SuicidePhoenix
Semiprofi
GOOC2010 live , sieht man nicht sonderlich viel aber wollt es trotzdem posten.
David von den Benchbros ist auch dort, gogo
Du benchst aber auch wie ein Irrerja bei den Temperaturen im Moment ist nicht viel rauszuholen unter Luft/Wasser...
Wenn das alle 300 Mitglieder so machen würden
We have some good news about the free version of the benchmark. Thanks to MSI's support and FutureMark's will to change their mind following the 3D Mark Vantage free version complaints on the net, 3D Mark11 free version won't be limited like 3D Mark Vantage's free version was, you will be able to run the benchmark multiple times, and probably be able to view the score without uploading the results to FutureMark's ORB first.
QuelleAFAIK they will allow you to run the benchmark as many times you desire, and you will also be able to submit the scores to your free ORB account, but you will only be able to have one PUBLISHED ( public result with compare URL ) score each time.
