[Sammelthread] Abit AW9D / MAX (Intel i975X)
Ich bin mal so frei und eröffne, da heute offiziell die ABIT AW9D Series vorgestellt wurde, einen Sammelthread:) !
Specs:
AW9D
Preis: http://www.geizhals.at/eu/a214105.html
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D&pSOCKET_TYPE=LGA775
CPU
* Designed for Intel® LGA775 processors with1066/800MHz FSB
* Supports Intel® Core™ 2 Duo & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
* Supports Intel® Hyper-Threading / XD-bit / EM64T / EIST Technology / Virtualization Technology
* Intel® Quad Core ready.
Chipset
*Intel® 975X / Intel® ICH7R Express Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual channel DDR2 800/667 Un-buffered / Non-ECC memory
Graphics
* Supports Dual PCI-Express X16 slots (dual ATI® CrossFire™ Graphics)
LAN
* On-board PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
* abit AudioMAX™ HD 7.1 CH
* Supports Jack Sensing and S/PDIF In/Out
* Dolby® Master Studio Certificated
Expansion Slots
* 2xPCI-EX16, 2xPCI-EX1, 1xPCI, 1xAudioMAX™
Internal I/O Connectors
* 1 x Floppy port, 1 x UDMA 100/66/33 connector,
* 4 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers
* 1 x FP-Audio header, 1 x CD-IN
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 4 x USB 2.0, 1 x RJ-45 LAN
Serial ATA
* ICH7R: 4 x SATA 3Gb/s supports Intel® Matrix Storage SATA RAID 0/1/0+1/5
* Support SATA AHCI, providing native command queuing and native hot plug
abit Engineered
* abit µGuru™ Technology
* abit OTES™ Technology
* Quick Power & Reset Buttons
* Low ESR and high ripple conductive polymer aluminum solid capacitors
RoHS
* RoHS Compliancy
Form Factor
* ATX form factor 305 x 245mm
* PCB Color: Black
AW9D-MAX
http://img208.imageshack.us/my.php?image=aw9dmaxangle500lz4.jpg
http://img209.imageshack.us/my.php?image=aw9dmaxtop500al3.jpg
http://img234.imageshack.us/my.php?image=maxof9.jpg
Preis: http://www.geizhals.at/eu/a214107.html
Lieferumfang:
- AudioMax HD 7.1 Soundkarte
- SLI Bridge
- Quick Setup Manual, ausführliches Manual, **** Manual
- Jumper Settings Aufkleber
- 7! SATA Kabel
- 3 SATA RAID Floppys (32 und 64 Bit Sil, Intel RAID)
- Treiber CD
- Optisches Audiokabel
- Je 1 IDE und Floppy Kabel, gerundet
- Bracket mit 2x USB und 1x Firewire
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D-MAX&pSOCKET_TYPE=LGA775
CPU
* Supports Intel® Core™ 2 Duo(Extreme Edition) & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
Chipset
Memory
Graphics
LAN
* On-board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
Expansion Slots
* 2xPCI-EX16,2xPCI-EX1,1 xPCI, 1x AudioMAX™
* 7 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers, 2 x IEEE1394 headers
Back Panel I/O
* 4 x USB 2.0, 2 x RJ-45 LAN,
* 1 x eSATA
Serial ATA
* ICH7R: Support SATA AHCI, providing native command queuing and native hot plug & play
* Silicon Image:3132: 4 x SATA 3Gb/s, two SATA connectors of the same area can support SATA RAID 0/1
IEEE 1394
* 2 ports IEEE1394a at 400 Mb/s transfer rate
abit Engineered
* abit Silent OTES™ 2 Technology
* Back-light Blue LED's
RoHS
* RoHS Compliancy
Form Factor
* PCB Color: Black & Blue
FAQ zum ABIT AW9D-MAX (Vielen Dank an Sicness):
Wichtige Links:
Produktseite bei abit
BIOS download
Manual download
abits interne Kompatibilitätstests
Thread @ XtremeSystems.org
Gelten die folgenden Angaben auch für das non-Max oder Fatality?
Nein, beide Boards sind bis heute nicht erhältlich. Daher gilt dieses FAQ ausschliesslich für die Max Version.
Passt meine PCI-Karte in den PCI Slot wenn ich CF/SLI nutze?
Wenn die GraKa nen Single Slot Kühler hat wird der PCI nicht blockiert, bei einer Flachen WaKü a la Inno oder AC ebenfalls nicht.
Hey, da ist ja ne SLI Bridge dabei. Wird SLI offiziell unterstützt?
