kann man eig was gegen die crew problematik machen wenn man die crew eines anderen Light Tanks auf einem type 62 leveln will ? die haben ja immer andere spezialisierungen...
- - - Updated - - -
- Havok will use a separate core thread
- multicore support: right now, developers are working on transferring some client and graphic calculations to separate threads. It takes a lot of work, devs are working on it for quite some time and the work will not be finished anytime soon.
- new motion physics will bring realistic tank movement, tanks will be able to perform “controlled drift”
- there will be a SD and HD texture split in the future the way it was made in 9.3 – SD textures have half the resolution and will be supplied as “standard” for everyone, while HD textures will be available for optional download. This was decided because there is very little difference between the ways HD and SD textures look.
