[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
@Dr. Ster
Danke für die Packungsbeilage :d die Risiken und Nebenwirkungen sind schon zu sehen :fresse2: :fresse2: :fresse2:
aber mal was anderes der weiße Fullcover und grüne Schlauch samt Sleeve passen aber farblich mal garnicht zusammen oder ???
weiß ich ja :fresse2:
baue gerade / noch immer an meinem Con
ZAR-Con...mehr OPIUM fürs Volk ;) - Die Hardware-Community für PC-Spieler - PC GAMES HARDWARE EXTREME
und das ist ja eigenlich ja nur meine HW Station und dafür wollte ich noch keinen neuen Schlauch kaufen...
der wird erst gewechselt wenn alles fertig ist ;)
hier die Station:
btw: vom EK Radi würd ich mir keine Verbesserungen zu deinem TFC erhoffen...nicht dass du enttäuscht sein wirst ;)
Schönes Teil.
Ja ich weiß der ist von der Leistung her schlechter als mein Feser aber dafür kann ich dann 25mm Lüfter verwenden die von der Leistung her besser sind als die Scythe Slim und vorallem viel leiser, da muss ich nicht so weit runter regeln.
Temps werden sich nicht verbessern was ich glaube. Wir werden sehen und zur Not stell ich den Rechner zum OC auf den Balkon raus in der Nacht dann komm ich auch an gute Temps :fresse:
Jup da hast Du Recht macht im Schnitt knapp 10°C aus und das ist es mir schon Wert bisserl höher im Takt zu kommen ;)
Werde mal gucken ob ich jetzt doch noch höher hinaus komme, ansonsten bleibt es bei 3,8Ghz und 3,6Ghz UC bei 8-8-8-21 1T das okay
Und ich sag immernoch bei 1800 RAM kannst du auf 7-8-7 gehen.
Das sollte klappen. Also ran! :d
Und jaaa ich bau mein LE wieder ein. Ich glaub Sonntag hab ich Zeit dafür.
Okay, ich hatte mich schon über die schlechten Temps von Dir gewundert, Heizer hin oder her, waren diese schlechter als meine @ Air @ 4GHz, aber jetzt weiß wenigstens warum.
Bin gespannt, wie hoch die Temps @ 3,8GHz jetzt sein werden.:wink:
@STER187
Saugeiles Case, hervorragende Arbeit, bin auf weitere Bilder gespannt.;)
Hab mich grad wieder bisserl gespielt. Denkt Euch nix bei den Temps hier ist es warm weil unser Baby im Raum spielt.
Nabend Mädels :wink
hab mich heute mal etwas hingesetzt und das Board ausgebaut.
- neue Dichtungen fürn HK 3.0
- Backplate fürn HK 3.0 montiert
- verbogene CPU Pins gerade biegen
Muss sagen, Operation geglückt :fresse2:
Jetzt zeigt er mir auch wieder die vollen 6GB an,dachte schon das der eine Ram Slot hinüber wäre, lag aber nur an dem verbogenen Pin.
Jap,waren Gott sei dank nur verbogen !
Doch nun net mehr :d
Moin Vita,
doch resetten muss ich immer noch :-[
Moin Arthur!:wink:
Das ist gut,:bigok: das mit Resetten hätte mich echt an:kotz:
Hast Du bei EVGA nachgefragt, was es sein könnte?
Die meinten das die 25 auf einen Fehler der Graka hinweist.
NT könnte zu schwach sein ausserdem hat er noch nie was von Coba Nitrox gehört, das war in seinen Augen ein no name NT :stupid:
Von der Leistung her, reicht Dein NT dicke, ich würde erst mit eine andere Grafikkarte versuchen.
Moin zusammen :wink:
@Artur
das Problem gibt es wohl bei anderen EVGA Board´s auch. Einer im EVGA Forum hat wohl mal was von Maus oder Tastatur Problemen gehört. Steck doch mal deine USB Verlängerung ab vielleicht tut sich da was.
Was war den da bei dir auf dem Schreibtisch??? Hattest du da nicht immer die Maus dran angeschlossen wegen dem Kabel???
bin mit dem 19'er Multi auch mehr zufrieden :d
Sieht gut aus Arthur da werd ich auch gleich mal testen :d
Du hast ja auch nen W3520. Artur hat mehr Multi zu Verfügung und könnte durch weniger Bclk auch weniger vtt brauchen.
also ich weiß net was bei mir los is, small und large läuft ohne vcore erhöhung durch und custom schmiert immer ab, dann hab ich vcore erhöht und custom lief dann bis 14K, dann hat sich ein Core verabschiedet :(
