WMDK
Legende
Some databases are just amazing
 . ... time will tell.
 ... time will tell.
				 www.leadtek.com
					www.leadtek.com
				I will look for these boardss as well then.Btw, I had checked my 256s and I have one matching batch with the three cpus you've got, so now I am torn between hoping it runs well,
so I would have at least a promising one and hoping it runs really bad so you might be inclined to help me get a matched pair... time will tell.
Regarding a single socket 940 Board, well there isn't much choice to begin with. The Asus SK8N comes to mind, but since mine back in the day was dead on arrival I can't really speak for its oc qualities. Other than that, I think @Strikeeagle1977 got ahold of a Leadtek K8NFXPRO which I had not previously heard of, but they had solid oc boards at the time as well iirc.
Edit:
If I ever get around to testing my MSI K8N Master2-FAR I could provide some insight wether it performs better than the K8N-DL, judging from the BIOS options alone it might be a fairly capable board as well, for either single or dual cpu use.
Die große Frage ist, ob mein 4800+ soweit mitspielt 200MHz und CL2.2.2.5 macht er
ich habe auch noch ein Set CMX512-3200LLPRO XMS3205v1.1
 4xTCCD, um möglichst hochzukommen (Hoffentlich) 250MHz 2.5-3-3-7
MSI K8T Master2 FAR7I was just wondering if there are dual s940 boards with AGP. Anyone?
Meine zwei sind ebenfalls CAB1E 0613CPMWMein Opteron 154 ist mittlerweile auch da. CAB1E 0613CPMW
DFI und seine BIOS Versionen für unterschiedliche RAM Typen ist auch so eine Wissenschaft für sich. Haben wir vllt. inzwischen genug Datenlage um in der Biosbude vllt. eine optimale Version für die jeweiligen Chips zu definieren? z.B. bestes BIOS für BH-5, BH-6, CE-5, TCCD, D5 usw? Würde auf der Plattform so manche frustrierte Stunde ersparen
würde ich auch toll finden. Bisher habe ich nicht viele BIOS Versionen getestet. Genug RAM habe ich eigentlich da.Brauche mehr Zeit.
good to know. Need to test several BIOSes. I used one of the Big Toe mod BIOSes this time.
Ich hole das mal hier rüber, passt im 939er Thread besser...You could try LD329, 704-BTA and ND623 (-1). I think I tested those myself after doing some research.
 Und ich würde wegen des 250er Ramteilers eher das 702er Bios als Basis nehmen, falls man den Teiler braucht.
 Und ich würde wegen des 250er Ramteilers eher das 702er Bios als Basis nehmen, falls man den Teiler braucht.Here is the differences between the dash numbered BIOS's:
-1 uses 3.26 ram table general purpose (most ram)
-2 uses 3.16 ram table UTT/BH
-3 uses 3.10 ram table TCCD
1) The 3/10 ram table limits you to 2 Memory Modules, Dual Channel, in Orange Slots only.
2) BIOS's starting with 3/16/05 and newer, the 2 Memory Modules could go into either the Yellow or Orange slots. This means BIOS's with RAM tables 3/16 and 3/26 can have 2 Memory Modules, Dual Channel, in either Yellow or Orange slots.
3) Yellow slots 1 and 3 are suppose to be better suited for Higher Vdimm voltages and therefore UTT/BH-5 types of Memory Modules.
4) Orange slots 2 and 4 are suppose to be better suited for normal-to-lower voltages and therefore TCCD/TCCC/TCC5 types of Memory Modules.
Danke für das Zusammenfassen.Ich hole das mal hier rüber, passt im 939er Thread besser...
Im Prinzip gibt's vier Möglichkeiten am DFI Ultra-D:
1. 3.26er Ramtable (-1)
2. 3.16er Ramtable (-2)
3. 3.10er Ramtable (-3)
4. Das letzte offizielle 329er Bios mit der Expert Ramtable
Das 704-2BTA basiert auf -2, das 623-1 auf -1, dann noch das 329 (Expert). Fehlt noch ein -3 Bios würde ich sagenUnd ich würde wegen des 250er Ramteilers eher das 702er Bios als Basis nehmen, falls man den Teiler braucht.
I was also thinking about it. If the Expert RAM Table are working fine, I would probably stay with it.I know I found it verry confusing all those different bios versions. On my Dr. Expert I use a stock BIOS and I reach high speeds on all ic’s. After noticing it always worked I never used my Ultra D again. I think I ended up with LD329 on my Ultra D because it is based on Dr. Expert.
Ich frage mich, was die verschiedenen BIOSe einstellen? Ich denke mal es geht um die Read Preamble / Max Async Latency Werte.Müsste man also mal die vier Varianten mit TCCD und BH-5 auf maximalen Takt und testen und bei einem festen Takt (z.B. 250Mhz BH und 280Mhz TCCD) auf Leistung testen.
