Assetto Corsa 1.3 Changelog
- 64bit build
- Car physics is now calculated in separate threads
- Fixed KERS disabled in pitlane
- Added soft locks (use [SOFT_LOCK] ENABLED=1 in system/cfg/assetto_corsa.ini)
- Added support for DRS zones
- acServer is now stressing much less Go' GC and should offer more stable performances
- Added FORCE_TGT to force low res timer in assetto_corsa.ini
- acServer is now using Go 1.5, faster GC
- Added server welcome message
- Fixed gear ratio appearing with a double "/" in setup screen
- Fixed acServer unable to read ini values with a "=" character (ex AUTH)
- Fixed driver name displayer not obeying to saved settings in MP
- Fixed acServer not creating "results" folder automatically
- New algorithms to calculate skid volumes and pitch, now working globally in the entire simulation
- Added grain and blister readings in the setup info screen
- Added downshift protection to gearboxes
- Lap count is now reported using 16bit unsigned integer to server plugins
- Now using triple buffer when vsync is on to reduce latency
- Exposure settings are now persistent
- Fixed audio clicks on surface events
- Tyre flat spots are now taking into account tyre softness
- Windscreens now receive shadows
- ksEditor: now it uses the same ingame engine.
- ksEditor: added project menagement
- ksEditor: added user personalizations
- ksEditor: added floating windows and layout system
- ksEditor: added Weather and PPfilter loader
- ksEditor: added recent files/project management
- ksEditor: added node filter in scene panel
- ksEditor: added Material by Texture in Materials panel
- ksEditor: added scene icons and side function buttons
- ksEditor: added texture detail on Material panel
- ksEditor: added Texture Review windows in Utilities
- ksEditor: fixed reload texture function
- ksEditor: now the default CultureInfo is en-US (number format, ect)
- ksEditor: added FOV, Near Plane Slider, Mouse sensitivity, camera angle and position under Viewport
- ksEditor: added Dashboard tab
- acServerManager: removed some upper limits on parameters
- acServerManager: preset name/description is more clear
- acServerManager: added welcome message
- acServerManager: added qualify limit
- acServerManager: added fixed setup management
- acServerManager: fixed upload on ftp. Now cfg folder is not deleted.
- Fixed driver textures on serveral cars
- Fixed circuit outline on track selection UI
- Camera Dev App now save F1 cameras' exposure and pitch, F6 cameras' exposure, fov and position and angle
- Removed background from Performance Delta App
- Redesigned and faster code for logging
- Updated Tyres V5 for GT2 and GT3 cars, should give less understeer.
- Zonda R and Ferrari 599XX and Formula Abarth now have V5 tyres.
- Less lift off oversteer for Evora S on street tyres V5
- GT3 and GT2 cars updated aero stalling for front splitter and diffuser
- GT3 slight performance balancing
- Mclaren MP4 GT3 tyre corrections
- Fixed TC digital item showing 0 based index when multiple TC level are available
- Now showing Cold and Hot pressure readings in setup status
- Added "NA" for IMO temps reading when no set has been swapped out
- Added support for track dynamic objects
- It is now possible to join a server using admin passoword and be automatically granted admin rights
- Joining a server with admin password will override the session "closed" status
- Added "ban_id" admin command to ban a user and send straight to blacklist
- Remote cars in multiplayer now generate skidmarks
- Fixed EDL wrong calculation order
