[Sammelthread] Asus P5B / P5B Deluxe /-WiFi–AP (Intel P965) [7]
Aktuell
Die komplette P5B-Reihe ist 45nm CPU ready : XS.org
1hoch
Inhalt
uber
Überblick
Sockel: LGA775
Unterstützte CPUs_
Intel® LGA775 Platform
Intel® Penryn Ready
Intel® Quad-core CPU Ready
Intel® Core™2 Extreme / Core™2 Duo Ready
Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
Unterstützte FSBs_ 1066/800/ 533 MHz
Chipsatz_ P965 Express
1 PCIe x16 PEG Link
Sehr gut übertaktbar, FSBs über 500MHz keine Seltenheit [P5B Deluxe]
[Ich brauch noch mehr Allgemeines]
p5b
P5B
  • Storage
    • 4x SATA 3Gb/s [ICH8]
    • 1x IDE über JMicron
    • 1x eSATA über JMicron
    • 1x SATA über JMicron
  • RTL8111B PCI-E Gb LAN
  • 8-channel HD Audio
  • AI NOS™ / AI Gear / AI Nap
^Inhalt
clbBios-Changelog fürs P5B
2104 - 2009/05/27
Support new CPUs. Please refer to our website: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
1604 - 2007/07/13
1. Enhance memory compatibility under FSB1333 mode
1501 - 2007/07/05
1. Add new CPU uCode to support new processor
1405 - 2007/06/13
1. Update CPU ucode to support new processor
2. Revise SLP 2.0 rule
3. Enable hotplug support under AHCI mode
4. Fix displayed CPU frequency incorrectly after downgrade CPU ratio
1202 2007/04/04
1. Fix system may sometimes hang after load default in setup then exiting right away while having Conroe CPU
installed.
2. Add new uCode to support new CPU.
1102 - 2007/01/31
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
1. Finetune Q-Fan control algorithm
2. Enable EIST under VISTA
3. Update CPU Ucode to support new CPU
4. Fix BBS device string not correct under AHCI mode
5. Support SLP2.0 string
6. Fix HCT unreported I/O and memory issuse
7. Support disable USB function item
8. Allow disable XD for conroe L
9. Add full reset after change DRAM mode to enhance memory compatibility
10. Support CONROE E0 CPU(FSB 1333)
11. Fix AC Power loss function not correct
12. Support x4 DIMM
0806 - 2006/11/
1. Enable support for WiFi-TV card
2. Enable PreslerXE 3.73 support
3. Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI
mode
4. Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
5. Enhance ATA ODD compatibility
6. Support Conroe-L CPU
7. Fix CPU VCORE too high after overclocking fail
0701 - 2006/10/5
2. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
3. Reduce system full reset of times
4. Patch some VGA card can't found when NB Vcore value has been set too high
5. Fix DDR frequency 889 unstable by SPD
6. Add new CPU Ucode to support Kentsfield B3 stepping CPU
7. Improve S3 resume time
8. Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
9. Fix chassis fan 2 speed not correct when fan speed too low.
^Inhalt
p5bp
P5B-Plus
  • Intel LGA775 Platform
  • Intel® Quad-core CPU Ready
  • Intel® Core™2 Extreme / Core™2 Duo Ready
  • Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
  • 1066/800/ 533 MHz
  • Dual-channel DDR2 800/667/533
  • 1x PCI Express x16
  • Storage
    • 6x SATA 3Gb/s [ICH8R]
  • PCI-E Gigabit LAN controller
  • AI NOS™ / AI Gear / AI Nap/ TPM Support
  • All High-quality Conductive Polymer Capacitors
^Inhalt
clpBios-Changelog fürs P5B Pus
0638 - 2008/10/29
Enhance the compatibility with certain memory.
0604 - 2007/06/13
1. Fixed PCProbe II fail to install problem
2. Add new uCode to support new processors
3. Enable SATA Hotplug support under AHCI mode
^Inhalt
p5bd
P5B Deluxe
  • Crossfire-Freigabe, 2te Karte über elektrischen PCIe-x4-Slot über die Southbridge angebunden [ca. 20% Leistungsverlust]
  • Storage
  • Dual Gigabit LAN controllers, Marvell® PCI-E and PCI Gigabit LAN controllers
  • 8 Phase Power Design
  • Fanless Design - Heat Pipe & Stack Cool 2
  • Array Mic / Noise Filter
    WiFi-AP: WiFi-AP Solo
^Inhalt
cldBios-Changelog fürs P5B Deluxe
Download --> http://amd.co.at/anti/asus/
1238 - 2009/02/11
Fix system hangs at POST while using certain 4GB memory and CPUs.
1215 - 2007/07/13
1212 - 2007/07/09
1. Add new CPU uCode to support new processors
3. Enable support for SATA hot plug function under AHCI mode
4. Fix after downgrade CPU ratio, the Conroe L frequency not correct under ASUSCPU
1101 - 2007/04/04
1 Add new uCode to support new CPU.
2 Fix system won''t complete POST with GV-MVP/RZ2(TV tuner) connected and power on before motherboard.
1004 - 2007.01.30
**This BIOS does not support roll back to older BIOS**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
0910 - 2006.01.16
1. Update Jmicron option ROM to 1.06.59
2. Fix AC Power loss function not correct
3. Support x4 DIMM
4. Moidfy Write to Precharge Delay default from 10 to 11
5. Enable support for EIST under VISTA
6. Finetune Q-Fan rule
7. Support SLP 2.0
8. Fix BBS device string not correct under AHCI mode
9. Enable Disable USB capability
10.Support ASUS WIFI-TV card
11.Revise CPU temperature calculation algorithm for PECI
0910 - 2006/12/27
no changelog avaible..
0908 - 2006/12
0903 - 2006/11/
0804 - 2006/10/25
1. Support conroe L processor
2. Update JMicron option rom 1.06.22
3. Modify CPU fan low limit speed from 800 RPM to 600 RPM
4. Implement ASUS CGI performance with ATI 1950 graphic cards
0801 - 2006/10/11
we havent changelog ...
