[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
hab es auch drauf und unter Windows geflasht. Ging wie immer problemlos.
aha, man muss also nur die AFUWIN.EXE starten und dann rennt das ganze. werd ich mal heute abend probieren;)
danke
edit: ich hab OCZ Platinum XTC Edition DIMM Kit 4GB PC2-8500U CL5-5-5-18 (DDR2-1066)
doch leider kann ich immo nur den pc starten, wenn ich nur einen riegel drinhab, und er wird auch nur als 800er erkannt. ich hoffe mit dem bios update kann ich beide riegel installieren
Es ist kein Geheimnis, dass AsRock Bretter die RAM-Taktung immer falsch erkennen bzw. eine Stufe zu niedrig ansetzen. Dies wird gemacht um eventuellen Kompatibilitätsproblemen aus dem Weg zu gehen. Manuelles korrigieren ist da immer nötig ;)
Warum es aber nur booten will, wenn du einen Riegel drin hast weiß ich nicht...
danke
Was für eine CPU hast du?
Wenn es ein normaler DualCore ist - Die können wegen dem IMC nur PC2 800er fahren. Dahilft nur manuelles übertakten des FSB.
die catalystsuite würde ich wenn direkt über game.amd.com beziehen und KÖNNTE es sein, dass du Motherboard/IGP und die normalen jeweils seperat installieren musst
tja die normalen (nur chipsatztreiber) gibt es ja nur in dem 4 in 1 paket?
das is der 8.10er Treiber bei ASRock. Das würd ich persönlich nich machen. Würde die neuen nehmen von hier:
http://game.amd.com/us-en/drivers_catalyst.aspx
Als erstes eben Motherboard/IGP für dein OS und dann die "normalen". Wobei auf Computerbase gibt's glaub ich auch eine Art Komplettpaket dafür. Bin ich mir aber nicht 100% sicher. Falsch machen kannst du jednefalls nix. ;)
€dit: So'n Quatsch :fresse: Motherboard/IGP und "Normal" sind ein und die selbe Datei. Also einfach Catalyst-Suite installieren und fertig is die Laube.
also ich hab jetzt das bios upgedatet, mein phenom 2 920 wird jetzt problemlos erkannt.
wie ist das nochmal mit dem ram? also er zeigt mir jetzt immer noch 800er an, hab aber ja nen 1066er. muss ich das jetzt irgendwo umstellen?
danke übrigens an alle die mir bisher geholfen haben:)
Das die 1066er RAMs als 800er eingestellt werden, scheint normal zu sein.
Da müsstest du dies manuell umstellen - im Bios unter Advanced - CPU-Konfiguration.
Bei mir wurde dann der Speicher bei Auto-Einstellung mit 5-7-7 und 2,08 Volt betrieben.
Nach dem Biosupdate auf Version 1,3 wurde der Speicher korrekt mit 5-5-5 uund 2 Volt betrieben (es handelt sich um 2x 2GB).
juhu ich kann nach dem bios update endlich mit meinen BEIDEN riegeln booten, komischerweise dauert das booten ca 3sec länger und der schwarze bootscreen mit dem bindestrich (-) links oben der blinkt ist jetzt auch etwas anderst. der strich wandert nämlich ein paar zentimeter nach unten, und erst dann startet er das windows bootscreen.
werd jetzt mal die 1066 testen:)
edit: hat funktioniert;)
welche treiber habt ihr eigtl für die cpu installiert? irgendwelche treiber von amd für den phenom 2?
warum wird bei mir bei cpuz unter memory die geschwindigkeit der ram richtig angezeigt, und unter SPD wird in den jeweiligen slots nur 800er angezeigt? (max bandwith 400 steht dran)
Mein Rechner ist nicht fähig HD Videos von youtube flüssig abzuspielen dank dem 790gx :grrr: Das kann's echt nicht sein. Mal abgesehen davon dann das Netzteil anfängt zu piepen/pfeifen. Hatte ich vorher auch nie gehabt.