Nein, SLI ist nur mit gehackten Treibern möglich.
Bei mir funzt µGuru nicht richtig! Was ist los?
Das Problem tritt beim Release Bios in Verbindung mit einem Raid auf!
Lösung ist das neue .12 Bios!
Laufen 7900/7950GX2 problemlos auf dem Board?
Ja, die 7900GX2 läuft absolut problemlos.
Meine 7950GX2 bringt nur die halbe Leistung! Was ist hier los?
Laut dem User Dr.Wakeman liegt das an der µGuru Software.
Es verträgt sich nicht mit den aktuellen Forceware Treibern!
Der SLI Algorithmus läuft weder mit SFR, AFR oder AFR2.
Gibt es bekannte Probleme mit irgendwelchen RAMs?
Bisher nur eine Meldung, OCZ XTC Gold PC6400 C5 mit Elpida Chips laufen nicht mit 1:1, mit anderen Teilern jedoch problemlos. Micron D9 laufen einwandfrei.
Kann ich die Heatpipe entfernen und die Passivkühler in Kombination mit meiner Chipsatzwakü nutzen?
Nein, die Heatpipes sind fest verlötet. Es müssten in diesem Fall seperate passive Kühlkörper besorgt werden.
Falsch! Turrican bestätigt dass die Heatpipe nicht verlötet ist!
Bilder:
Was taugt die Heatpipe Konstruktion?
Die Kühlung arbeitet überraschend effizient, einen gewissen Luftstrom vorrausgesetzt lassen sich moderate Übertaktungen ohne zusätzliche Kühlung bequem bewältigen.
Sehe ich richtig? Das Board hat Lochhalterungen? Ich dachte Intel benutzt Ösen.
Richtig, abit bildet hier eine Ausnahme.
Wie hoch geht denn nun der FSB?
Die bisher höchsten Meldungen liegen im Bereich 450-460MHz, jedoch sind hier wohl die Chipsatztimings straffer als bei anderen 975X Boards. Sicher ist aber wohl ~420 MHZ!
hipro5 schrieb:
I also would like to add that ABIT "played" my Fadbodies a bit tighter that ASUS or Bad Axe......In 2k5 I got about 80 to 100 points more with ABIT with the EXACT same config as with ASUS/INTEL.......No big deal especially on air BUT when you go for the max, it counts.....Those points will be 200 - 300 on LN2 so as for me it counts.....
Ist es besser als die anderen 975X Bretter?
Lässt sich bisher noch nicht sagen, das Board hat bisher noch kein offizielles BIOS Update erfahren und ist wesentlich kürzer am Markt als Asus & Co. Es ist in jedem Fall vielversprechend und scheinbar sein Geld wert.
Welche Spannungsoptionen sind vorhanden?
VCore: 1,32V - 1,725V
VDIMM: 1,80V - 2,65V
MCH: 1,50V - 2,00V
Hat das Board auch das Shutdown Problem nach Übertaktung (vgl. Asus P5WDH)?
Nein.
Welche Straps und Teiler gibt es?
PSB533: 1:2
PSB800: 3:4, 3:5, 1:2
PSB1066: 1:1, 4:5, 2:3
Wieviele Lüfter kann ich anschliessen und was kann die Lüftersteuerung?
Das Board hat 7 Lüfteranschlüsse, jeder Lüfter ist zwischen 6 und 12V regelbar. Ausgenommen ist der CPU Lüfter, dieser kann nach Temperatur geregelt werden.
Was taugt die **** Software?
Die Software liest unter Windows Temperaturen, Spannungen, Lüftergeschwindigkeit und sogar Power Cycles aus. Übertakten in Windows ist hiermit kinderleicht möglich und funktioniert absolut einwandfrei, sofern man nicht die Grenzen der Hardware überschreitet ;)
Gibt es schon Alternativen zur **** Software?
W1zzard wird diese Woche (18.09.2006 ff) ein AW9D-Max bekommen und Support fürs Brett in SysTool einbauen.
Hilfe! Mein Board bootet einwandfrei aber ich habe trotzdem ein Piepkonzert! Ich benutze eine Wasserkühlung.
Sehr wahrscheinlich handelt es sich um das Notsignal des Boards zu Warnung vor 0 RPM am CPU Lüfter Anschluss. Das lässt sich im BIOS (abit EQ) deaktivieren.
Was hat es mit den LEDs auf sich?
Das Board besitzt blaue LEDs, die folgende Optionen besitzen: Alle LEDs an, aus oder verschieden blinkende Modi.
