Neuer Patch kommt. Dieses Mal ohne Wipe
http://forum.escapefromtarkov.com/topic/54782-06xx-preliminary-patch-notes/
Dear Escapers!
We are pleased to announce the preliminary patch notes for patch 0.6.xx.
We plan to release this in the coming days.
NO WIPE THIS TIME!
Added:
Additional small passage area at the Customs
Extended spawn area in the outskirts of the Woods
AI Improvements:
Bots now correctly close the doors that hinder their passage
Fixed the bug that allowed bots to occupy the same position
Reduced accuracy of AI grenade throws
Optimizations:
Server performance optimization
Skills tab loading optimization
Minor optimization of locations
Fixed:
Server errors potentially leading to disconnects and desync
Bug that changed the extraction points after reconnect
Bug that displayed “The price has been changed" error while trading
Perception skill progress is now counted properly for long in-raid times
Bug with SMG skill ergonomics bonus
Bug with Sniper Rifle skill recoil bonus
Correct item examining speed bonus
Bug with looting sound hangup
Bug related to profile processing on reconnect
Bug in helmet level-dependent earpiece functioning
Bug related to profile saving
Redesigned player spawn points at the Woods location
Visual and functional fixes of locations
Bug that prevented the second beacon installation attempt if the character was killed during the first one
Adjustments of the quest mechanics
Quest skill level requirement detection bug
Bug with insurance disappearing
A number of bugs related to the screens’ overlapping
Part of the bugs associated with hands deadlocking while opening doors
Various effects fixes
Adjusted helper point of the Attention skill (not shown while aiming, works only with single loot items)
Various fixes associated with sounds
Minor interface fixes
Bug fixes that affect performance
Miscellaneous:
Door opening will be much faster (STILL TESTING)
Perception skill now increases with objects that you have picked up, not just discovered
The game can now only be ran through the launcher
Added window mode selection to the launcher settings (exclusive fullscreen, borderless)
Pressing O once now displays the session end timer, pressing it twice shows the list of extraction points
10 minutes before the end of the raid, the timer will turn red
Added high ping notification (upper right corner). It will be displayed if the ping exceeds 100.
