ColeTrickle
Urgestein
für wieviel???
was gibt eigentlich dein budget her,nur mal so...?
für wieviel???
Für 100 Euro inkl. ^^
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8x
Fine CPU Clock Ratio.....................:.+0.50
CPU Frequency ...........................: 4003,50
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 471MHz
PCI Express Frequency (Mhz) .........: 100Mhz
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 900mv
PCI Express Clock Drive.................: 800mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance...................: [Turbo]
Extreme Memory Profile (X.M.P.).....: auto
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: 2.00B
Memory Frequency (Mhz) ..............: 942Mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................: 5
tRCD .........................................: 5
tRP'...........................................: 5
tRAS..........................................: 15
Advanced Timing Control [Press Enter]
tRRD...........................................: 4
tWTR..........................................: 4
tWR............................................: 8
tRFC...........................................: 56
tRTP...........................................: 4
Command Rate (CMD) ....................: Auto
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value.........................: auto
tRD Phase0 Adjustmen....................: Auto
tRD Phase1 Adjustment...................: Auto
tRD Phase2 Adjustment ..................: Auto
tRD Phase3 Adjustment...................: Auto
Trd2rd(Different Rank)....................: Auto
Twr2wr(Different Rank)...................: Auto
Twr2rd(Different Rank)...................: Auto
Trd2wr(Same/Diff Rank)..................: Auto
Dimm1 Clock Skew Control...............: Auto
Dimm2 Clock Skew Control...............: Auto
DDR2 Write Training........................: auto
Channel A Driving Settings [Press Enter]
Driving Strength Profile.................: Auto
Data Driving Pull-Up Level.............: Auto
Cmd Driving Pull-Up Level..............: Auto
Ctrl Driving Pull-Up Level...............: Auto
Clk Driving Pull-Up Level................: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down Level...........: Auto
Ctrl Driving Pull-Down Level............: Auto
Clk Driving Pull-Down Level.............: Auto
Channel B
Channel B Timings Settings [Press Enter]
DDR2 Write Training........................: Auto
Channel B Driving Settings [Press Enter]
Data Driving Pull-Up Level..............: Auto
Cmd Driving Pull-Up Level...............: Auto
Ctrl Driving Pull-Up Level................: Auto
Clk Driving Pull-Up Level.................: Auto
Data Driving Pull-Down Level...........: Auto
Cmd Driving Pull-Down Level............: Auto
Clk Driving Pull-Down Level..............: Auto
Motherboard Voltage Control:
Loadline Calibration.………................ Disabled
CPU Vcore….……….........................: 1.35000
CPU Termination…..... 1.200V*.......: 1.30
CPU PLL…………………....1.500V*.......: 1.5
CPU Referen.…………....0.760V*.......: 0.878
MCH/ICH
MCH Core…………….....1.100V...........: 1,30
MCH Reference….…….0.760V...........: 0.863
MCH/DRAM Ref.…......0.900V...........: auto
ICH I/O……………….....1.550V............: auto
ICH Core…………...……1.100V............: auto
DRAM
DRAM Voltage ……....1.800V............: 2,1
DRAM Termination .…0.900V............: auto
Channel A Reference 0.900V............: auto
Channel B Reference 0.900V............: auto
CPU Clock Ratio .......................: 8x
Fine CPU Clock Ratio...................:.+0.5
CPU Frequency .........................: 4.00 Ghz
Clock Chip Control
PCI Express Frequency (Mhz) .........: Auto
CPU Clock Drive.......................: 800mv
PCI Express Clock Drive...............: 900mv
CPU Clock Skew (ps)...................: 0ps
Performance Enhance....................: [Standard]
Extreme Memory Profile (X.M.P.)........: disabled
(G)MCH Frequency Latch.................: 400
System Memory Multiplier ..............: 2.00 D
Memory Frequency (Mhz) ................: 942 Mhz
CAS Latency Time..............................: 5
