobleme hab ich keine. Laut WebTemp hat das Board aktuell 32Grad und das bei Dauervollast der CPU und der GPU.
Naja FSB400 ist schon Optimal beim P5B, und nur um den Speicher höher zu bekommen lohnt es nicht da zu wechseln, da ja eh der FSB der limitierende Faktor ist. Mehr Leistung ist bei DDR1000 eh nicht zu erwarten... sieht halt nur schöner aus. :cool:
Tag zusammen! [...]
BIOS-Ver.: 1238
CPU-Freq.: 333 MHz
RAM auf 833 MHz (eventuell die Fehlerquelle? RAM ist eigentlich für 800 / 900 MHz ausgelegt, siehe weiter unten)
VCore-Spannung: 1,25V
RAM-Spannung: 1,9 (drunter gings nicht, Rechner hat nicht gebootet; eventuell ist sie sogar zu niedrig und ist der Grund für den Absturz, nur leider hab ich den genauen Namen des Speichers nicht im Kopf und kann nicht nachgucken, ob er mit mehr Spannung noch sicher läuft ohne zu schmoren)
Hardware-Infos:
CPU: Q9550
RAM: 2*OCZ 800 MHz + 2*OCZ 900 MHz (läuft auch auf 800), Details kommen nach, sobald ich zuhause bin und nachgeguckt habe
Ich wäre auch sehr dankbar für Vermutungen [...]
Hast Du 4*1 GB oder 4*2 GB RAM eingebaut?
VCore könnte mit 1,25V vielleicht zu niedrig eingestellt sein (VDroop Mod?). Mal mit CPU-Z gucken, was wirklich ankommt.
An Deiner Stelle würde ich mal folgendes probieren:
  • Spannung fürs RAM auf 2,00V oder 2,05V setzen
  • VCore zum Test auf AUTO stellen
Dann mal schauen ob es überhaupt im Normalbetrieb (nicht unter Volllast!) 'ne Zeit vernünftig läuft... einfach 'n bißchen im I-Net surfen, oder so. Dabei auf CoreTemp achten (wegen VCore auf AUTO) und gucken was CPU-Z als VCore angibt.
Danach, falls bis hier hin alles problemlos geklappt hat, VCore manuell einstellen (z.B.: mit 1,35V beginnen) und langsam nach unten tasten. Dabei neue VCore im Windowsbetrieb unter Volllast (z.B.: mit Prime95) testen und CoreTemp im Auge behalten (ich denke, das machst Du eh ;)).
Wenn Du glaubst irgendwann die richtige Mischung aus VCore, Stabilität und Temperatur gefunden zu haben, dann ist es spätestens an der Zeit Prime95 (natürlich auf allen Kernen) für ein paar Stunden laufen zu lassen. Falls ein Kern zwischendurch mit einem Fehler abbricht, solltest Du die VCore etwas erhöhen.
Tja... so würde ich vorsichtig vorgehen... Viel Glück!
ich weiß das es nicht viel bringt, aber es bringt schon etwas.
Auch kleinvie macht mist.
ich werd dann wohl die 4gb zurückgeben wenns ja nicht so läuft wie ich will.
Kann man nix ändern. Bleibt meine ramdisk eben bei 1GB.
Danke nochmal für den Tipp, es lag aber am RAM. Der eine braucht zum stabilen Betrieb bei 333 MHz 1,9V (max.) und der andere mindestens 2V. Guck jetzt mal nach besseren RAM :-) (Es waren übrigens 4*1 GB RAM, beide Pärchen leider unterschiedlich, das eine Pärchen vor längerer Zeit gekauft, das andere vor einem halben Jahr)
Jetzt stürzt auch nichts mehr ab, danke für die Tipps :-)
hi.
könnt ihr mir bitte was helfen? ich möchte meinen rechner wieder was aufrüsten. ich habe das p5b deluxe und derzeit nen 3 ghz pentium und ne 6600 gt grafik + 2 gb ram (pc2-4300).
mit win 7 und hd videos stößt das langsam an seine grenzen. bei meiner tv-karte ruckelt das bild....
hab mir nen Core 2 Duo E7500, 9600 gt und 2x 1 gb ram PC2-6400 rausgesucht.
ist schon was an der oberen grenze denk ich....
ich möchte nicht übertakten und zocken tu ich gar nicht.
kanns da auch weniger sein?
