[Sammelthread] Abit AW9D / MAX (Intel i975X)
Ich bin mal so frei und eröffne, da heute offiziell die ABIT AW9D Series vorgestellt wurde, einen Sammelthread:) !
Specs:
AW9D
Preis: http://www.geizhals.at/eu/a214105.html
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D&pSOCKET_TYPE=LGA775
CPU
* Designed for Intel® LGA775 processors with1066/800MHz FSB
* Supports Intel® Core™ 2 Duo & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
* Supports Intel® Hyper-Threading / XD-bit / EM64T / EIST Technology / Virtualization Technology
* Intel® Quad Core ready.
Chipset
*Intel® 975X / Intel® ICH7R Express Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual channel DDR2 800/667 Un-buffered / Non-ECC memory
Graphics
* Supports Dual PCI-Express X16 slots (dual ATI® CrossFire™ Graphics)
LAN
* On-board PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
* abit AudioMAX™ HD 7.1 CH
* Supports Jack Sensing and S/PDIF In/Out
* Dolby® Master Studio Certificated
Expansion Slots
* 2xPCI-EX16, 2xPCI-EX1, 1xPCI, 1xAudioMAX™
Internal I/O Connectors
* 1 x Floppy port, 1 x UDMA 100/66/33 connector,
* 4 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers
* 1 x FP-Audio header, 1 x CD-IN
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 4 x USB 2.0, 1 x RJ-45 LAN
Serial ATA
* ICH7R: 4 x SATA 3Gb/s supports Intel® Matrix Storage SATA RAID 0/1/0+1/5
* Support SATA AHCI, providing native command queuing and native hot plug
abit Engineered
* abit µGuru™ Technology
* abit OTES™ Technology
* Quick Power & Reset Buttons
* Low ESR and high ripple conductive polymer aluminum solid capacitors
RoHS
* RoHS Compliancy
Form Factor
* ATX form factor 305 x 245mm
* PCB Color: Black
AW9D-MAX
http://img208.imageshack.us/my.php?image=aw9dmaxangle500lz4.jpg
http://img209.imageshack.us/my.php?image=aw9dmaxtop500al3.jpg
http://img234.imageshack.us/my.php?image=maxof9.jpg
Preis: http://www.geizhals.at/eu/a214107.html
Lieferumfang:
- AudioMax HD 7.1 Soundkarte
- SLI Bridge
- Quick Setup Manual, ausführliches Manual, **** Manual
- Jumper Settings Aufkleber
- 7! SATA Kabel
- 3 SATA RAID Floppys (32 und 64 Bit Sil, Intel RAID)
- Treiber CD
- Optisches Audiokabel
- Je 1 IDE und Floppy Kabel, gerundet
- Bracket mit 2x USB und 1x Firewire
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D-MAX&pSOCKET_TYPE=LGA775
CPU
* Supports Intel® Core™ 2 Duo(Extreme Edition) & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
Chipset
Memory
Graphics
LAN
* On-board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
Expansion Slots
* 2xPCI-EX16,2xPCI-EX1,1 xPCI, 1x AudioMAX™
* 7 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers, 2 x IEEE1394 headers
Back Panel I/O
* 4 x USB 2.0, 2 x RJ-45 LAN,
* 1 x eSATA
Serial ATA
* ICH7R: Support SATA AHCI, providing native command queuing and native hot plug & play
* Silicon Image:3132: 4 x SATA 3Gb/s, two SATA connectors of the same area can support SATA RAID 0/1
IEEE 1394
* 2 ports IEEE1394a at 400 Mb/s transfer rate
abit Engineered
* abit Silent OTES™ 2 Technology
* Back-light Blue LED's
RoHS
* RoHS Compliancy
Form Factor
* PCB Color: Black & Blue
FAQ zum ABIT AW9D-MAX (Vielen Dank an Sicness):
Wichtige Links:
Produktseite bei abit
BIOS download
Manual download
abits interne Kompatibilitätstests
Thread @ XtremeSystems.org
Gelten die folgenden Angaben auch für das non-Max oder Fatality?
Nein, beide Boards sind bis heute nicht erhältlich. Daher gilt dieses FAQ ausschliesslich für die Max Version.
Passt meine PCI-Karte in den PCI Slot wenn ich CF/SLI nutze?
Wenn die GraKa nen Single Slot Kühler hat wird der PCI nicht blockiert, bei einer Flachen WaKü a la Inno oder AC ebenfalls nicht.
Hey, da ist ja ne SLI Bridge dabei. Wird SLI offiziell unterstützt?
