[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
Falls er Vista nutzt, brauch er das ja gar nicht.
Treiber auf dem USB Stick entpacken und diese beim Installations-Dialog unterjubeln.
XP Home solls (wieder) werden.
Gibts da keinen anderen Weg bezüglich der Sata Treiber ausser der nlite Geschichte?
Einbinden via Nlite oder die altbekannte DOS-Diskette.
XP kennt kein SATA und hat somit keine SATA Treiber an Bord.
Hmm.. ich hab bisher nie Sata Treiber installiert. Probleme haben sich dadurch nicht ergeben.
@Ixus Danke für den Link. Werd ich mir mal anschauen.
Hast du denn vor AHCI einzustellen?
Wenn nicht, dann kannste auch einfach den IDE Modus einstellen und brauchst dann auch keine SATA Treiber installieren.
Da AHCI anscheinend keine eindeutige Vorteile für mich bringt, und ich im IDE Modus keine Probleme hatte, kann ich mir das mit den Sata Treibern wohl sparen- thx.
Bringt der AHCI Modus eigentlich einen spürbaren Performanceschub, oder liegt das nur im minimalen Bereich?
Ich habe lange Zeit IDE genutzt, bin dann auf AHCI rüber gewechselt und habe dann wieder IDE zum Vergleich benutzt.
Mein Fazit: Ich merke es nicht! Vielleicht kann man es messen, aber was nützt mir das?
PS: AHCI ist bei mir trotzdem an. :p
Gab bei Planet3dnow mal nen Sammelthread drüber. Der größte Vorteil von AHCO ist, dass NCQ möglich wird. Und das bringt bei mehrerer parallelen Schreib und Lesevorgängen schon was.
hab gerade mal das AMD gpu clock tool probiert und da ändert er die Taktrate gar nicht erst. Bleibt immer bei 62 stehen. Jemand nen entscheidenden Tip?
Mittlerweile ist die neue Hardware installiert, und der original CPU Fan (AMD X2 5050e) dreht fröhlich mit 3000 U/min. Das würde ich gerne ändern, kann jedoch die entsprechenden Optionen im Bios nicht ändern, das diese ausgegraut sind. Ausserdem steht dort was von "geht nur mit 4pin Lüfter", aber der Lüfter ist ja ein 4pin Lüfter.
Weiss jemand Rat?
Im IDE-Mode funzen nur 4 der 6 Ports. Man kann aber mit Vista SP1 einfach im abgesichterten Mode den Standard-AHCI-Treiber zwangsinstallieren und dann mit AHCI neu starten, um das zu beheben. Merkbar sind da natürlich kaum Performanceunterschiede - wie auch man merkt ja selbst dann kaum den Unterschied, wenn man 2 unterschiedliche Festplatten hat. Aber vollen Funktionsumfang gibts nunmal nur mit AHCI.
Weiss jemand Rat?
Du musst die Lüftersteuerung erst einschalten
Mal ein anderes Problem: Hat schon jemand 533 bzw 1066MHz Speichertakt stabil am Laufen?
Mein 2x2 GB A-Data Vitesta Extreme Edition DDR2-1066 Kit bekomme ich nur mit 400/800 MHz stabil zu laufen und auch nur mit Einstellung der Timings von Hand. 533/1066 will gar nicht.
STB
Jo is klar. Nur wie war die Frage gestern Abend... hat sich aber mittlerweile geklärt. Ich hatte versucht eine Auswahl mit den Pfeiltasten zu treffen, ging aber nicht. Der einzige Eintrag auf der Seite war ja die ganze schon ausgewählt, man musste eben nur Enter drücken :rolleyes: :d
Noch nen Tipp: aufjedenfall nicht den mitgeliferten ATI IGP Treiber installieren, damit ist die Performance unter aller Sau. Hab jetzt Catalyst 9.1 drauf und läuft gut damit.
Beiträge zusammengeführt, da Antwort auf eigenen Beitrag innerhalb von 4 Stunden:
Ich mal wieder- hoffentlich zum letzten mal.
Benutzt einer von euch den Standby Modus mit XP?
Bei mir laufen im Standby die Lüfter der CPU und Netzteil weiter. Das ist anscheinend abhängig vom ACPI Modus. Diesen kann man normalerweise im BIOS einstellen- in diesem Fall ist es aber nur möglich zwischen Auto und Disabled zu wählen. Beide Einstellungen haben keinen Effekt auf den Standbymodus- er funktioniert in beiden Fällen und in beiden Fällen laufen die Lüfter weiter.
Ich würd gerne S3 oder S4 einstellen.
Problem gelöst:
Microsoft hält für dieses Problem ein Tool bereit:
ftp://ftp.microsoft.com/products/Oemtest/v1.1/WOSTest/Tools/Acpi/dumppo.exe
dieses nach "C:\" downloaden und wie folgt aufrufen:
Start>Ausführen>cmd <ENTER>
In die Dos-Kosole folgendes eingeben:
C:\dumppo.exe ac minsleep=s3 maxsleep=s4 <ENTER>
Schönes Wochende
@spam_for_stb
Was hast du denn schon alles versucht um den Speicher stabil zu bekommen?
@spam_for_stb
Ich bin ja inzwischen einen Schritt weiter: Die 533 MHz laufen, aber nicht prime-stable. Nach 1 Minute stoppt prime.
Das erste Problem war wohl bei mir, daß der Northbridge-Takt bei Umschaltung auf manuelle Einstellung nur auf 1000 steht. Dahingehend ist das Board für mich eh ein Rätsel. Die Umstellung von Automatik auf manuell liefert eh erstmal eine nicht lauffähige Konfiguration, sowohl was Spannungen als auch Multiplikatoren angeht.
Die vom Hersteller vorgebenen Einstellungen meiner A-Data EXTREME DDR2 1066+ von 5-5-5-15 bei 2,3 bis 2,4 bootet, aber prime stoppt, auch bei z.B. 5-6-6-18.
Was kann ich noch einstellen?
STB
1 oder 2T ?
nein aber bei den nicht onboardkarten ist es nicht so aufgefallen.
mal blöde frage,
kann man den neuen treiber einfach drüber installieren, oder sollte man zuerst den alten treiber über systemsteurung deinstallieren?
wo sieht man eigentlich um welche treiberversion es sich handelt (im welchen register)?
Ich hatte bisher keine Probleme mit "drüber installieren".
Version kannst du im CCC unter "Information Center" unter dem Menüpunkt "Graphics Software" nachgucken :)
es gibt im Ati Verzeichnis ein Tool mit dem man den alten Treiber komplett deinstallieren kann.
anscheinend hat das Board ein paar probleme mit 2x2 GB RAMs.
Hatte mir Take MS geholt die liefen nur auf 191 MHz egal was ich eingestellt habe.
Habe mir dann Aeneons geholt mit den der Rechner immer abgeschmiert ist egal wie weit ich runter mit den MHz bin und egal wie hoch mit der Spannung.Nachdem ich dann auf 2T gestellt habe liefen die auch @ Stock.
Ein riegen läuft ohnen probleme auf 1T und 2x1GB laufen auch auf 1T