0711 - 2006/10/04
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
0706 - 2006/09/20
1. Enhance CrossFire performance.
2. Enable NVIDIA 7950GX2 display under crashfree mode
3. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
4. Fix memory display message not correct under multi-language (dank an Norstern)
5. Add Kentsfield B3 uCode
0701 BETA - 2006/09/11
1. Fix chassis fan2 may not detect fan speed under ProbII if low spin fan is used.
0614 - 2006/09/06
1 Support DDR2 SO DIMM
2 Support DDR2 double side X16
3 Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
4 Fix Kentsfield B0 stepping CPU can't adjust ratio issue
5 Support Conroe / Kentsfield ratio overclocking higher than default (multi max 6- 11 (x-6800) -13
6 Fix CPU Fan Profile mode not correct after system shutdown
^Inhalt
ram
Kompatibler Speicher
kein Anspruch auf Vollständigkeit
sämtliche Micron D9: D9GMH und mit D9GKX
AENEON PC2-5300U-555-12 (DDR2-667) (AET760UD00-30DA98Z)
A-DATA Vitesta Extreme Edition DDR2-800+MHz PC2-6400 Dual Channel Kit CL4-4-4-15 2x1024MB
Corsair XMS2 PC2-5300U CL4-4-4-12 (DDR2-667) (TWIN2X1024-5400C4)
Corsair XMS2 PC2-6400U CL5-5-5-12 (DDR2-800) (TWIN2X1024-6400)
Corsair XMS2 PC2-6400U CL3-4-3-9 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400U CL4-4-4-12 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400PRO CL4-4-4-12 (DDR2-800) (TWIN CM2X1024-6400C4PRO)
Corsair XMS2 PC2-8500U CL5-5-5-15 (DDR2-1066) (TWIN2X2048-8500C5)
Corsair XMS2 Dominator Series PC2-8500U CL5-5-5-15-2T (DDR2-1066) (TWIN2X2048-8500C5D)
Corsair XMS2 Dominator Series PC2-8888U CL4-4-4-12-2T (DDR2-1111) (TWIN2X2048-8888C4DF)
Crucial Ballistix PC2-6400U CL4-4-4-12 (DDR2-800) (BL2KIT12864AA804)
Crucial Ballistix PC2-5300 3-3-3-12 D9GMH
Crucial Value CL5 D9GMH + D9GKX
GSkill GBHZ old D9GMH
G.Skill PC2-4200U CL4 (DDR2-533) (F2-4200PHU2-2GBNT)
G.Skill PC2-5300U CL5 (DDR2-667) (F2-5400PHU2-2GBNS)
G.Skill 2GB F2-6400PHU2-2GBNS ab 0614 Bios
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNR)
G.Skill PC2-8000U CL4-4-4-5 (DDR2-1000) (F2-8000PHU2-2GBHZ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-1GBNQ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNQ)
^Inhalt
G.e.i.L PC2-6400 CL4-4-4-12 (PC800) (GX21GB6400UDC)
Kingston DDR2-RAM 2x512MB 533MHz KVR533D2N4/512
Kingston DDR2-RAM 2x1024MB 533MHz KVR533D2N4K2/2G
Kingston HyperX DIMM 1 GB DDR2-750, KHX6000D2/1G ( max 850 mhz)
MDT PC2-6400U CL5 (DDR2-800) (M1GB-800K)
Mushkin EM2-5300 2048MB PC2-5300U CL5 (DDR2-667) (991382)
Mushkin EM2 PC6400 2048MB DualKit
Cellshock DDR2-800 CL4 (CS2221041)
OCZ OCZ2P10002G-K (OCZ Platinum Enhanced Latency XTC)
OCZ2N9001GEB
OCZ28001024EBDCPE- (OCZ Platinum DIMM Kit 1024MB PC2-6400U CL4-3-3-8)
OCZ2N11001G
Hynix HYMP564U64BP8-S5 (512MB 5-5-5)
Hynix HYMP512U64BP8-S5 (1GB 5-5-5)
Hynix HYMP564U64AP8-S6
Hynix HYMP512U64AP8-S6
Golden Emp. 8HTF6464AY-80EA3
Golden Emp. 16HTF12864AY-80EA3
Golden Emp. 8HTF6464AY-80ED4
Golden Emp. 16HTF12864AY-80ED4
Transcend TS64MLQ64V8J (Transcend DIMM 512MB PC2-6400U CL5)
TwinMos ??? M2Y51264TU88A2B-25
NANYA NT512T64U88B0BY-25
NANYA NT1GT64U8HB0BY-25C
^Inhalt
eigEigenarten
botBoot-Bug/An-Aus-Bug
Wie äußert sich dieser Bug?
Wird der PC nach dem Herunterfahren komplett vom Strom getrennt, zum Beispiel in dem man das NT danach abschaltet, wird das Board beim nächsten Systemstart zuerst einmal starten, dann wieder ausgehen um dann normal zu booten, was nicht gerade lebensdauerförderlich für die angeschlossenen Festplatten ist.
Kann man dieses Verhalten umgehen?
Den "Boot Bug" nach Netztrennung kann man auf verschiedene Weisen umgehen: Den Rechner herunterfahren und Netzschalter des NT auf AN lassen, sodaß das Board weiterhin mitStandBy-Strom versorgt wird, dann bootet der Rechner beim nächsten Start normal oder mittels Master / Slave Leiste. Der Verbrauch hierbei schwankt zwischen 2 und 20 Watt - je nach angehängten Verbrauchern. Achtung: auch die verwendete Leiste kann den Verbrauch beeinflussen. Mit einer alten Lidl-Leiste lag der Verbrauch bei 3 Watt und mit einer viel aktuelleren Aldi-Leiste zeigte der Verbrauchsmesser bei gleicher Konfig fast 18Watt. Sofern ich mich nicht verrechnet habe, hier ein Rechenbeispiel: 14 Std. täglich "Standby" (also PC heruntergefahren an der Leiste) mit 20Watt bei 0,18€ pro kw/h ergeben ~ 19€ für ein Jahr. Ist Umweltpolitisch nicht ganz korrekt, aber mir den 1,50€ im Monat wert ;)
Strap-Verhalten [Umschalten der internen Timings][/B]von Sven Bode
Hier gehts weiter>>
messMesspunkte
vCore
vFSB
^Inhalt
BiosBIOS
bif0Bios-Flashen *BETA*
Vor dem Flashen das System auf Standardtakt zurücksetzen.