Nein, SLI ist nur mit gehackten Treibern möglich.
Bei mir funzt µGuru nicht richtig! Was ist los?
Das Problem tritt beim Release Bios in Verbindung mit einem Raid auf!
Lösung ist das neue .12 Bios!
Laufen 7900/7950GX2 problemlos auf dem Board?
Ja, die 7900GX2 läuft absolut problemlos.
Meine 7950GX2 bringt nur die halbe Leistung! Was ist hier los?
Laut dem User Dr.Wakeman liegt das an der µGuru Software.
Es verträgt sich nicht mit den aktuellen Forceware Treibern!
Der SLI Algorithmus läuft weder mit SFR, AFR oder AFR2.
Gibt es bekannte Probleme mit irgendwelchen RAMs?
Bisher nur eine Meldung, OCZ XTC Gold PC6400 C5 mit Elpida Chips laufen nicht mit 1:1, mit anderen Teilern jedoch problemlos. Micron D9 laufen einwandfrei.
Kann ich die Heatpipe entfernen und die Passivkühler in Kombination mit meiner Chipsatzwakü nutzen?
Nein, die Heatpipes sind fest verlötet. Es müssten in diesem Fall seperate passive Kühlkörper besorgt werden.
Falsch! Turrican bestätigt dass die Heatpipe nicht verlötet ist!
Bilder:
Was taugt die Heatpipe Konstruktion?
Die Kühlung arbeitet überraschend effizient, einen gewissen Luftstrom vorrausgesetzt lassen sich moderate Übertaktungen ohne zusätzliche Kühlung bequem bewältigen.
Sehe ich richtig? Das Board hat Lochhalterungen? Ich dachte Intel benutzt Ösen.
Richtig, abit bildet hier eine Ausnahme.
Wie hoch geht denn nun der FSB?
Die bisher höchsten Meldungen liegen im Bereich 450-460MHz, jedoch sind hier wohl die Chipsatztimings straffer als bei anderen 975X Boards. Sicher ist aber wohl ~420 MHZ!
hipro5 schrieb:
I also would like to add that ABIT "played" my Fadbodies a bit tighter that ASUS or Bad Axe......In 2k5 I got about 80 to 100 points more with ABIT with the EXACT same config as with ASUS/INTEL.......No big deal especially on air BUT when you go for the max, it counts.....Those points will be 200 - 300 on LN2 so as for me it counts.....
Ist es besser als die anderen 975X Bretter?
Lässt sich bisher noch nicht sagen, das Board hat bisher noch kein offizielles BIOS Update erfahren und ist wesentlich kürzer am Markt als Asus & Co. Es ist in jedem Fall vielversprechend und scheinbar sein Geld wert.
Welche Spannungsoptionen sind vorhanden?
VCore: 1,32V - 1,725V
VDIMM: 1,80V - 2,65V
MCH: 1,50V - 2,00V
Hat das Board auch das Shutdown Problem nach Übertaktung (vgl. Asus P5WDH)?
Nein.
Welche Straps und Teiler gibt es?
PSB533: 1:2
PSB800: 3:4, 3:5, 1:2
PSB1066: 1:1, 4:5, 2:3
Wieviele Lüfter kann ich anschliessen und was kann die Lüftersteuerung?
Das Board hat 7 Lüfteranschlüsse, jeder Lüfter ist zwischen 6 und 12V regelbar. Ausgenommen ist der CPU Lüfter, dieser kann nach Temperatur geregelt werden.
Was taugt die **** Software?
Die Software liest unter Windows Temperaturen, Spannungen, Lüftergeschwindigkeit und sogar Power Cycles aus. Übertakten in Windows ist hiermit kinderleicht möglich und funktioniert absolut einwandfrei, sofern man nicht die Grenzen der Hardware überschreitet ;)
Gibt es schon Alternativen zur **** Software?
W1zzard wird diese Woche (18.09.2006 ff) ein AW9D-Max bekommen und Support fürs Brett in SysTool einbauen.
Hilfe! Mein Board bootet einwandfrei aber ich habe trotzdem ein Piepkonzert! Ich benutze eine Wasserkühlung.
Sehr wahrscheinlich handelt es sich um das Notsignal des Boards zu Warnung vor 0 RPM am CPU Lüfter Anschluss. Das lässt sich im BIOS (abit EQ) deaktivieren.
Was hat es mit den LEDs auf sich?
Das Board besitzt blaue LEDs, die folgende Optionen besitzen: Alle LEDs an, aus oder verschieden blinkende Modi.