ich kenn mich mit den cpus überhaupt nicht aus. und umsomehr ich lese, desto mehr bin ich verwirrt... was ist denn von den core2duo vergleichbar mit nem 3ghz pentium. verleichbar sind se nicht, aber von der größe und der bezeichnung, daß ich mal ne orientierung habe...
strom sollt das ganze auch nicht übermäßig ziehen... aber das ist 2.rangig...
danke für eure hilfe...
radix3
hi.
radix3
Die CPU ist in Ordnung, bei einer CPU mit einem höheren FSB-Takt (wie z.B. 1333 MHz könnte es leichte Schwierigkeiten geben). Du solltest dir vorher das aktuellste BIOS für dein Board von der ASUS-Seite suchen und updaten. Wichtig ist, dass es während des Updates keine Unterbrechung vom Strom gibt, sonst ist das Board (in der Regel) futsch. Ein BIOS-Update sollte nicht länger als 2 Minuten dauern. RAM wird auch in Ordnung zu sein (Hauptsache PC2-6400). Bei der Grafikkarte würde ich an deiner Stelle wenn es deinen finanziellen Rahmen nicht sprengt auf eine GTS 250 oder 9800 GT setzen. Die 9600 GT soll aber auch soweit ich weiß HD-Videos (genauso) gut beschleunigen können. Die von mir vorgeschlagenen Grafikkarten bieten einfach noch eine ganze Ecke mehr Leistung.
Wenn es dein finanzieller Rahmen erlaubt, wäre ein Quad-Core-Prozessor besser, da er über mehr Leistungsreserven verfügt.
Die Taktangaben kannst du so nicht wirklich vergleichen. Selbst ein Core 2 Duo mit 2,4 GHz bietet deutlich mehr Leistung als ein 3,6 GHz schneller Pentium IV.
Schönen Gruß,
Andy
hi.
radix3
Normal sollte das ruckeln sich in grenzen halten...Ich habe Windows 7 auf meinem EEE 901 (mit ner nachgerüsteten 32gb SSD) laufen und der ist ja wohl noch ne ecke langsamer wie dein Rechner. HD geht natürlich leider nich so toll aber sonst funst alles wunderbar.
Normal müsste jeder erhältliche C2D schneller sein als dein P4.
Aber ich würde an deiner stelle nen Intel Dual-Core E5200 kaufen für 50 euro. Der verbraucht nicht so viel wie dein P4, ist schneller/min gleichgut und kostet nur 50 euro.
Bei ner neuen Graka würde ich das kleinste mögliche Modell kaufen was nen ne Hardwarebeschleunigung für H.264 usw bietet.
Die HD 3450 kann das und ist mit 25 euro ne sehr gute Wahl. Weil is auch passiv.
danke für eure antworten.
nen quad kommt gar nicht in frage.
ich werd nen c2d nehmen... mal sehen, wos drauf hinausläuft. wenn ich mir was hole, dann wirds wieder ein paar jahre halten, wie meine derzeiten bauteile. das was ersetzt wird, kommt in nem anderen wieder zum einsatz.
ich werd die tage noch was im netz recherchieren.
Jo Quad kannst auch nehmen. Bietet sich zb nen Q8200 oder Q8300 an. Geile CPUs und auch sehr günstig. Mehr würde ich aber echt nich reinschrauben. Macht einfach kein Sinn.
Sowie die Graka den passenden Hardwarebeschleuniger besitzt, hat die CPU nicht mehr wirklich was zutun. Bei HD Material hab ich ne CPU-Auslastung von unglaublichen 5-8% :d
MfG
Tobi
Vielleicht stimmt etwas mit deinem Windows nicht, wenn du eine permanente Auslastung vom Prozessor hast;) Mal mit Hijack-This und SpyBot den PC gescannt?
nene... hatte was runtergeladen, was entpackt und versucht ne größere wave zum laufen zu bringen. bin dann noch mit verschiedenen programmen hin und hergesprungen..
mein win7 ist grad mal 1,5 wochen drauf und bei mir is alles clean...
war einfach zu viel für meine ältere cpu...
Hallo, ich brauche mal dringend hilfe.
Mein Rechner hat arge probleme zu starten wenn er kalt ist. Also am Morgen nachdem er die nacht aus war (Allerdings nuicht vom strom getrennt wegen kalt start bug).
Ich starte unds es kommt kein bild, drücke reset es kommt ein bild bleibt aber beim erkennen der usb geräte hängen also bevor er die festplatten ausliest das erste bild halt. Dann drücke ich wieder reset es kommt gar kein bild, wieder reset und er startet. Läuft dann absolut stabil.