tRP'..........................................: 5
tRRD...................................: Auto
tWTR...................................: Auto
tWR....................................: Auto
tRFC...................................: Auto
tRTP...................................: Auto
Channel A
Static tRead Value.....................: 10
tRD Phase0 Adjustmen...................: Auto
tRD Phase1 Adjustment..................: Auto
tRD Phase2 Adjustment .................: Auto
tRD Phase3 Adjustment..................: Auto
Trd2rd(Different Rank).................: Auto
Twr2wr(Different Rank).................: Auto
Twr2rd(Different Rank).................: Auto
Trd2wr(Same/Diff Rank).................: Auto
DDR2 Write Training......................: Auto
Ctrl Driving Pull-Up Level.............: Auto
Clk Driving Pull-Up Level..............: Auto
Ctrl Driving Pull-Down Level..........: Auto
Clk Driving Pull-Down Level...........: Auto
Channel B
Static tRead Value......................: 10
DDR2 Write Training....................: Auto
Driving Strength Profile................: Auto
Ctrl Driving Pull-Up Level..............: Auto
Clk Driving Pull-Up Level...............: Auto
Ctrl Driving Pull-Down Level...........: Auto
{U]Motherboard Voltage Control{/U]
Loadline Calibration.………...........: Disabled
CPU Vcore….……….....................: 1,425V
CPU Termination…..... 1.200V*......: 1,28V
CPU PLL…………………....1.500V*..........: 1,50V
CPU Referen.…………....0.76V*.........: 0.85
MCH/ICH
MCH termination...1.100V...........: 1,3V
MCH Reference….…….0.760V...........: 0,89
MCH/DRAM Ref.…......0.900V.........: Normal
ICH I/O……………….....1.50V............: 1,5V
ICH Core…………...……1.100V............: 1,1V
DRAM
DRAM Voltage ……....1.800V.............: 2,1V
DRAM Termination .…0.900V.............: Normal
Channel A Reference 0.900V............: Normal
Channel B Reference 0.900V............: Normal
Code:MB Intelligent Tweaker(M.I.T.) Robust Graphics Booster ...............: Auto CPU Clock Ratio ..........................: 8x Fine CPU Clock Ratio.....................:.+0.50 CPU Frequency ...........................: 4003,50 Clock Chip Control Standard Clock Control CPU Host Clock Control..................: [Enabled] CPU Host Frequency (Mhz) ............: 471MHz PCI Express Frequency (Mhz) .........: 100Mhz C.I.A. 2.......................................: Disabled Advanced Clock Control [Press Enter] [B][COLOR="Red"]CPU Clock Drive...........................: 900mv tauschen 800mV PCI Express Clock Drive.................: 800mv tauschen 900 mV[/COLOR][/B] CPU Clock Skew (ps)....................: 0ps MCH Clock Skew (ps)...................: 0ps DRAM Performance Control Performance Enhance...................: [Turbo] Extreme Memory Profile (X.M.P.).....: auto (G)MCH Frequency Latch...............: 333 System Memory Multiplier ..............: 2.00B Memory Frequency (Mhz) ..............: 942Mhz DRAM Timing Selectable ................: [Manual] Standard Timing Control CAS Latency Time........................: 5 tRCD .........................................: 5 tRP'...........................................: 5 tRAS..........................................: 15 Advanced Timing Control [Press Enter] tRRD...........................................: 4 tWTR..........................................: 4 tWR............................................: 8 tRFC...........................................: 56 tRTP...........................................: 4 Command Rate (CMD) ....................: Auto Channel A Channel A Timings Settings [Press Enter] Static tRead Value.........................: auto tRD Phase0 Adjustmen....................: Auto tRD Phase1 Adjustment...................: Auto tRD Phase2 Adjustment ..................: Auto tRD Phase3 Adjustment...................: Auto Trd2rd(Different Rank)....................: Auto Twr2wr(Different Rank)...................: Auto Twr2rd(Different Rank)...................: Auto Trd2wr(Same/Diff Rank)..................: Auto Dimm1 Clock Skew Control...............: Auto Dimm2 Clock Skew Control...............: Auto