W1nter
Ja,nur hab ich keine Geduld mehr für Small^^
Aber die Idee hatte ich grade auch schon,und werde es auch noch umsetzten!!
Hier mal mein Finale Template für 500 FSB wen es interessiert.
500 FSB Prime Custom Stable
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8
CPU Frequency ...........................: 500
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................:
CPU Host Frequency (Mhz) ............: 4Ghz
PCI Express Frequency (Mhz) .........: 100
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800
PCI Express Clock Drive.................: 900
CPU Clock Skew (ps)....................: 50
MCH Clock Skew (ps)...................: 100
DRAM Performance Control
Performance Enhance...................: Standard
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: 2.00b
Memory Frequency (Mhz) ..............: 1000Mhz
DRAM Timing Selectable ................: Auf manuell halt^^
Standard Timing Control
CAS Latency Time........................: 5
tRCD .........................................: 5
tRP'...........................................: 5
tRAS..........................................: 15
Motherboard Voltage Control:
Loadline Calibration.………................ Disabled
CPU Vcore….……….........................: 1.26875v
CPU Termination…..... 1.200V*.......: 1.3v
CPU PLL…………………....1.500V*.......: 1.500v
CPU Referen.…………....0.760V*.......: 0,823v
MCH/ICH
MCH Core…………….....1.100V...........: 1.32
MCH Reference….…….0.760V...........: 0,863
MCH/DRAM Ref.…......0.900V...........: Auto
ICH I/O……………….....1.550V............: 1.500v
ICH Core…………...……1.100V............: 1.100v
DRAM
DRAM Voltage ……....1.800V............: 2.02v
DRAM Termination .…0.900V............: Auto
Channel A Reference 0.900V............: Auto
Channel B Reference 0.900V............: Auto
So,dieses Settings ist natürlich nicht auf jedes System zu übertragen sprich es klappt nicht bei jedem.
Mit hohe Wahrscheinlichkeit muss man die vNB und vFSB anpassen und die Skews wie die GTL`s.
Heya ich bin auch seit kurzem Besitzer eines UD3P
naja hatte zunächst aber doch probs mit den 500 FSB costom stabil - dank deinem Post hier klappts nun
So und jetzt schau ich mal wieviel Vcore meine CPU für den Spaß haben will. Ich hab aber die bittere Vermutung das es etwas mehr wird wie bei dir
greetz