Ich habe von einem fehlerhaften 8 Pin EPS Stecker gelesen. Muss ich beim Board Kauf aufpassen?
Nein, ein solch fehlerhaftes Modell ist bisher weltweit nur ein einziges Mal aufgetaucht und der Fall wurde von abit direkt untersucht. Dies wird nicht mehr vorkommen.
Mein Netzteil hat nur einen 4 Pin 12V Stecker, kann ich das Board auch damit betreiben?
Ja.
Funktioniert EIST mit einem übertaktetem System?
Ja.
Hat abit auch ein BIOS Flashtool für Windows?
Ja, das abit Flashmenu ist im **** Softwarepaket enthalten und funktioniert problemlos.
Kann ich den Multi meiner CPU verstellen?
Ja, seit dem beta BIOS vom 15.09. ist es möglich, den Multi nach unten hin zu ändern. Dies gilt sowohl für ES als auch Retail CPUs.
Seit Alpha Bios 13 ist es auch möglich Multi nach oben zu verändern!
Wie gut ist der Support seitens abit für das Board?
Exzellent. abit ist bestrebt alle auftretenden Probleme so schnell wie möglich aus der Welt zu schaffen und arbeitetet dazu mit Speicherherstellern und einigen Leuten von Anandtech und XtremeSystems.org zusammen. Fortschritte werden umgehend in BIOS Updates umgesetzt.
Welche RAM Bänke soll ich nutzen? 1 und 3 oder 2 und 4?
Macht nach bisherigem Kenntnisstand keinen Unterschied.
Ein paar Bilder des Boards und der OVP bitte!
Die LEDs möcht ich auch mal sehen!
Das BIOS dann bitte auch noch.
Warum zum Teufel komme ich nur bis zu einem FSB von 350MHZ?
Fürs schnelle Testen (natürlich auf eigene Gefahr!!) am besten folgendes einstellen:
C1 und EIST disabled
VMCH: 1,75V-1,9V
DDR2 Voltage: 2,0-2,1V
Ram Timings by SPD / oder manuell
Vcore: 1,4V
Speicherteiler 1:1
Dann Testen und vorsichtig heran tasten! Gegebenfalls dann Spannungen nach unten senken!
Das ABIT ist anscheinend sehr abhängig vom richtigem RAM!
Deshalb nicht gleich aufgeben:)
WICHTIG:
Laut Hipro aus Xtremesystems undervoltet die MCH Spannung mit 0,2V!
Hier der Link zum Statement und Mod:
http://www.forumdeluxx.de/forum/showpost.php?p=4447534&postcount=1118
Hier die Vcore Tabelle von w1zzard (THX):
MIPS Wasserkühler für das ABIT AW9D-MAX
Preise:
Freezer: 39,90€
Mosfet Bridge: 43,00€
Komplettset : 155,00€
die freezer sind wie immer aufgebaut, d.h. kupferboden 5mm, messingdeckel
5mm.
Unterschiede zwischen AW9D und AW9D MAX:
Das MAX hat ne Blaue LED Rückseitenbeleuchtung+
den angewinkelten IDE Port + Firewire
Links & Downloads:
Final Bios 12 (THX@Kabautermann):
http://www.hardwarextreme.de/dave/aw9d12.rar
BIOS Downloads vom ABIT ftp server:
ftp://ftp.abit.com.tw/pub/download/bios/
Die Biosversionen fürs Non-MAX und MAX sind anscheinend die gleichen, da nur ein
AW9D Verzeichnis vorhanden ist!
Thread zum Retail Board bei Xtremesystems (Sicness:):
http://www.xtremesystems.org/forums/showthread.php?t=115839
Thread zum Retail Board im ABIT Forum (Danke Sicness):
http://forum.abit-usa.com/showthread.php?t=112896
Vielen Dank an TuricanM3 und Latest für die Pics und Scines für die FAQ
Naja, man könnte es auch einfach als "dazulernen" bezeichnen. Allerdings kannst du das wohl aus Erfahrung mit dem "alt werden" besser beurteilen. :d
Ich glaub ich hab's eh falsch asgedrückt. Das modifizieren der Hardware interessiert mich nach wie vor brennend, schon alleine weil ich eben langsam immer mehr Möglichkeiten habe und eben jetzt weiß was ich tue, wenn ich was modde. Nur ob nun durch nen Mod ein Paar MHz mehr rauskommen, oder es am Ende halt doch "nur" stabil bei den alten Taktraten läuft, ist mir eigentlich inzwischen wurscht. Das Modifizieren an sich war für mich eh schon immer interessanter, als die OC-Weltrekorde.
