Nexus Unveils the Socket LGA 1366-ready FLC-3000 Processor Cooler
Holland-based Nexus unveiled today what's I believe the first cooling reported on our site to support Intel Socket LGA 1366. That's the same socket that will be used with Intel's next-gen Core i7 processors, scheduled to be released later this year (Q4 2008). Made out of pure copper, the Nexus FLC-3000 houses a rather unusual design, measuring 128 (L) x 105 (W) x 119 (H) mm. It weights in 450 grams, has an aluminum heatsink and four 6mm copper heatpipes angled at 30 degrees. The cooling surface is chilled by a 90mm RPM-controlled fan that works between 900 and 2500 RPM and has a sound output between 15 dB(A) and 24 dB(A) depending on the rotation speed. The fan is also equipped with two orange LEDs. In addition, the Nexus FLC-3000 is also Intel LGA 775 and AMD AM2/AM2+ socket compatible. The cooler is yet to be priced.
http://www.techpowerup.com/70822/Ne...LGA_1366-ready_FLC-3000_Processor_Cooler.html
