Manchmal ist weniger mehr
VTT, falls sie das ist, auf 0.975V
standart ist bei mir 1,050
---------- Beitrag hinzugefügt um 20:50 ---------- Vorheriger Beitrag war um 20:49 ----------
System Agent Voltage ist das evt bei dir?! Da ist 0,925v standart bei mir
VCCIO: more commonly known at QPI/VTT voltage, this is the VTT voltage. Formally known as
Processor Power for I/O it is the voltage for the integrated memory controller as well as the PCI-E
controller. While Intel’s Maximum is 1.05 +/- 3% = 1.08v, you can go higher, much higher. I would
recommend staying below 1.2v for 24/7 use, but depending on the quality of the IMC on your chip, I
have seen 2133 MHz done on as little at 1.1v. I used 1.12v for overclocking my Dominator 1600 MHz to
1866 MHz, and it did it without any problems. Do realize that this voltage contributes heat as well to the
whole thermal package.
Baller doch mal VTT auf 1,1 und VCCSA um 2-3 Schritte nach oben.
Außerdem kannst mal die PLL runter setzen auf 1,76.
Was ist denn VCCSA?
