[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
im moment max 71 grad bei 1,189 vcore LINX.
So dann hab ich mal abgeschrieben. VCore unter Last sind 1.294V. Speicher die 2000er CL9 Trident. NT ein HX750.
Bios-Template
Dummy OC [disabled]
>Memory Feature:
Memory Frequency [167MHz/2:8]
Target Memory Frequency [1834MHz]
Parameters
tCL Setting [7]
tRCD Setting [8]
tRP Setting [7]
tRAS Setting [22]
tRFC Setting [59]
Command Rate [1T]
>Voltage Control:
CPU VCore [1.40625V]
CPU VTT Voltage [+150mV]
CPU PLL VCore [1.83V]
QPI PLL VCore [1.1V]
DIMM Voltage [1.64V]
DIMM DQ Vref [+0mV]
IOH VCore [1.225V]
IOH/ICH I/O Voltage [1.5V]
ICH VCore [1.1V]
>CPU Feature:
Intel SpeedStep [Enabled]
Turbo Mode Function [Disabled]
CxE Function [C1E]
CPU Clock Ratio [19 X]
CPU Host Frequency(Mhz) [229MHz]
Target CPU Frequency [4357MHz]
Target Memory Frequency [1834]
MCH Strap [1867MHz]
CPU Clock Skew [100 ps]
PCIE Frequency(Mhz) [102]
Bios-Template
Dummy OC [disabled]
>Memory Feature:
Memory Frequency [1067mhz/2:8]
Target Memory Frequency [1600Mhz]
Parameters
tCL Setting [9]
tRCD Setting [9]
tRP Setting [9]
tRAS Setting [27]
tRFC Setting [auto]
Command Rate [T1]
>Voltage Control:
CPU VCore [1,368v]
CPU VTT Voltage [+125mv]
CPU PLL VCore [1,8v]
QPI PLL VCore [1.1v]
DIMM Voltage [1,68]
DIMM DQ Vref [+0mV]
IOH VCore [1,1v]
IOH/ICH I/O Voltage [1,5v]
ICH VCore [1,05v]
>CPU Feature:
CxE Function [C6]
QPI Frequency Selection [4800]
CPU Host Frequency(Mhz) [201]
Target CPU Frequency [4200mhz]
Target Memory Frequency [1600mhz]
MCH Strap [1600]
CPU Uncore Frequency(Mhz) [3200 (16x)]
hi,
DJ ich habe heute mal den 21 multi getestet , und was soll ich sagen RENNT :-)
201 mal 21 vcore unter LINX 1,247 werde dann mal einen screenshot machen.
danke fuer eure HILFE
gruss benny
Moin,
und zwar habe ich hier nen neues Mainboard, Cpu und Ram zugelegt. (Evga x58 SLI Le, Intel I7 920, 3x 2gb 1600Mhz)
Wollte das ganze nun in meinen Rechner verbauen jedoch bekomm ich den Rechner nicht zum starten.
Habe alles versucht jedoch wenn ich den 8 Pin Stecker entferne läuft er aber komme weder ins Bios noch sonst wo hin (also kein Bild). Meine Vermutung ist das das Netzteil vielleicht zu schwach ist. Könnt ihr das bestätigen? Verbaut ist ein Tagan TG600-U25.
Habe wirklich alles ausprobiert, platten mal abgeklemmt genauso wie einzelne Ram Bausteine aber wirklich das Board läuft nur endlos lang wenn ich den 8 Pin Stecker entferne der ja eigentlich für die CPU zuständig ist und die sitzt auch richtig aufm Board. Fehlermeldungen bekomme ich leider keine an der LED anzeige angezeigt und auch die anderen Led's leuchten so wie sie es sollte.
moin,
das nt hat 600 watt , und die sollten dicke langen.
ich wuerde sagen das das nt was hat (defekt oder so was).
kannst du dir nicht ein nt vom kumpel leihen und testen . dann siehst du gleich ob es am nt liegt.
gruss benny
moin,
gruss benny
Ja ein Kollege bringt die Tage sein Netzteil mit.
Sollte glaub ein Tagan TG900-BZ PipeRock
900 Watt, sollte wohl langen oder?
900 watt kommt drauf an was du noch so im rechner hast ( sli oder crossfire )
es sollten schon deine 600 dicke langen. meine ich
gruss benny
So Leute, ich dachte mir ich probiers nochmal mit meinem alten Netzteil und siehe da es funktioniert ^,.,.^.
Immer bevor es ausging wurde F3 & F6 angezeigt.
Nun habe ich alle Ram Riegel um einen Slot verschoben, sprich anstatt den 1. 3. und 5. Slot zu belegen habe ich nun 2. 4. und den .6 belegt.
Woran kann das liegen? Das der Ram vielleicht standartmäßig auf 1600 Mhz läuft? Oder könnten die Slots Defekt sein?
Laufen die dennoch im Tripple Channel?
Ruf doch mal beim deutschen Support an. Die sind da recht fit und freundlich :)
Wenn du alles Austauschbar hast, außer die Grafik, würde ich aber schon auf genau diese tippen. Über Google find ich da grad nicht aussagekräftiges auf die Schnelle.
