CPU Feature
Thermal Management Control: Disabled
PPM(EIST) Mode: Enabled
Limit CPUID MaxVal: Disabled
CIE Function: Enabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Core Multi-Processing: Enabled
Exit Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 9
Target CPU Clock: 3600
CPU Clock: 400
Boot Up Clock: Auto
DRAM Speed: 333/800...glaub ich^^kann mich auch vertippt haben
Target DRAM Speed: 1030
PCIE Clock: 110mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.5000V
CPU VID Special Add: .23%
DRAM Voltage Control: 2.150V
SB Core/CPU PLL Voltage: 1.510V
NB Core Voltage: 1.55V
CPU VTT Voltage: 1.415V
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: enabled
x CPU GTL1/3 REF Volt: 140
x CPU GTL 0/2 REF Volt: 140
x North Bridge GTL REF Volt: 110
DRAM Timing
Enhance Data transmitting: Fast
Enhance Addressing: Fast
T2 Dispatch: Enabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: Aggressive
DIMM 1 Clock fine delay: Current
DIMM 2 Clock fine delay: Current
Ch 1 Command fine delay: Current
Ch 1 Control fine delay: Current
Ch2 Clock Crossing Setting: Aggressive
DIMM 3 Clock fine delay: Current
DIMM 4 Clock fine delay: Current
Ch 2 Command fine delay: Current
Ch 2 Control fine delay: Current
Ch1Ch2 CommonClock Setting: Aggressive
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 15
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): 58
Performance LVL (Read Delay) (tRD): 8
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
Channel 1 Phase 0 Pull-In: Enabled
Channel 1 Phase 1 Pull-In: Enabled
Channel 1 Phase 2 Pull-In: Enabled
Channel 1 Phase 3 Pull-In: Enabled
Channel 1 Phase 4 Pull-In: Enabled
Ch2 Read delay phase (4~0)
Channel 2 Phase 0 Pull-In: Enabled
Channel 2 Phase 1 Pull-In: Enabled
Channel 2 Phase 2 Pull-In: Enabled
Channel 2 Phase 3 Pull-In: Enabled
Channel 2 Phase 4 Pull-In: Enabled
MCH ODT Latency: 2
Write to PRE Delay (tWR): 14
Rank Write to Read (tWTR):11
ACT to ACT Delay (tRRD): 3
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): 3
ALL PRE to Refresh: 5
erst damit läuft prime 2 stunden und mehr stabil...game und windows stable isset mit weniger...aber nja
hab ich so ne krücke vom q66 erwischt?
ist ein q6600 G0 SLACR... -.-
EDIT1: Kann ich das BIOS vom UT Problemlos auf mein LT aufspielen?vllt hilft ja ein neues Bios zur Abhilfe ;o)
EDIT2: bei 430x7 brauch nur die NB etwas mehr spannung...ram läuft auf 1071 MHz...und die Cpu nur 1,3V ...ich versteh die Welt nicht mehr^^
mitm Dfi 680i bin ich irgendwie besser klar gekommen
bin für hilfe und tipps gerne offen
...Fragen über Fragen^^
XrayN-1H
