[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
es ist u.U. ziemlich praktisch eine onboard Grafiklösung zu haben. Es gibt aber zudem kaum noch Chipsätze ohne IGP.
die onboard karte hat doch keinerlei nachteile, deswegen ist es ja eigentlich ziemlich egal.
und die chipsätze mit grafikkarte werden auch immer mehr werden, damit lösungen wie office=onbaordkarte, gamen=externe karte gefahren werden können.
AOD: AMD Overdrive
Auf der Support-CD von Asrock dürfte die Version 2.12 sein.
Bei AMD findet man aktuell die Version 2.15
http://game.amd.com/us-en/drivers_overdrive.aspx?p=1
Es gibt Tools, die die CPU-Temp auslesen und andere zeigen die Core-Temp an.
Eigentlich ist die CPU-Temp die wichtigere Angabe und sie darf bei Phenom X4 Prozessoren zwischen 61 uns 64 C° liegen (je nach Modell).
Es gibt einige CPUs mit einer maximalen CPU-Temp von 70 C° (speziell X3 CPUs).
AOD und Coretemp zeigen bei mir wohl relativ richtig die Temperaturen an und bei AOD liegt die Core- und CPU-Temp praktisch gleichauf.
Bei Athlon X2 CPUs liegt wohl oft ein defekt der integrierten Temperatursensoren vor und die Temperatur wird nicht genau ausgelesen.
Ja weil Coretemp zeigt mir bei Core1 -2° - 3° und Core2 so ziwischen 15 - 23° an, und das kann ja definitiv nicht sein. :fresse:
Und AOD zeigt mir unter CPU Status gar nix an und unter Board Status:
CPU Diode ~25°
NB Diode ~40°
Jetzt unter last ändert sich Temp unter CPU Diode, geht also hoch. Scheint also zu stimmen.
Die Temperaturen von AOD scheinen halbwegs zu stimmen.
Aber wozu willst du noch einen 4850e oder 5050e?
Du hast doch schon eine Stromspar-CPU auf Basis des Athlon X2.
Und wirklich mehr Leistung haben diese Prozessoren doch auch nicht.
hmmm, bin auch gerade am überlegen.
Habe den 2400 gerade bei 2,75 ghz ohne vcore erhöhung!
Und ob ich die Leistung eines X3 oder X4 brauche ist fraglich.
Oder ich warte erstmal aufs erscheinen des Phenom 2 und dem dazugehörigen X2.
Das wird wohl die beste alternative sein.
Eben.
Und da macht ein anderer Speicher auch keinen Sinn und so brauchst du überhaupt keine neue Hardware zu kaufen.
Krieg aber bald nen ECS 780G wieder aus der RMA und wollte dieses dann mit den alten sachen bestücken!
Naja, mal durch den kopf gehen lassen.
Laufen bei euch, die das Board haben, die Rams bei eingestellten 400Mhz auch nur mit ~360 Mhz?? Das zieht sich durch alle Frequenzen. auch bei 333 usw fehlen mir Mhz.
Das ist nicht nur ein Messfehler, das kann man durch Benchmarks auch bestätigen.
Ausserdem funktioniert die CPU Temperatur bei meinem neuen AMD 4850e auch nicht.
So langsam denk ich, das Board is hin.
die Tempsensoren in den X2 CPU´s sind defekt daher die falschen Angaben.
Stell ihn mal genau auf 2000mhz und siehe da er hat seine 400mhz Ramtakt, dann wieder bei 2400mhz usw.
Moin,
ich habe mein Board jetzt auch seit einer Woche und ich muss sagen, das ist ein Spitzenboard. Ich habe nach ausgiebigen Stabilitätstests und Funktionstests keinen Fehler gefunden. Und ich komme sogar bei gleichen OC Einstellungen 100Mhz höher als beim dreckeligen MSI KA790GX.
Ich hatte lange nicht mehr so ein Spitzenboard für einen so fairen Preis!
Wie sieht denn dein restliches System aus?
Wenn da nichts weltbewegendes dazukommt sollte es eigentlich gehen...
Tachchen, Leutz!