Ich habe von einem fehlerhaften 8 Pin EPS Stecker gelesen. Muss ich beim Board Kauf aufpassen?
Nein, ein solch fehlerhaftes Modell ist bisher weltweit nur ein einziges Mal aufgetaucht und der Fall wurde von abit direkt untersucht. Dies wird nicht mehr vorkommen.
Mein Netzteil hat nur einen 4 Pin 12V Stecker, kann ich das Board auch damit betreiben?
Ja.
Funktioniert EIST mit einem übertaktetem System?
Ja.
Hat abit auch ein BIOS Flashtool für Windows?
Ja, das abit Flashmenu ist im **** Softwarepaket enthalten und funktioniert problemlos.
Kann ich den Multi meiner CPU verstellen?
Ja, seit dem beta BIOS vom 15.09. ist es möglich, den Multi nach unten hin zu ändern. Dies gilt sowohl für ES als auch Retail CPUs.
Seit Alpha Bios 13 ist es auch möglich Multi nach oben zu verändern!
Wie gut ist der Support seitens abit für das Board?
Exzellent. abit ist bestrebt alle auftretenden Probleme so schnell wie möglich aus der Welt zu schaffen und arbeitetet dazu mit Speicherherstellern und einigen Leuten von Anandtech und XtremeSystems.org zusammen. Fortschritte werden umgehend in BIOS Updates umgesetzt.
Welche RAM Bänke soll ich nutzen? 1 und 3 oder 2 und 4?
Macht nach bisherigem Kenntnisstand keinen Unterschied.
Ein paar Bilder des Boards und der OVP bitte!
Die LEDs möcht ich auch mal sehen!
Das BIOS dann bitte auch noch.
Warum zum Teufel komme ich nur bis zu einem FSB von 350MHZ?
Fürs schnelle Testen (natürlich auf eigene Gefahr!!) am besten folgendes einstellen:
C1 und EIST disabled
VMCH: 1,75V-1,9V
DDR2 Voltage: 2,0-2,1V
Ram Timings by SPD / oder manuell
Vcore: 1,4V
Speicherteiler 1:1
Dann Testen und vorsichtig heran tasten! Gegebenfalls dann Spannungen nach unten senken!
Das ABIT ist anscheinend sehr abhängig vom richtigem RAM!
Deshalb nicht gleich aufgeben:)
WICHTIG:
Laut Hipro aus Xtremesystems undervoltet die MCH Spannung mit 0,2V!
Hier der Link zum Statement und Mod:
http://www.forumdeluxx.de/forum/showpost.php?p=4447534&postcount=1118
Hier die Vcore Tabelle von w1zzard (THX):
MIPS Wasserkühler für das ABIT AW9D-MAX
Preise:
Freezer: 39,90€
Mosfet Bridge: 43,00€
Komplettset : 155,00€
die freezer sind wie immer aufgebaut, d.h. kupferboden 5mm, messingdeckel
5mm.
Unterschiede zwischen AW9D und AW9D MAX:
Das MAX hat ne Blaue LED Rückseitenbeleuchtung+
den angewinkelten IDE Port + Firewire
Links & Downloads:
Final Bios 12 (THX@Kabautermann):
http://www.hardwarextreme.de/dave/aw9d12.rar
BIOS Downloads vom ABIT ftp server:
ftp://ftp.abit.com.tw/pub/download/bios/
Die Biosversionen fürs Non-MAX und MAX sind anscheinend die gleichen, da nur ein
AW9D Verzeichnis vorhanden ist!
Thread zum Retail Board bei Xtremesystems (Sicness:):
http://www.xtremesystems.org/forums/showthread.php?t=115839
Thread zum Retail Board im ABIT Forum (Danke Sicness):
http://forum.abit-usa.com/showthread.php?t=112896
Vielen Dank an TuricanM3 und Latest für die Pics und Scines für die FAQ
jo denke ich auch
und big thx für den link -- hab ich so noch nirgendwo gelesen oder erklärt bekommen.
und wir haben schon gedacht ( Arbeitskollege und ich )
das Board spinnt ein bisschen als da was von 580-600MHz FSB stand
aber das erklärt so einiges. und wirft bei mir gleich 2 ne 3 Fragen auf.
1. trifft das nur bei 965/975X chipsets oder auch bei den
Chipsätzen P:35/45 X:38/48 zu?
2. wie bekommendie das dann mit EIST bzw C1E hin?
