[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
ins bios gehen und auf dieses load last bootable setting - "load" draufentern würde ich sagen...
Is auf "Load" gesetzt.
Soblad ich den FSB z.B. auf 310 erhöhe startet der Rechner aber nicht mehr.
Er springt auch nicht auf die letzte lauffähige Konfiguration zurück.
nee, das geht dann im bios.
du musst also beim experimentieren nicht extra auf eine bank speichern, sondern kannst einfach das cmos löschen wenn er nicht hochfährt (reset und power gleichzeitig drücken), dann ins bios und dann dort auf load gehen und enter drücken. dann lädt er das last bootable setting...
Mahlzeit
hab mir einen x4 9550 gegönnt und will meinen x2 6000+ in Rente schicken.
Nun ist leider nichts mehr wie es schon mal war
folgendes Problem hab ich nun:
neustes Bios vom 1.12.2008 eingespielt, alles auf auto im ganged modus
heb ich nun den HTT an ( egal ob 5 oder 20 MHz) startet der Rechner nicht mehr
und ich komme auch nicht mehr ins Bios rein - hilft nur Cmos Clear
vllt kann mir mal einer seine Settings durchgeben
wahrscheinlich bin ich zu doof :(
Sys:
hab Vollbestückung mit 4x1066er mit jeweils 1 gig
600Watt Bequiet
Hast CnQ noch an?
Dasselbe prob hatte ich wie ich n vernünftiges CnQ setting für 24/7 machen wollte...
Entweder du verzichtest auf Stromsparfunktionen od. du stellst "CPU Clock" & "Boot up clock" auf den selben wert (htt) :wink:
Mahlzeit
Sys:
600Watt Bequiet
würde ausserdem die beta von 26.12. nutzen. bei der version vom 01.12. geht unter vista das LAN nicht...
ausserdem boote erstmal mit speicher auf ddr800...
Hast CnQ noch an?
die Werte waren schon gleich, CnQ enable
aber eigentlich hatte ich das CnQ eingeplant :grrr:
@Öse
wo kann ich das saugen
weder bei us.dfi noch bei eu.dfi zu finden
Dank euch
doch, musst auf die beta-seite gehen.. kann man über den einzelnen downloads umschalten..
Hast CnQ noch an?
CnQ disable, wars leider nicht
ich schätz das Bios ist grottenschlecht :heul:
DFI Server down
jop der ***** server ist seit heute mittag nicht mehr erreichbar :/
würd echt erstmal nen neu bios testen. das 01/12 ist murks. das 16/12 auch..
es soll übrigens ne 01/16 geben von diesem jahr. hat bruder esau schon drauf. aber aufm server ist die noch nicht...
was die immer rausgeben
war damals schon froh als der x2er richtig lief
hast du den tlb cache fix auf auto
habe hier ein B3 stepping
nee hab ich immer auf disabled gemacht auch beim b3...
Das Bios gibt's eh nicht auf'm DFI Seite und das neue von vorgestern auch nicht :/
Weiß jemand, wo man das herbekommt?
Edit: gefunden :d - weicht der einfach vom Namenschema ab :rolleyes:
da steht ht in der readme die ich habe. ich weiss nicht was gmeint ist. htt wär ja geil. ht-link hört sich aber auch so an als wäre das vorher ein prob gewesen, das uns zurückgehalten hat. mal sehen...
download geht doch über wishes' link!!
Hmm, HTT werd ich heute noch testen. Leider haben se die twtr einstellung gekillt, ist jetzt immer 7 :/. Außerdem wird jetzt 2,04 anstatt wie vorher 2,03 bei eingestellen 2,04V angezeigt. Keine Ahnung ob sich auch die real anliegende Spannung sich auch geändert hat, glaub eigentlich nicht, dass das möglich ist. Naja ansonsten läuft bis jetzt alles wie im 26er.
Werd das BIOS dann auch gleich mal draufknallen, mal sehen, ob sich für die X2 User auch irgendwas ändert...
Hab leider immernoch das Problem, dass ich bei 3-4h nen Error bei large-inplace krieg :fresse:
Edit: BIOS ist drauf und zumindest bei mir ist die TWTR immernoch frei wählbar... außerdem ist die HT-Link Select Option vom HT Menü ins Hauptmenü gewandert... sonst ist alles beim alten soweit.
sry, hab nicht gesehen dass er den dazueditiert hat....
Das teste ich doch gleich mal aus :)
Mit dem alten Beta bios gingen ~280mhz htt und mit dem neuen war das max. 288mhz
Ich teste mal das CnQ aus :d
€€: CnQ will einfach noch immer nicht mit 235 htt... :/
danke für den Link
werde es auch mal testen
schlimmer wie jetzt kanns nicht mehr werden :)
bei mir geht alles. max htt 345mhz... cnq geht auch... kann mich nicht beklagen^^
aber steht auch in dem readme das ich zu dem bios dazu bekommen hab dass es probs mit cnq gibt. und ich hab ja nur mit vista getestet... da läufts..
@Öse
oha
verrat mir mal, ob Du diese Einstellungen mit Vollbestückung erreicht hast
oder mit 2x2 gigs
habe das Bios mal draufgespielt, jedoch keine Besserung
CnQ geht, jedoch ist es immernoch Glücksache ob er startet
keine ahnung. hab 4x1gb..
load optimized defaults, ddr800 teiler rein, timings einstellen, htt boot up clock und cpu host clock einstellen und rumms. je nachdem wie man braucht ram spannung, vcore und nb-voltage eingestellt und funzt...
und ich hab alle board-spannungen auf default.
an der wakü kannst auch nicht liegen, ging bei mir so auch schon mitm pI und der original heatpipe aufm board...
das einzige wo das board zickt ist der ht-link.. da mag er nicht so schnell... evtl. mal auf 1,6ghz stellen?
wie kriegst Du den Teiler FSB : DRAM auf 1:1
bei mir bleibt der immer auf 1:2
komisch oder
