Mehrjungfraumann
schlag zu, hab ich auch gemacht !
Date , GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Temperature [°C] , Fan Speed (%) [%] , Fan Speed (RPM) [RPM] , GPU Load [%] , Memory Usage (Dedicated) [MB] , Memory Usage (Dynamic) [MB] , 12V [V] , VDDC [V] , VDDCI [V] , VDDC Current In [A] , VDDC Current Out [A] , VDDC Power In [W] , VDDC Power Out [W] , VRM Temperature 1 [°C] , VRM Temperature 2 [°C] ,
2014-03-07 10:32:51 , 1000.0 , 1260.0 , 88.0 , 54 , - , 99 , 3081 , 415 , 11.63 , 1.141 , 1.000 , 16.8 , 143.5 , 181.8 , 151.8 , 85 , 81 ,
2014-03-07 10:32:52 , 1000.0 , 1260.0 , 88.0 , 54 , - , 99 , 3081 , 415 , 11.75 , 1.141 , 1.000 , 15.3 , 134.0 , 200.3 , 159.8 , 85 , 81 ,
2014-03-07 10:32:53 , 1000.0 , 1260.0 , 88.0 , 54 , - , 100 , 3081 , 415 , 11.63 , 1.148 , 1.000 , 15.4 , 136.5 , 202.5 , 145.5 , 85 , 81 ,
2014-03-07 10:32:54 , 1000.0 , 1260.0 , 88.0 , 54 , - , 99 , 3081 , 415 , 11.75 , 1.141 , 1.000 , 16.0 , 137.0 , 207.5 , 149.3 , 85 , 81 ,
2014-03-07 10:32:55 , 1000.0 , 1260.0 , 88.0 , 54 , - , 98 , 3081 , 415 , 11.63 , 1.141 , 1.000 , 15.4 , 137.0 , 205.3 , 162.8 , 85 , 81 ,
2014-03-07 10:32:56 , 1000.0 , 1260.0 , 88.0 , 54 , - , 100 , 3081 , 415 , 11.63 , 1.148 , 1.000 , 16.6 , 148.5 , 189.0 , 153.0 , 85 , 81 ,
2014-03-07 10:32:57 , 1000.0 , 1260.0 , 88.0 , 54 , - , 98 , 3081 , 415 , 11.75 , 1.141 , 1.000 , 16.0 , 136.0 , 206.0 , 149.8 , 85 , 81 ,
2014-03-07 10:32:58 , 1000.0 , 1260.0 , 88.0 , 54 , - , 100 , 3081 , 415 , 11.75 , 1.141 , 1.000 , 17.2 , 144.5 , 193.3 , 146.0 , 85 , 81 ,
2014-03-07 10:32:59 , 1000.0 , 1260.0 , 88.0 , 54 , - , 98 , 3081 , 415 , 11.63 , 1.141 , 1.000 , 15.1 , 135.5 , 203.8 , 164.3 , 85 , 81 ,
2014-03-07 10:33:00 , 1000.0 , 1260.0 , 88.0 , 54 , - , 99 , 3081 , 415 , 11.63 , 1.141 , 1.000 , 15.7 , 135.0 , 192.5 , 170.3 , 85 , 81 ,
2014-03-11 14:25:04 , 980.0 , 1250.0 , 76.0 , 78 , - , 98 , 3133 , 368 , 11.63 , 1.141 , 1.000 , 12.6 , 108.0 , 143.0 , 136.3 , 87 , 67 ,
2014-03-11 14:25:05 , 980.0 , 1250.0 , 76.0 , 78 , - , 100 , 3133 , 368 , 11.63 , 1.141 , 1.000 , 15.7 , 133.0 , 174.8 , 130.3 , 87 , 67 ,
2014-03-11 14:25:06 , 980.0 , 1250.0 , 76.0 , 78 , - , 99 , 3133 , 368 , 11.63 , 1.141 , 1.000 , 14.0 , 109.5 , 161.5 , 131.5 , 88 , 67 ,
2014-03-11 14:25:07 , 980.0 , 1250.0 , 76.0 , 78 , - , 100 , 3133 , 368 , 11.63 , 1.156 , 1.000 , 13.5 , 116.0 , 175.0 , 149.5 , 88 , 67 ,
2014-03-11 14:25:08 , 979.1 , 1250.0 , 76.0 , 78 , - , 97 , 3133 , 368 , 11.63 , 1.148 , 1.000 , 12.4 , 113.5 , 155.5 , 142.0 , 88 , 67 ,
2014-03-11 14:25:09 , 980.0 , 1250.0 , 76.0 , 78 , - , 100 , 3133 , 368 , 11.63 , 1.141 , 1.000 , 15.8 , 127.0 , 158.0 , 133.0 , 88 , 67 ,
2014-03-11 14:25:10 , 980.0 , 1250.0 , 76.0 , 78 , - , 99 , 3133 , 368 , 11.63 , 1.141 , 1.000 , 13.9 , 112.5 , 153.3 , 128.8 , 88 , 67 ,