Ich habe nen fsb von 395 ramm 1:1 4 riegel a 1 gb.
Timings 4-4-4-12
Ram spannung 2.1v - weiß aber leider net was ankommt weil cpu z mir die spannung net anzeigt, bzw gar kein tool tut das.
Ich hoffe ihr könnt mir helfen.
Danke.
Edit habe jetzt mal screens angehängt mit den bios settings die ich drin habe.
Habe jetzt mal die timings auf 5-5-5-12 eingestellt und den fsb auf 390 runter gedreht. Dann wollte ich mit clock gen den fsb auf 400 erhöhen doch nach 45 sekunden orthos stress test ist der rechner eingefrohren.
Ich denke es liegt an falschen einstellungen von den spannungen und timings habe da leider net so die ahnung von. Deshalb hoffe ich sehr auf fachmännischen rat.^^
Seit eingen Wochen wobei es schlimmer wird, vorher reichte einmal reset jetzt muss ich bis zu 5 mal reseten.
Ah, okay.
Ich hatte ziemlich von Anfang an Probleme mit dem Kaltstart (also wie bei Dir, wenn der Rechner über Nacht ausgeschaltet im Standby war). Das Bild flackerte und die USB-Geräte wurden meistens nicht erkannt. Wenn ich den Rechner zehn Minuten in diesem Zustand laufen gelassen hatte und ihn dann aus- und gleich wieder eingeschaltet habe, funktionierte alles ganz prächtig so wie es soll. Sehr nervig und nicht gerade der Brüller für die Hardware...
Ab und zu lief er aber auch sofort nach einem Kaltstart ganz normal... was mich sehr wunderte. Lange Rede, kurzer Sinn: Eines schönen Tages fand ich heraus warum hin und wieder alles ohne Murren funktionierte. Immer wenn ich einen Datenträger (CD oder DVD, selbstgebrannt oder gekauft) in den DVD-Brenner eingelegt hatte, gab es keine Probleme beim Kaltstart. Tja, seit dem liegt halt immer 'n Datenträger im Laufwerk. Klingt komisch, ist aber so.
Ich dachte, bei Dir sei das vielleicht so etwas ähnliches...
Timings 4-4-4-12
Danke.
Mein P5B hat damals auch solche Zicken gemacht. Nach 2-3 Monaten war es dann ein Stück schrott und Asus hat es nicht mal ausgetauscht.
Die meinten bei einer Unkostenbeteiligung von rund 60€ bekäme ich ein neues Brett.
Ich hab denen gesagt, dass die das Teil behalten können und ich bei mir, im Kunden- und Bekanntenkreis kein Asus mehr verbauen werde.
Nun kauf ich vermehrt Gigabyte und Asus soll mal so weitermachen.
Nun aber zurück zum Thema. Die vielen Cmos Clear Aktionen haben mir das Board geschrottet.
Ok das mit der DVD CD werde ich austesten.
Aber schaut euch bitte mal die screens an Spannungen und timings.
Da stimmt was nicht. Stelle ich fsb 400 ein bei 2.15 V im Bios für den ram bei 5-5-5-15 timings friert das bild nach spätestens 40 sekunden stress test ein.
Ist denn 2.15 v im bios eingestellt zu wenig?
Passen die Mainboard spannungen viell nicht?
Bitte schaut mal genau drauf wenn ich noch mehr angaben machen soll sagt bescheid.
Danke.
Tausch den ram mal gegen zb 2x2gb corsair xms2 ddr2 800....das war bei mir des rätsels lösung...anscheind macht das board komischerweise entweder den ram kaputt bzw das spd kaputt oder mag es irgendwann einfach nich mehr...bei mir war das auch so bis ich einfach den ram getauscht hab...probier ma mit 3 riegel bzw verschiedene...ich wette das es daran liegt.
Habe den Ram zu der Zeit gekauft wo er schweine teuer war die ersten 2gb 240€ und die 2. 2 gb für 150 € oder so ähnlich.
Würde ungern wieder neuen kaufen auch wenn er jetzt billig is.
Wie schauts mit den spannungen aus bzw. timings was sagt ihr dazu?
Ich würde mal die Riegel einzeln mit Memtest überprüfen. Denke mal das ein ein Speicherriegel defekt ist. Wichtig ist immer nur einen einbauen und dann Memtest laufen lassen.
