Modbox
@ColeTrickle,
OC Setting für Quad Q9550 Batch: L839A992
500 x 8.5 = 4250 MHz
mit 4 x 1GB OCZ Reaper Edition auf DDR2-1200
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .................: Auto
CPU Clock Ratio .........................: 8x
Fine CPU Clock Ratio.....................:.+0.50
CPU Frequency ...........................: 4250Mhz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...................: [Enabled]
CPU Host Frequency (Mhz) ................: 500Mhz
PCI Express Frequency (Mhz) .............: 103Mhz
C.I.A. 2.................................: Disabled
Advanced Clock Control:
CPU Clock Drive..........................: 800mV
PCI Express Clock Drive..................: 900mV
CPU Clock Skew (ps)......................: 200ps
MCH Clock Skew (ps)......................: 250ps
DRAM Performance Control
Performance Enhance......................: [Standard]
Extreme Memory Profile (X.M.P.)..........: Disabled
(G)MCH Frequency Latch...................: 333
System Memory Multiplier ................: 2.40B
Memory Frequency (Mhz) ..................: 1200Mhz
DRAM Timing Selectable ..................: [Manual]
Standard Timing Control
CAS Latency Time.........................: 5
tRCD ....................................: 5
tRP'.....................................: 5
tRAS.....................................: 15
Advanced Timing Control:
tRRD.....................................: 5
tWTR.....................................: 3
tWR......................................: 5
tRFC.....................................: 48
tRTP.....................................: 4
Command Rate (CMD) ......................: 2
Channel A Timings Settings:
Static tRead Value.......................: 9
tRD Phase0 Adjustmen.....................: 1-Advanced
tRD Phase1 Adjustment....................: 1-Advanced
tRD Phase2 Adjustment ...................: 1-Advanced
tRD Phase3 Adjustment....................: 1-Advanced
Trd2rd(Different Rank)...................: Auto
Twr2wr(Different Rank)...................: Auto
Twr2rd(Different Rank)...................: Auto
Trd2wr(Same/Diff Rank)...................: Auto
Dimm1 Clock Skew Control.................: Auto
Dimm2 Clock Skew Control.................: Auto
DDR2 Write Training......................: Auto
Channel A Driving Settings:
Driving Strength Profile.................: Auto
Data Driving Pull-Up Level...............: Auto
Cmd Driving Pull-Up Level................: Auto
Ctrl Driving Pull-Up Level...............: Auto
Clk Driving Pull-Up Level................: Auto
Data Driving Pull-Down Level.............: Auto
Cmd Driving Pull-Down Level..............: Auto
Ctrl Driving Pull-Down Level.............: Auto
Clk Driving Pull-Down Level..............: Auto
Channel B Timings Settings:
Channel B Driving Settings:
Motherboard Voltage Control
Loadline Calibration.....................: Disabled
CPU Vcore................1.250V*.........: 1.33750 (mit Vdroop Mod)
CPU Termination......... 1.200V*.........: 1.300
CPU PLL..................1.500V*.........: 1.500
CPU Referen..............0.760V*.........: 0.893
MCH/ICH
MCH Core.................1.100V..........: 1,320
MCH Reference............0.760V..........: 0.863
MCH/DRAM Ref.............0.900V..........: 1.020
ICH I/O..................1.550V..........: 1,500
ICH Core.................1.100V..........: 1,100
DRAM
DRAM Voltage.............1.800V..........: 2,040
DRAM Termination.........0.900V..........: 1.020
Channel A Reference......0.900V..........: 1.020
Channel B Reference......0.900V..........: 1.020
Advanced Settings:
Limit CPUID Max. to 3....................: Disabled
No-Execute Memory Protect................: Disabled
CPU Enhanced Halt (C1E)..................: Disabled
C2/C2E State Support.....................: Disabled
x C4/C4E State Support...................: Disabled
CPU Thermal Monitor 2(TM2) ..............: Disabled
CPU EIST Function........................: Disabled
Virtualization Technology................: Disabled
Dann schafft dieses Apogee GT 1150 Kit keine 600 MHz stabil...schade...da hilft auch keine höhere
DIMM Spannung oder entschärfen der Timings mehr. Scheint doch große Streuung mit diesen Kits zu geben.
Da würde ich mich auch ärgern, denn dann hätten die DDR2-1066 auch gereicht, aber nah ja.
Wenn du den RAM ausfahren möchtest, dann wären interessant:
Dein Vorschlag, 460 FSB x 2.5A = 1150MHz mit Strap 266
oder 467 FSB x 2.4B = 1120MHz mit Strap 333
Müsstest du mal ausprobieren, beim 266er Strap könntest du noch die PL6 nehmen.
Beim 333er Strap die PL 7-8.... würde aber das letzte nehmen.
"wüsste garnicht was ich dann sagen soll!"
-> du hast doch wiederrufsrecht!
bei den corsair hast du natürlich auch keine garantie, dass die die 1200 packen...musst du selber entscheiden...ich bin jedenfalls über diesen "glücksgriff" so richtig happy. vor allem weil die auch zusätzlich ncoh so kühl sind
genau...ist inkompatibel mit dem board und abstürze unter windows...
deswegen "sicherheitshalber wieder corsair" ; wenn du verstehst was ich meine!
zu den beiden versionen...grundsätzlich sind beide gleich nur die version mit dem "F" hintendran hat noch ein lüftermodul zusätzlich (F = Fan)
in jedem fall sind es die, die ich auhc habe!
seltsamerweise sind die versionen mit dem F (also die mit mehr lieferumfang) billiger...wer weiß wie das kommt! würde dann aber einfach die nehmen...du kannst auch mal nach der revision gucken und dich an mir orientieren...
bei mir steht auf allen riegeln: ver2.1
welche chips da nun genau drin sind kann ich dir net sagen...nur, dass was bei mir mit OC rausgekommen ist!
