[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
Das kann schon mal passieren weil ja inplace FFT gesetzt sind.
Kann immer sein das Custom 1-2 Stufen mehr VCore braucht. Aber warum tust Dir den Stress an wenn Small und Large einzeln laufen ?
Jeep da hat der graebens recht. Custom braucht immer ne Stufe mehr vcore. Da beim X58 noch feiner skaliert ist als beim p45 können es auch 2 Stufen sein. Wenn Small paßt kannst du es so lassen.
Nabend @ All!:wink:
Gr3g schrieb:
dann hab ich vcore erhöht und custom lief dann bis 14K, dann hat sich ein Core verabschiedet
Rundungsfehler!
Ich glaube aber nicht, dass Du mit eine Stufe mehr Vcore auskommst, denn dafür, kam der Fehler ziemlich früh, deshalb kann es durch aus sein, dass Du noch zwei Stufen brauchst um den Custom durch zu bekommen.
@ Michael!:wink:
Der AGB ist dran.:fresse2:
danke jungs, hab schon 2 stufen vcore angehoben und dann blieb er bei den 14k hängen :drool: bin bei 1.2375v
Vitalij :wink: na siehst du, es findet sich immer ne Lösung.
Lasse mal linx laufen. Es sollten über 50 gflops Anliegen dann bist du auf dem richtigen weg ;)
Moin @ All!:wink:
Moin Micha!
Ich schick Dir nachher ein Bild, kannst Dir mal anschauen und sagen, ob es so okay ist.
Mach doch mal paar Screens von Deinem Setting, dann schauen wir mal.;)
Wenn jemand Hardware abzugeben hat oder sucht, möge bitte den Marktplatz verwenden.:wink:
Hehe also meins ist jetzt im MP drin. Aber hast Recht Arthur hier ist es echt langsam zu viel des guten :d
Wenn hier jemand etwas loswerden möchte, so kann er sich gern bei der Moderation melden.:wink:
Liebe X58 SLI LE Community,
hat jemand positive Erfahrungen mit G.SKill Trident 6GB PC-16000U (2000MHz) in Kombination mit dem X58 SLI LE?
Vielen Dank und Gruß,
OMA!
Die haben sogar einige hier laufen. Sind mit dem Board eigentlich die Standard-Empfehlung an RAM. :)
Sauber, dann hab ich die richtigen gekauft :)
Vielen Dank für den schnellen Support!
Werde die Woche mal berichten, wie der i7 950 so auf dem EVGA harmoniert ;)
Gru´ß,
OMA!
So ich meld mich noch ein letztes mal an Euch, meine ganzen i7 Sachen haben einen neuen Besitzer gefunden und ich werde hier nicht mehr aktiv sein.
War ne schöne Zeit bei Euch ;)
Moin!:wink:
Was hast Du dir jetzt geholt?
Füll doch mal das BIOS-Template der ersten Seite aus und gib mal an, wie alles gekühlt ist.
Vom Lesen her hab ich rausgehört, dass die Extreme wohl nicht so gut gehen mitm BCLK (muss aber nicht stimmen), wieso gehst du also nicht über den offenen Multi?
hey ich bräuchte nocmal eure hilfe.
ich scheitere derzeit am Versuch die 220BCLK zu schaffen.
der sperrt immer bei ca.180
PCIe Takt liegt bei 102
Ram ist entschärft
bei soviel BCLK bräuchtest du zuviel vtt. Bei 190 BCLK kannst du mal +150mv Einstellen (dient nur als Richtlinie). Die QPI PLL kannst du senken ;)
ich wollte das machen weil ich das Board verkaufen wollte aber der Abnehmer gerne mir 220BLCK arbeiten möchte.
und da wollte ich einen Screen leifern um zu zeigen, dass das Board das mitmacht.
EDIT:Gekühlt wird mit Luft.
Bios-Template
Dummy OC [disabled]
>Memory Feature:
Memory Frequency [2:8]
Target Memory Frequency [1480Mhz]
Parameters
tCL Setting [11]
tRCD Setting [11]
tRP Setting [11]
tRAS Setting [29]
tRFC Setting [88]
Command Rate [1T]
>Voltage Control:
EVGA VDroop Control [Without VDroop]
CPU VCore [1,125V]
CPU VTT Voltage [1,1V]
CPU PLL VCore [1,8V]
QPI PLL VCore [1,225V]
DIMM Voltage [1.65V]
DIMM DQ Vref [+0mV]
IOH VCore [1,1V]
IOH/ICH I/O Voltage [1,5V]
ICH VCore [1,1V]
>CPU Feature:
Turbo Mode Function [Disabled]
QPI Frequency Selection [4.800GT/s]
CPU Clock Ratio [14X]
CPU Host Frequency(Mhz) [185]
Target CPU Frequency [2590Mhz]
MCH Strap [1600]
CPU Uncore Frequency(Mhz) [2960]
PCIE Frequency(Mhz) [102]
So ich hoffe ihr könnt mir helfen.