Ich habe zwei Sata II Festplatten und einen Sata II Brenner in meinem System:
Meine Frage ist nun an welche S-ATA Ports ich diese sinniger Weise anschließe.
Die Systemplatte logischer Weise an den Primary Master (also Port 1), aber an welche Ports die Daten/Backup HDD sowie den DVD Brenner?! Gibt es da Unterschiede, ob die 2. HDD am Secundary Master hängt, oder sollte an diesen lieber der DVD-Brenner?
Bei S-ATA gibt's ja nur Master und keine Slaves mehr. Das heißt, dass du die Geräte eigentlich anschließen kannst wie du willst. Du kannst auch die Systemplatte an den 4. Port hängen. völlig wurscht.
Nur sollte man schauen an welchem Controller die Ports hängen.
Die Platten würde ich auf jeden Fall an die ICH7R (SATA1-4) hängen. Die optischen Laufwerke kannst sicher auch ohne Leistungsverluste am 2. Controller (SATA 5/6) betreiben.
jup da stimme ich zu
nur würde ich den Brenner auch an den Intel Controller hängen und
den anderen im Bios ausschalten-und demnach auch nicht installieren- was man nicht braucht kann auch nicht bremsen.
P.S.
ich habe meine Landose fertig
chick son Abit max -- etwas älter aber dennoch kein altes Eisen
und schön schwarz
Zu dumm, dass man von der Boardoptik nichts mehr sieht, wenn die Kühler alles verdecken :fresse:
Werde demnächst mal meine MIPS Freezer weiß lackieren und mir daraus ein Zweitsystem mit einem kleinen E2xxx oder Celeron D aufbauen, will ja eh keiner mehr das Board, und verschenken möchte ich's nicht.
ja is n sch.. Foto :fresse:
im Original wikt das schon nicht schlecht
aber mit dem weiß lackieren klingt nicht verkehrt-- ist ja gerade die Trendfarbe.
danke für eure antworten :) es war mir nicht bewusst, dass es keinerlei auswirkungen hat...
Hat denn jemand noch ein Abit AW9D-MAX übrig ?
Hätte vielleicht Interesse daran.
MFG Thomsen
hab meins auch aus der Bucht-- war Ende Dez08 von fichtel
aber schau mal hier
Ebay
Artikelnummer: 200328774786
Artikelnummer: 260388822364
oder von "4th floor"
aber der hat es mit verbauter Wakü und so wie es aussieht
wird er es wohl doch behalten
denn Recht haste -- zum verschenken ist`s viel zu schade
Jup, von denen habe ich auch ein AW9D-MAX. Das hat jetzt der Vater. War vor ein paar Tagen auch persönlich bei Fichtel. Wahrscheinlich kommt am Mittwoch nochmal eine Fuhre Boards rein, was dann aber die Letzte ist.
Fichtel hat das vor einigen Monaten gewerblich in größeren Stückzahlen verramscht bei eBay für 35-50€ (neu! - wahrscheinlich Konkursware von Abit), kenn den Händler auch persönlich, da ich früher mal um die Ecke gewohnt habe, aber mein Board (damals noch für ~210€ gekauft) ist nun verkauft.
ja ~200€ronen habe ich für mein erstes Max auch geblecht
und bei Fichtel ~55€ fürn neues gelöhnt.
Da darf man einfach nicht drüber nachdenken;)
Glückwunsch. Ist schon ein würdiger MAX3-Nachfolger.
@4th Floor, du müsstest mich noch aus dem tualatin Forum kennen. Unter Southpole bin ich da angemeldet.
MFG Thomsen
Das Abit ist aber ganz schön zickig was höhere FSB's größer 266MHz betrifft.
Habe Corsair 800MHz, der 3-3-3-9 macht. Aber stabil läufts nicht, wenn ich FSB 278 MHz habe und dann DDR667 mit 3-3-3-9. Ich betreibe es mit einem P4EE 3,46 GHz. Kann es sein, das irgendwie die Chipsatzteimings zu scharf sind bei den Ram Timings?
Wie wär's mit ausprobieren? Ist es so schwer den Strap mal testweise höher zu setzen? Dann siehst du gleich ob das das Problem war. Aber vergiss nicht den Speicherteiler anzupassen.