Es gibt 3 verschiedene Methoden:
EZ-Flash
1. Neues Bios von Asus herunterladen und entpacken
2. Bios-Datei auf Diskette oder USB-Stick speichern
3. Neustarten
4. Entweder beim POST ALT+F2 drücken, oder EZ-Flash im Bios unter Tools/Werkzeuge auswählen
5. Laufwerk auswählen mit TAB, dann ENTER zum Flashen
6. Der Rechner startet nach Abschluss des Flashvorgangs neu​
Afudos
2. Am besten direkt in P5B.rom umbenennen
3. entsprechendes Afudos-Programm von Asus herunterladen
4. Bootbare Diskette erstellen
5. afudos.exe und P5B.rom auf die Diskette kopieren
6. Rechner mit der Diskette im Laufwerk neustarten
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom
9. ENTER Der Flashvorgang beginnt. Den weiteren Anweisungen folgen​
Unter Windows mit ASUSUpdate[Erhöhtes Risiko]
2. ASUSUpdate von Asus herunterladen
3. ASUSUpdate installieren
4. ASUSUpdate starten und dem folgenden Dialog folgen
5. Rechner neustarten​
Nun wieder alles so einstellen, wie gewohnt.
Das Flashen war erfolgreich und ihr habt euer BIOS auf die den Letzten Stand aktualisieren.
bif1Flashen älterer Versionen
1. Bios von Asus herunterladen
3. Afudos v2.07 von hier herunterladen
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom /n /pbnc
bif1Totes Bios wiederbeleben
Bei Ami-BIOS braucht man eine Diskette, bei dem das BIOS-Image als "amiboot.rom" im Rootverzeichnis liegt. Die legt man ein, schaltet den Rechner ein und hält eine magische Tastenkombination (üblicherweise Ctrl + Home, deutsch Strg + Pos1) gedrückt. Das System sollte dann beepen, auf die Disk zugreifen und das BIOS flashen (der Bildschirm bleibt dabei aber dunkel - Flash-Ende wird durch einen oder mehrere Beeps angezeigt).
Weitere Verarbeitung folgt, bei Fehlern PM an mich.
bif2PECI-Interface
***In Arbeit***​
bif3Static Read Control
***In Arbeit***​
trsTreiber/Software
Aktuelle Treiber gibt es auf
support.asus.com
  • chipAktuelle Chipsatztreiber bei Intel
    >>Link<<
  • soundSoundtreiber
  • ahciAHCI-Einbindung
    AHCI-Einbindung bei der Neu-Installation von Win XP (für alle, die das auch wissen wollten).
    Vorbereitung (Treiberdiskette erstellen)
    1. Datei iata62_cd.exe von der Intel-Webseite runterladen
    2. Datei in d:\temp\ kopieren (Beispiel)
    3. Start>Ausführen> "d:\temp\iata62_cd.exe -a -a"
    4. Den Lizenzvereinbarungen zustimmen.
    Anmerkung zu 3. und 4.: Keine Angst, es wird nichts installiert, auch wenns so aussieht.
    5. Die Dateien aus dem Verzeichnis c:\programme\intel\Intel Matrix Storage Manager\Driver (...\Driver64 bei der
    64bit edition) auf eine Diskette speichern (direkt nach a:\ )
    Win-XP-Installation
    1. Nach dem Neustart ins Bios gehen
    2. Main > IDE Configuration > SATA Configuration [Enhanced]
    3. Configure SATA as: [IDE/RAID/AHCI]
    4. AHCI auswählen
    5. Bootreihenfolge: CD oder DVD-Laufwerk muss an erster Stelle stehen
    6. F10 und Neustart (vorher noch Win XP Installations-CD einlegen )
    7. Irgendwann gleich zu Beginn wird man aufgefordert, F6 zu drücken -> F6 drücken
    Anmerkung zu 7.: Bei mir ist dann nicht gleich was passiert, hab F6 noch paarmal weitergedrückt, ist nix
    "Schlimmes" passiert
    8. Irgendwann stellt Windows fest, dass es gar keine Festplatte gibt, aber man kann, wenn man möchte, einen
    externen Treiber einbinden (JA!)
    9. Diskette rein, Windows-Installation lädt die nötigen Dateien ohne zu mucken von der Diskette
    10. Dann wird festgestellt, dass 3 Treiber zur Verfügung stehen (RAID, AHCI, SCSI) - AHCI wählen
    11. Danach alles wie gehabt - bis es dann heisst: Fertig!
    Dank an pheeacs für dieses Tutorial]
^Inhalt
nbsStrap-Verhalten[Umschalten der internen Timings]
Auslöser der ganzen Problematik - verbunden mit dem Performanceeinbruch ist
hier zu finden.
Für die Praxis relevant ist der Verlauf der grünen Linie welcher sich bzgl. der Performance wie folgt äußert.
Beispiele:
Boot bis 400 (laut Kurvenverlauf Strap 1333 genannt) - hier im Forum gerne 1067er genannt - ein SuperPi 32M
Durchlauf:
bis dorthin ist die Welt noch in Ordnung (bis FSB 400) aber dann mit FSB 401:
wie kann man diese Situation umgehen - diesen Performanceabfall, hervorgerufen durch Verlangsamung der internen
Chipsatztimings, wenn man im Bios FSB 401 einstellt und somit in der "langsameren" Strap (1600 lt. Diagramm oder
im Forum 1333) landet? [Anm.: Strapverhalten wg. FSB1333-CPUs neu prüfen]
Mittels eines Tools wie
Clockgen
wenn man vorher mit einem FSB von max 400 gestartet hat. Aber dabei gilt es zu bedenken:
1. Boot mit 333-400 - wenn Boot mit weniger werdet ihr Schwierigkeiten haben die 400 zu erreichen (langsamere
Straps)
2. Genug Boardspannung einstellen - ein guter Wert für FSB 400-420 bei der Arbeit mit Clockgen sind 1,45V - 1,55V
auch möglich, mehr bitte nur mit WaKü.