Habe mir heute das Board geholt und habe ein Prob mit dem Onboard Sound. Ich bekomme unter keiner Einstellung ein Audiogerät angezeigt.
Unter Sound-und Audiogeräte ist nichts und im Gerätemanager tauchen nur Audiocodecs auf.
Habe im Bios schon alle settings durch und finde auch im Handbuch keinen Anhaltspunkt, woran es liegen könnte.
Ist das erste Mal, dass Onborad-Audio nicht sofort nach Treiberinstallation klappt (letzten 4 Boards ausschließlich Onboard benutzt).
Thx!
Aso: WinXP Pro als OS.
Hast du die neusten Realtek Treiber installiert? Bzw. welche Version hast du?
Also mehrmals den 2.14er ausprobiert und zu Anfang den mitgelieferten, kA muss so 1.8x gewesen sein.
Höchstwahrscheinlich defekt. Hatte ich bei einem neuen DUAL939-SATA2 Board. Treiber gingen zwar drauf, die Soundgeräte waren da aber kein Ton. Weder am Reapanel noch per FrontHeader. Wurde vom Händler getauscht und dann wars gut.
Wie stark ist die HD3300 im Gegensatz zu meiner X1950pro?
Hast du zufällig eine aktuelle Linux Live CD (Ubuntu etc.)? Damit müsste es von Haus aus Ton geben. Ansonsten würde ich mal neuinstallieren und nicht die Treiber vom Boardhersteller nehmen, sondern die aktuellen ausm Internet.
Welche Bios Version hast du? Auch schon CMOS Reset getestet?
2.14 ist soweit ich weiß der aktuellste, aber das checke ich nochmal.
Jo, Linux müsste ich mal irgendwo auf der Platte haben.
Klappte bei Bios schon 1.00 nicht und da ich eh wegen PhII updaten musste ist jetzt 1.30 drauf. Danach brav Defaults geladen, nüscht. Aber Cmos-reset ist noch ne Option.
Fuck, das ist immer ärgerlich, wenn man ein fluffiges Sys hat und dann nach MB-Wechsel doch gezwungen ist, neu zu insten.
Um alles auszuschließen, komme ich aber wohl nicht daran vorbei. Hatte gehofft, dass einer sagt - ganz einfach, mach xyz und es funzt ;-).
Thx@all for help
@ Stratotanker
"Wie stark ist die HD3300 im Gegensatz zu meiner X1950pro?"
Der HD 3300 Chip bringt in etwa die Leistung einer Radeon HD 3450, speziell wenn er etwas übertaktet ist.
Im Internet findest du sicherlich genügend Tests über die HD 3450.
Für mehr als Windows Aero, 3D Programme (Google Earth), 2D Spiele und alte bzw. einfache 3D Spiele taugt die Karte nicht.
Welche Karte denn nun?
Also ich konnte mit meinem x2 5000+@3100 Mhz und nicht OC HD3300 CSS auf mittleren Details absolut flüssig und vernünftig spielen.
Achja, das AsRock hat in der PC Games Hardware die Spartipp Auszeichnung bekommen und liegt sogar vor Boards wie MSI DKA790GX
Bios 1,3
Ich habe diese Biosversion mal ausprobiert und doch einige Änderungen feststellen können.
So wurde mein 1066er Speicher von Transcend mit den älteren Biosversionen standardmäßig mit 5-7-7-24 und 2.08 Volt betrieben.
Mit der 1.30 Biosversion wird der Speicher korrekt mit 5-5-5-15 und 2 Volt betrieben.
Der Teiler für den Multiplikator der CPU ist nun nicht mehr vorhanden.
Es können also keine Viertel-Multiplikatoren eingestellt werden.
Dafür wird nun die Taktrate der CPU sofort angezeigt z.B. 12.5 x 200 = 2500.
Ein Kaltstartproblem habe ich noch.
Bei den ersten Starts wird ein Lesefehler angezeigt und der Bootvorgang abgebrochen -
a disk read error occurred.
Könnte an den LG DVD-Brennern liegen.
Sind diese nicht installiert, tritt der Fehler nicht auf.
Vielleicht liegt es an einem defekten S-ATA-Kabel, muss ich noch weiter testen.