( denn hier wird ja der multi verändert um somit die Corespannung reduzieren zu können um Energie/Wärmeverlustleistung im Sys idle zu sparen )
oder wird einfach der multi @ boot genommen (default z.B.9 ) um die NBCC zu setzen/ermitteln welche dann nicht mehr verändert wird wenn der Multi nachträglich herabgesetzt wird z.B durch EIST.
3. könntest du mich mal im hinterkopf behalten wenn es mit dem X3120 soweit ist?
Klar kann ich dich wegen dem Xeon im Hinterkopf behalten. Ist ein G0 X3210, der bei Standard Vcore von ~1.15V die 3GHZ locker mitmachte (mit Linpack getestet). Alles weitere war durch's umodifizierte XBX2 begrenzt. Ins AW9D konnte ich ihn zum testen nicht einbauen, weil das System für meine Projektarbeit laufen musste. Sprich da durfte ich mir keine Probleme leisten.
Wenn du Interesse hast, schreib mir einfach mal ne PM mit nem Preisvorhsclag. Man kann über alles reden. ;)
Und zum Thema, ob das oben verlinkte Problem auch für neuere Chipsätze zutrifft, k.A.. Dazu hab ich zuwenig Detailinfos zu den Dingern. Und ohne Entwickler zu sein (was ich noch nicht bin), kommt man da leider auch schwer dran.
Der Gedanke mit EIST/C1E könnte hinkommen. Sprich, eventuell tritt das Problem nur auf, wenn der Multi bereits bei Bootup verändert ist. Aber wiederum kan ich nur sagen, dass ich hierfür zuwenig Infos habe. Ich kann da leider auch nur genauso mutmaßen. Aber da ich eher weniger von konkreten Problemen mit EIST/C1E gelesen habe, können sie wohl nicht allzu extrem sein, selbst wenn sie existieren.
Tach auch Ihr Leuts.
Ich hab da mal Fragen:
Da mein Gigabyte GA-965P-DS4 nun langsam den Geist aufgibt, ums genauer zu sagen Der Chipsatz hat einen Schaden im Bereich Intel SATA Controller und PCIE Bus, muss ich nun leider ein neues Board kaufen, obwohl ich im Sommer zur I7 Plattform wechseln möchte.
Nun gut, jetzt habe ich mir dieses Forum (nicht komplett) durchgelesen und war einerseits überrascht, auch der anderen Seite erschrocken.
Überrascht weils doch immer noch ein gutes Board ist und erschrocken ob der vielen Probleme die einige damit so haben.
Da einiges für mich doch etwas verwirrend ist, möchte ich hier lieber mal Euch fragen, die Ihr das Board schon lange habt, bzw. hattet.
Wie gesagt, es soll zur Überbrückung bis Sommer 09 sein und mein 965er ersetzen.
Ich habe gerade fokgendes gekauft und möchte es mit dem Board weiternutzen:
Intel Core2Quad Q6700 Boxed.
XFX-GTX260-xXx-OC 691/1458/1152 Undervoltet @1,03V Modbios.
OCZ-XTC-Gold PC6400 (800Mhz) 4x1GB Rev. 2.0 Dualchannelkit
Arctic Freezer Extreme (ein richtiger Brocken) 8 Heatpipes
Nun die Fragen:
1.
Der Quad soll mit Std. 1333 Mhz, also 333 ;hz FSB 24/7 bei allen aktivierten Stromsparmechanismen laufen. Natürlich möchte ich da auch nochmal das Maximum ausloten. Mit meinem beschädigten Board (siehe Sig) gingen Max. 3,8 Ghz bei 1,46 V (real).
Gehen die 333 Mhz FSB Problemlos mit einem Quad?
Ist auch weiteres OC möglich?
2.
Der CPU Kühler ist ja ein richtiger Brocken, der bei meinem Board auch noch zwischen den Heatpipes passt. Optisch sehen die Kühler des AW9D-Max größer aus.
Kann es Platzprobleme geben?
3.
Die Grafikkarte nutzt ja PCIE 2.0, mein Board und das AW9D hat aber nur 1.1 Standart, um das auszugleichen, habe ich meinem Board den PCIE Bus auf 110-120 Mhz anheben können, dazu die PCIE Spannung um +0,05V angehoben.
Wie sieht es hier bei dem Board aus?
4.
Ich las, dass es mit den OCZ Gold Probleme mit den Teilern geben soll.
War damit der alte OCZ Gold gemeint oder auch der XTC Rev. 2.0?
Und zum Abschluss.
Ich nutze Vista Ultimate x64, wie siehts da beim Wechsel aus? Muss ich alles neu installieren?