2014-03-11 14:25:11 , 980.0 , 1250.0 , 76.0 , 78 , - , 100 , 3133 , 368 , 11.63 , 1.156 , 1.000 , 13.7 , 125.0 , 180.5 , 143.5 , 88 , 67 ,
2014-03-11 14:25:12 , 980.0 , 1250.0 , 76.0 , 78 , - , 99 , 3133 , 368 , 11.63 , 1.156 , 1.000 , 13.5 , 115.0 , 168.5 , 123.5 , 88 , 67 ,
2014-03-11 14:25:14 , 980.0 , 1250.0 , 76.0 , 78 , - , 99 , 3133 , 368 , 11.63 , 1.148 , 1.000 , 14.3 , 108.0 , 154.8 , 131.5 , 88 , 67 ,
2014-03-11 22:25:37 , 1110.0 , 1250.0 , 76.0 , 78 , - , 99 , 3166 , 382 , 11.63 , 1.133 , 1.000 , 15.2 , 112.5 , 148.3 , 122.9 , 90 , 68 ,
2014-03-11 22:25:38 , 1110.0 , 1250.0 , 76.0 , 78 , - , 99 , 3166 , 382 , 11.63 , 1.125 , 1.000 , 14.4 , 107.0 , 145.3 , 120.3 , 90 , 68 ,
2014-03-11 22:25:39 , 1110.0 , 1250.0 , 76.0 , 78 , - , 100 , 3166 , 382 , 11.63 , 1.133 , 1.000 , 12.9 , 125.5 , 171.0 , 127.5 , 90 , 68 ,
2014-03-11 22:25:40 , 1110.0 , 1250.0 , 76.0 , 78 , - , 98 , 3166 , 382 , 11.63 , 1.125 , 1.000 , 12.4 , 105.0 , 154.8 , 140.3 , 90 , 68 ,
2014-03-11 22:25:41 , 1109.2 , 1250.0 , 76.0 , 78 , - , 100 , 3166 , 382 , 11.63 , 1.125 , 1.000 , 13.1 , 111.5 , 144.5 , 122.9 , 90 , 68 ,
2014-03-11 22:25:42 , 1110.0 , 1250.0 , 76.0 , 78 , - , 100 , 3166 , 382 , 11.63 , 1.133 , 1.000 , 12.4 , 110.5 , 166.5 , 124.0 , 90 , 68 ,
2014-03-11 22:25:43 , 1110.0 , 1250.0 , 76.0 , 78 , - , 98 , 3166 , 382 , 11.63 , 1.125 , 1.000 , 12.6 , 108.0 , 148.8 , 124.0 , 90 , 68 ,
2014-03-11 22:25:44 , 1110.0 , 1250.0 , 76.0 , 78 , - , 100 , 3166 , 382 , 11.63 , 1.133 , 1.000 , 12.5 , 109.5 , 165.5 , 122.5 , 90 , 68 ,
2014-03-11 22:25:45 , 1110.0 , 1250.0 , 76.0 , 78 , - , 99 , 3166 , 382 , 11.63 , 1.117 , 1.000 , 12.7 , 108.5 , 149.3 , 122.5 , 90 , 68 ,
2014-03-11 22:25:46 , 1110.0 , 1250.0 , 76.0 , 78 , - , 99 , 3166 , 382 , 11.63 , 1.133 , 1.000 , 13.6 , 109.0 , 142.3 , 120.8 , 90 , 68 ,
2014-03-11 22:25:47 , 1110.0 , 1250.0 , 76.0 , 78 , - , 99 , 3166 , 382 , 11.63 , 1.117 , 1.000 , 12.5 , 107.0 , 142.8 , 126.0 , 90 , 68 ,
Du kannst die Lüfterkurve mittels ASUS GPUTweak unter Fan Speed -> User Define anpassen. Hat aber z.B. bei mir aber so gut wie nichts gebracht....
Aber eines ist mir aufgefallen die Lüfter Geschwindigkeit steigt im vergleich zur Temperatur nur sehr Mäßig bsp. 75 zu 38% ,80 zu 45% und 84 zu 50%.
Wie kann ich am besten die Lüftersteuerung konfigurieren und sind Temperaturen um die 80-90 Grad auf Dauer verträglich ?
Warum sind eigentlich alle so am moppern?
Bei mir lauft die Karte im Idle bei 36-40°C.
Gerade hab ich nochmal ein Benchmark in Thief durchlaufen lassen, da geht sie auf 70°C hoch.
Treiber ist der aktuelle 14.3 Beta.
Bin bisher eigentlich sehr mit der DirectCU zufrieden.
Die Probleme die entstehen sehe ich eher bei AMD und ihren unreifen Treibern.
