eratte
Ja dann lese dir mal die Aussagen von AMD dazu durch, und z.B. den Warnhinweis wenn man Ryzen Master startet.
https://www.hardwareluxx.de/index.p...st-overdrive-der-neuen-ryzen-prozessoren.html
"PBO is absolutely overclocking. It's not on by default, and it breaks warranty like manual OC. Max boost is max boost, too, either what's on the box or what you've set as an override with PBO."