Hab die 965er Treiber alle auf dem neuesten Stand.
Also Intel Storage Manager und Treiber 8.6.0.1007
J-Micron Sata Storage Controller 1.17.39
Marvel Lan Treiber 10.64.9.3
Intel Chipsatz 9.1.0.1007
Realtek HD Sound R2.13
Was muss/sollte ich vor dem Umbau beachten?
Welche Biosversion sollte ich Flashen?
Vielen dank schon mal.
1. Quad auf unmodifiziertem AW9D = kein Overclock oder im besten Fall weniger als von anderen Boards gewohnt. 300MHz FSB scheinen schon gut zu sein mit nem Quad auf dem Board. Man kann eigentlich froh sein, wenn er bei Standardtaktung optimal läuft. Alles weitere ist Bonus auf dem Board.
2. Leider keine Ahnung, weil ich weder die original Heatpipekonstruktion des Boards, noch den AC Freezer Extreme nutze.
3.Das Board hat im BIOS keine Möglichkeit den PCI-E Takt anzuheben. Die PCI-E Spannung ist gleich der Chipsatzspannung. Dein Plan wird also so nicht funktionieren.
4. Frage am Besten an OCZ stellen, das wäre pures Glück wenn hier jemand genau die Kombination hat. Aber vielleicht hast du ja Glück.
Und zum Wechsel auf's neue Board:
Mit dem alten möglichst noch einmal booten, alle Treiber deinstallieren, die du von Hand deinstallieren kannst. Dann herunterfahren und Board wechseln. So kann das neue Board erkannt werden ohne eventuell von alten Treibern "gestört" zu werden. Danach alle nötigen Treiber installieren, und es sollte gehen. Dafür gibt's aber keine Garantie, also vorher schön Daten sichern.
Danke für Deine Antwort, aber was meinst Du mit "unmodifiziert"???
Gibts da Tricks, bei denen ich meinen Schneidbrenner endlich wieder nutzen kann?
Meinst Du nachrüstung der Chipsatzkühlung?
Ein weiterer Wink wäre nett.
Dann noch:
Wie siehts denn mit dem PCIE Bus aus, bei meinem Board auf Atu stehen hebt sich der mit Anheben des FSB mit an, es sei denn ich verstelle den manuel.
Man kann also sagen, dass für den Quad das Board "weniger" oder "nur" mit std. Einst. brauchbar ist?
Ich meine du solltest mal die letzten Seiten dieses Threads lesen, dann sind deine Fragen beantwortet. ;)
also mein G0 Q6600 schafft auf meinem IX38Quad GT 3,885GHz
( armea Brett -- kurz vorm Spawa tod bei ca 100-110A )
und das AW9D-max das ich damals hatte mit gleichem Q6600
waren am Anfang knapp 3GHz drin was schon überm durschnitt war.
wenn du einen "sehr guten Q9700 hast"
werden es vielleicht 3,2-3,3 GHz aber dann müsstest du echt
Glück haben.
hab das Brett wieder gekauft weil es so schön leuchtet und blinkt
für``n Black mod mit Fenster usw
ich denke du solltes nach nem P35-P45 Brett ausschau halten
die bekommst du gebraucht im Marktplat ab 50€ aufwärts
je nach Hersteller.
Ich denke Gigaschrott; MSI oder Asus wären ok
DFI hat n Mörder Bios da brauchste fast ne Schulung drauf
( macht aber auch Laune )
und wenn es kein Enthusisten Brett sein muß
bist du damit im grünen Bereich.
P.S. mein Max hab ich für 50€ neu aus der Bucht gezogen
:heul::heul::heul:vor 2 Jahren waren das noch knapp 200€ :heul::heul::heul:
Also was glaubst Du, was ich gemacht habe?
Deine Antwort
Es ist meine Art, zunächst zu lesen und dann Fragen zu stellen.
Da aber nach dem Lesen immer noch die Fragen offen waren die ich hatte, bzw. sogar neue dazu gekommen sind, habe ich meine Fragen gestellt.
Ich glaube, alsi ich hier angefangen habe, bekam ich ständig solche Antworten.
Jetzt geht das schon wieder los?
Gibts nicht nur ein FSB Loch sondern auch ein Antwortloch???
Manchmal fragt man sich, warum man solche Aussagen, die keine Antworten sind, bekommt.
Selbst wenn man was überlesen hat, und Du das weist. dann poste doch: "Lies mal hier; und füge nen Link zum Post ein.
Ich helfe ja auch in den threads hier, in denen ich mich beteilige.