Hallo, das habe ich schon ausprobiert. Hat nur teilweise was gebracht. Ich konnte dann nur auf 3,536 GHz gehen. 2 Volt habe ich bei MCH eingestellt. Danach war dann wieder Sense. Ich bitte vielmals um Entschuldigung, dass ich es nicht dazu geschrieben habe.
Was willst du denn bei knapp über 266MHz FSB mit 1,8-2V VMch? (in Realität liegen beim unmodifizierten Board weniger als die eingestellten Werte an).
Selbst bei sehr niedrigen Timings wirst du das in den Taktregionen nicht brauchen.
Ist wahrscheinlich ein schlichtes Timing-Problem, wenn Strap auch nicht hilft. Soll heißen, dass das Board wohl irgendein Subtiming zu scharf setzt. Kannst ja mal mit Memset schauen wie's aussieht. Wenn nicht zufällig jemand weiß woran's dann genau liegt, wirst probieren müssen. Ich habe mich schon lange nicht mehr damit beschäftigt. Ich kann also hier höchstwahrscheinlich nicht groß im Detail helfen.
Achja, und nochwas: Hör auf die CPU mit zu übertakten (sollte beim XE ja gehen), wenn du sehen willst was der Speicher kann. Finde erstmal die individuellen Grenzen der Teile und schau danach, was sie zusammen können.
also mein läuft derzeit bei stabilen 382MHz mit 2x2GB kit OCZ ReaperX
und nem Xeon 3060 bei MCH 1,7v -- kann ich aber noch weiter runtersetzen
ist noch von der Testerei mit nem kleinen Multi
wegen der Besonderheit von den Chipsätzen
http://www.thetechrepository.com/showthread.php?t=30
ist hier prima beschrieben
P.S
bin mal gespannt wie demnächst der 7300er auf dem Brettchen läuft ( wenn er unterstützt wird)
Ich wusste garnicht, dass es da so viele verschiedenen Farben gab (das 4. ist das Non-MAX), offenbar handelt es sich dabei um verschiedene Revisionen (Vorserienmodelle?) oder gar für unterschiedliche Märkte bestimmte Varianten (die Asiaten stehen wohl eher auf bunt).
Beim Kauf unterscheiden?
Das Board hat eine Klappe an der OVP, hinter der du das Board sehen kannst.
Aber ich denk mal hierzulande kriegst du nur das mit den schwarzen Slots (1.).
Ja danke schonmal. Gut bekommt mans ja nimmer aber ich hoffe auch, dass es überwiegend schwarz sein wird.
Ich weiß nicht wie lange die das Board gefertigt haben, aber vielleicht ist ihnen auch der Zulieferer für die schwarzen Slots zu teuer geworden, und so haben sie halt kurz vor der Pleite gerade das darauf verbaut, was sie billig kriegen konnten.
Die einzig am Markt erhältliche Version des AW9D war die mit blauer Platine und die einzige des AW9D-Max, die mit schwarzer Platine und blau-schwarzen Speicherslots. Alles andere war soweit ich weiß nie normal zu kaufen. Das bunte war einfach ne Vorserienversion, bei der einfach ein AW8D mit dem neuen Chipsatz ausgestattet wurde. Wahrscheinlich sehr früh. Danach kamen dann wohl 2 Prototypen. Einmal rot-schwarz und einmal blau-schwarz. Na und was am Ende im Laden stand hab ich ja schon erwähnt.
Das ist ne gute Nachricht. Das Schwarze mit blauen RAM-Slots sieht halt sehr geil aus.
Aber das mit roten Buchsen gefällt mir auch sehr gut, passt aber halt nicht in mein Konzept. (und es gibt es wohl auch nicht zu kaufen)
Wissen? Nein.
Offiziell wird jedenfalls kein Q8200 unterstützt.
Die alten 65nm-Quads mag das AW9D-Max schon mal gar nicht gern,
könnte selbst Probleme haben, den Stock FSB von 333 zu erreichen.
OC mit nem Quad kannst du vergessen.
Wenn man dann noch berücksichtigt, dass der Q8200 vielleicht
überhaupt nicht läuft, ist das AW9D dafür nicht zu empfehlen.
Würdest ein neueres Board brauchen.
Ach ja hab meins jetzt schon ne Weile:
Und ich hab auch schon die LEDs getauscht:
Die LEDs passten einfach net zum rest ...
... und doppellagig mit dem Locher ausgestanztes Isoklebeband hilft nur wenig ...
... löten ist der einzige Ausweg ...
Ich bin mit dem Teil total zufrieden. Auch wenn der PCI-Slot nicht richtig tut...
