This is the wayFor 2D Benchmarks I would probably go with Winbond as well,
Usually you can't match the efficiency of low latency at 270Mhz with TCCD, even at 300+ Mhz. Depending on the achievable clocks on your 2x512 and 2x256 sticks you might want to run the dual ranked 512mb, as these also have a little efficiency boost over the 256mb ones. Usually the smaller sticks won't compensate it with higher clocks.
I'm not sure if this also applies when TCCD sticks (binned on chip level) come into play. Iirc bschicht86 has made some sticks with clock 310Mhz+ at 2.5-3-3 in memtest. Same applies for winbond though, i expect chip-binned winbond to clock 250 at 3.2V and 260 at 3.3V easily. Maybe 280-290Mhz at 3.7-3.8V.
Iirc the best bios for expert is the latest, as DFI made adjustments to the ram tables. On the regular Ultra-D you got four options: some modbios with different sips (-1/-2-3) and the last official. Dfi ported the expert ram tables to ultra-d.I switched my BIOS to the E704-2BT
Yes, sadly i'm lacking a lot of files. I got a backup of Lejabeach though (yes, it's missing a SSL cert...) :didn't find any on BiosBude either.
And there's the TPU DFI pages:
TechPowerUp