So ich hab mich auch mal versucht an meinem EVGA X58 SLI LE und mir gefällt das sehr gut
Bios Template kommt noch !!!
Bios-Template
Dummy OC [disabled]
>Memory Feature:
Target Memory Frequency [1698Mhz]
Parameters
tCL Setting [8]
tRCD Setting [8]
tRP Setting [8]
tRAS Setting [24]
tRFC Setting [auto]
Command Rate [T1]
>Voltage Control:
CPU VCore [1,306v]
DIMM Voltage [1,65]
DIMM DQ Vref [+0mV]
IOH VCore [1,1v]
ICH VCore [1,05v]
>CPU Feature:
QPI Frequency Selection [4800GT/s]
CPU Host Frequency(Mhz) [212]
Target CPU Frequency [4050mhz]
Target Memory Frequency [1698mhz]
MCH Strap [1600]
CPU Uncore Frequency(Mhz) [3609 (16x)]
hab ein Problem mit dem Board,
seit ich vn meiem 775er System auf 1366 umgestiegen bin ist mein Rechner ehr langsamer als schneller geworden weiß nicht wodran das liegt evtl. habt ihr ja eine idee.
Arith
Kannst du das etwas genauer beschreiben ?
Also ich bin auch von einem 775 (Q9550 + UD3P) auf mein jetziges System umgestiegen und ich bin begeistert
Es ist so das z.b. WC3 teilweiße stark laggt was das 775er System nicht tat,
es kommt mir auch in windoof langsamer vor.
Dachte schonmal an BIOS update ob das wohl was bringt??
Arith
Das System neu aufgesetzt hast du aber?
Also ich habe auch bisher keinerlei Probleme mit den beiden Boards gehabt, die schon in meinem Rechner waren. Ich würde denken das ist eine Einstellungs-/Softwaregeschichte.
Füll doch mal das Bios-Template aus dem ersten Post aus, dann schauen wir mal rüber.
Auch wenn ich denke, dass das Problem eher anderweitig sitzt.
LöL :d
Naja läuft jetzt alles 1a!
Bin super zufrieden habe noch kein OC betrieben und ich merk da schon so nen mega unterschied grad bei Battlefield Bad Company 2 die Ladezeiten sind sowas von kurz.
Hatte davor halt nur nen E6600 :)
So heute kommt mein Mainboard Kühler (EK Water Blocks EK-FB EVGA X58 LE - Acetal Nickel). Hat von euch jemand das Teil schon mal verbaut und gibt es Tipps für den einbau ?
Einfach an die Anleitung halten, ist ziemlich einfach. Am besten aber PC erstmal bissl laufen lassen dann bekommst die Standartkühler leichter ab.
Kann ich so Unterschreiben, was Spitsign sagt. Einfach an die Anleitung halten, dann ists total einfach. Wenn du den PC nicht extra laufen lassen willst vorher, tuts auch ein Fön als Hilfe zum Kühler entfernen.
So es hat alles reibungslos funktioniert - da das Mainboard ja noch recht neu ist gingen die Kühler sehr leicht und auch im kaltem Zustand ab.
Was für Audio Treiber habt ihr?
Hab mir eben ein 5.1Headset gekauft und brauch irgendwas, dem ich sagen kann, dass ich die ganze Zeit Sourround hab(Wegen Bass und so)
Nur irritiert mich gerade, dass der Evga Download des TreiberZip dings schon über 40mb ist, normal??
tach leute,
so mein zweites sli le board will leider wieder nicht ganz wie ich.
im prinzip wurde das board getestet per luftkühlung und funktionierte einwandfrei. jetzt habe ich aber folgendes problem:
nach installation der wakü habe ich meine beiden 5870er eingebaut
und in die wakü integriert. leider bootet das board jetzt nicht mehr.
weder ein "boot piipen" noch ein bild ist zu hören/sehen.
also komme ich auch nicht ins bios..!
das "fehlercodedisplay" zeigt immer fehler b2 = Initialize Video
so läuft es dann im leerlauf durch bis ich das nt ausschalte.
hat jemand eine idee was ich probieren könnte oder ich falsch mache?
ps. beide grakas wurden getestet und funktionieren.
crossfire bridge ist installiert.
um jede hilfe bin ich sehr dankbar
Entschuldigt.
Ich hatte keine Lust den alten Sammelthread komplett durchzulesen ;)
Kann mir einer evtl sagen, warum der Lüfter, der am Fan Anschluss neben der I/O Blende liegt - immer nur 10 sek läuft und danach ausgeht? Muss ich da irgendwas besonderes Einstellen? :fresse:
Wäre dankbar für Hilfe :wink:
Grüße
Hi, habe auch ne Frage, die bestimmt schon öfter kam, aber habe grad auf dei schnelle nichts gefunden.
Wenn ich neuen RAM einbaue, muss ich doch die Speichereinstellungen des alten RAMs oder so löschen. Reicht der clear Cmos Button oder muss ich was anderes drücken?
@sNook
Wie wird er denn geregelt? Manuell oder per SmartFan?
@ipuoL
Clear cmos setzt doch alles auf default. Sollte reichen wenn Du nur die Einstellungen vom RAM im Bios wieder zurücksetzt.