Habe ich eigentlich das Recht das Mainboard zurückzugeben? Habs bei Mindfactory gekauft.
hast du den neuesten Treiber drauf?
Jep, 9.1.
Mit dem Treiber der auf der CD dabei war (8.5 oder so?) ging gar nix. Das war so als wenn man bei XP noch keine Grafiktreiber installiert hat.
@Bio verwendest du die onboard graka?
Ja, die verursacht ja die Probleme. Ich brauche im Prinzip keine stromfressende Grafikkarte. Die IGP sollte mehr als ausreichend sein für meine Anwendungen.
Hier z.B
http://www.youtube.com/watch?v=G2UqrlWZnXM#
Immer wieder kleine Ruckler- Prozessorlast bei ~30%
Ich denke das ist ein Youtube Problem. Das ruckelt sowohl auf 7600GT als auch auf HD 4830.
teste ich morgen mal obs bei mir auch ist. Könnte aber auch das Problem sein, was P3Dnow angesprochen hatte.
Auf meiner HD3870 ruckelt es nicht. Vielleicht ganz zu Beginn einmal kurz
@Micki_Krause: Hast du auch wirklich das HD-Video angeschaut?
jupp hab das Video einmal komplett laden lassen - Player auf Pause - und es mir dann angeschaut. Kein Ruckeln.
Irgendwie hat mein Board garnicht drauf reagiert als den VCore auf 1.3V gesetzt habe. Everest und CPU-Z haben immernoch was um 1.35V angezeigt.
Vielleicht weil ich Enhanced Halt State an hatte?
nein daran sollte es nicht liegen. Aber Enhanced Halt erhöht komischer weise den Stromverbrauch etwas. Ursache ist unbekannt.
Evtl. hast du nun ein DVD- oder CD-Laufwerk als erstes Bootlaufwerk im Bios aktiv - dann habe ich die gleichen Effekte wie du.
Es braucht keinen Treiber für den Prozessor und für das Board wären auch nur der Soundtreiber und der LAN-Treiber nötig.
Bei meinen ersten Versuchen mit dem neuen System habe ich mich das auch gefragt.
Scheint aber normal zu sein.
Es sind halt im Grunde übertaktete 800er-Speicher und die werden auch so erkannt.
Beiträge zusammengeführt, da Antwort auf eigenen Beitrag innerhalb von 4 Stunden:
Es gibt zwar Präsentationsfolien von AMD, wo ein Support von C1E ausgewiesen wird, doch laut CPUID eines Phenom I, ausgelsen mit dem Tool von AMD, unterstützt der Prozessor diese Funktion nicht.
Bei einigen Tests konnte ich eine leicht höhere Performance mit aktiviertem C1E bei einigen Anwendungen feststellen.
Aber dies bewegt sich im 1 bis 2 Prozent-Bereich und könnte auch ein Meßfehler oder eine normale Schwankung der Ergebnisse sein.
Der Stromverbrauch im IDLE-Modus steigt allerdings deutlich an.
Dafür steigt dann der Stromverbrauch im "Roten Modus" von AOD nicht mehr an.
Dieser Modus sorgt für eine höhere Performance im Single-Thread-Bench von Cinebench.
Was hier genau geändert wird dürfte aber niemand wissen.
Jep, 9.1.
Hier z.B
Was hast du den beim Speicher für die IGP eingestellt
Das Video läuft auf meine NV 630a/7050 ohne ruckler
Sorry, wo soll ich den was einstellen?
Das merkwürdige ist ja das ich die DVD von dem verlinktem Youtube Video habe und das diese absolut flüssig bei mir läuft.
Im Bios kannst du Einstellen welcher Speicher verwendet werden soll also der normale RAM oder der Sideport ober beide zusammen.Die menge kann man glaube auch noch einstellen.
Musst du mal durch probieren ob es daran liegt.
