[Sammelthread] Gigabyte GA-EX58-UD5 / Extreme (Intel X58) [5]
[blockquote]
Spezifikationen Spezifikationen
CPU
  • LGA 1366 socket for:
    - Intel® Core i7 920/940 & 965XE
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 24 GB, DDR3 2130(*)/1860(*)/1600(*)/1333/1066/800
  • Triple Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
Expansion Slots
  • 3 x PCIe 2.0 x16 (support x16/x16 or x16/x8/x8)
  • 1 x PCIe x4
  • 1 x PCIe x1
  • 2 x PCI 2.2
BIOS
  • Dual-Bios
Audio
  • HD Audio, 8-channel
Storage Interface
  • South Bridge:
    - 6 x SATA 3Gb/s connectors (SATA2_0, SATA2_1, SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 6 SATA 3Gb/s devices
    - Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
  • GIGABYTE SATA2 chip:
    - 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
    - 2 x JMB322 chips (Smart Backup):
    - 4 x SATA 3Gb/s connectors (GSATA2_0, GSATA2_1, GSATA2_2, GSATA2_3) supporting up to 4 SATA 3Gb/s devices (Note 5)
    - Support for SATA RAID 0, RAID 1 and JBOD
  • iTE IT8720 chip:
    - 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Internal I/O Connectors
  • 1 x 24-pin ATX main power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x floppy disk drive connector
  • 1 x IDE connector
  • 10 x SATA 3Gb/s connectors
  • 1 x CPU fan header
  • 3 x system fan headers
  • 1 x power fan header
  • 1 x North Bridge fan header
  • 1 x front panel header
  • 1 x front panel audio header
  • 1 x CD In connector
  • 1 x S/PDIF In header
  • 1 x S/PDIF Out header
  • 2 x USB 2.0/1.1 headers
  • 2 x IEEE 1394a headers
  • 1 x power LED header
  • 1 x chassis intrusion header
  • 1 x power switch
  • 1 x reset switch
Rear Panel I/O Connectors
  • 1 x PS/2 keyboard port
  • 1 x PS/2 mouse port
  • 1 x coaxial S/PDIF Out connector
  • 1 x optical S/PDIF Out connector
  • 1 x IEEE 1394a port
  • 1 x clearing CMOS switch
  • 8 x USB 2.0/1.1 ports
  • 2 x RJ-45 ports
  • 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone
Features
  • Dynamic Energy Saver Advanced
  • Ultra Durable 3
  • Dynamic 6-Gear Swithching
  • 45nm CPU Optimized
  • 3 way CrossFireX
  • 3 way SLI support
  • Debug LED
  • Dolby Home Theater
  • Blu-ray Support
  • OV-Alert LED, OC-Alert LED, TMP-Alert LED
  • Hybrid Silent-Pipe 2 (nur das Extreme!)
BilderBilder
Bilder vom EX58-UD5
Die Verpackung und das Zubehör
Das BiosDas Bios (bei UD5 sowie Extreme identisch!)
Erste OC ErgebnisseErste OC Ergebnisse
Ersten eigenen OC Ergebnisse mit einem Retail Core i7-920 & Geforce 8800GTS G92 SLI
Voltage ModsVoltage Mods & read Points
*Jede Modifikation geschieht auf eigene Gefahr und führt zum erlöschen der Garantie!
DownloadsDownloads
Das Flashen geschieht wie immer auf eigene Gefahr!
Bios Downloads EX58-UD5
  • Bios F2
    - Auslieferungsbios
  • Bios F3
    - Fix CPU compatibility issues
  • Bios F4
    - Fix S3 resume turbo mode issue
    - Fix DualBIOS recovery issue
    - improve System Stability
  • Bios F5
    - Improve VGA card compatibility
    - Improve S3 resume compatibility
    - Intel®Core™ i7 processor D-0 stepping support
  • Bios F6a (beta / Testversion)
    - keine Changelog
  • Bios F6b (beta / Testversion)
    - Fix: QPI/Vtt Kaltstart Bug größer 1.280V
    - Bug: S3 fehlerhaft (E1) bei OC
  • Bios F6c (beta / Testversion)
    - Info: Neue Intel® AHCI ROM Version 1.20E... keine Wartezeit mehr !!!
    - Bug: S3 bei OC teilweise immer noch fehlerhaft (E1)... er wird daran gearbeitet !
Bios Downloads EX58-Extreme
  • Bios F3
  • Bios F4
  • Bios F5
  • Bios F6d (beta / Testversion)
    - Info: Erfolgreich geflasht...
  • Bios F6e (beta / Testversion)
    - keine Changelog
Thx @ JZElectronic für die aktuellen Bios Versionen :)
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 16 im Handbuch nachschlagen.
Wichtige LinksWichtige Links
Garantieverlängerung für in D, A, CH gekaufte Mainboards
Bedingung hierfür ist die vorangegangene Registrierung des Produktes innerhalb von 12 Wochen nach Kauf.
[/blockquote]
hassu mal die anderen slots durchprobiert?
hmm nicht wirklich. da ich ne gtx460 mit 4 slotverschlingenden thermalright shaman nutze ist das die einzige möglichkeit.
ich schicke die karte zurück. mit 2.0 kabel funktioniert das teil einwandfrei. mit 3.0 habe ich jetzt noch wackelkontakte dazu bekommen. platte meldet sich permanent neu an. hd tach läuft nicht mal durch. kabel in 2.0 buchse funktioniert.