PS: finde die module generell aber sehr teuer...habe ein paket für etwa 50€ bekommen...also überleg dir ob du nicht vielleicht lieber irgendwo bestellst...ich hatte es bei nilstech geholt
husch husch grashüpfer
Nah er hat mich doch angeschrieben, habe ihn ein angepasstes Template zugeschickt, zum probieren.
Er muss die Skews und DIMM Spannung ändern, evtl. auch die tRFC erhöhen.
Mein Finale Template für 4.25 GHz und DDR2-1200 sieht so aus:
Code:OC Setting für Quad Q9550 Batch: L839A992 500 x 8.5 = 4250 MHz mit 4 x 1GB OCZ Reaper Edition auf DDR2-1200 MB Intelligent Tweaker(M.I.T.) Robust Graphics Booster .................: Auto CPU Clock Ratio .........................: 8x Fine CPU Clock Ratio.....................:.+0.50 CPU Frequency ...........................: 4250Mhz Clock Chip Control Standard Clock Control CPU Host Clock Control...................: [Enabled] CPU Host Frequency (Mhz) ................: 500Mhz PCI Express Frequency (Mhz) .............: 103Mhz C.I.A. 2.................................: Disabled Advanced Clock Control: CPU Clock Drive..........................: 800mV PCI Express Clock Drive..................: 900mV CPU Clock Skew (ps)......................: 200ps MCH Clock Skew (ps)......................: 250ps DRAM Performance Control Performance Enhance......................: [Standard] Extreme Memory Profile (X.M.P.)..........: Disabled (G)MCH Frequency Latch...................: 333 System Memory Multiplier ................: 2.40B Memory Frequency (Mhz) ..................: 1200Mhz DRAM Timing Selectable ..................: [Manual] Standard Timing Control CAS Latency Time.........................: 5 tRCD ....................................: 5 tRP'.....................................: 5 tRAS.....................................: 15 Advanced Timing Control: tRRD.....................................: 5 tWTR.....................................: 3 tWR......................................: 5 tRFC.....................................: 48 tRTP.....................................: 4 Command Rate (CMD) ......................: 2 Channel A Timings Settings: Static tRead Value.......................: 9 tRD Phase0 Adjustmen.....................: 1-Advanced tRD Phase1 Adjustment....................: 1-Advanced tRD Phase2 Adjustment ...................: 1-Advanced tRD Phase3 Adjustment....................: 1-Advanced Trd2rd(Different Rank)...................: Auto Twr2wr(Different Rank)...................: Auto Twr2rd(Different Rank)...................: Auto Trd2wr(Same/Diff Rank)...................: Auto Dimm1 Clock Skew Control.................: Auto Dimm2 Clock Skew Control.................: Auto DDR2 Write Training......................: Auto Channel A Driving Settings: Driving Strength Profile.................: Auto Data Driving Pull-Up Level...............: Auto Cmd Driving Pull-Up Level................: Auto Ctrl Driving Pull-Up Level...............: Auto Clk Driving Pull-Up Level................: Auto Data Driving Pull-Down Level.............: Auto Cmd Driving Pull-Down Level..............: Auto Ctrl Driving Pull-Down Level.............: Auto Clk Driving Pull-Down Level..............: Auto Channel B Timings Settings: Static tRead Value.......................: 9 tRD Phase0 Adjustmen.....................: 1-Advanced tRD Phase1 Adjustment....................: 1-Advanced tRD Phase2 Adjustment ...................: 1-Advanced tRD Phase3 Adjustment....................: 1-Advanced Trd2rd(Different Rank)...................: Auto Twr2wr(Different Rank)...................: Auto Trd2rd(Different Rank)...................: Auto Trd2wr(Same/Diff Rank)...................: Auto Dimm1 Clock Skew Control.................: Auto Dimm2 Clock Skew Control.................: Auto DDR2 Write Training......................: Auto Channel B Driving Settings: Driving Strength Profile.................: Auto Data Driving Pull-Up Level...............: Auto Cmd Driving Pull-Up Level................: Auto Ctrl Driving Pull-Up Level...............: Auto Clk Driving Pull-Up Level................: Auto Data Driving Pull-Down Level.............: Auto Cmd Driving Pull-Down Level..............: Auto Ctrl Driving Pull-Down Level.............: Auto Clk Driving Pull-Down Level..............: Auto Motherboard Voltage Control Loadline Calibration.....................: Disabled CPU Vcore................1.250V*.........: 1.33750 (mit Vdroop Mod) CPU Termination......... 1.200V*.........: 1.300 CPU PLL..................1.500V*.........: 1.500 CPU Referen..............0.760V*.........: 0.893 MCH/ICH MCH Core.................1.100V..........: 1,320 MCH Reference............0.760V..........: 0.863 MCH/DRAM Ref.............0.900V..........: 1.020 ICH I/O..................1.550V..........: 1,500 ICH Core.................1.100V..........: 1,100 DRAM DRAM Voltage.............1.800V..........: 2,040 DRAM Termination.........0.900V..........: 1.020 Channel A Reference......0.900V..........: 1.020 Channel B Reference......0.900V..........: 1.020 Advanced Settings: Limit CPUID Max. to 3....................: Disabled No-Execute Memory Protect................: Disabled CPU Enhanced Halt (C1E)..................: Disabled C2/C2E State Support.....................: Disabled x C4/C4E State Support...................: Disabled CPU Thermal Monitor 2(TM2) ..............: Disabled CPU EIST Function........................: Disabled Virtualization Technology................: Disabled
Man, man, man.... das Internet ist heute sooooo lahmarschig, laufen wohl wieder viele Anträge für Abwrackprämie an!
