>CPU Feature:
Thermal Management Control.......... - Enabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Enabled
Virtualization Technology........... - Disabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Fast
Enhance Addressing.................. - Fast
T2 Dispatch......................... - Auto
>Clock Setting Fine Delay Press Enter:
DLL And RCOMP Settings.............. - Manual
Ch1 Dram Defaul Skew................ - Model 3
Ch2 Dram Defaul Skew................ - Model 3
RCOMP Settings...................... - Model 1
Fine Delay Step Degree.............. - 70ps
Ch1 Clock Crossing Setting.......... - Nominal
DIMM1 Clock Fine Delay.............. - Current[1346ps]
DIMM2 Clock Fine Delay.............. - Current[1346ps]
Ch1 Control0 Fine Delay............. - Current[166ps]
Ch1 Control1 Fine Delay............. - Current[166ps]
Ch1 Control2 Fine Delay............. - Current[124ps]
Ch1 Control3 Fine Delay............. - Current[110ps]
Ch1 Command Fine Delay.............. - Current[262ps]
Ch2 Clock Crossing Setting.......... - Nominal
DIMM3 Clock Fine Delay.............. - Current[1346s]
DIMM4 Clock Fine Delay.............. - Current[1346ps]
Ch2 Control0 Fine Delay............. - Current[14ps]
Ch2 Control1 Fine Delay............. - Current[56ps]
Ch2 Control2 Fine Delay............. - Current[0ps]
Ch2 Control3 Fine Delay............. - Current[0ps]
Ch2 Command Fine Delay.............. - Current[110ps]
Ch1 Ch2 Common Clock Setting........ - Nominal
Ch1 RDCAS GNT-Chip Delay............ - Auto
Ch1 WRCAS GNT-Chip Delay............ - Auto
Ch1 Command To CS Delay............. - Auto
Ch2 RDCAS GNT-Chip Delay............ - Auto
Ch2 WRCAS GNT-Chip Delay............ - Auto
Ch2 Command To CS Delay............. - Auto
Flex Memory Mode.................... - Auto
CAS Latency Time (tCL).............. - 5
RAS# to CAS# Delay (tRCD)........... - 5
RAS# Precharge (tRP)................ - 5
Precharge Delay (tRAS).............. - 15
All Precharge to Act................ - Auto
REF to ACT Delay (tRFC)............. - 56
Performance Level................... - 9
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In........... - Auto
Channel 1 Phase 1 Pull-In........... - Auto
Channel 1 Phase 2 Pull-In........... - Auto
Channel 1 Phase 3 Pull-In........... - Auto
Channel 1 Phase 4 Pull-In........... - Auto
Channel 2 Phase 0 Pull-In........... - Auto
Channel 2 Phase 1 Pull-In........... - Auto
Channel 2 Phase 2 Pull-In........... - Auto
Channel 2 Phase 3 Pull-In........... - Auto
Channel 2 Phase 4 Pull-In........... - Auto
Write to PRE Delay (tWR)............ - Auto
Rank Write to Read (tWTR)........... - Auto
ACT to ACT Delay (tRRD)............. - Auto
Read to Write Delay (tRDWR)......... - Auto
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
ALL PRE to Refresh.................. - Auto
>Voltage Settings:
CPU VID Control..................... – 1,2200V
CPU VID Special Add................. - Disabled
CPU VID Special Add................. – 123 60% genau % weiss ich jetzt nicht lagen aber 1.248V an.
DRAM Voltage Control................ - 1.99v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.275V
CPU VTT Voltage..................... – 1.224v
Vcore Droop Control................. - Enabled
Clockgen Voltage Control............ - 3.45v
GTL+ Buffer Strength................ - Weak
CPU GTL 0 REF Volt.................. - 0.6200
CPU GTL 2 REF Volt.................. - 0.6200
CPU GTL 1 REF Volt.................. - 0.6250
CPU GTL 3 REF Volt.................. - 0.6250
North Bridge GTL 0 REF Volt......... - 0.6375
North Bridge GTL 1 REF Volt......... - 0.6375
FSB Vref............................ - 21
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Exist Shutdown After AC loss........ - Enabled
AC Shutdown Free.................... - Enabled
O.C Clock Fail Retry Counter........ - 1
O.C Clock Fail CMOS Reloaded........ - Bank1
CPU Clock Ratio..................... – 8,5
Target CPU Clock.................... - 4000 MHz
CPU Clock........................... - 470
Boot Up Clock....................... - Auto
RAM 1:1 Strap 333
