Alter Falter jetzt bin ich aber mal platt
Heute (Samstag, nur für die dies nicht mitbekommen haben) an Seasonic um 10:20 geschrieben....
11:04 die Antwort!
Hi Frank,
Nice Mod Frank! I thought Eheim was only for fish tanks.... but looks great!
IMO, for your system, it really depends on what is your wattage consumption and how comfortable you feel about not having a fan. Many people swear that you must have a fan but in our view, that is not necessary when the consumption is low considering notebook adapters are without fan, even at 75w consumption.
The X-560 will run in fanless mode up to around 120 watts and thereafter, when the internals heat up, the fan will start to rotate. The X-400 & X-460 are actually baed on a 850w circuit so it is very much "over engineered" to withstand the temperature stresses. You can look here for some reviews...
Test for the X-400FL:
Seasonic X-400 Fanless PSU | silentpcreview.com
Seasonic X-400 Fanless Power Supply Review | Hardware Secrets
Stress Test:
Fanless PSU Torture Test Roundup | silentpcreview.com - Cached - Similar
As you do not OC, then most likely your PSU consumption will not be stressed. As well, the PSU comes with dual mounting positions so you can turn the PSU as you wish, so I would suggest the X-460FL for total silence but then again, the X-560 is not too loud either....
I hope I have answered your questions, if you have any further issues, please let me know.
Regards,
Walter