Nebenbei sei gesagt, dass der mit diesen settigs nicht starten möchte ich muss die immer erst mit Eleet reinhauen.
Ok...
Ungeachtet des CPU-Takts zum ausschließen der Fehlerquelle auch die VCore erhöhen.
Vor die NB bei Luft am besten einen Lüfter hängen und dann mal folgendes probieren:
VCore 1.200V
VTT +150mV
QPI PLL und IOH VCore syncron auf 1.15V
PCI-E 102MHz
Das sollte für 200-210 BCLK eigentlich reichen, es sei denn die CPU macht den BCLK nicht mit. Ab 210 musst du eventuell den PCI-E wieder hochschrauben, ab 220 hab ich bei meinem letzten 104MHz gebraucht. VTT wird denke ich auch in +250mV Regionen landen und QPI PLL/IOH VCore in der Ecke 1.2V.
Aber immer gut auf die Temps achten. Gerade die SpaWa's sind beim LE ziemlich schnell mal weg und der NB-Kühlerr ist halt auch nicht das Wahre.
ich habe jetzt die einstellungen für 220BLCK genommen stecke aber immernoch bei 188 fest.
hast du vielleicht noch eine andere Idee? ich weiß, dass ich die CPU schonmal auf 208 hatte. also vom Ding her muss es drin sein.
Eiknfahc die Einstellungen übernehmen geht eh nicht. Und vor allem nicht direkt die für hohen BCLK.
Der X58 ist relativ Sensibel und wird oft auch bei "zu viel" instabil. Es gibt also nur ein von untern rantasten. Zu viel VTT kann genauso nciht klappen wie zu wenig, das ist eben eine Probieraktion, die einige Stunden wegfressen kann.
Den PCI-E am besten erstmal auf 102MHz lassen und nur mit der VTT spielen. Normal sollten 200MHz bei +125-175 VTT und IOH VCore/QPI PLL von 1.15V laufen.
so jetzt hab ich wie du gesagt hast die QPI/IOH auf 1,15V gesetzt und VTT auf 1.15V gestellt.
von 150 Mhz angefangen habe ichd ann mit Prime Run FFT's in Place stabilität getestet.
so mit Eleet dann blck angehoben und bei 185mhz viel dann ein Thread wegen fehler aus.
ok VTT eine stufe mehr gegeben und nochmal angeschaltet.
viel wieder aus. Auch 2 weitere Stufen brachten nichts. Alos Vtt wieder zwei stugfen runter und QPI/IOH syncron auf 1,175V angehoben. brachte aus nichts.
wo hab ich denn dort was falsch gemacht?
Das ist aber echt ein kniffliger Fall. Ich grübel beim Wiedereinbau von meinem LE mal drüber...
Übrigens wären VTT +150mV eigentlich 1.25V VTT, nicht 1.15V.
Groß hab ich bei meiner CPU folgendes eingestellt
211*19
VTT +125mv
QPI/IOH 1,175V
RAM: 1,60
Rest auf minimal Spannung außer VCore !
So wie Dj schon schrieb da ist nur testen angesagt und so wie ich das sehe hast das noch nie wirklich oft gemacht denn sonst würdest deine CPU ein wenig kennen wie Sie reagiert bei höherem Takt. Ist kein Angriff aber wenn man sich langsam nach oben tastet weiß man das ungefähr und ich glaube das geben mir die anderen auch Recht. Ich bin Stunden gesessen um heruaszufinden wie meine CPU tickt also viel Glück. Mein LE bin ich schon los geworden ;)
Moin Moin,
ich habe mir das Board jetzt auch geholt. Nun hab ich aber mal ne Frage dazu. Hat das Brett nun 2x PCIe 16x für ein eventuelles SLI, oder hat es "nur" 16x/8x ?
Bei Geizhals steht zum Beispiel "2x PCIe 2.0 x16, 2x PCIe 2.0 x16 (elektrisch nur x8)", im Handbuch (online bei EVGA) steht das nur eine PCIe 16x hat.
BTW: Was bedeutet eigentlich genau das mit dem "elektrisch nur" ? Das habe ich noch nicht ganz so genau geblickt....
Das mit dem elektrisch bedeutet: Du hast physikalisch einen Slot für x16 verlötet, dieser ist jedoch real nur mit x8 angebunden.
Die richtiges Werte vom LE sind folgende (von oben nach unten, wenn der CPU-Sockel oben ist):
PCI-E x16 (physikalisch x16)
PCI-E x1 (physikalisch x1)
PCI-E x8 (physikalisch x16)
alter PCI
PCI-E x4 (physikalisch x16)
Das ist auch auf dne Bildern auf der ersten Threadseite ersichtlich, steht nämlich auf dem Board drauf. :)
Bei Verwendung von 2 Grafikkarten haben dann beide nur noch 8 Lanes zur Verfügung, laufen also beide auf x8.