GTX260
Core2Quad
P965
Ahci
8800GT
Und was weiß ich noch wo alles.
Nimm doch mal eine meiner Frage und poste dazu eine Antwort dieses Threads oder von sonstwo bei Luxx.
@All
Es soll ja "nur" bis Sommer reichen bei 3,33 Ghz @24/7
Dan kann ich ja lieber hoffen, dass mein Board es noch bis zum Sommer schafft. Dann wird es erlöst, dann kommt I7, mit dann endlich offener PCIE Schnittstelle, statt der Fesseln CF oder SLI.
Aber ich denke, das kann ich knicken.
GTX260
Core2Quad
P965
Ahci
8800GT
Genau deine Fragen wurden in den letzten (~10) Seiten dieses Threads mindestens 1x beantwortet. Das weiß ich, weil ich derjenige war, der unter anderem die Antworten beigetragen hat. Also entweder kannst du nicht lesen, oder du verstehst das gelesene nicht. Wenn du also zu deinen gestellten Fragen noch antworten brauchst, dann zitiere den Beitrag in dem die Antwort bereits gegeben wurde und nenne explizit was dir unklar ist. ;)
Willst Du hier den Bock zum Gärtner machen oder was soll das?
Dieser Thread besteht aus 21 Seiten, die ich praktisch alle gelesen habe.
Ich las nirgends von:
Ich hab die OCZ-XTC-Gold Rev 2.0 PC6400, laufen die?
Ich hab nen Q6700 G0 (nicht Q6600 B3), wie weit kann ich den Ocen?
Meine Graka hat PCIE 2.0 kann ich den PCIE Bus anheben?
Passt mein Arctic Freezer zwischen die Chipsatzkühlung.
Aber behallte Dein Wissen dann für Dich, wenn ein Board bei Deluxx derart Supportet wird, möchte ich es nicht haben.
Sollte mir derartige Antworten ev. auch angewöhnen.
Thema hat sich für erledigt.
Abo für den Thread lösche ich jetzt.
Abo für den Thread lösche ich jetzt.[/QUOTE]
tja. ich will ja nicht böse klingen: ist aber auch gut so
denn Celemine hat recht. Nicht nur lesen sondern auch verstehen.
1. habe dir doch eigentlich schon gesagt das du das mit dem Q6XXX auf dem Brett knicken kannst. denn alles über Standart mit egal welchen Q ist Glücksache
2. Mit dem PCIe Bus fix@100MHz wurde kürzlich erwähnt.
und das die Karten der PCIe 2.0 Version abwärtskompatibel sind steht auf diversen Hersteller Seiten.
3 ob " dein " Speicher nun auf dem Board läuft. who should know? nobody!
4 Dein Monsterkühler der AC sollte eigendlich passen oder steht das Board
in verbindung mit dem Hühler in irgend einer InkompatibilitätsListe ( booaahh
was ein Wort ).
nochwas
Celemine behält sein Wissen nicht für sich. sondern teilt es allen auf Wunsch hier mit.-- Er hat es halt nur schon so oft getan das er mal n bisschen genervt reagiert.-- da hast du widerum recht- das geht auch etwas netter
und das der Fred hier noch so frequentiert wird liegt wohl mit Bestimmtheit daran das dieses schon 2 1/2 Jahre alte Board so schlecht supportet wird:fresse:
Edit
bist zwar schon raus abwer nochmal für dich Post`s
http://www.forumdeluxx.de/forum/showpost.php?p=10941785&postcount=571
http://www.forumdeluxx.de/forum/showpost.php?p=10626582&postcount=542 und volgende
Ich würde ja gar nix sagen, wenn's nicht wirklich direkt auf den letzten Seiten stehen würde.
Da er noch nichtmal richtig Bezug auf etwas nehmen kann, das direkt auf der gleichen Seite steht, bezweifle ich, dass er den Thread wirklich gelesen und verstanden hat.
Also nix für ungut. Ich kann durchaus netter antworten. Aber ich bin nicht der Forenbuttler, der auf Zuruf Antworten ausspuckt, auch wenn diese schon mehrmals, erst kurz zuvor gegeben wurden.
Eigeninitiative scheint immer mehr ein Fremdwort zu werden.
ich weiß
hatten ja schon des öfteren das Vergnügen.
aber sah jetzt schon fast n bisschen Zickig aus
also nix für ungut und viel erfolg im Verkaufsfred.
hab gerade noch n X38 von DFI geschossen daher erst mal Kohle alle.
