[Sammelthread] GigaByte GA-EP45[T]-UD3P / UD3R / UD3 (Intel P45) [3]
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8x
Fine CPU Clock Ratio.....................:.+0.50
CPU Frequency ...........................: [COLOR="#ff0000"]3800[/COLOR]
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: [COLOR="#ff0000"]448[/COLOR]MHz
PCI Express Frequency (Mhz) .........: 100Mhz
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: [COLOR="#ff0000"]800[/COLOR]mv
PCI Express Clock Drive.................: [COLOR="#ff0000"]900[/COLOR]mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance...................: [COLOR="#ff0000"]Standart[/COLOR]
Extreme Memory Profile (X.M.P.).....: [COLOR="#ff0000"]Disabled[/COLOR]
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: [COLOR="#ff0000"]240[/COLOR]B
Memory Frequency (Mhz) ..............: [COLOR="#ff0000"]1075[/COLOR]Mhz
DRAM Timing Selectable ................:[COLOR="#ff0000"] [Manuell][/COLOR]
Standard Timing Control
CAS Latency Time........................: 5
tRCD .........................................: 5
tRP'...........................................: 5
tRAS..........................................: 15
Advanced Timing Control [Press Enter]
tRRD...........................................: 4
tWTR..........................................: 4
tWR............................................: 8
tRFC...........................................: [COLOR="#ff0000"]48[/COLOR]
tRTP...........................................: 4
Command Rate (CMD) ....................: Auto
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value.........................: [COLOR="#ff0000"]8[/COLOR]
tRD Phase0 Adjustmen....................: [COLOR="#ff0000"]1-Advanced[/COLOR]
tRD Phase1 Adjustment...................: Auto
tRD Phase2 Adjustment ..................: Auto
tRD Phase3 Adjustment...................: Auto
Trd2rd(Different Rank)....................: Auto
Twr2wr(Different Rank)...................: Auto
Twr2rd(Different Rank)...................: Auto
Trd2wr(Same/Diff Rank)..................: Auto
Dimm1 Clock Skew Control...............: Auto
Dimm2 Clock Skew Control...............: Auto
DDR2 Write Training........................: auto
Channel A Driving Settings [Press Enter]
Driving Strength Profile.................: Auto
Data Driving Pull-Up Level.............: Auto
Cmd Driving Pull-Up Level..............: Auto
Ctrl Driving Pull-Up Level...............: Auto
Clk Driving Pull-Up Level................: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down Level...........: Auto
Ctrl Driving Pull-Down Level............: Auto
Clk Driving Pull-Down Level.............: Auto
Channel B
Channel B Timings Settings [Press Enter]
DDR2 Write Training........................: Auto
Channel B Driving Settings [Press Enter]
Data Driving Pull-Up Level..............: Auto
Cmd Driving Pull-Up Level...............: Auto
Ctrl Driving Pull-Up Level................: Auto
Clk Driving Pull-Up Level.................: Auto
Data Driving Pull-Down Level...........: Auto
Cmd Driving Pull-Down Level............: Auto
Clk Driving Pull-Down Level..............: Auto
Motherboard Voltage Control:
Loadline Calibration.………................ Disabled
CPU Vcore….……….........................: [COLOR="#ff0000"]1,33750[/COLOR]
CPU Termination…..... 1.200V*.......: [COLOR="#ff0000"]1,26[/COLOR]
CPU PLL…………………....1.500V*.......: 1.5
CPU Referen.…………....0.760V*.......: [COLOR="Red"]0,825[/COLOR]
MCH/ICH
MCH Core…………….....1.100V...........: [COLOR="#ff0000"]1,24[/COLOR]
MCH Reference….…….0.760V...........: [COLOR="#ff0000"]0,825[/COLOR]
MCH/DRAM Ref.…......0.900V...........: [COLOR="#ff0000"]1.080[/COLOR]
ICH I/O……………….....1.550V............: [COLOR="#ff0000"]1,50[/COLOR]
ICH Core…………...……1.100V............: [COLOR="#ff0000"]1,10[/COLOR]
DRAM
DRAM Voltage ……....1.800V............: [COLOR="#ff0000"]2,18[/COLOR]
DRAM Termination .…0.900V............: [COLOR="#ff0000"]1,000[/COLOR]
Channel A Reference 0.900V............: auto
Channel B Reference 0.900V............: auto
so, das ist meiner . Damit läufts Super[/QUOTE]
futzis kiste läuft erstmal...aber an den feineinstellungen hapert es noch arg!!!
