[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
also ich habe den neueun ninja drauf bekommen, und dieser ist meiner ansicht nach etwas grösser als mugen:d
weiß jemand ob es einen unterschied gibt, wenn ich meine dual-slot graka auf den unteren pci-express slot stecke anstatt auf den oberen?
Ja, kommt auf die Stzellung der Bridge-Karte an. Voreingestellt ist sie so, dass der obere Slot 16 Lanes hat und der untere 1 Lane. Dreht man die Bridge um, haben beide Slots je 8 Lanes.
hab ich leistungsmäßig nen nachteil wenn meine 8800gts mit nur 8lanes angebunden ist? und kann ich es so einstellen, dass ich unten die vollen 16lanes habe und oben dann halt was niedrigeres?
lg
Nee, geht nur 16x / 1x oder eben 8x / 8x.
schade
läuft die grafikkarte mit 8x langsamer als mit 16x? gibts da irgendwie tests oder weiß da jemand drüber was?
Ich habe das Board auch hab nur folgende Probleme:
In Windows Vista x64 werden immer 2 Grafikkarten erkannt und wenn ich den Grafik-Treiber installiere.
Stimmt dann irgendwas nicht
kann man die fest deaktivieren?
Mein System
Das Asrock Board
Phenom II x4 940
Graka ATI Radeon 4550
MfG
Dir ist schon bewusst, dass das Board auch eine Onboard-Graka hat? Sprich es ist völlig normal, dass 2 Karten erkannt werden. :shot:
ich hab bei meinem netztteil so ein cpu stromkabel das auf 2x4pins aufeteilt ist. soll ich da schon alle 8pins verwenden oder nur ein 4er von den beiden?
weil bei meinem alten board war nur ein anschluss für 4pins,deswegen frag ich jetzt.
freu mich auf ne schnell antwort:)
Denke mal, die kann man im BIOS deaktivieren aber sicher weiß ich das nicht, weil ich das Dingen nicht zu Hause hab. Beim noch aktuellen Gigabyte kann man das jedenfalls :)
Leider hab ich im Bios nicht gefunden
ja ich will die Onboard Grafik deaktivieren
weil irgentwas passt nich wenn ich den treiber installiere ich glaube er weis nicht auf Welche grafikkarte es es installiert
Beide werden gleichermaßen installiert. Wenn du aber eh eine dedizierte Grafikkarte laufen hast, kannste die Onboardgrafik wirklich abschalten. Wozu soll die denn sonst ungenutzt laufen?
nein muss man auch gar nicht. Stand meine ich im Handbuch wie man es mit einem 4 pin anschließen kann oder war da nicht sogar ein Aufkleber auf den nicht benutzen 4 Pins?
Ja, steht im Handbuch. 4-pin oder 8-pin Möglich
Bin ürbigens unzufrieden mit der 2D Grafikleistung. Aktueller Treiber 9.1 ist drauf. Ich würde niemanden das Board empfehlen der auf nur Onboard Grafik setzt (die normalerweise völlig ausreicht, würde AMD endlich mal auf das Problem bei 780 790 Chipsätzen reagieren).
Das ist aber ein Problem der Architektur bei XP und kein AsRock Problem.
Richtig, hatte ich auf der letzten Seite aber auch schon verlinkt. Hoffentlich tut sich da noch etwas oder wir müssen alle auf Vista umsteigen.
Naja mit dem 8.12er Treiber war doch schon Besserung in Sicht, vll lässt sich da über zukünftige Treiberversionen noch etwas rausholen bzw retten.
optimal ist es aber auch mit dem 9er noch nicht. Sind ja viele Beispiele auf p3dnow zu sehen wo es zu massiven Störungen kommt.
Wenn jemand interesse an dem Board hat. Ich mache im laufe des Tages einen VK thread auf. Könnt euch ja per PM melden
Grund: Will mir ein µATX Board holen.
Weder der Enzotech Chipsatz-Kühler CNB-S1L noch der Enzotech CNB-S1 Chipsatz Kühler passen auf die NB/SB
Woran hapert es denn?
Löcher passen bei der NB/SB nicht und bei der SB ist auch noch ein Bauteil im Weg
hat hier jemand schon ein bios update durchgeführt mit dem 1.3 bios? wie habt ihr das gemacht? und wie kann ich das bios ohne diskette durchführen?
lg
Einfach unter Windows als Admin starten? (Also die Windows-Version des Updates!)
Ich habe es drauf.Habe es AFUWIN gemacht,liegt beim BIOS bei