Kurze Erläuterung bei der Einstellung des Tools:
1. Herunterladen (Siehe Link) oder eben hier:
http://www.computerbase.de/downloads/software/systemueberwachung/clockgen/?url=11187
2. Tool Starten und auf "PLL Setup" klicken
3. Im Clock Genarator Setup den Taktgeber CY28551 auswählen
4. Ignore GSB/PCI anklicken
5. Apply Selection
6. Dann über PLL Control den Takt erhöhen
Selbstverständlich muss man dieses nicht nach jedem Start einstellen,
Unter "Options" Punkt "Apply Current Setting at Startup" einfach aktivieren ;)
Resultat ist dann folgendes:
keine Verlangsamung mehr :d...
...und funktioniert auch mit 4GB
Dank an Sven Bode
^Inhalt
oceOC-Einstellungen
  • Gute Erklärung zu den wichtigsten Einstellungen bei XS.org
    >>Link<<
  • Overclocking-Guide bei tthetechrepository
    >>Link<<
  • Zusammenspiel von FSB, CPU und RAM (Teiler) (dank an Shaguar)
    >>Link<<
oclOC-Liste
oclhwmHardware-Mods
Hier Pics zum VDroop Mod
Anklicken der Bilder führt zur großen Version]
noch ein Link dazu: http://www.xtremesystems.org/forums/showpost.php?p=2007217&postcount=30
Ein Bleistift ist ausreichend dafür ;)
[Modifikationen auf eigene Gefahr und unter Verlust der Garantie]
^Inhalt
raz
Passendes Zubehör
  • Speicherkühler
    • OCZ - XTC Memory Cooler
    • Corsair Airflow RAM-Kühler
Unterschiede P5B --- P5B deluxe (WiFi):
Die Unterschiede werden in dieser Liste von Asus sehr gut dargestellt:
http://event.asus.com/2006/mb/P5B/models.html
Darüber hinaus gibt es Unterschiede in den Bios-Einstellungen, die dazu führen, dass das P5B keine so guten OC
Eigenschaften wie das P5B Deluxe (WiFi) besitzt. (Dies wird hoffentlich durch ein Bios-Update gelöst)
vDimm 1,8-2,1 / vCore 1,2125 - 1,7 (P5B)
vDimm 1,8-2,45 / vCore 1,1 - 1,7 (P5B Deluxe)
Einmal kann man die Speicher-Riegel beim P5B Deluxe mit mehr Spannung versorgen, was dazu führt, dass man sie bei
höherer Taktung stabil laufen lassen kann.
Zum anderen kann die Spannung der CPU beim P5B deluxe deutlich niedriger gesetzt werden als beim P5B
(non-deluxe). Im Fall eines Allendale hat dies z.B. den Vorteil, dass man ihn mit dem Standard-Takt auf 1,1V
laufen lassen kann, während man beim non-deluxe erst bei 1,2125V anfangen kann und somit Potenzial verschenkt
(Strom / Temperatur).
amnAnmerkungen zum Thread
allAllgemeines
Eure Mitarbeit ist natürlich erwünscht!​
chaChangelog
26.03.10 V1.00: Die jeweils letzten BIOS-Versionen nachgetragen
28.07.07 V0.41: BIOS-Flash-Guide hinzugefügt
20.07.07 V0.35: Noch mehr Infos eingefügt
20.07.07 V0.30: Weitere Infos eingefügt
19.07.07 V0.11: Geordnet, Bios-Changelogs aktualisiert
19.07.07 V0.10: Erster Release: Vorläufige Gliederung eingefügt​
danDanksagungen
  • Seppelchen dafür, mich zu überreden, den Thread zu übernehmen und Infos
  • Sven Bode für das Versorgen mit Infos
  • pheeacs für das AHCI-Tutorial
  • Berlinrider
  • Antivirus für das Erstellen des ersten Sammelthreads
  • Und die vielen anderen, die hier aktiv sind
^Inhalt
cpu-z angaben und bioseinstellung für speicher
hi leute. hab mal eine ganz dumme frage, die mir seid geraumer zeit auf dem herzen liegt.
mich interessiert wie die speichertiming-angaben unter cpu-z in dem BIOS sich schimpfen?
und zwar gehts nur um die angaben TRC und Command Rate.
welche wären das denn im Bios?:confused:
(falls jemand auch eine empfehlung hat wie ich die timings einstellen soll, so nehm ich diesen rat auch gerne an.)
MfG Greekdef
Edit: oder wenns noch genauer sein soll, wie stell ich die entsprechenden angaben der Everest angaben ein? welche angaben in den progs spiegeln die angaben im BIOS wieder?
MfG Greekdef
Die Frage ist doch:
Hast du mit den jetzigen Settings Probleme?
Es ist von Board/Hersteller/Bios unterschiedlich ob und welche Timings man verändern kann.
Desweiteren werden sie manchmal "herstellerspezifisch" umbenannt und man kann nicht mehr wirklich nachvollziehen um welche Timings es da geht.
My ASUS P5B-E has the following 3 "Northbridge Chipset" options:
1) Rank Write to Read Delay - I am assuming this is what other tools call just Write to Read Delay (tWTR).
2) Read to Precharge Delay - My best guess is that this is the Read to Write Delay. Which I've seen as both RWT and tRTW. Any more enlightened input appreciated.
3) Write to Precharge Delay - My best guess is that this the Write Recovery Time (tWR)? Any other wild ass guesses appreciated.
Ich fahre mit 2GB Modulen und folgenden Timings ganz gut.
5-5-5-15-6-42-11-11-11-11
Wenn du aber Probs hast, solltest du den tRFC wert höher nehmen. 2GB Module brauchen da scho etwas entspanntere Timings als 1GB Module.
