Ja hier bitte:
Thermal Management Control.....: Enabled
PPM(EIST) Mode.................: Enabled
Limit CPUID MaxVal.............: Enabled
CIE Function...................: Enabled
Execute Disable Bit............: Disabled
Virtualization Technology......: Disabled
Core Multi-Processing..........: Enabled
CPU VID Control..................: 1.2350v Auto
CPU VID Special Add Limit........: Enabled
CPU VID Special Add..............: 107,56
DRAM Voltage Control.............: 1,90V
SB Core/CPU PLL Voltage..........: 1.55V
NB Core Voltage..................: 1.28V
CPU VTT Voltage..................: 1.23V
Vcore Droop Control..............: Disabled
Clockgen Voltage Control.........: 3.45v
GTL+ Buffers Strength............: Strong
CPU GTL 0 REF Volt...............: 0,67
CPU GTL 2 REF Volt...............: 0,67
CPU GTL 1 REF Volt...............: 0,67
CPU GTL 3 REF Volt...............: 0,67
NB GTL 0 REF Volt................: 0,67
NB GTL 1 REF Volt................: 0,67
FSB Vref.........................: 21
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss...........: Enabled
O.C. Fail retry Counter..........: 1
O.C Fail Cmos Reload.............: Disabled
CPU Clock Ratio..................: 8,5x
CPU N/2 ratio....................: Enabled
Target CPU Clock.................: 4000 MHz
CPU Clock........................: 470 MHz
Boot Up Clock....................: Auto
CPU Clock Amplitude..............: 800mV
CPU Clock0 Skew..................: 200ps
CPU Clock1 Skew..................: 100ps
DRAM Speed.......................: 333/800
Target DRAM Speed................: 1130 MHz
PCIE Clock.......................: 102 MHz
PCIE Slot Config.................:
CPU Spread Spectrum..............: Disabled
PCIE Spread Spectrum.............: Disabled
Wo wohnst denn in Augsburg?
