JojoTheMaster
Urgestein
Die haswell nucs konnten auch 4k...und bisher sieht es nicht so aus dass Intel bei den broadwell U-Prozessoren 4k@60Hz bringt
..die integrierte Grafik hat ordentlich zugelegt. Die Ausbaustufe GT2 – bei den neuen Broadwell-CPUs HD 5500 genannt – hat 24 Shader-Prozessoren statt vormals 20 (HD 4400); bei der größten Variante GT3 alias HD 6000 oder Iris 6100 sind es 48 statt bisher 40 (HD 5000, Iris 5100). Intel verspricht dadurch eine rund 20 Prozent höhere 3D-Leistung. Zudem hat auch die Video-Einheit hinzugelernt, die nun HEVC, VP8 und VP9 unterstützt...
legitreviews.com schrieb:If you are a fan of Intel’s NUC – Next Unit of Computing – chances are you’ve been waiting for the NUC 2.0 to be released. The NUC 2.0 hasn’t changed that much visually from the original versions, but internally they feature the latest Core i3, Core i5 and Core i7 Broadwell processors along with some Braswell processors. Along with the new processors come some rather significant new features. For example, Intel has moved away from the mSATA storage interface and went with the latest and greatest M.2 interface. They also ditched all the external HighSpeed USB 2.0 ports and went with external SuperSpeed USB 3.0 headers on the front and back of the devices with a pair of internal USB 2.0 ports for those that need even more USB support. Some models also feature a pair of mini-DisplayPort v1.2 headers, which means these little boxes support triple display setups and are capable of 4K video output. Intel will also have a NUC system coming out in Q2’15 that is powered by an Intel Core i7 processor for the very first time (NUC5i7RYH)! The Intel NUC 2.0 might be great as a home theater PC, but these could easily replace your traditional desktop PC as they are very powerful little systems.
Intel will also be offering various lids that can be purchased for the NUC 2.0 models. They had a prototype Hauppauge TV tuner on one model...
...and then another with a removeable lid that had built-in NFC. Intel is working with a number of companies to come up with innovative removable lids as that is one of the new features of the Broadwell based NUC’s.
powercfg -devicequery wake_from_any
Die kleineren NUC sollen im Februar und März starten, für die Variante mit Core i7 setzt Intel großzügig den Rahmen „zweites Quartal“.
Kann mir jemand im Besitz eines Haswell-NUC mit dem eingebauten Infrarot Empfänger vielleicht einen Gefallen tun?
Müsste nur mal kurz in der Eingabeaufforderung folgenden Befehl eingeben und nachschauen, ob in der Auflistung dort ein Gerät mit der Bezeichnung "ehome" oder "ir6" auftaucht:
Code:powercfg -devicequery wake_from_any
Müsste ungefähr so aussehen:
ah, verdammt ist das Ding laut (Intel NUC DN2820FYK)
lauter als so ziemlich jeder Kühler den ich jemals hatte (Mugen, Apfelfoehn, Noctua, Big Shurriken), und da hilft die empfohlene 20% Einstellung auch nicht. Warum baut man nicht einfach einen 90mm lüfter rein? Warum muss man diese kleinen scheissdinger nehmen? Sonst isser perfekt ja.
Wird wieder verkauft