Zum Thema Command Rate:
Soweit ich weiß, ist 2T bei Intel üblich und mir sind auch nur sehr wenige Boards bekannt wo man dieses Timing überhaupt ändern könnte. Von daher keinen Kopf machen das passt schon ;)
ja gut. aus deiner antwort geht heraus, dass ich beim übertakten einfach austesten muss was geht. anscheinend gibts zu den "nicht näher definierbaren" timingseinstellungen keine konkreten beschreibungen zu.
ich glaub ich werd dann einfach die ram nicht übermäßig übertakten, sondern diese per multiplikator immer in der nähe derer vorgaben belassen. zumal schnellerer ram gewöhnlich kaum einen merkbaren perfomancegewinn bringt.
laut deinen screenshots läuft dein ram eh "nur" auf DDR2-800 ;) DDR2-1066 wirst du aber auch nicht erreichen können mit dem p5b (leider) ist aber auch nicht wirklich tragisch...nur kann man eben den fsb nicht mehr so hoch setzen wie mit 1gb modulen. die timings, welche man nicht einstellen kann müssten eigentlich automatisch optimal eingestellt sein vom bios her. den trfc wert eben im zweifel auf das maximum von 42 stellen und bei ddr2-800 kannst du die ersten 4 timings auf 5-5-5-15 stellen und dann sollte alles zufriedenstellend laufen.
also die werte aus den screenshots waren nur grobe einstellungen. hab jetzt den prozi auf
wieder auf 2,6 ghz getaktet, mit dem ram auf 1110 mhz mit den timings 5-6-6-18-6-42-11-11-11-11.
mir ist halt wichtig, dass die ram bei einem später neueren cpu, der nen höheren fsb fahren kann, auch nicht ausbremsen. deshalb kam der wechsel von den ddr2-800 zu den ddr2-1066.
Bist du dir sicher das die auf DDR2-1110 laufen?! kannst da ma nen Screenshot machen? CPU-Z zb? kann mir das nicht vorstellen :\
Du müsstest im moment folgende Einstellungen haben:
FSB : 371mhz FSB
Multi CPU : 7
Multi Ram : 1,5 (entspricht DDR2-800 bei 266mhz FSB)
Was mich wundert, dass es überhaupt läuft wenn das wirklich stimmen sollte :O
Weil dann wäre der Ram SEEEEEEEEEEEEEEHR interessant für mich!!!
Wenn du also mal nen Screen davon machen könntest, wäre das sehr nett!
Hallo Leute,
habe meinen alten Ram (800, 4-4-4-12) gegen einen 1066 5-5-5-15 getauscht. Habe einen E6300 der der auf 3150 getaktet ist , und die DRAM Feq war bis jetzt auf 450 eingestellt.
Stelle ich sie jetzt einfach auf 533 (1066) um , springt der Rechner nicht mehr an.
Mainboard : P5B Deluxe
Wo kriege ich den Ram auf 1066 eingestellt ? Es ist dieser Ram hier : 8500C5DF Corsair Dominator. Eingestellt habe ich 2.1 Volt.
Mit diesen Spannungen lief der Rechner über 1 Jahr problemlos.
Mfg
ssj3rd
hab jetzt zu den rams keine genauen timing-werte gefunden, aber ich denke wie fast alle module wollen die tRFC größer 42, was das p5b deluxe im bios nicht anbietet...
also bei mir ergab auto auch nur tRFC 42, selbst mit umgeflashtem SPD, bekommst du 45?
einzige möglichkeit ist mit memset unter windows nen höheren wert einzustellen und dann erst mit clockgen den takt erhöhen.
also mein ram läuft grad auf etwas mehr als 1066.
@ssj3rd deine ram sind ja an sich auch besser, da sie bessere timingeigenschaften haben, die sich gegenfalls nochmals entschärfen lassen falls nötig. sollte mit deinen auch klappen.
hab auch die dominator, nur halt mit den empfohlenen timings von 5-6-6-18.
meine bioseinstellungen diesbezüglich lauten
5
6
6
18
6
42
11
11
11
11
würd mich wundern wenns so bei dir nicht läuft.
Asus P5B mit Q9550 /Q9650
Hallo zusammen
Hat jemand von euch Erfahrungen mit dem Asus P5B und Intel Core 2 Quad Q9550 bzw. Q9650 gemacht?
Auf der Asus-Seite steht nämlich hinter den Bios-Versionen, die diese CPUs unterstützen sollen, dass es Betas sind.
Würde mich interessieren, ob bei jemanden tatsächlich so eine Konfig. läuft.
gruss
edit:typo
Jap, das funktioniert zumindest mit einem Q9550.
Bios Update
E6600 raus
Q9550 rein
Bios Clear
läuft.
NAtürlich funktioniert es.
Du glaubst doch nicht das Asus die verscheißern will.;)
BTW
Bei mri läuft auf dem P5B auch ein Wolfi
schön schön.
Welche Bios Version fahrt ihr?
Habt ihr den Q9550 e0 oder c1?
FSB 1333?
Und nur nochmal zur Sicherheit: Ihr nutzt dass "normale" P5B (nicht Deluxe oder so).
Danke für eure Antworten und ein schönes WE.
PS:
Könnt ihr aktuell Speicher für diese Konfig. empfehlen.
Hi Leute.
Ich brauch mal einen Rat bzw. Empfehlungen bzgl. Speicher.
Ich habe ein P5B-E (ohne Plus) - das hat im Prinzip fast das gleiche LayOut wie das normale P5B.
Hier sieht man es recht schön: Asus P5B-E P965 motherboard Review - PCSTATS.com
Auf dem Board habe ich einen VDroop MOD per Bleistift gemacht der echt gut funktioniert hat und ich habe das Board eine Zeit lang superstabil mit einem Q6700 @ 333MHz FSB und RAM 1:1 laufen gehabt.
RAMs waren 2 x 1GB Kingston HyperX DDR2-800 CL4 und 2 x 1GB Patriot DDR2-1066 CL5 RAMs die ich wie schon erwähnt auf DDR2-667 und 4-4-4-12 laufen lies. (sowie TRFC auf 42 da sonst das Board / der Chipsatz mucken machte)
Nun habe ich den Q6700 auf mein neues P45 Board gepackt und den Speicher auch da der dort weit besser läuft.
Für das P5B-E habe ich einen Pentium E6500 besorgt (2,93GHz und 266MHz FSB sowie 2MB Cache und in 45nm Fertigung hergestellt). Das Board unterstützt den Prozessor und das aktuellste BIOS (1807) ist drauf.
