Hoffentlichtwixter schrieb:Naja da Alternate ja die Lieferung erhalten hat, wird Hardwareversand die wohl spätestens morgen auch haben, oder?
=BAM= schrieb:was mich so ewig stört, ist das meine grafik immer mit vollen lüfterdrehzahlen läuft ! so viel ich weiss is das bei allen 7900gts so
twixter schrieb:@Jokerboy
Nur der BIOS Edit geht das nicht. Liegt aber an NiBiTor. In der nächsten Version sollte das möglich sein, dann werden auch die Speichertimings erkannt.
t024484 schrieb:I have tried to bundle all the wisdom of previous mails in the pictures plus the explaination below.
Resistor "J" is a 5Kohm resistor, and causes the Core Voltage, Vgpu, to be 1.2Volt in the unmodified situation.
Replacing this resistor with a 50Kohm resistor, changes the Vgpu to 1.5Volt.
In the picture hereafter, you can add to this voltage, thus being 1.2 or 1.5Volt, another .05, .1 and .2, either as a single step or as a combined set of steps.
So your options are: 1.2, 1.25, 1.3, 1.35, 1.4, 1.45, 1.5 or 1.55Volt
and with the 50Kohm mod: 1.5, 1.55, 1,6, 1.65 and 1.7Volt as a maximum.
Resistor "H" measures 3.5 Kohm, and controls the Over Current Protection.
If you suspect the OCP giving you trouble, you can double this resistor to 6K8 Ohm. I had no problems, so you can probably leave it as it is.
Resistors "I" are said in the previous thread to disable the Over Current protection . THIS IS NOT THE CASE.
These resistors. measuring 1,8Kohm, are meant to balance the current between the two pair of switching Mosfets to carry an equal amount of load.
Leave them, or replace them with values of 3,9 kohm which should only be done if you are having mysterious problems.
And than comes a very important Mod, being resistor K.
This resistor measures ca 80Kohm, and sets the switching frequency.
Connecting a 100Kohm resistor in parallel, almost doubles the switching frequency, and solved my problems completely.
You could eventually do this mod by pencil, try to get the value down to approx. 45Kohm.
The next picture shows the Mods to change the 1.2 or 1.5 Volt to a higher value.
C gives 0.05 Volt increase when shorted to ground
B gives 0.1 Volt increase to ground and
A gives 0.2 volt increase to ground,
Plus any combination of A, B and C.
I have given two possible routes to achieve your Vgpu increase.
Use either the upper or the lower set of traces.
When you only use the red trace, you will have 0.05Volt increase. (1.25V or 1.55Volt)
When you use Red plus Yellow, you will have a 0.15Volt increase (1.35Volt or 1.65Volt)
When you use Red, Yellow plus Purple, you will have a 0.35Volt increase ( 1.55Volt, do not use it in combination with the 50Kohm resistor mod)
Of course you can also connect a single point to get what you want, f.i. ground point B to get 1.4Volt.
Although a bit more difficult to achieve, it is still doable.
Go with conductive ink with a large U around all the other points towards ground.
You can either do the modding with a thin wire and solder, or with conductive ink.
Do not worry about all the points between C and B, they are not connected to anything, and are used to keep the lines as simple as possible.
twixter schrieb:Naja die GT XXX hat 15 MHz mehr RAM Takt als die Standard GTX und 90MHZ weniger Coretakt. Sie ist eigentlich schon fast @ GTX Niveau.
falconx schrieb:wie sieht es denn eigentlich mit dem arctic kühler aus ? kann man sich den antun ? der bläst ja nun mitlerweile die luft nur noch aufs mobo und nicht mehr nach hinten raus. find das war eine der blödesten ideen die ein designer haben kann
twixter schrieb:Leute. Der 7900 Test von CB ist da.
Mal abwarten, wie sich das entwickelt.Nach Rücksprache mit MSI können wir dem Testsample jedoch ein Defekt der Lüftersteuerung attestieren. Ein neues Exemplar befindet sich auf dem Weg zu uns und wir werden die Lautstärke erneut kontrollieren.
dirtdevil1975 schrieb:Tue dir nen Gefallen und lass den Acccelro im Laden!
Habe ihn bestellt um ihn zutesten. Hatte vorher auf meiner (noch) 7800 Gtx nen Silencer drauf.
Also.Der Accelro ist Klasse leise! Er läuft auch über die Lüftersteuerung! Sehr fein.
ABER . Die warme Luft blässt er direkt vor das Board und das schlimmste direkt auf den Chipsatz. Vorher hatte Ich den Chipsatzkühler schön auf 5 Volt und max 40°C. Jetzt kämpfe Ich mit voller Drehzahl des Chipsatzes gegen 50°C Temeratur. Und es wird erst Sommer.
Ich muss mein flüssterleises System wieder ändern.
Für alle die nen Silencer oder Vf 700 haben, können auf dieses Teil verzichten.
Ich war bisher wirklicher Artic Fan, aber dieses Teil ist echt Schrott..... Meine Meinung! Dann doch lieber den neuen VF 900 .