an was lags?
zu deiner frage zwecks speicher...hab mal irgendwo was gefunden,wo das da stand....da stand glaub ich bei ver. 2.1 quimonda....finde das aber net mehr...*mist*
@mr bo
bitte mal bei mir durchklingeln!! einfach pn schicken dann bekommst du telenummer
@cole
lag glaube ich an zu hohem multi, latch und ich i/o spannung!!! win startet jetzt jedenfalls mit 471MHz...jetzt muss multi erhöht werden bis 4ghz erreicht sind; latch, performance level, performance enhanced anpassen, dann probieren die spannung runter zubekommen = viel arbeit!!!
wegen ram -> guck mal in dem corsair thread...da ist irgendwo ein link!!!
Code:
CPU Clock Ratio ..........................: 6x
Fine CPU Clock Ratio.....................:.+0,0
CPU Frequency ...........................: 2826,50
Clock Chip Control
CPU Host Frequency (Mhz) ............: 471MHz
CPU Clock Drive...........................: 800mv
PCI Express Clock Drive.................: 900mv
Performance Enhance...................: [Standard]
Extreme Memory Profile (X.M.P.).....: auto
(G)MCH Frequency Latch...............: 400
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 942Mhz
DRAM Timing Selectable ................: [Manual]
tRAS..........................................: 18
tRRD...........................................: Auto
tWTR..........................................: Auto
tWR............................................: Auto
tRFC...........................................: Auto
tRTP...........................................: Auto
Channel A
Static tRead Value.........................: 11
tRD Phase0 Adjustmen....................: Auto
Channel B
CPU Vcore….……….........................: 1.30000
CPU Termination…..... 1.200V*.......: 1.28
CPU Referen.…………....0.760V*.......: 0.865
MCH/ICH
MCH Core…………….....1.100V...........: 1,30
MCH Reference….…….0.760V...........: 0.890
MCH/DRAM Ref.…......0.900V...........: auto
ICH I/O……………….....1.550V............: 1,5
ICH Core…………...……1.100V............: 1,1
DRAM
DRAM Voltage ……....1.800V............: 2,1
DRAM Termination .…0.900V............: auto
so hier mal die settings, mit dem er hoch fuhr ;)
Die Quimonda sind auf den 2x1GB Domis Rev2, bei den 2x2GB gibt es bei Corsair selbst (noch) keine Angabe. Für mich sind die allerdings uninteressant weil ich XP32 weiter fahre und mit 4x1GB bedeutend höher komme bei besseren Timings.
glücklicherweise können cole und ich uns da gar nicht beschweren!!
vor allem ich bin halt happy...weil die auch bei 1200 laufen...das bei insgesamt 8GB!!!
Ist auch keine schlechte Sache, aber für XP eben bei 32bit unsinnig, daneben brauche ich definitiv keine 8GB. Fahre die 600 dann eben mit 5-5-5-15 bei 1,9V mit harten Subtimings, bringt mir mehr Leistung und ich muß nicht über die angegebenen Spezifikationen beim Ram gehen.
Das blöde ist, dass man eben bisl mehr MCH braucht bei 4x1 GB....
Kann ich auch 3 Riegel reinstecken? :d Passiert da was? Macht das was aus^^ wegen dual Channel und blah?
klar kannst du auch 3 rein stecken, müsstest dann halt nur noch single channel laufen haben wenn ich mich nicht irre.
Weil wozu volle Rambänke und 32 bit :d wenns ned anders geht kann ich mich auch mit 2 GB vergnügen :)
Am besten hätt ich so viel Luck mit RAMS wie Cole :d aber naja...
Hey Leute, kennt jemand ein Proggi mit dem man CPU-Profile erstellen kann. So etwas wie RM Clock was aber auch unter 64bit Vista funzt...
Mein PC läuft oft lange durch und dabei muss er halt nicht immer übertaktet laufen....
mfg DKMDD
Edit: Noch ne Frage, muss man beim ud3r bios irgendwo was einstellen wenn man die RAMs im Dual Channel Betrieb laufen lassen möchte?
ich glaub das board erkennt automatisch ob es im single oder dual modus ist.
das andere kenn ich nur von rivatuner, allerdings nur für grakas
Ja,aber wenn man 3 Dims drinne hatt erkennt es das als Single Channel!
