[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
Okay, dann messe ich bei Gelegenheit +350mV auf meinem Brett, gebencht hatte ich schon, aber noch nicht nachgemessen!:fresse::wink:
moin moin
kann mir jemand das neuste bios hochladen, irgend wie kann ich nichts von der Evga Seite laden, Fehler ist: "Seite nicht gefunden"
und evtl Links zu den neusten Treiber für Chipsatz, Lan und audio
ui Links gehn nicht :( sorry Cartago
bezüglich Spannungen:
Eleet(BIOS) / DMM
Vcore / 1.39(1,4) / 1,324
Vdim / 1,65 / 1,642
Vtt / 1,35 / 1,324
IOH / 1,125 / 1,13
CPU PLL / 1,8 / 1,715
QPI PLL / 1,15 / 1,094
die Roten find ich echt schlimm...
Last wurde erzeugt mit MSI Kombustor und OCCT LINX 90% RAM (with Vdrop- disabled)
:d alles wird untervoltet nur nicht die IOH
Cartago ich mach dir grad ein Paket fertig. Neuestes Bios und LAN-/ Audio-/ Chipsatztreiber.
Ich editier den Download-Link dann gleich hier rein.
Download-Link
Habe meins unter Wasser sonst hätte ich dir sagen können was unter Luft so anliegen würde. Fast 70° sind aber zuviel.
und was hast unter wasser? und welche kühler der von EK oder Mips? der von Ek passt mir besser schade nur das kein Plexi top drauf
edi: habe geschwind den Hecklüfter gedreht damit er ins case bläst und gleich 10° weniger, ist schon was
Der Gedanke kam mir gerade auch. Würde mich schon mal Interessieren ob die NB dadurch so viel wärmer wird.
kA, wie das bei den "kleinen" boards ist, beim classified kann die nb auch mal 83°C warm werden :fresse:
aha, andere frage wieso zu teufel blink die LED im Reset Knopf genau im takt der HDD?`ist das normal? und bei mir funz der Reset Knopf überhaupt nicht weder am case noch der auf mobo, absolut keine Reaktion????
Ja das ist die LED für die HDD, so wie beim Power-Knopp die Power-LED drin ist.
Das mit dem nicht reagierenden Reset ist dann wohl ein Fall direkt für den Support von EVGA. So einen Fehler hatte ich bei 4 LE's noch kein einziges Mal.
oh nee, nicht schon wieder was defektes aus dem MP, vielleicht weiß jemand ein andere Rat? wie lange dauert solche rma? wo soll es geschickt werden?
RMA dauert normal 2-3 Wochen.
Aber kontaktier den Support erstmal so. Irgendwo im Thread gabs eine Telefonnummer für den deutschen Support, die sind eigentlich immer sehr freundlich und ums helfen bemüht.
Ich drück dir die Daumen, dass du es ohne RMA hinbekommst. (Die geht dann übrigens direkt über EVGA Deutschland)
Meins geht nun auch in RMA -> bekomme endlich einen neuen Sockel :banana:
Preis: 60,-
Hab zwar schon eine RMA Nummer bekommen aber weis noch net wo ich es hinschicken soll ...
Trotzdem schonmal besten Dank an die 2 freundlichen Kollegen vom EVGA Support :wink:
Rennt die kiste mit 3x 285 GTX pci technisch 16x-16x-8x oder 16x-8x-8x ?????
Leute brauch kurz eure Hilfe, habe gestern das neuste bios drauf gemacht und ich kann mein Ram nicht mehr auf 2000MHz fahren, egal was und wie ich es mache es wird immer runter auf 1600MHz gestellt. OC Recovery ist aus und trotzdem wird der 2:10 teiler nicht übernommen
Stell mal die Turbo Performance auf Disabled. Meine aber nicht den zuzätzlichen Multi.
hm funzt nicht, wird einfach nicht übernommen. CPU und RAM macht das locker mit hatte ich auch schon vor bios update gehabt, jetzt geht es nicht
CxE solltest auch auf C1E oder Auto lassen, dann ging es damals bei mir auch :wink:
