ja das ist alles normal, um die CPU festzuklemmen braucht man wirklich viel Kraft.
Hau' rein
So Danke hab einfach gedrückt und lief alles (fast ^^) nach Plan.
Hau' rein
CPU Feature Page
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Disabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Disabled
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................1
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................9x
CPU Clock.................................422 MHz
Boot Up Clock.............................Auto
DRAM Speed................................266/667
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................1.49375
CPU VID Special Add.......................Auto
DRAM Voltage Control......................2.3V
SB Core/CPU PLL Voltage...................1.55V
NB Core Voltage...........................1.45V
CPU VTT Voltage...........................1.43V
VCore Droop Control.......................Disabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................N/A
CPU GTL 0/2 REF Volt......................N/A
North Bridge GTL REF Volt ................N/A
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Auto
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................5
Precharge Delay (tRAS)....................15
All Precharge to Act......................4
REF to ACT Delay (tRFC)...................48
Performance Level.........................6
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................Auto
Write to PRE Delay (tWR)..................Auto
Rank Write to Read (tWTR).................Auto
ACT to ACT Delay (tRRD)...................Auto
Read to Write Delay (tRDWR)...............Auto
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................Auto
ALL PRE to Refresh........................Auto
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Enabled
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................Current 1312ps
DIMM 2 Clock fine delay...................Current 462ps
Ch 1 Command fine delay...................Current 862ps
CH 1 Control fine delay...................Current 400ps
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................Current 1186ps
DIMM 4 Clock fine delay...................Current 374ps
Ch 2 Command fine delay...................Current 912ps
CH 2 Control fine delay...................Current 300ps
Ch1Ch2 CommonClock Setting................More Aggressive
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
Hallo
bin neu, und habe gleich ein Paar Fragen .
Will diese Mainboard mit dem q9450/x3350 betreiben, braucht die Mainboard einen Bios-update? Oder wuerde es auch so (die ist neu) den CPU erkennen?
Ich glaube ich brauche nen anderen 775 CPU um den BIOS zu flashen damit die Mainboard den q9450 erkennt, bin aber mir nicht so ganz sicher?
Habe jetzt den 500er FSB für meinen Xeon 3075 (=E6750) herausgependelt, nun wollte ich fragen da ich auf einen Quad umsteige was ich da groß ändern muss oder ob ich die Werte ruhig drinnen lassen kann bzw. sollte ? Vllt. hat ja auch jemand nen paar Richtwerte für einen Q6600 !
@ All
Hat schon jemand eine Nvida 9800 GX2 am Laufen? will mir nicht was kaufen was dan nicht geht!
IM DFI Forum steht jetz schon öfter die ATI karte geht die jetzt schon?
Netten Gruß
Alex
Nach meinem Wissen sollte das Board auch ohne neuere Bios Versionen den Prozessor richtig erkennen(sollte normal sein beim X38^^), schließlich gibts ja den Yorkfield core schon etwas länger (QX9650) und abgesehen davon hab ich auch in den Bios Notes von den neuen Versionen nie etwas davon gelesen, das der Support für die entsprechenden CPU's hinzugefügt wurde, daher gehe ich mal davon aus das er schon immer vorhanden war.
100%ig werde ich es dir wohl am Freitag sagen können, da ich hier grade das Board mit fertig verbautem Q9450 rumliegen habe und nur noch auf mein Gehäuse warte. Bis zum WE hab ich leider weder Zeit noch die Nerven das Ding so schonmal zu testen. Jedenfalls wenn ich mit meiner Annahme das der Standardmäßig supported wird falsch liege:
Dann darf ich sehen wo ich ne CPU zum flashen herbekomme, hab nämlich keine^^.
die 500 mit dem Q6600 kannst du schonmal komplett vergessen, das macht m.E.
kein Q6600 mit. Ansonsten musst du vermutlich nur die NB-Spannung
erhöhen da die Quads gewaltig am Speichercontroller "rumsaugen".
Richtwerte gibt es nicht; jede CPU ist anders (..amen)
Ein X3350(Q9450) macht sich doch sicher gut auf dem Board.
Braucht man für die Penryns eigentlich ein Biosupdate?
So, hab meinen PC endlich zusammengeschraubt und so wies aussieht läuft alles gut, also ohne Bios flashen läuft mein Q9450 @ 2.66GHz und mit 1.1V nach VID. Also damit sollte das Bios Thema 45n CPU's abgeschlossen sein.
Hab aber noch ne Frage zur Diagnostic LED... Wo gibts denn da ne Liste der Errorcodes, im Handbuch steht nix...
Meine LED zeigt FF an was nach dem was ich finden konnte bedeutet, dass der Bootvorgang normal abläuft, was ja auch dazu passen würde das ich aufm Bildschirm keine Fehler angezeigt bekomm^^
Trotzdem würd ichs gut finden wenn mir jemand bestätigen könnte das FF nichts "schlimmes" bedeutet und ne komplette Liste wäre auch ganz gut falls es mal Probleme gibt.
ich hab letztens einmal ein vier GB Kit PC-8000 von OCZ probiert.
http://geizhals.at/deutschland/a295145.html
Anscheinend laufen die auf Lanparty X38/X48 nicht.
Hat sonst noch jemand solche Module mal getestet?
MfG
Das DFI gefällt mir langsam immer besser.
mein kleiner e63 läuft unn auch seine 3,5GHz mit 1,4V anliegend, während es beim ASUS noch 1,5 waren, und der da auch schonmal des öfteren die Biege gemacht hat.
Aber ma ne Frage.
Es werklen bei mir ja 2x 2GB RAM mit 500MHz.
was ist da ein trfc richtwert?
42 ist ja bekanntlich zu niedrig... hab imo 52 eingestellt. ist das schon der noraml bereich, oder doch lieber 48 etc. oder ist auch hier wieder intensives Testen angesagt?
Moin,
also mit den 2x2GB riegeln kenn ich mich net aus. Meine 4x1GB Crucial Tracer 8500 werden bei Bios AUTO mit trfc 42 eingestellt.Nun laufen sie aber auf 1000 was ja niedriger ist als die 1066 wie sie locker könnten.
Mit den 42er trfc hab´ ich nie Prob´s bekommen, weder Memtest noch das OS haben gemeckert. Ach ja, das Ganze bei entspannten 1,9VDIMM.