Speicher habe ich noch 4 x 1GB DDR2-667 CL5 Speicher aufgetrieben - den hier:
OCZ Systems Integrator OCZ2SI6671G (4 Stück) - OCZ System Integrator DIMM 1GB PC2-5300U CL5-5-5-15 (DDR2-667) (OCZ2SI6671G) Preisvergleich bei Geizhals.at EU
Das war kein Kit aber die Riegel haben aufeinanderfolgende Seriennummern.
Tja nur machen mit die Speicher ziemliche Probleme.
Habe ich nur 2 Stück (2GB) drin läuft das ganze z.B. mit 350MHz FSB - RAM 1:1 CL5 stabil (CPU rennt dann mit 3,8GHz und leicht erhöhter VCore)
Doch sobald ich die anderen 2 (oder auch nur einen) dazu stecke komme ich nicht mal mehr ins Windows und Memtest bringt Fehler.
Auch mit 333MHz FSB und RAMs 1:1 ist das System nicht stabil. (Hebe ich die VDimm auf 2,1V komme ich zumindest ins Windows - aber das Sys ist nicht stabil)
Und nun das schockierenste ... sogar @default - sprich FSB 266 und RAM 1:1 (= DDR2-533) mit CL5 (oder auch 6) und VDimm bis zu 2,1V ist das System mit 4 Riegel NICHT stabil.
Die einzelnen Riegel sind alle OK - und wie gesagt wenn ich die (egal in welcher Kombi) nur mit 2 Stück verwende läuft das Sys auch übertaktet absolut stabil.
Mit den alten RAMs (Kingston DDR2-800 CL4 und Patriot DDR2-1066 CL5) lief das Board allerdings ohne Probleme mit Vollbestückung.
Habt Ihr noch irgendwelche Ideen? Ich bin mit meinem Latein am Ende.
Bzw. hat wer Empfehlungen welche 4 x 1GB oder 2 x 2GB Speicher auf dem Board einwandfrei laufen??? DDR2-667 würden mir schon genügen da schnellere Einstellungen kaum mehr Leistung bringen.
Danke.
Hallo, ich würde gerne wissen, welches BIOS Optimal für einen Q9650 wäre.
P5B BIOS defekt, System (RAID0) mit neuem gleichem Board ohne Probleme startbar?
mein ASUS P5B Deluxe BIOS hat sich soeben verabschiedet (bitte keine Tipps zum Wiederherstellen, es geht nicht!).
Habe mir das gleiche Modell nun gebraucht gekauft. Wird das System nachdem ich dort im BIOS alles so wie beim Alten konfiguriert habe, ohne Probleme starten oder ist mein RAID zwingend an das alte Board gebunden, weil dort auf dem Controller die Konfiguration gespeichert ist??
hi leute. nach jahren des leichten taktens habe ich heut mal angefangen meinen e6300 zu übertakten. hab ich soweit erfolgreich auf 2.92 ghz gebracht. habe nur ein paar fragen bezüglich der temperatur und der eingestellten spannung.
erstmal zu den jetztigen daten und anschließend zu den fragen.
temperatur : 51/57 °C (idle/last; mit tjmax bei 85°C)
Vcore bios: 1,315 V
Vcore tatsächlich: 1.272/1.256 V (idle/last; mit CPU-Z ausgelesen)
VID der cpu laut coretemp: 1.325
sind die temperaturen noch im gesunden bereich? (ich selbst tippe mal auf ja, aber sicher ist sicher, deshalb die frage)
habe mal gelesen, dass die vcore der cpu sich nach dem VID wert richtet. wenn ich danach gehe, wäre meine cpu ja untertaktet, und das soll ja schädlich sein. wenn ich jedoch den vcore im bios auf auto setze, und den standard-fsb laufen lasse, pendelt die spannung zwischen 1.22 und 1.25. ist die spannung also soweit ok bei meinen OC-settings?
MfG GreekDef
Hallo, wie kriege ich meinen eSATA Anschluss zum Laufen (Normales P5B Deluxe)?
Der JMicron Controller ist im BIOS aktiviert und auf AHCI gestellt. Von der JMicron Seite wurde "JMB36X_WinDrv_R1.17.55_WHQL_eSATA" setup.exe ausgeführt und installiert. Über einen Lösungsvorschlag per PN wäre ich sehr dankbar!
Kann es an der Kabellänge liegen? Ich habe ein 1m langes eSATA Kabel.
P5B-Deluxe aufrüsten
ich würde gerne auf mein Board eine neue CPU draufsetzen und die Grafikkarte tauschen.
Habe mal vorab den E7600 ins Auge gefasst. Gibt es Alternativen mit besseren P/L-Verhältnis?
Bei der Grafikkarte stelle ich keine sehr hohen Anforderungen. Bin kein großer Zocker. Momentan hab ich eine Xpertvision 7900GS. Da stört mich aber der sehr laute Lüfter. Vorschläge?
Danke.
Grüße,
Tobias
@tobizzle
Die Raid Info ist normalerweise auf den Platten gespeichert. Sprich wenn Du das neue Board hast solltest Du das alte Raid weiterverwenden können.
Achten solltest Du nur darauf daß Du zumindest die gleiche BIOS Version (oder eventuell höher) hast - und vielleicht daß Du bevor Du die Platten anschliesst eben alle Einstellungen im BIOS machst (Controller auf RAID etc.) und dann logischerweise die Platten GENAU so anschliesst wie sie am alten waren.
Aber anscheinend hast Du das nun eh hinbekommen, oder?
Zu dem eSATA kann ich Dir leider nichts genaues sagen. Treiber solltest Du den richtigen installiert haben. Was funktioniert denn nicht? Wird das Gerät gar nicht erkannt? Auch nicht wenn Du es vor dem booten angeschlossen hast?
Temps sollten okay sein. Alles unter 60°C ist bei einer 65nm Core2 CPU im grünen Bereich würde ich sagen. Wobei mir die Werte schon etwas hoch vorkommen für einen nicht-boxed Lüfter. (AC Freezer Pro 7 lt. Deiner Sig? Der ist eigentlich ganz gut)
Du meinst wohl nicht untertaktet sondern untervolted oder?