Leute ohne Eigeninitiative haben mich im Studium schon dermaßen viel Nerven gekostet, dass ich nun ein wenig allergisch drauf reagiere. Kann ich absolut nicht mehr ab.
Und X38 und DFI in einem Satz, das klingt vielversprechend. Bin ja mal gespannt, ob du mit Optimierungen an die Clock/Clock Leistung des 975X rankommen kannst.
Hallo, gibt es schon was Neues in Sachen E8600 ?
Wäre nicht schlecht, wenn der auf dem Board laufen würde.
In der CPU Support Liste steht, dass es getestet wird.
Habe mir auch das Board geangelt, wird aber vorerst mit einem P4EE 3,46 GHz (Gallatin Core) und 2 GB Corsair 5400UL 3-3-2 Speicher laufen.
MFG Thomsen
Da Abit den Betrieb einstellt, bezweifle ich mal stark, dass du da noch eine offizielle Aussage dazu bekommen wirst. Es wird wahrscheinlich drauf hinauslaufen, dass du selber testen musst, sofern sich nicht zufällig doch hier noch jemand findet.
naja hab das mal gerade überschlagen und komm mit
locker 100€ weniger für die gleichen komponenten aus
aber zum problem mit dem E8600
das C0 stepping lüppt bis auf die halben multi`s
sprich n 8500er läuft nur als 8400er
ich weiß nicht ob es den E8600er überhaupt noch im C0 gegeben hat-
meine aber nicht
und als vergleich hätte ich nur n 7200er wobei das stepping unklar ist/bleibt
also wenn du richtig günstig an nen 8600er rankommst um zu testen
wirst du den hier im MP sicher wieder los wenn er nicht läuft.
und wenn er läuft dürfte oc mäsig denke ich mal nicht viel drin sein.
werde jedenfalls nicht meinen E8500er vom IX nehmen und mal eben testen
sorry
aber ich denke auch nicht das da nochmal was kommt-- Bios mäsig
ist zwar für die E8xxx nochmal was passiert aber schon letztes Jahr
und das 17er beta gibt es auch nicht mehr
denn wie bekannt Abit hat die Mobo fertigung eingestellt.
also so wie es "leider " momentan aussieht könntest du hier der erste sein der es genau weiß:d
Es gibt zwar kein 17er Beta mehr, dafür ist das 17er Final schon seit Monaten (fast ein Jahr) auf der Abit Site.
ok dann ist halt das final nicht mehr verfügbar.
ich habe schon des öfteren danach gesucht immer ohne Erfolg
So, nächste Woche bekomme ich vielleicht einen E8xxx mit E0 ausgeliehen und dann werden wir sehen, ob es geht oder nicht ;-)
na da bin ich mal gespannt
aber mehr als 4 GHz ( 400Mhz ) werden wenn er läuft denke ich nicht drin sein
aber schaunmermal
So, da bin ich wieder.
Jetzt zum Test. Gestern Abend hatte ich einen offenes System aufgebaut, um die Komponenten schnell wechseln zu können, falls was nicht funktioniert.
Das Erste was mir passiert ist, der P4EE wurde nicht unterstützt, obwohl Dieser älter als das Board ist. Also bin ich dann schnell zum Kumpel und habe mir einen Pentium D805 geholt. Zack, die Kiste gibt Bild. Schnell die Bios Version 17 drauf geladen. Dann wieder den P4EE ins Board und er postet. Genial dachte ich *g*. P4EE wieder raus und nun kam der neue E8400 im E0 Step rein. Knopf gedrückt und das Teil postet auch :-). Im Windows taktet er im Idle auf 2 GHz und unter Load wechselt er ordentlich auf die 3 GHz. CPU-Z zeigt leider kein SSE4.1 Support. Das ist aber auch der einzige Nachteil, ansonsten funktioniert alles.
So, ich hoffe etwas Licht ins Dunkel gebracht zu haben :-).
Ich denke aber, dass das SSE4 "Problem" eher ein Auslesefehler von CPU-Z ist. Würde mich wundern, wenn die Unterstützung durch's BIOS beschränkt wäre. Dachte eigentlich, dass das CPU-intern geregelt wird.
Aber vielleicht würde's auch helfen einfach den Microcode aus nem anderen BIOS (anderes mit E0 Unterstützung) ins 17er einzubauen um die volle Unterstützung zu bekommen. Who knows?