Heute Überweise ich das Geld an Reeis,dann kann ich bald loslegen "juhu"^^
Nee^^,bin selber ein oc noob bei cpu`s
ich werd mich viel am Startpost richten,also da stehen ja Welche Spannungen man geben kann,und demnach werde ich testen,und ein paar Settins schau ich mir an von anderen,sowas hilft sicherlich auch gut weiter.
Und im MSN hab ich auch noch nen Profi also Reiis^^
hehe will auch, cole kommt nich dazu msn zu instl..
ich denke auch mal, das mein mobo keine 500 schafft, und die cpu auch keine 4gig, aber mal sehn, was da noch so geht.
also ich hab ja jetzt schon mal die 471 stable mit 6er multi, hab gestern einfach mal den multi auf 7 erhöht, da kann freeze nach 20 min prime. wie sollte ich denn jetzt besser weiter vorgehn?
was den betrieb mit 3 modulen angeht...es wird ein dualchannel erzwungen...allerdings besteht da ein höheres risiko für instabilitäten. außerdem ist die verteilung auf die bänke nicht sonderlich gleichmäßig...deshalb ist es wohl besser wenn man 2 oder 4 module benutzt!
@reeis: kannst ja mal anfragen ob du den corsair ram (den cole und ich haben) in der revision 2.1 bekommst???
@whitecker
freut mich das es klappt :d
@futzi: ich glaube, dass so 90% der UD3R/UD3P die 500 schaffen...(entsprechende Spannung vorausgesetzt). bei mir müssen es nur 0,2V mehr sein (allerding nur mit 4gb) um die 500 stable zubekommen!
ich würde an deiner stelle jetzt wohl oder übel mal die vcore noch ein stück nach oben setzen, damit es beim multi 7 läuft...check das mal bitte!!!
ok, mach ich mal, also stell ich jetzt von 1,3000 auf 1,5? isn bissl viel oder?
Neeee bloß nicht,maximal 1.4V im Bios,kannst ja mal 1.5V einstellen und dir die Temps dann ankucken,ne 1.5V sind derbe zu viel,maximal im Bios 1.4V würde ich sagen,aber besser dadrunter,teste dich einfach hoch ab wann es stabil wird.
1,5V definitiv erstmal zu viel...mach bitte langsam!!! wenn es noch nicht klappen sollte kannst du immer noch einen schritt höher gehen!
guck dich auch mal in den OC-Threads um...was die so brauche für die 4GHz bei LuKü!!!
und nimm dir einen Wert als Maximum über den du nicht gehen willst oder wirst!
Ansonsten ist man immer versucht noch etwas mehr zugeben und mehr und mehr und dann zack, muss man neue hardware kaufen ;)
Sowas dauert leider manchmal etwas sonne Woche oder so,aber danach haste dann echt ein geiles Ergebnis,ich bin selber mal gespannt wie lange ich brauche,aber das board von Reis ist gut,da werde ich nicht sooo viel zu testen haben denke ich mal.
was wahre stabilität angeht, habe ich mich immer an coles testweise orientiert!
also im großen und ganzen waren das dann 3 Tests:
prime small über eine laufzeit von 4,5h
prime large über eine laufzeit von 4,5h
und als letztes prime custom (mit in-place) über 10h
danach kann man glaube ich das wort rockstable verwenden! :d
Das kann man erst verwenden wenn die Kiste auch im Alltagsbetrieb stabil ist, wäre nicht das erste mal das Prime läuft aber andere Anwendungen (vor allem Spiele) Probleme machen;)
so hab gemacht, mit latch 333 bootet er nicht, mit 400 widerum schon, mal sehn ob er jetzt zumindest small stable ist, wenn prime abkackt vcore erhöhn? bin jetzt bei 1,31250v
ok, hab auch noch n rechnfehler entdeckt, bei mch anstatt 0.890/1,3..... 0,890/1,32= 67% hat das denn große auswirkungen wenn die gtls nich gleich sind?
änder ich beim nächsten run, er primelt ja noch =)