VID und VCore sind nicht dasselbe. Wie ich das bisher verstanden habe leitet sich die VCore (Auch Vcc genannt) vom VID ab. Hier ein ganz interessanter Beitrag den man jedoch vielleicht erst mit etwas Geduld und zweifachen Lesen bzw. anderen Beiträgen dazu zu lesen versteht: LINK
Kurzform davon:
VID sollte von Intel die Obergrenze der (bei Lastwechsel schwankenden) VCore sein, um die Leistungsangaben der CPU nicht zu überschreiten. Bzw. die Obergrenze die unter Last (was eventuell bei Intel die Schwankungen beinhaltet) nicht überschritten werden sollte damit die CPU noch in Ihren Spezifikationen / Leistungsangaben läuft.
Du hast eine VID von 1,325
Dein Board leitet davon die VCore ab (kann von Board zu Board unterschiedlich sein) und kontrolliert somit auch wie in der Grafik im Link oben zu sehen den VOffset und VDroop.
Scheint bei Dir ganz normal zu funktionieren denn die VID ist höher als die VCore im Leerlauf und die VCore unter Last ist noch niedriger.
@snoopy99
Kommt ganz drauf an wie Du eingestellt bist:
Willst Du übertakten?
Willst Du möglichst wenig ausgeben?
Hast Du irgendwelche Anforderungen an die CPU (Videoencoding, Spiele oder sowas)?
Stromsparen?
usw.
Mögliche CPUs im unteren Preissegment bzw. um den E7600 herum wären:
Pentium E5400 ( 2 x 2,7GHz, 200MHz FSB, 2MB 2nd Level Cache) um etwa 55 EUR
den könntest Du bestimmt recht einfach auf über 3GHz übertakten indem Du den FSB anhebst. Mit 223MHz FSB hättest Du die 3GHz schon geknackt und das macht die CPU auch ganz bestimmt mit.
Pentium E6500 ( 2 x 2,93GHz, 266MHz FSB, 2MB 2nd Level Cache) um etwa 64 EUR
den habe ich auch vor einer Weile für mein P5B-E gekauft. Bietet ne ordentliche Grundleistung für's Geld finde ich. Übertakten ist da auch noch drin - vorrausgesetzt Du hast einen flotten Speicher und kein zickiges Board.
Pentium E6600 ( 2 x 3,06GHz, 266MHz FSB, 2MB 2nd Level Cache) um etwa 80 EUR
finde ich schon etwas zu teuer im Vergleich zum E6500. 16 EUR mehr für gerade mal ~ 133MHz mehr.
Core2Duo E7600 ( 2 x 3,06GHz, 266MHz FSB, 3MB 2nd Level Cache) um etwa 105 EUR
Vorteile gegenüber obigen CPUs: 3MB statt 2MB Cache. Macht in der Praxis aber gerade mal so ca. 3-5 % Mehrleistung aus. Und er kann SSE4.1 was eventuell bei einigen Encoder/Decoder oder Renderingprogrammen genutzt wird.
Alternative wäre auch noch ein gebrauchter E8400 oder so. Der hat gleich 6MB Cache und einen 333MHz FSB. Sollte hier im Marktplatz so um die 60 - 80 EUR zu bekommen sein schätze ich.
Für alle obigen CPUs würde ich jedoch zuvor ein BIOS Update machen damit die auch alle unterstützt werden.
Was hast Du denn derzeit für eine CPU drauf bzw. was für Speicher?
Zur Graka ... hier kommt es natürlich auch stark darauf an was Du ausgeben willst bzw. was Du wirklich brauchst. Eine gute Mittelklasse Karte ist bestimmt die HD5750 um knapp 100+ EUR oder HD5770 ab knapp 115 EUR.
Etwa gleichschnell bzw. teils ne Spur langsamer (zumindest als ne HD5770) wäre auch eine HD4850 die man neu ab etwa 85 EUR bekommt.
Von nVidia gibts in dem Preisbereich nicht viel ... vielleicht ne GTS 250 ab ca. 85 EUR. Die ist zwar im Prinzip ne 9800GTX+ die wiederrum ne höhergetaktete 8800GTS 512MB mit mehr Speicher ist. Also schon ein recht alter Chip der etwas aufgeblasen wurde. Ist aber nach wie vor eine brauchbare Karte.
Die GT 240 finde ich schon wieder etwas schwach auf der Brust, auch wenn man die schon ab etwa 70 EUR bekommt.
Gerade die 48xx Serie bzw. die GeForce 8800/9800er Serie kann man aber auch schon sehr günstig gebraucht bekommen.
Bzgl. Lautstärke musst Du halt nachlesen welche Karte es in welchen Varianten gibt und was da gut/leise davon ist.
Hallo zusammen,
ich habe ein P5B Deluxe mit einem E6600 Proz @ 2,4ghz laufen.
Ram sind imho Corsair XMS, DDR2-800er meine ich...ist alles schon lange her, mit
dem Kauf ;) 4 x 1GB.
Als Graka werkelt eine 8800GT. Ich will nun aufrüsten auf eine
Ati 5770 und nun auch den Proz etwas übertakten.
Ich hab nur einen boxed Lüfter. Kann ich den FSB trotzdem auf 400 bringen?
Lüfter ersetzen? Wenn ja, durch welchen?
Oder lieber im Bereich von 300 rumtesten und nicht so stark übertakten?
Wenn FSB 400...welchen Mulitplikator einstellen? 9 stehen lassen?
/Der Edith ist noch eine Frage eingefallen
Ich habe ja 4 x 1GB Ram drin. Das Board zeigt aber nur 3072 MB an, im Bios wie auch im Windows.
Stelle ich nun im Bios diese remapping Funktion um, zeigt er mir beim booten zwar 4096MB an, im
Windows aber nur noch 2048MB oO
Ich nutze WinXP Prof 32bit. Was schafft da abhilfe? Win7 64bit?Wieso zeigt er mir im Windows nur noch 2048MB an?
Wenn du die vollen 4GB nutzen möchtest, brauchst du ein 64bit OS, unter 32bit sind 3GB das Maximum.
Remapping lässt du demzufolge also aus, so lange du noch XP 32bit nutzt.
Alles klar, hab mir gerade Win7 mit 64Bit bestellt und nen xigmatek hdt-s1283 Kühler.
