cstkl1 schrieb:tested just now with 4.2ghz HT on on two different procs
one proc can do it at 1.375v set
the other uses 4.2ghz HT OFF at 1.3625v set..
whatever voltage i use doesnt work with HT ON tested up to 1.52v
will test with one more proc tommorow
to see whether is this a one off case.
Helli schrieb:yepp, the TDP Limit is gone - for me.
Now i can do 21x210 (4,4GHz) Vcore 1,55 with my i7 920 and Load on all
8 cores. With Bios 1001 and lower the Multi decreases to 20x if i start
Prime95.
hatte ich leider auch mit dem locked.
sagt mal den punkt ``cpu turbo power limit`` hat man aber dann erst ab dem neuen bios , oder hab ich was falsch verstanden ?
wegen dem screen von subaru....
