Beim Ausbauen des FX-55 hat sich nun wie erwartet auch der zweite Pin verabschiedet, sollte aber ebenfalls ein nicht belegter sein, wenn ich mich recht erinnere
Immerhin hab ich bei dem Kollegen dann keine Scham auch mal unter Trockeneis (oder so ich es mal hinbekomme LN2) etwas Feuer zu geben - hoffentlich hat er auch Potenzial
@Sparksnl since (at least by perception) you're working a lot with the NF4 Expert - do you use it with TCCD or mostly with Winbond?
Did some testing yesterday and mine absolutely did not like any TCCD modules, after spending some time with google this doesn't seem to be unusual.
I switched my BIOS to the E704-2BT (BigToe Modbios for the Expert), which certainly did help, got to 300 2.5-4-4-8 1M, but 32M stability still is an issue.
Apparently there were Merlin Modbioses for the Expert as well, but I did not find any working mirrors, didn't find any on BiosBude either.
I will cross check with other modules which I already tested on my Ultra-D and maybe another CPU (currently using an Opteron 154), but figured it might be worth asking for insights here.
My NF4 Ultra-D certainly is less picky with Samsung sticks and I have most settings dialed in to where I get solid results, maybe I'll switch back to that for testing the new DIMMs from redux.