Hoffe der hat bissel mehr Kühlleistung, als der boxed Kühler.
@jiri01
Du weisst aber schon daß die HD5770 jetzt nicht soooo viel schneller sein wird als die 8800GT. Über den Daumen sag' ich mal so etwa 40-50%
Mit was für einer Auflösung spielst Du? Drehst Du Antialiasing hoch?
Aber ja - Preis/Leistung ist die HD5700er Serie derzeit ziemlich gut, da kann man nix sagen.
Du willst den mit 400 x 9 = 3,6GHz laufen lassen? Das wird schwer ... und mit dem boxed Kühler wohl auch nicht so zu empfehlen.
Wenn Du den auf 333 x 9 = 3,0GHz stellst sollte das denke ich auf jeden Fall funktionieren. Eventuell musst Du da schon mit der VCore oder mit der Chipsatzspannung hoch gehen - und auch überprüfen auf was die Speicher da laufen. Kleinster Speicheteiler bei Intel ist 1:1 - sprich die würden da mit DDR2-667 laufen. Nächster Schritt ist ca. 833 oder so. Wenn Deine Speicher DDR2-800 sind sollten die da auch noch funktionieren.
Alles über 3GHz wird schon etwas viel für den boxed Lüfter.
Alle 32Bit Systeme können nur bis max. 4GB adressieren. Das beinhaltet jedoch auch sämtliche Speicherbereiche wie Grafikkartenspeicher oder diverse Speicherbereiche von anderen Komponenten. Sprich im alleroptimalsten Fall hat man da etwa 3,75GB zur Verfügung. Wenn man eine Graka mit 512MB hat sind es schon meist nur noch 3,25GB oder gar weniger. Und mit einer Graka >512MB dementsprechend noch weniger.
Memory Remap musst Du bei 32Bit OS immer auf DISABLED lassen.
Mit XP64, Vista64 oder Win7 64 kannst Du das ENABLEN und hast den kompletten 4GB Speicherbereich zur Verfügung.
Danke für die Infos.
Ja mir ist klar, das die HD5770 nicht extrem viel schneller ist. Mit meinem PC sind die meissten Games auch noch ganz gut spielbar, aber eben nicht alle. Und ich denke mal, wenn ich jetzt ein bisschen mehr Prozessorleistung schaffen sollte und dazu mehr Grafikleistung, dann hab ich hoffentlich noch nen Jahr Ruhe, bis ich ein komplett neues System baue. Hätte ich eine KArte der 58xx Reihe genommen, hätte ich wohl nen auch noch ein neues Netzteil gebraucht. Irgendwann kann man dann direkt nen neuen PC holen.
Ich spiele mit 1920 x 1080. Grafikdetails und AA schraube ich halt runter, wenn ich Performanceprobleme bekomme, wie z.b. in Battlefield Bad Company 2.
Ja im ersten Schritt ist FSB333 erst mal ein Ziel. Meinst du, ich kann mit dem Xigmatek Lüfter dann auf 400 gehen? Oder schafft der die Kühlleistung nicht?
Ich sitze leider gerade nicht vor dem PC, den ich übertakten will, deshalb kann ich nicht selber nachschauen...kann ich den Speicherteiler selbst einstellen, oder stellt der sich automatisch anhand des FSB oder so ein? Das ist (erstmal) die einzige Sache, die mir trotz zig gelesener Postings nicht klar geworden ist.
Uii ... Full HD (1080P) - da wirst Du wohl auch mit der HD5770 zumindest bei ein paar aktuelleren Spielen ein wenig runterschrauben müssen.
Nimm auf jeden Fall die 1GB Version da die nur ein paar EUR teurer als die 512MB Version ist, du aber gerade in höheren Auflösungen etwas mehr Luft hast.
Leider sind die HD5850 Karten noch recht teuer und noch nicht sooo toll verfügbar (eventuell auch deswegen so teuer).
Aber es stimmt schon - für eine HD58xx Karte sollte der restliche PC auch Fit sein - sprich die CPU ordentlich flott und das Netzteil ausreichend.
Der Xigmatek ist ein ganz guter Kühler. Wenn Du vielleicht noch einen Gehäuselüfter hinten hast und dadurch einen guten Luftstrom im Gehäuse schaffst sollte der sehr gut kühlen - ja. Definitiv einiges besser als der boxed Kühler.
Ob die CPU und das Board (bzw. in Kombination) die 400MHz FSB mitmachen musst Du halt ausprobieren. 400 x 8 = 3,2 GHz könnte ich mir ganz gut vorstellen.
Den Teiler kannst Du wählen, oder auch auf "AUTO" belassen - dann sollte der den versuchen automatisch zu wählen. Und ja - der richtet sich nach dem FSB.
Sprich wenn Du den Teiler immer gleich auf einer manuellen Stellung lässt und den FSB nach oben schraubst erhöht sich auch der Speichertakt. Bei AUTO versucht das Board den passenden Teiler zu finden.
Das sind die niedrigsten manuellen Teiler die das Board kann:
Bei 266MHz FSB
1:1 - nennt sich DDR2-533
4:5 - nennt sich DDR2-667
2:3 - nennt sich DDR2-800
und bei 333MHz FSB
1:1 - nennt sich DDR2-667
4:5 - nennt sich DDR2-833
2:3 - nennt sich DDR2-1000
usw.
Die "AUTO" Einstellung versucht jeweils anhand den im SPD des Speichers zum FSB passenden höchsten Wert zu finden. Sprich wenn da DDR2-800 drin programmiert ist sollte der bei dem 266MHz FSB den 2:3 Teiler wählen. Allerdings hat nicht jeder DDR2-800 oder schnellerer Speicher auch wirklich solche Einstellungen im SPD programmiert! Oft steht da aus kompatibilitätsgründen nur ein Eintrag für DDR2-667 drin. Bei meinen Kingston HyperX DDR2-800 CL4 ist das z.B. so. Da stehen nur Einstellungen für DDR2-400, 533 und 667 drin. Und bei 667 sogar auch nur CL5. Liegt eben daran daß halt jedes Board damit booten soll. Dann kann man manuell auf DDR2-800 CL4 und 2.0V stellen und die sollten auf der Einstellung laufen.
