Habe meinen i5 750 jetzt Stabil bekommen auf 3,37 Ghz da geht aber noch ne Menge mehr werde noch weiter testen.Und dann schreiben was daraus geworden ist.
Mein Bios Template
BIOS Version:
Ai Overclock Tuner .................. [Manual]
CPU Ratio Setting .................... [21]
Intel SpeedStep Tech .............. [Disable]
Intel TurboMode Tech .............. [Disable]
Xtreme Phase Full Power Mode ... [Enable]
BCLK Frequency ...................... [160]
PCIe Frequency ....................... [100]
DRAM Frequency ..................... [1600]
QPI Frequency ......................... [Auto]
DRAM Timing Control: [Manual]
1st
CAS# Latency : 9
RAS# to CAS# Delay : 9
RAS# Precharge : 9
RAS# ActivateTime : 24
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
CPU Differential Amplitude ............ [Auto]
CPU Clock Skew ......................... [Auto]
____________________________________
CPU Voltage Mode ...................... [Manuell]
Offset Voltage ........................... [-----]
Fixed Voltage .............................[1,120v]
IMC Voltage .............................. [1,11]
Dram Voltage ............................. [1,50]
CPU PLL Voltage ......................... [1,80]
PCH Voltage .............................. [1,05]
Load-Line Calibration .................. [Disable]
CPU Spread Spectrum ................. [Disable]
PCIE Spread Spectrum ................ [Disable]
Intel C-STATE Tech .................... [Disabled]
Da geht noch was !
![](http://sig.sysprofile.de/gfx/sysp-77386.gif)
