So müsste es in etwar bei mir ausschauen
Target CPU Frequency 4103MHz
Target DRAM Frequency 1864MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Enabled***
Sync Mode [Disabel]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [22.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Disabel]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
MPS and ACPI MADT ordering [Modern]
Intel(R) Virtualization Tech [Disabel]
CPU TM Function [Disabled]
Execute Disable Bit [Disabel]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Disabel]
Intel(R) C-STATE Tech [Disabel]
BCLK Frequency [186]
PCIE Frequency [100]
DRAM Frequency [1864]
UCLK Frequency [3728]
QPI Link Data Rate [6714]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 7 [6]
RAS# to CAS# Delay 7 [9]
RAS# PRE Time 7 [9]
RAS# ACT Time 18 [24]
RAS# to RAS# Delay 4 [AUTO]
REF Cycle Time 72 [84]
WRITE Recovery Time 10 [10]
READ to PRE Time 6 [6]
FOUR ACT WIN Time 24 [Auto]
Back-To-BackCAS# Delay 0 [Auto]
Timing Mode 1N [1N]
Round Trip Latency on CHA 59 [56]
Round Trip Latency on CHB 61 [57]
Round Trip Latency on CHC 62 [58]
WRITE To READ Delay(DD) 8 [Auto]
WRITE To READ Delay(DR) 8 [Auto]
WRITE To READ Delay(SR) 18 [Auto]
READ To WRITE Delay(DD) 7 [Auto]
READ To WRITE Delay(DR) 7 [Auto]
READ To WRITE Delay(SR) 7 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 7 [Auto]
WRITE To WRITE Delay(DR) 7 [Auto]
WRITE To WRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Auto]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Ensabled]*
Extreme OC [Auto]
CPU Voltage 1.2xx [1.2xxx]
CPU PLL Voltage 1.800 [1.475]
QPI/DRAM Core Voltage 1.429 [1.2750]
DRAM Bus Voltage 1.654 [1.654]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage 1.111 [Auto]
IOH PCIE Voltage 1.508 [Auto]
ICH Voltage 1.111 [Auto]
ICH PCIE Voltage [Auto]
*QPI Voltage OCP [Enabled]
*IOH Voltage OCP [Enabled]
*DRAM Voltage OCP [Enabled]
*QPI PWM Frequency [Auto]
*IOH PWM Frequency [Auto]
*DRAM PWM Frequency [Auto]
Sync Mode [Disabel]
A20M [Disabled]
CAS# Latency 7 [6]
RAS# PRE Time 7 [9]
Timing Mode 1N [1N]
Extreme OC [Auto]