Sse4.1
Nope, das ist ein BIOS Problem, das E0-Step spezifisch ist, trat auch auf meinem Intel D975XBX2 (i975X) auf, und auch andere Mainboards mit P35 Chipsatz oder sonstigen Chipsätzen brauchen spezifischen BIOS Support für E0 Step C2D/C2Q, damit SSE4.1 geht.. Grund liegt meiner Meinung nach darin, daß die Feature Flags, bzw. deren Register verschoben wurden.. Konnte das aber noch nicht nachweisen, müßte man mit WPCREdit o.ä. schaffen können denke ich.. Mit irgendeinem PCI Registereditor / MSR Editor halt.
btw., von mir stammt übrigens der P4EE, viel Spaß damit! ;)
Danke. Damit wäre das auch geklärt. Fazit: Offizielle Lösung ausgeschlossen. Aber das war ja bei Abit im Moment eh klar. :)
E5200 & Abit AW9D-MAX
weiss zufällij jemand, ob die obenstehenden Komponenten problemlos harmonieren?
lt dieser Liste steht der E5200 ja unter kompatiblen CPUs, oder?
http://www.abit.com.tw/cpu-support-list/mb/intel_975x_aw9d_series.htm
Was mich allerdings irretiert ist, dass da bei dem E5200 bei Results ''Test'' steht.
Kann mir da einer genauere Informationen geben evtl. sogar jemand hier mit der Konfig (E5200 + Abit AW9D-MAX).
Wichtig ist auch, dass es mit dem Auslieferungsbios läuft - da ich nur diese Sockel 775 CPU besitze.
Der E5200 besitzt übrigens einen x12,5 Muliplikator - wir sicher nicht damit laufen, oder?
Vielen Dank.
@celtic, das musst du wohl testen. Beim E8400 E0 steht auch Test.
Aber er läuft ja, wie du siehst.
Eine alte CPU zum flashen wirst du benötigen.
Mein Board habe ich vom Händler neu gekauft und es war die Bios Version 12 drauf. Nicht mal der P4EE ging damit, obwohl die CPU älter als das Board ist.
Danke für deine Antwort.
Übrigens eine sehr, sehr geile, kultige Konfig. die du hast: AW9D-MAX, Gallatin und die Corsair UL mit Micron D9DQW oder DQT, oder?
Na ja, eine alte CPU zum testen habe ich wie gesagt nicht und der engere Freundeskreis auch nicht. Die Tage krieg ich wohl ein E8400 C1 rein.
Also es exestieren auf jeden fall screens im internet, wo jemand die Sachen zusammen laufen hat, meine ich. zumindest hab ich das gelesen.
Ich werd nochmal schauen. Danke schonmal.
Bitte, kein Problem.
Ja, ist schon ein tolles System.
Bei dem Speicher weiß ich jetzt nicht, was da für Chips drauf sind, aber es sind die Corsair 5400UL mit 3-3-2-8 Timings.
Die laufen mit den schärfsten Timings, was das Board hergibt, also 3-2-2 Timings mit 4 fach Bestückung ( 4x 512 MB ). Dank geht an den Admiral Thrawn :-) . Die E8400 C1 Step wird auch nicht laufen, weil sie mit dem alten Bios nicht unterstützt wird. Nimm irgend einen alten P4 oder Pentium D damit wird es gehen. Bios 17 habe ich auch noch da, falls es jemand brauchen sollte.
MFG Thomsen
ich hab das 1.7 er BIOS installiert und für euch nochmal hochgeladen. Hab es seinerzeit vom Abit FTP geladen...
*Download*
Die anderen Versionen befinden sich alle auf dem Abit FTP
Mich würde ja nurmal interessieren, warum das 17er nicht mehr offiziell angeboten wird. Schon irgendwie seltsam.
Also ich hab's seit Monaten drauf und keinerlei Probleme. :hmm:
ich kann ebenfalls nichts schlechtes über die biosversion sagen...
vielleicht liegt es an der changelog? es scheint keine großen veränderungen gegenüber der 1.6er zu geben, außer dem quick power on self test problem:
BIOS release V.16 for AW9D, AW9D-MAX
Release information:
[ENGLISH]
1. Fixed the option in uGuru Utility can't be adjusted when Virtualization Technology is Disable.
2. Fixed CPU Multiplier can't adjust when EIST function is Disable.
3. Enhanced the compatibility with NVIDIA GeForce7950GX2.
4. Support Core2 Duo E8200 and E8400.
5. BIOS compiled date: 01/15/2008.
_________
BIOS release V.17 for AW9D, AW9D-MAX
[ENGLISH]
1. Fixed Quick Power On Self Test function abnormality.
2. BIOS compiled date: 03/03/2008.
