[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
Hey Fokka,
ich habe bisher mit überhaupt nix geregelt, der läuft ab Werk nur 10 sec. dann hört er auf. Das ist das was mich stutzig macht.. :wink:
wenn ich das BIOS flashen will, muss ich da die Bios Versionen Stück für Stück flashen?
Habe das Standard Bios von Dez. 09 bisher drauf und frage mich nun, ob ich sofort das aktuellste flashen kann oder ob ich Bios Version für Bios Version flashen muss.
Vielen Dank!
Direkt das aktuellste drauf. Und am besten vorher und nachher einen CMOS Reset machen.
danke, finde nur grad kein programm um eine .bin datei zu brennen^^nero10 sagt nein und cdrwin8 sagt auch nein... bräuchte anscheinen immer ein cue datei...
Brennen??? :fresse:
Äh, das is aber kein Image diese .bin-Datei.
Bei evga gibt es mehrere Methoden. Deine .bin kannste auf nen Stick packen und von da aus aktualisieren.
Für die CD/DVD-Methode gibt es extra eine ISO-Datei zum Brennen bei evga.
Greet
http://www.evga.com/support/drivers/default.asp?switch=2
ah lol ^^dann such ich mal weiter... prob ist, dass ich atm kein stick habe, deswegen wollte ich die cd methode nehmen :d Danke dir Fokka :)
€: man war das ein peinlicher Fehler^^hat mit der Iso super geklappt :d
Wird bei euch bei Lukü die Nortbridge auch so Warm? Also der Kühler?
Brauch wer von euch nen ek fullcover?
Ja, wurde er. Hab dann erstmal im Bios den Turbo-Mode und Speedstep enabled. Jetzt taktet er zwischen 1,6 und 2,8Ghz munter hin und her, aber ist bei weitem nicht mehr so warm wie vorher.
Und warum geht der EK jetzt wieder weg??
weil ich 2 habe^^einen gebrauchten und einen neuen für mich^^... ok, da schaue ich mal in das BIOS, habe schon angst bekommen, dass vllt Wärmeleitpaste oder so nicht richtig ist^^aber das erklärt ja dann auch was
Jetzt nur noch einen ! ;) Ich habe mir auch nen LE zugelegt. Nach 2 Tagen des Testens läuft es nun endlich auch im OC bei mir. Die Cpu ist zwar nicht die beste und das Board ne echte Zicke, aber 4ghz primestable sind jetzt kein Problem mehr.Bei mir war wohl der Knackpunkt, dass ich den QPI-VCore auf 1,35V anheben musste.
Naja jetzt läufts ja endlich und die Optik entschädigt für einiges :shot:
Btw .. recht still hier ! Alle wieder auf Asus umgestiegen ?
Ja habs gelesen, kann dir da allerdings auch nicht wirklich helfen. Ich habe bei mir alles über nen bigNG gesteuert und nutze keinerlei Anschüsse am Board. Einzig die Einstellungen im Bios [SmartFan Function] kannst du zum Einstellen benutzen. Wenn dort das Board unter die Anlaufspannung deines Lüfters regeln sollte, so ist es klar, wenn er nicht mehr läuft. Hast du dort mal versucht, den Fanspeed manuell einzustellen ?
Umsteigen auf Asus??? :eek: :lol:
Niemals... mein Board rennt zur Zeit mit 230MHz BCLK (also real 229.4MHz)...
Das geb ich nicht mehr weg. War noch nie so zufrieden mit einer anderen Board-CPU Kombi.
19x230 ist schon was feines. RAM läuft zwar "nur" auf 1835MHz, dafür aber 7-8-7-21 1T und der UC liegt bei 3900 :bigok:
Ich rück davon nix raus gegen so ein komischen Anus Teil... Niemals :d
Bios-Template
Dummy OC [disabled]
>Memory Feature:
Memory Frequency [167MHz/2:8]
Target Memory Frequency [1840MHz] ---> 1835MHz real
Parameters
tCL Setting [7]
tRCD Setting [8]
tRP Setting [7]
tRAS Setting [22]
tRFC Setting [59]
Command Rate [1T]
>Voltage Control:
CPU VCore [1.40625V] ---> 1.294V unter Last
CPU VTT Voltage [+200mV]
CPU PLL VCore [1.80V]
QPI PLL VCore [1.225V]
DIMM Voltage [1.64V] ---> 1.66V real
DIMM DQ Vref [+0mV]
IOH VCore [1.225V]
IOH/ICH I/O Voltage [1.5V]
ICH VCore [1.15V]
>CPU Feature:
Intel SpeedStep [Enabled]
Turbo Mode Function [Disabled]
CxE Function [C1E]
Virtualization Technology [Enabled]
CPU Clock Ratio [19 X]
CPU Host Frequency(Mhz) [230MHz] ---> 229.4MHz real
Target CPU Frequency [4370MHz] ---> 4359MHz real
Target Memory Frequency [1840] ---> 1835MHz real
MCH Strap [1867MHz]
CPU Uncore Frequency(Mhz) [3910MHz] ---> 3900MHz real
CPU Clock Skew [100 ps]
PCIE Frequency(Mhz) [105]
Nicht viel anders, als das auf der ersten Seite :)
So so der DJ gibt seine Sachen nimmer her :d
Kann sein das ich auch bald wieder von der partie bin denn das Anus Rampage II Gene ist nicht so mein Ding und überlege gerade das Micro zu kaufen, dann hast wieder verstärkung hier im Threat :d
Mal sehen wo eins Lieferbar ist und ob ich mein Rampage los bekomme.
Ja prima. Hau weg das Anus. :d
Bei mir gibs nix mehr außer EVGA. Die Tage hab ich ein DFI verbaut, das ist im direkten Vergleich zum LE mal 'ne totale Zicke. Mal ganz ab von dem BIOS...
Ja wenn es aus der RMA kommt verkauf ich es und heute Abend bin ich schlauer was das Micro angeht :d
Mhh, hatte heute meinen zweiten Systemabsturz. Der erste ist zwar schon ein wenig her, aber ist natürlich schon blöd.
Mit was für einem Fehler Code wenn ich Fragen darf ? Bluescreen oder was ist passiert ?
Kein Fehler Code, kein Bluescreen, er ist einfach ausgegangen.
Ich habe dabei nur mit Powerpoint gearbeitet, also ausgelastet war er kein bisschen
"autom. Neustart bei Fehlermeldung" abschalten. Dann zeigt er auch was an.
Yayyyyyyyy...
Willkommen zurück :bigok:
@*Luke*: Füll doch mal das BIOS Template aus. Vllt findet man dann direkt nen Fehler.
Thx DJ
@Luke mach mal das was Fokka vorgeschlagen hat und beim nächten Abschalten sieht den Fehler Code und dann kann man evtl. direkt sagen was es ist.
Kann aber evtl. zu wenig Nb Spannung sein.
hei hei hei, Frage:
beim neuen Bios was bewirk / bzw ist der Nutzen des AC/RC Einstellung bei den Ram Timings?
STER187
Moin,
mal eine kleine Frage am Rande....
Hat von euch irgend jemand in diesem Monat ein SLI LE bestellt und schon erhalten? Ich warte nun schon 22 Tage auf das Board und nun auf 1 mal ist es nicht mehr lieferbar bei dem Shop -___-
Moin,
Ich warte die ganze Zeit darauf das es überhaupt mal Lieferbar ist :hail:
Laut Auskunft von EVGA sollten die jetzt dann wieder lieferbar sein. Man bin ich froh mein Micro doch noch bekommen zu haben :fresse:
Ihr müßt euch wohl doch noch ein wenig gedulden.
