Guten Morgen
Mein I5 750 läuft jetzt auf 3400MHz 10h Prime Stable. Das reicht mir. Evtl. versuche ich noch mal an den Spannungen zu spielen.
Eine Frage habe ich zur QPI Frequency. Bringt es was dort einen festen Wert einzustellen?
Board: ASUS P7P55D
BIOS Version: 1207
Ai Overclock Tuner .................. [Manual]
CPU Ratio Setting .................... [Auto]
Intel SpeedStep Tech .............. [Enabled]
Intel TurboMode Tech .............. [Enabled]
Xtreme Phase Full Power Mode ... [Auto]
BCLK Frequency ...................... [162]
PCIe Frequency ....................... [100]
DRAM Frequency ..................... [1620MHz]
QPI Frequency ......................... [Auto]
DRAM Timing Control: Manual
1st
CAS# Latency : 9
RAS# to CAS# Delay : 9
RAS# Precharge : 9
RAS# ActivateTime : 24
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
CPU Differential Amplitude ............ [Auto]
CPU Clock Skew ......................... [Auto]
____________________________________
CPU Voltage Mode ...................... [Offset]
Offset Voltage ........................... [0,01250]
Fixed Voltage ............................. [Disabled]
IMC Voltage .............................. [1,15]
Dram Voltage ............................. [1,6375]
CPU PLL Voltage ......................... [1,80]
PCH Voltage .............................. [1,05]
Load-Line Calibration .................. [Disabled]
CPU Spread Spectrum ................. [Auto]
PCIE Spread Spectrum ................ [Auto]
Intel C-STATE Tech .................... [Disabled]
Board: ASUS P7P55D
BIOS Version: 1207
1st
CAS# Latency : 9
RAS# Precharge : 9