Bei mir war es jedenfalls so, das Memtest fehlerfrei durchgelaufen ist als alle Riegel eingebaut waren und einzeln hat er mir dann bei einem tausende von Fehlern ausgespuckt. Hatte damals das Problem, das er immer mal wieder abgeschmiert oder schon beim booten hängengeblieben ist.
Also er läuft ja stabil, erst ab fsb 397 1:1 kommen abstürze. Und halt die start probleme.
Kann denn niemand was zu den timings und spannungen sagen?
Ich hab jetzt nicht geschaut wie die Spezifikationen sind, aber ich denke CL4 sollten die schon mit 2,1V schaffen. Problem kann auch die Vollbestückung sein, aber es lief ja schon ne Weile so? Ohne Probleme?
Was hast du denn noch so für Spanungen?
Versuch mal: NB 1,45V, SB 1,6V, VMem 2,1V
Auslesen der Speicherspannung ist beim P5B nicht möglich, kann man nur direkt messen. Dächte mal gelesen zu haben, das es leicht untervoltet...... so ca. 0,02 - 0,03 Volt.
Das nächste wären noch deine Subtimings. Aber die sind in der Standarteinstellung eher noch zu lasch......
Habe ja zwei screens angehängt wenn da noch was fehlt sagt bescheid dann mache ich noch mehr bios screens. Bei mir is halt zu beachten das ich nur ne recht schwache luftkühlung habe deshalb traue ich mir net zu viel rumzuprobieren, gerade was die MainBoard spannungen angeht habe ich gar kein plan.
Was meinst du mit subtimings?
Sorry, hab ich übersehen.
Stell mal zum testen noch die SB auf 1,6V und die FSBTv auf 1,4V und subtimings alle 4 von 10 auf 11. Hast Du eigentlich das neueste Bios drauf?
Keine Angst wegen den Spannungen, die sind auf jeden Fall auf Dauer vertretbar. Hatte vorher ein P5B non Deluxe und da ist die Kühlung viel schlechter. Trotzdem lief das Board übern ein Jahr mit den Spannungen ohne Probleme.
FSB392/ 397 ? was soll das? schalte den auf 400 direkt!
und dann teiler 4:5 auf ddr1000 ! und lass das spd an!
hast doch cellshock rams, die sollten doch noch die alten D9GMH chips haben und locker ddr1000 schaffen, wenn es nicht eh 1000er sind.
NB spannnung reicht mit 1,45v, evt gibste der cpu ein bischen mehr.
Weil er mit fsb 400 net läuft das mit dem teiler habe ich noch net probiert. Das problem mit SPD is das es 2 verschiedene spd´s sind. Am besten schau dir den everest screen an. der gleiche ram aber verschiedene spd´s.
Bios is glaube ich 804 drauf.
Wenn ich den Teiler auf 4:5 stelle dann entlaste ich den ram net sondern dreh ihn noch auf oder?
Ich weiß das is hammer guter ram aber er kommt mit fsb 400 net klar bzw nicht der ram sondern irgendwelche einstellungen.
sieht nach 4 mal den gleichen ram aus.
4 x http://preisvergleich.hardwareluxx.de/deutschland/a217265.html ???
Versuch es nochmal mit FSB400 und teiler 1:1 (DDR800).
Aber es kann natürlich am ram liegen. Das board sollte keine probleme machen. Wenn ich du wäre würd ich 2 riegel rausnehmen und den maximal fsb so testen.. und wenn du dann wieder die anderen beiden riegel reinsteckst und es nicht geht wäre mein fazit das ich die rams verkaufe und mir 2 x 2 GB DDR1000 für 50 euro oder so besorge.
Mag sein das der speichercontroller in der nb zu sehr belastet wird mit 4 riegeln.
meine mich dran erinnern zu können das ich auch mal das problem hatte mit 4 riegeln.
aber fsb 400 muss dein board machen. ist eigentlich ein klacks...
Die riegel sind exackt die gleichen nur 2 wurde einige monate später gekauft ddeshalb unterscheidet sich die spd einstellung man kann das irgendwie flashen das alle vier den gleichen spd haben.
400 fsb schaff ich nicht mit meinen einstellungen irgendwas stimmt da net.
Da sind halt ne menge settings im nios die ich net verstehe.
Static read control fällt mir gerade ein und viele andere ich denke es liegt an irgendeiner einstellung.
Wenn mal jemand so nett wäre und sich die alle mal anschaut, oder mir zu allen sagt was ich einstellen soll, wäre mir sehr geholfen.
Ich kann auch gern von jedem bios bild n screen machen.