DDR2 Write Training........................: auto Channel A Driving Settings [Press Enter] Driving Strength Profile.................: Auto Data Driving Pull-Up Level.............: Auto Cmd Driving Pull-Up Level..............: Auto Ctrl Driving Pull-Up Level...............: Auto Clk Driving Pull-Up Level................: Auto Data Driving Pull-Down Level..........: Auto Cmd Driving Pull-Down Level...........: Auto Ctrl Driving Pull-Down Level............: Auto Clk Driving Pull-Down Level.............: Auto Channel B Channel B Timings Settings [Press Enter] Static tRead Value.........................: auto tRD Phase0 Adjustmen....................: Auto tRD Phase1 Adjustment...................: Auto tRD Phase2 Adjustment ..................: Auto tRD Phase3 Adjustment...................: Auto Trd2rd(Different Rank)....................: Auto Twr2wr(Different Rank)...................: Auto Trd2rd(Different Rank)....................: Auto Trd2wr(Same/Diff Rank)..................: Auto Dimm1 Clock Skew Control...............: Auto Dimm2 Clock Skew Control...............: Auto DDR2 Write Training........................: Auto Channel B Driving Settings [Press Enter] Driving Strength Profile.................: Auto Data Driving Pull-Up Level..............: Auto Cmd Driving Pull-Up Level...............: Auto Ctrl Driving Pull-Up Level................: Auto Clk Driving Pull-Up Level.................: Auto Data Driving Pull-Down Level...........: Auto Cmd Driving Pull-Down Level............: Auto Ctrl Driving Pull-Down Level............: Auto Clk Driving Pull-Down Level..............: Auto Motherboard Voltage Control: Loadline Calibration.………................ Disabled CPU Vcore….……….........................: 1.35000 CPU Termination…..... 1.200V*.......: 1.30 CPU PLL…………………....1.500V*.......: 1.5 [B][COLOR="Red"]CPU Referen.…………....0.760V*.......: 0.878 eins runter[/COLOR][/B] MCH/ICH MCH Core…………….....1.100V...........: 1,30 MCH Reference….…….0.760V...........: 0.863 MCH/DRAM Ref.…......0.900V...........: auto ICH I/O……………….....1.550V............: auto ICH Core…………...……1.100V............: auto DRAM DRAM Voltage ……....1.800V............: 2,1 DRAM Termination .…0.900V............: auto Channel A Reference 0.900V............: auto Channel B Reference 0.900V............: auto
so da isses
Ich brauch 1.32 MCH also was willst du? bis auf die Vcore ist alles ok VTT hab ich auch so viel gebrauchtKönnte jemand mal so als groben Vergleichswert messen was Euer Quad@4Ghz bzw das Gesamtsystem mit LinX konsumiert?
Bei meinem Sys kommen 382W zusammen, Prime Small 315.
Mir ist bewusst das sich unsere Systeme in den seltensten Fällen gleichen, nur interessehalber.
Habe meine 4 GHZ Settings inzw gefunden...Prime & Linx stabil. Braucht leider viel Spannung und die Temps sehen entsprechend aus..
Clock Chip Control
[COLOR="Red"]tRRD...........................................: auto
tWTR..........................................: auto
tWR............................................: auto
tRFC...........................................: auto
tRTP...........................................: auto
Command Rate (CMD) ....................: Auto [/COLOR]
Channel A
Channel B
MCH/ICH
[COLOR="#ff0000"]MCH Reference….…….0.760V...........: 0.863 eins hoch[/COLOR]
[COLOR="#ff0000"]ICH I/O……………….....1.550V............: 1,5V
ICH Core…………...……1.100V............: 1,1V[/COLOR]
DRAM
Clock Chip Control
CPU Clock Drive...........................: 800mv
PCI Express Clock Drive.................: 900mv
Performance Enhance...................: [Standard]
(G)MCH Frequency Latch...............: 400
System Memory Multiplier ..............: 2.00D
tRAS..........................................: 18
tRRD...........................................: Auto
tWTR..........................................: Auto
tWR............................................: Auto
tRFC...........................................: Auto
tRTP...........................................: Auto
Channel A
Static tRead Value.........................: 11
Channel B
MCH/ICH
MCH Reference….…….0.760V...........: 0.903
DRAM