Ich habe nu noch was... hab mal die F13q Biosversion eingespielt und stelle nun fest, dass meine Spannung unter Last nicht mehr passt. Bin mit der Dynamic Vcore schon auf +0,1500V. und komme immer noch nicht auf meine benötigten 1,320V unter Last laut CPU-z. Hab ich was falsch eingestellt???
ok ok... erledigt... habe ein paar posts durchgelesen... mit der LLC ging zurvor nie der Dynamic VCore Part. Jetzt mit LLC klappt es auch... Trotzdem muss ich ein wenig mehr einstellen. Na ja solange alles stabil läuft... egal.
6x2 kann dazu führen das die Timings und sogar die Geschwindigkeit entschärft werden müssen!
Ich nutze zur Zeit 4 Riegel (2gb) mit allem Komfort!
Bei 6 Stück muss ich zurück auf 800Mhz
also mit 3x4GB hab ich keine erfahrung, aber mit 6 Modulen a 2GB hatte ich nur Probleme. Hab dann 3 Riegel wieder verkauft. Musste soviel Spannung geben und trotzdem Abstürze bzw. Bootprobleme.
Huhu Leute. Hab ein kleines Problem mit neuen RAM-Riegel für das UD5. Habe jetzt schon ein Thread im Speicher Subforum erstellt aber mir dann gedacht dass es vlt. besser gewesen wäre hier zu posten.
hier ein Link zum Thread
Ich glaube eh nicht mehr dass es mit diesen Riegeln noch hinhaut. Werde sie wohl zurückschicken und bräuchte eine Kaufempfehlung.
Vlt. könnte mir da jemand weiterhelfen.
Greets
Greets
ich hab keine berechtigung darauf zuzugreifen... link ist falsch. such jetzt auch nicht rum.... habe aber mit corsair bislang nur gute erfahrungen gemacht.
@Wilhelm
leider nein
@JZ_
ich habe gerade begeißtert gelesen das es einen efi bios für das GA-X58A-UD5 rev.2.0 das Fe1
würdest du mir vill die zugangsdaten zukommen lassen? ich verspreche auch hoch und heilig das ich nicht maule :d
Ich habe mir das FF7 für das UD3R herunter geladen u. ich kann es nicht flashen, weil das Bios mault *Wrong Size*
@ Black.
Du kannst es herunter laden, musst nur genau lesen. :wink:
Ich glaube es wird dir auch so ergehen, solange man den *Kniff* nicht erklärt bekommt, lass ich von allem die Finger.
Ich weiss, das ich hier mit dem Brett falsch bin, aber das Thema ist das selbe... ;)
Gruss Micha.
@Mmichel
firma dankt und als keinen bonus von mir
das neue @BIOS benutzen, damit geht es
und um ehrlich zu seinen, efi hatte ich mir iwie anders vorgestellt ...
oberfläche ist 1:1 die alte, läuft aber mit den alten settings stabil
Danke dir für den Tip.
Soll ja nur den Bootloader beinhalten, was immer jetzt davon zuhalten ist.
Die richtigen EFI Biosse sind ja ca 4000 Kb gross.
Aber wenns stabil läuft ;)
Hast du jetzt auch beim Start das Backupbios flashen können ?
Gruss Micha.
Glaube *ALT F12 oder ALTGr F12*
Letztenz wurde mir es nochmal erklärt...... schäm.... .
Gruss.
Meine Herren es ist immer wider ein vergnügen mit Ihnen zusammen zu arbeiten :d:d:d
Also er hat das Backupbios ohne Probleme geflasht, 2048KB ist es groß ;)
Naja vielleicht lässt man uns noch in den Genuss eines "echten" EFI´s kommen.
Glaube ich nicht so ganz, denn dann müsste das Eprom grösser sein.
Aber Wunder geschehen immer wieder.
Gruss.
naja scheinbar sind die Eprom ja mindestens 2048Kb groß ... vielleicht überrascht man uns ja
msi hat, wenn ich mich recht erinnere, auch mal beta´s eines EFI´s für ein mb raus gebracht welches normalerweise mit einem üblichen bios arbeitet
Ich habe gerade das Bios mit Q Flash aufgespielt u. das Tool zeigt 8 Mb :)
Scheint doch was im Anmarsch zusein...
Gruss.
Ich weiss nur was von der Rev 2.0
Aber JZ wird vielleicht noch ein Statement abgeben ?!
Brauchen wir nicht mehr.
Der neue Bootloader sorgt dafür, das Festplatten über 2 Terra erkannt werden, das ist das *Geheimniss*.
Gruss.
Servus
Hab gerade das F13q Modbios geflasht. Bis jetzt sehr geil. Alles settings aus meinem geliebten F9p gehen ohne probleme. Gerade läuft Prime, DVID geht genauso gut wie mit dem alten Bios. Teu teu teu... hoffen wir das es so bleibt.
Wie schaut es eigentlich mit der Garantie bei nem UD5 aus, war da nicht was, dass man die verlängern kann, wenn das Board bei GB registriert ist?
Habe vor mein R2E gegen ein UD5 auszutauschen...
Zum übertakten taugt das UD5 ja auch?
Kommt das UD5 mit meinen Komponenten klar? Besonders geht es mir um das Modu82+ II mit Lüfternachlauf, den Speicher (Kingston HyperX 2000Mhz Cl9) und um den W3520..
Vielen Dank!
Gruss
xXRadioaktivXx
garantie bekommst du nur soweit ich weis, wen du nach kauf den garantie erweiterung ausfüllst, innerhalb des 1 monats oder wahren es 14 tage .... dan wird erweitert von 2j auf 5j
Wie ich nun erfahren musste, haben das leider die wenigsten gemacht :(
Deswegen wäre das UD5 für mich eine gute Alternative zum R2E...
vielleicht finde ich ein gebrauchtes mit den 5 Jahren Garantie.
wann kommt denn endlich ein neues bios für das extreme ??
ich habe immer noch das F13o drauf, da mein pc mit dem F13q immer abschmiert !!
